[U-Boot] [PATCH v4 0/4] add support for rk3399 soc and evb
This patchset add support for rk3399 with ATF based on Rockchip miniloader as secondary bootloader instead of U-Boot SPL.
Rockchip miniloader init the DRAM and load the ATF and U-Boot to runing address, and then jump to ATF, the ATF do some init and switch to EL2/EL1 mode before jump to next loader which is U-Boot here.
Pls reference board/rockchip/evb_rk3399/README to setup the board.
Will migrate to SPL once its ready for ATF.
This patch set is based on below patch: "board: move all the rockchip board in one folder"
This patch set has been test on rk3399 evb board.
In this version, I split the mmc driver in seperate thread, because when I enable the full-model for mmc driver, Seems bug happen in blk layer, will descript detail in mmc patch.
Changes in v4: remove extra blank line in evb_rk3399.h, remove unnecessary including file in rk3399_common.h, fix base on commend from Andreas, Rebase on U-Boot ToT. move config CONFIG_SYS_NS16550 from chip common to defconfig
Changes in v3: Rebase on patch from Andreas: [PATCH] rockchip: Exclude rk_timer for ARM64 [PATCH] rockchip: Clean up CPU selection
Changes in v2: fix description error on board Kconfig fix a binary path error
Kever Yang (4): dts: add support for Rockchip rk3399 soc ARM64: rockchip: add support for rk3399 SoC based evb config: add config file for evb-rk3399 ARM64: evb-rk3399: add a README for this board setup
arch/arm/Kconfig | 2 - arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3399-evb.dts | 104 ++++ arch/arm/dts/rk3399.dtsi | 1028 ++++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/Kconfig | 18 + arch/arm/mach-rockchip/rk3399/Kconfig | 18 + board/rockchip/evb_rk3399/Kconfig | 15 + board/rockchip/evb_rk3399/MAINTAINERS | 0 board/rockchip/evb_rk3399/Makefile | 7 + board/rockchip/evb_rk3399/README | 73 +++ board/rockchip/evb_rk3399/evb-rk3399.c | 40 ++ configs/evb-rk3399_defconfig | 33 + include/configs/evb_rk3399.h | 24 + include/configs/rk3399_common.h | 71 +++ include/dt-bindings/clock/rk3399-cru.h | 746 +++++++++++++++++++++++ 15 files changed, 2179 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/rk3399-evb.dts create mode 100644 arch/arm/dts/rk3399.dtsi create mode 100644 arch/arm/mach-rockchip/rk3399/Kconfig create mode 100644 board/rockchip/evb_rk3399/Kconfig create mode 100644 board/rockchip/evb_rk3399/MAINTAINERS create mode 100644 board/rockchip/evb_rk3399/Makefile create mode 100644 board/rockchip/evb_rk3399/README create mode 100644 board/rockchip/evb_rk3399/evb-rk3399.c create mode 100644 configs/evb-rk3399_defconfig create mode 100644 include/configs/evb_rk3399.h create mode 100644 include/configs/rk3399_common.h create mode 100644 include/dt-bindings/clock/rk3399-cru.h
These files are from kernel upstream with some modification need by U-Boot: - chosen with stdout-path to uart2.
Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Simon Glass sjg@chromium.org ---
Changes in v4: None Changes in v3: None Changes in v2: None
arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3399-evb.dts | 104 ++++ arch/arm/dts/rk3399.dtsi | 1028 ++++++++++++++++++++++++++++++++ include/dt-bindings/clock/rk3399-cru.h | 746 +++++++++++++++++++++++ 4 files changed, 1880 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/rk3399-evb.dts create mode 100644 arch/arm/dts/rk3399.dtsi create mode 100644 include/dt-bindings/clock/rk3399-cru.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index acecb7c..13f990a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -31,7 +31,8 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-firefly.dtb \ rk3288-jerry.dtb \ rk3288-rock2-square.dtb \ - rk3036-sdk.dtb + rk3036-sdk.dtb \ + rk3399-evb.dtb dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-odroidc2.dtb dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts new file mode 100644 index 0000000..bbcfcd0 --- /dev/null +++ b/arch/arm/dts/rk3399-evb.dts @@ -0,0 +1,104 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include <dt-bindings/pwm/pwm.h> +#include "rk3399.dtsi" + +/ { + model = "Rockchip RK3399 Evaluation Board"; + compatible = "rockchip,rk3399-evb", "rockchip,rk3399", + "google,rk3399evb-rev2"; + + chosen { + stdout-path = &uart2; + }; + + vdd_center: vdd-center { + compatible = "pwm-regulator"; + pwms = <&pwm3 0 25000 0>; + regulator-name = "vdd_center"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-always-on; + regulator-boot-on; + status = "okay"; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vcc_phy: vcc-phy-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_phy"; + regulator-always-on; + regulator-boot-on; + }; +}; + +&emmc_phy { + status = "okay"; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&pwm3 { + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&pinctrl { + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <1 21 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pmic_dvs2: pmic-dvs2 { + rockchip,pins = + <1 18 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; +}; diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi new file mode 100644 index 0000000..fb5af54 --- /dev/null +++ b/arch/arm/dts/rk3399.dtsi @@ -0,0 +1,1028 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dt-bindings/clock/rk3399-cru.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/pinctrl/rockchip.h> + +/ { + compatible = "rockchip,rk3399"; + + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + aliases { + serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + serial3 = &uart3; + serial4 = &uart4; + }; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu_l0>; + }; + core1 { + cpu = <&cpu_l1>; + }; + core2 { + cpu = <&cpu_l2>; + }; + core3 { + cpu = <&cpu_l3>; + }; + }; + + cluster1 { + core0 { + cpu = <&cpu_b0>; + }; + core1 { + cpu = <&cpu_b1>; + }; + }; + }; + + cpu_l0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x0>; + enable-method = "psci"; + #cooling-cells = <2>; /* min followed by max */ + clocks = <&cru ARMCLKL>; + }; + + cpu_l1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x1>; + enable-method = "psci"; + clocks = <&cru ARMCLKL>; + }; + + cpu_l2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x2>; + enable-method = "psci"; + clocks = <&cru ARMCLKL>; + }; + + cpu_l3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x3>; + enable-method = "psci"; + clocks = <&cru ARMCLKL>; + }; + + cpu_b0: cpu@100 { + device_type = "cpu"; + compatible = "arm,cortex-a72", "arm,armv8"; + reg = <0x0 0x100>; + enable-method = "psci"; + #cooling-cells = <2>; /* min followed by max */ + clocks = <&cru ARMCLKB>; + }; + + cpu_b1: cpu@101 { + device_type = "cpu"; + compatible = "arm,cortex-a72", "arm,armv8"; + reg = <0x0 0x101>; + enable-method = "psci"; + clocks = <&cru ARMCLKB>; + }; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; + }; + + xin24m: xin24m { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "xin24m"; + #clock-cells = <0>; + }; + + amba { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + dmac_bus: dma-controller@ff6d0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff6d0000 0x0 0x4000>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + clocks = <&cru ACLK_DMAC0_PERILP>; + clock-names = "apb_pclk"; + }; + + dmac_peri: dma-controller@ff6e0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff6e0000 0x0 0x4000>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + clocks = <&cru ACLK_DMAC1_PERILP>; + clock-names = "apb_pclk"; + }; + }; + + sdio0: dwmmc@fe310000 { + compatible = "rockchip,rk3399-dw-mshc", + "rockchip,rk3288-dw-mshc"; + reg = <0x0 0xfe310000 0x0 0x4000>; + interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; + clock-freq-min-max = <400000 150000000>; + clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, + <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + status = "disabled"; + }; + + sdmmc: dwmmc@fe320000 { + compatible = "rockchip,rk3399-dw-mshc", + "rockchip,rk3288-dw-mshc"; + reg = <0x0 0xfe320000 0x0 0x4000>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; + clock-freq-min-max = <400000 150000000>; + clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, + <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + status = "disabled"; + }; + + sdhci: sdhci@fe330000 { + compatible = "rockchip,rk3399-sdhci-5.1", "arasan,sdhci-5.1"; + reg = <0x0 0xfe330000 0x0 0x10000>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + assigned-clocks = <&cru SCLK_EMMC>; + assigned-clock-rates = <200000000>; + clocks = <&cru SCLK_EMMC>, <&cru ACLK_EMMC>; + clock-names = "clk_xin", "clk_ahb"; + phys = <&emmc_phy>; + phy-names = "phy_arasan"; + status = "disabled"; + }; + + usb_host0_ehci: usb@fe380000 { + compatible = "generic-ehci"; + reg = <0x0 0xfe380000 0x0 0x20000>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>; + clock-names = "hclk_host0", "hclk_host0_arb"; + status = "disabled"; + }; + + usb_host0_ohci: usb@fe3a0000 { + compatible = "generic-ohci"; + reg = <0x0 0xfe3a0000 0x0 0x20000>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>; + clock-names = "hclk_host0", "hclk_host0_arb"; + status = "disabled"; + }; + + usb_host1_ehci: usb@fe3c0000 { + compatible = "generic-ehci"; + reg = <0x0 0xfe3c0000 0x0 0x20000>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>; + clock-names = "hclk_host1", "hclk_host1_arb"; + status = "disabled"; + }; + + usb_host1_ohci: usb@fe3e0000 { + compatible = "generic-ohci"; + reg = <0x0 0xfe3e0000 0x0 0x20000>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>; + clock-names = "hclk_host1", "hclk_host1_arb"; + status = "disabled"; + }; + + gic: interrupt-controller@fee00000 { + compatible = "arm,gic-v3"; + #interrupt-cells = <3>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + interrupt-controller; + + reg = <0x0 0xfee00000 0 0x10000>, /* GICD */ + <0x0 0xfef00000 0 0xc0000>, /* GICR */ + <0x0 0xfff00000 0 0x10000>, /* GICC */ + <0x0 0xfff10000 0 0x10000>, /* GICH */ + <0x0 0xfff20000 0 0x10000>; /* GICV */ + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; + its: interrupt-controller@fee20000 { + compatible = "arm,gic-v3-its"; + msi-controller; + reg = <0x0 0xfee20000 0x0 0x20000>; + }; + }; + + uart0: serial@ff180000 { + compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; + reg = <0x0 0xff180000 0x0 0x100>; + clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; + clock-names = "baudclk", "apb_pclk"; + interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer>; + status = "disabled"; + }; + + uart1: serial@ff190000 { + compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; + reg = <0x0 0xff190000 0x0 0x100>; + clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; + clock-names = "baudclk", "apb_pclk"; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart1_xfer>; + status = "disabled"; + }; + + uart2: serial@ff1a0000 { + compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; + reg = <0x0 0xff1a0000 0x0 0x100>; + clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; + clock-names = "baudclk", "apb_pclk"; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + reg-shift = <2>; + reg-io-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart2c_xfer>; + status = "disabled"; + }; + + uart3: serial@ff1b0000 { + compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; + reg = <0x0 0xff1b0000 0x0 0x100>; + clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; + clock-names = "baudclk", "apb_pclk"; + interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart3_xfer>; + status = "disabled"; + }; + + spi0: spi@ff1c0000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff1c0000 0x0 0x1000>; + clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi1: spi@ff1d0000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff1d0000 0x0 0x1000>; + clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi2: spi@ff1e0000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff1e0000 0x0 0x1000>; + clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi4: spi@ff1f0000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff1f0000 0x0 0x1000>; + clocks = <&cru SCLK_SPI4>, <&cru PCLK_SPI4>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi4_clk &spi4_tx &spi4_rx &spi4_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi5: spi@ff200000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff200000 0x0 0x1000>; + clocks = <&cru SCLK_SPI5>, <&cru PCLK_SPI5>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi5_clk &spi5_tx &spi5_rx &spi5_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + pmugrf: syscon@ff320000 { + compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd"; + reg = <0x0 0xff320000 0x0 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + + pmu_io_domains: io-domains { + compatible = "rockchip,rk3399-pmu-io-voltage-domain"; + status = "disabled"; + }; + }; + + spi3: spi@ff350000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff350000 0x0 0x1000>; + clocks = <&pmucru SCLK_SPI3_PMU>, <&pmucru PCLK_SPI3_PMU>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi3_clk &spi3_tx &spi3_rx &spi3_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + uart4: serial@ff370000 { + compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; + reg = <0x0 0xff370000 0x0 0x100>; + clocks = <&pmucru SCLK_UART4_PMU>, <&pmucru PCLK_UART4_PMU>; + clock-names = "baudclk", "apb_pclk"; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart4_xfer>; + status = "disabled"; + }; + + pwm0: pwm@ff420000 { + compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; + reg = <0x0 0xff420000 0x0 0x10>; + #pwm-cells = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm0_pin>; + clocks = <&pmucru PCLK_RKPWM_PMU>; + clock-names = "pwm"; + status = "disabled"; + }; + + pwm1: pwm@ff420010 { + compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; + reg = <0x0 0xff420010 0x0 0x10>; + #pwm-cells = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm1_pin>; + clocks = <&pmucru PCLK_RKPWM_PMU>; + clock-names = "pwm"; + status = "disabled"; + }; + + pwm2: pwm@ff420020 { + compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; + reg = <0x0 0xff420020 0x0 0x10>; + #pwm-cells = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm2_pin>; + clocks = <&pmucru PCLK_RKPWM_PMU>; + clock-names = "pwm"; + status = "disabled"; + }; + + pwm3: pwm@ff420030 { + compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; + reg = <0x0 0xff420030 0x0 0x10>; + #pwm-cells = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm3a_pin>; + clocks = <&pmucru PCLK_RKPWM_PMU>; + clock-names = "pwm"; + status = "disabled"; + }; + + pmucru: pmu-clock-controller@ff750000 { + compatible = "rockchip,rk3399-pmucru"; + reg = <0x0 0xff750000 0x0 0x1000>; + #clock-cells = <1>; + #reset-cells = <1>; + assigned-clocks = <&pmucru PLL_PPLL>; + assigned-clock-rates = <676000000>; + }; + + cru: clock-controller@ff760000 { + compatible = "rockchip,rk3399-cru"; + reg = <0x0 0xff760000 0x0 0x1000>; + #clock-cells = <1>; + #reset-cells = <1>; + assigned-clocks = + <&cru PLL_GPLL>, <&cru PLL_CPLL>, + <&cru PLL_NPLL>, + <&cru ACLK_PERIHP>, <&cru HCLK_PERIHP>, + <&cru PCLK_PERIHP>, + <&cru ACLK_PERILP0>, <&cru HCLK_PERILP0>, + <&cru PCLK_PERILP0>, + <&cru HCLK_PERILP1>, <&cru PCLK_PERILP1>; + assigned-clock-rates = + <594000000>, <800000000>, + <1000000000>, + <150000000>, <75000000>, + <37500000>, + <100000000>, <100000000>, + <50000000>, + <100000000>, <50000000>; + }; + + grf: syscon@ff770000 { + compatible = "rockchip,rk3399-grf", "syscon", "simple-mfd"; + reg = <0x0 0xff770000 0x0 0x10000>; + #address-cells = <1>; + #size-cells = <1>; + + io_domains: io-domains { + compatible = "rockchip,rk3399-io-voltage-domain"; + status = "disabled"; + }; + + emmc_phy: phy@f780 { + compatible = "rockchip,rk3399-emmc-phy"; + reg = <0xf780 0x24>; + #phy-cells = <0>; + status = "disabled"; + }; + }; + + watchdog@ff840000 { + compatible = "snps,dw-wdt"; + reg = <0x0 0xff840000 0x0 0x100>; + clocks = <&cru PCLK_WDT>; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + }; + + spdif: spdif@ff870000 { + compatible = "rockchip,rk3399-spdif"; + reg = <0x0 0xff870000 0x0 0x1000>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmac_bus 7>; + dma-names = "tx"; + clock-names = "mclk", "hclk"; + clocks = <&cru SCLK_SPDIF_8CH>, <&cru HCLK_SPDIF>; + pinctrl-names = "default"; + pinctrl-0 = <&spdif_bus>; + status = "disabled"; + }; + + i2s0: i2s@ff880000 { + compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; + reg = <0x0 0xff880000 0x0 0x1000>; + rockchip,grf = <&grf>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmac_bus 0>, <&dmac_bus 1>; + dma-names = "tx", "rx"; + clock-names = "i2s_clk", "i2s_hclk"; + clocks = <&cru SCLK_I2S0_8CH>, <&cru HCLK_I2S0_8CH>; + pinctrl-names = "default"; + pinctrl-0 = <&i2s0_8ch_bus>; + status = "disabled"; + }; + + i2s1: i2s@ff890000 { + compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; + reg = <0x0 0xff890000 0x0 0x1000>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmac_bus 2>, <&dmac_bus 3>; + dma-names = "tx", "rx"; + clock-names = "i2s_clk", "i2s_hclk"; + clocks = <&cru SCLK_I2S1_8CH>, <&cru HCLK_I2S1_8CH>; + pinctrl-names = "default"; + pinctrl-0 = <&i2s1_2ch_bus>; + status = "disabled"; + }; + + i2s2: i2s@ff8a0000 { + compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; + reg = <0x0 0xff8a0000 0x0 0x1000>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmac_bus 4>, <&dmac_bus 5>; + dma-names = "tx", "rx"; + clock-names = "i2s_clk", "i2s_hclk"; + clocks = <&cru SCLK_I2S2_8CH>, <&cru HCLK_I2S2_8CH>; + status = "disabled"; + }; + + pinctrl: pinctrl { + compatible = "rockchip,rk3399-pinctrl"; + rockchip,grf = <&grf>; + rockchip,pmu = <&pmugrf>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gpio0: gpio0@ff720000 { + compatible = "rockchip,gpio-bank"; + reg = <0x0 0xff720000 0x0 0x100>; + clocks = <&pmucru PCLK_GPIO0_PMU>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <0x2>; + + interrupt-controller; + #interrupt-cells = <0x2>; + }; + + gpio1: gpio1@ff730000 { + compatible = "rockchip,gpio-bank"; + reg = <0x0 0xff730000 0x0 0x100>; + clocks = <&pmucru PCLK_GPIO1_PMU>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <0x2>; + + interrupt-controller; + #interrupt-cells = <0x2>; + }; + + gpio2: gpio2@ff780000 { + compatible = "rockchip,gpio-bank"; + reg = <0x0 0xff780000 0x0 0x100>; + clocks = <&cru PCLK_GPIO2>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <0x2>; + + interrupt-controller; + #interrupt-cells = <0x2>; + }; + + gpio3: gpio3@ff788000 { + compatible = "rockchip,gpio-bank"; + reg = <0x0 0xff788000 0x0 0x100>; + clocks = <&cru PCLK_GPIO3>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <0x2>; + + interrupt-controller; + #interrupt-cells = <0x2>; + }; + + gpio4: gpio4@ff790000 { + compatible = "rockchip,gpio-bank"; + reg = <0x0 0xff790000 0x0 0x100>; + clocks = <&cru PCLK_GPIO4>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <0x2>; + + interrupt-controller; + #interrupt-cells = <0x2>; + }; + + pcfg_pull_up: pcfg-pull-up { + bias-pull-up; + }; + + pcfg_pull_down: pcfg-pull-down { + bias-pull-down; + }; + + pcfg_pull_none: pcfg-pull-none { + bias-disable; + }; + + pcfg_pull_none_12ma: pcfg-pull-none-12ma { + bias-disable; + drive-strength = <12>; + }; + + pcfg_pull_up_8ma: pcfg-pull-up-8ma { + bias-pull-up; + drive-strength = <8>; + }; + + pcfg_pull_down_4ma: pcfg-pull-down-4ma { + bias-pull-down; + drive-strength = <4>; + }; + + pcfg_pull_up_2ma: pcfg-pull-up-2ma { + bias-pull-up; + drive-strength = <2>; + }; + + pcfg_pull_down_12ma: pcfg-pull-down-12ma { + bias-pull-down; + drive-strength = <12>; + }; + + pcfg_pull_none_13ma: pcfg-pull-none-13ma { + bias-disable; + drive-strength = <13>; + }; + + i2c0 { + i2c0_xfer: i2c0-xfer { + rockchip,pins = + <1 15 RK_FUNC_2 &pcfg_pull_none>, + <1 16 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c1 { + i2c1_xfer: i2c1-xfer { + rockchip,pins = + <4 2 RK_FUNC_1 &pcfg_pull_none>, + <4 1 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c2 { + i2c2_xfer: i2c2-xfer { + rockchip,pins = + <2 1 RK_FUNC_2 &pcfg_pull_none_12ma>, + <2 0 RK_FUNC_2 &pcfg_pull_none_12ma>; + }; + }; + + i2c3 { + i2c3_xfer: i2c3-xfer { + rockchip,pins = + <4 17 RK_FUNC_1 &pcfg_pull_none>, + <4 16 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c4 { + i2c4_xfer: i2c4-xfer { + rockchip,pins = + <1 12 RK_FUNC_1 &pcfg_pull_none>, + <1 11 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c5 { + i2c5_xfer: i2c5-xfer { + rockchip,pins = + <3 11 RK_FUNC_2 &pcfg_pull_none>, + <3 10 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c6 { + i2c6_xfer: i2c6-xfer { + rockchip,pins = + <2 10 RK_FUNC_2 &pcfg_pull_none>, + <2 9 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c7 { + i2c7_xfer: i2c7-xfer { + rockchip,pins = + <2 8 RK_FUNC_2 &pcfg_pull_none>, + <2 7 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c8 { + i2c8_xfer: i2c8-xfer { + rockchip,pins = + <1 21 RK_FUNC_1 &pcfg_pull_none>, + <1 20 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2s0 { + i2s0_8ch_bus: i2s0-8ch-bus { + rockchip,pins = + <3 24 RK_FUNC_1 &pcfg_pull_none>, + <3 25 RK_FUNC_1 &pcfg_pull_none>, + <3 26 RK_FUNC_1 &pcfg_pull_none>, + <3 27 RK_FUNC_1 &pcfg_pull_none>, + <3 28 RK_FUNC_1 &pcfg_pull_none>, + <3 29 RK_FUNC_1 &pcfg_pull_none>, + <3 30 RK_FUNC_1 &pcfg_pull_none>, + <3 31 RK_FUNC_1 &pcfg_pull_none>, + <4 0 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2s1 { + i2s1_2ch_bus: i2s1-2ch-bus { + rockchip,pins = + <4 3 RK_FUNC_1 &pcfg_pull_none>, + <4 4 RK_FUNC_1 &pcfg_pull_none>, + <4 5 RK_FUNC_1 &pcfg_pull_none>, + <4 6 RK_FUNC_1 &pcfg_pull_none>, + <4 7 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + