Re: [U-Boot-Users] Porting U-Boot on to Cogent CSB535FS
-----Mensaje original----- De: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] En nombre de Midhun Agnihotram Enviado el: jueves, 31 de mayo de 2007 15:25 Para: TXEMA LOPEZ; u-boot-users@lists.sourceforge.net Asunto: Re: [U-Boot-Users] Porting U-Boot on to Cogent CSB535FS
Hi Txema,
I will indeed use your patch. But I would also like to have some pointers as to how to develop this patch. I am new to the embedded world although not that new to Linux. I want to fully port U-boot to CSB535FS as we require the support for SD card and Compact Flash. Hi Midhun,
The support for the SD Card an CompactFlash is needed in U-Boot or only in Linux? If your really need it in U-Boot one good starting point could be the Linux existing drivers.
How do I start porting U-Boot to a new board? I have read the README of U-Boot. And I know that I need to set a lot of parameters - but they are Greek and Latin for me. How do I start off? Any web sites?? Books?? Links?? Were do I get these parameters from?? From the board manufacturer / supplier??
Usually, you can use a porting done to a board similar to your new board. You need a new configuration file and a new directory where you must put the board related code. But in your case this work is done in my patch: I got the IMX porting as a reference. But my tree structure was not accepted and this is what Wolfgang suggested:
"So if you have a IMX serial driver that should go to drivers/serial/imx.c and an ethernet driver to drivers/net/imx.c and your I2C driver to drivers/i2c/imx.c As a minimum, you should start this new directory structure and use it for the IMX related code (and leave the cleanup of the other, already existing code in the drivers/ directory to others). Even better, you would include this restructuring of the existing code, too. [And ideally, you would clean up all the U-Boot code, merge all open patches and fix all the remaining bugs as well. But I guess I'm asking for too much :-) ] Best regards,
Wolfgang Denk "
So the code I put in cpu/arm926ejs/imx21 was in the wrong place. And it was very similar to the IMX related code and another suggestion was to use only one source file for both boards with some ifdef's.
I don't know where you can find some information about the porting of U-Boot to a new board. My experience is that all the documentation is in the U-Boot source code. Good luck.
Best Regards,
Txema.
Thanks and Regards, Midhun Agnihotram.
On 5/30/07, Txema Lopez tlopez@aotek.es wrote:
Midhun Agnihotram wrote:
Hi Txema,
I got the patch and I have gone through the conversation - when you submitted the patch. But I did not really understand the "threats". What is all about.
The discussion was about how the patch must be done to be accepted and more exactly where to put the porting related code in the U-Boot directory tree.
Is porting U-Boot to CSB535 not advised??
I don't think so. We have developped a CSB535 based custom board and U-Boot is working fine.
Or is it that there is more work to be done??
The patch has not support for USB, SD Card or CF, but you can launch a linux kernel from flash or tftp.
Thanks & Regards, Midhun Agnihotram,
On 5/30/07, TXEMA LOPEZ tlopez@aotek.es wrote:
Hi Midhun,
I sent a patch for a U-Boot 1.2.0 version but It was not accepted. See the threats "Support for csb535fs / i.MX21 LiteKit" and "arm SoC code in U-Boot". I pushed this work in my "todo stack" but unfortunately it's still there (And I'm afraid It will be for long time). The patch It's working fine and you can get it from the U-Boot users mailing list or I can resend it to you.
Best Regards
J.M. Lopez.
------------------------------------------------------------------------- This SF.net email is sponsored by DB2 Express Download DB2 Express C - the FREE version of DB2 express and take control of your XML. No limits. Just data. Click to get it now. http://sourceforge.net/powerbar/db2/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Hi All,
Thanks for all the Help. I will now try to replace Micromonitor with U Boot.
Regards, Midhun.
Hi Txema,
Wolfgang Denk "
Best Regards,
Txema.
Hi Txema,
Hi Midhun,
Best Regards
J.M. Lopez.
Midhun Agnihotram
TXEMA LOPEZ