spdif { + spdif_bus: spdif-bus { + rockchip,pins = + <4 21 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + spi0 { + spi0_clk: spi0-clk { + rockchip,pins = + <3 6 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_cs0: spi0-cs0 { + rockchip,pins = + <3 7 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_cs1: spi0-cs1 { + rockchip,pins = + <3 8 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_tx: spi0-tx { + rockchip,pins = + <3 5 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_rx: spi0-rx { + rockchip,pins = + <3 4 RK_FUNC_2 &pcfg_pull_up>; + }; + }; + + spi1 { + spi1_clk: spi1-clk { + rockchip,pins = + <1 9 RK_FUNC_2 &pcfg_pull_up>; + }; + spi1_cs0: spi1-cs0 { + rockchip,pins = + <1 10 RK_FUNC_2 &pcfg_pull_up>; + }; + spi1_rx: spi1-rx { + rockchip,pins = + <1 7 RK_FUNC_2 &pcfg_pull_up>; + }; + spi1_tx: spi1-tx { + rockchip,pins = + <1 8 RK_FUNC_2 &pcfg_pull_up>; + }; + }; + + spi2 { + spi2_clk: spi2-clk { + rockchip,pins = + <2 11 RK_FUNC_1 &pcfg_pull_up>; + }; + spi2_cs0: spi2-cs0 { + rockchip,pins = + <2 12 RK_FUNC_1 &pcfg_pull_up>; + }; + spi2_rx: spi2-rx { + rockchip,pins = + <2 9 RK_FUNC_1 &pcfg_pull_up>; + }; + spi2_tx: spi2-tx { + rockchip,pins = + <2 10 RK_FUNC_1 &pcfg_pull_up>; + }; + }; + + spi3 { + spi3_clk: spi3-clk { + rockchip,pins = + <1 17 RK_FUNC_1 &pcfg_pull_up>; + }; + spi3_cs0: spi3-cs0 { + rockchip,pins = + <1 18 RK_FUNC_1 &pcfg_pull_up>; + }; + spi3_rx: spi3-rx { + rockchip,pins = + <1 15 RK_FUNC_1 &pcfg_pull_up>; + }; + spi3_tx: spi3-tx { + rockchip,pins = + <1 16 RK_FUNC_1 &pcfg_pull_up>; + }; + }; + + spi4 { + spi4_clk: spi4-clk { + rockchip,pins = + <3 2 RK_FUNC_2 &pcfg_pull_up>; + }; + spi4_cs0: spi4-cs0 { + rockchip,pins = + <3 3 RK_FUNC_2 &pcfg_pull_up>; + }; + spi4_rx: spi4-rx { + rockchip,pins = + <3 0 RK_FUNC_2 &pcfg_pull_up>; + }; + spi4_tx: spi4-tx { + rockchip,pins = + <3 1 RK_FUNC_2 &pcfg_pull_up>; + }; + }; + + spi5 { + spi5_clk: spi5-clk { + rockchip,pins = + <2 22 RK_FUNC_2 &pcfg_pull_up>; + }; + spi5_cs0: spi5-cs0 { + rockchip,pins = + <2 23 RK_FUNC_2 &pcfg_pull_up>; + }; + spi5_rx: spi5-rx { + rockchip,pins = + <2 20 RK_FUNC_2 &pcfg_pull_up>; + }; + spi5_tx: spi5-tx { + rockchip,pins = + <2 21 RK_FUNC_2 &pcfg_pull_up>; + }; + }; + + uart0 { + uart0_xfer: uart0-xfer { + rockchip,pins = + <2 16 RK_FUNC_1 &pcfg_pull_up>, + <2 17 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_cts: uart0-cts { + rockchip,pins = + <2 18 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_rts: uart0-rts { + rockchip,pins = + <2 19 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uart1 { + uart1_xfer: uart1-xfer { + rockchip,pins = + <3 12 RK_FUNC_2 &pcfg_pull_up>, + <3 13 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + uart2a { + uart2a_xfer: uart2a-xfer { + rockchip,pins = + <4 8 RK_FUNC_2 &pcfg_pull_up>, + <4 9 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + uart2b { + uart2b_xfer: uart2b-xfer { + rockchip,pins = + <4 16 RK_FUNC_2 &pcfg_pull_up>, + <4 17 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + uart2c { + uart2c_xfer: uart2c-xfer { + rockchip,pins = + <4 19 RK_FUNC_1 &pcfg_pull_up>, + <4 20 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uart3 { + uart3_xfer: uart3-xfer { + rockchip,pins = + <3 14 RK_FUNC_2 &pcfg_pull_up>, + <3 15 RK_FUNC_2 &pcfg_pull_none>; + }; + + uart3_cts: uart3-cts { + rockchip,pins = + <3 18 RK_FUNC_2 &pcfg_pull_none>; + }; + + uart3_rts: uart3-rts { + rockchip,pins = + <3 19 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + uart4 { + uart4_xfer: uart4-xfer { + rockchip,pins = + <1 7 RK_FUNC_1 &pcfg_pull_up>, + <1 8 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uarthdcp { + uarthdcp_xfer: uarthdcp-xfer { + rockchip,pins = + <4 21 RK_FUNC_2 &pcfg_pull_up>, + <4 22 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + pwm0 { + pwm0_pin: pwm0-pin { + rockchip,pins = + <4 18 RK_FUNC_1 &pcfg_pull_none>; + }; + + vop0_pwm_pin: vop0-pwm-pin { + rockchip,pins = + <4 18 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + pwm1 { + pwm1_pin: pwm1-pin { + rockchip,pins = + <4 22 RK_FUNC_1 &pcfg_pull_none>; + }; + + vop1_pwm_pin: vop1-pwm-pin { + rockchip,pins = + <4 18 RK_FUNC_3 &pcfg_pull_none>; + }; + }; + + pwm2 { + pwm2_pin: pwm2-pin { + rockchip,pins = + <1 19 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pwm3a { + pwm3a_pin: pwm3a-pin { + rockchip,pins = + <0 6 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pwm3b { + pwm3b_pin: pwm3b-pin { + rockchip,pins = + <1 14 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + }; +}; diff --git a/include/dt-bindings/clock/rk3399-cru.h b/include/dt-bindings/clock/rk3399-cru.h new file mode 100644 index 0000000..0a86aec --- /dev/null +++ b/include/dt-bindings/clock/rk3399-cru.h @@ -0,0 +1,746 @@ +/* + * Copyright (c) 2016 Rockchip Electronics Co. Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H + +/* core clocks */ +#define PLL_APLLL 1 +#define PLL_APLLB 2 +#define PLL_DPLL 3 +#define PLL_CPLL 4 +#define PLL_GPLL 5 +#define PLL_NPLL 6 +#define PLL_VPLL 7 +#define ARMCLKL 8 +#define ARMCLKB 9 + +/* sclk gates (special clocks) */ +#define SCLK_I2C1 65 +#define SCLK_I2C2 66 +#define SCLK_I2C3 67 +#define SCLK_I2C5 68 +#define SCLK_I2C6 69 +#define SCLK_I2C7 70 +#define SCLK_SPI0 71 +#define SCLK_SPI1 72 +#define SCLK_SPI2 73 +#define SCLK_SPI4 74 +#define SCLK_SPI5 75 +#define SCLK_SDMMC 76 +#define SCLK_SDIO 77 +#define SCLK_EMMC 78 +#define SCLK_TSADC 79 +#define SCLK_SARADC 80 +#define SCLK_UART0 81 +#define SCLK_UART1 82 +#define SCLK_UART2 83 +#define SCLK_UART3 84 +#define SCLK_SPDIF_8CH 85 +#define SCLK_I2S0_8CH 86 +#define SCLK_I2S1_8CH 87 +#define SCLK_I2S2_8CH 88 +#define SCLK_I2S_8CH_OUT 89 +#define SCLK_TIMER00 90 +#define SCLK_TIMER01 91 +#define SCLK_TIMER02 92 +#define SCLK_TIMER03 93 +#define SCLK_TIMER04 94 +#define SCLK_TIMER05 95 +#define SCLK_TIMER06 96 +#define SCLK_TIMER07 97 +#define SCLK_TIMER08 98 +#define SCLK_TIMER09 99 +#define SCLK_TIMER10 100 +#define SCLK_TIMER11 101 +#define SCLK_MACREF 102 +#define SCLK_MAC_RX 103 +#define SCLK_MAC_TX 104 +#define SCLK_MAC 105 +#define SCLK_MACREF_OUT 106 +#define SCLK_VOP0_PWM 107 +#define SCLK_VOP1_PWM 108 +#define SCLK_RGA_CORE 109 +#define SCLK_ISP0 110 +#define SCLK_ISP1 111 +#define SCLK_HDMI_CEC 112 +#define SCLK_HDMI_SFR 113 +#define SCLK_DP_CORE 114 +#define SCLK_PVTM_CORE_L 115 +#define SCLK_PVTM_CORE_B 116 +#define SCLK_PVTM_GPU 117 +#define SCLK_PVTM_DDR 118 +#define SCLK_MIPIDPHY_REF 119 +#define SCLK_MIPIDPHY_CFG 120 +#define SCLK_HSICPHY 121 +#define SCLK_USBPHY480M 122 +#define SCLK_USB2PHY0_REF 123 +#define SCLK_USB2PHY1_REF 124 +#define SCLK_UPHY0_TCPDPHY_REF 125 +#define SCLK_UPHY0_TCPDCORE 126 +#define SCLK_UPHY1_TCPDPHY_REF 127 +#define SCLK_UPHY1_TCPDCORE 128 +#define SCLK_USB3OTG0_REF 129 +#define SCLK_USB3OTG1_REF 130 +#define SCLK_USB3OTG0_SUSPEND 131 +#define SCLK_USB3OTG1_SUSPEND 132 +#define SCLK_CRYPTO0 133 +#define SCLK_CRYPTO1 134 +#define SCLK_CCI_TRACE 135 +#define SCLK_CS 136 +#define SCLK_CIF_OUT 137 +#define SCLK_PCIEPHY_REF 138 +#define SCLK_PCIE_CORE 139 +#define SCLK_M0_PERILP 140 +#define SCLK_M0_PERILP_DEC 141 +#define SCLK_CM0S 142 +#define SCLK_DBG_NOC 143 +#define SCLK_DBG_PD_CORE_B 144 +#define SCLK_DBG_PD_CORE_L 145 +#define SCLK_DFIMON0_TIMER 146 +#define SCLK_DFIMON1_TIMER 147 +#define SCLK_INTMEM0 148 +#define SCLK_INTMEM1 149 +#define SCLK_INTMEM2 150 +#define SCLK_INTMEM3 151 +#define SCLK_INTMEM4 152 +#define SCLK_INTMEM5 153 +#define SCLK_SDMMC_DRV 154 +#define SCLK_SDMMC_SAMPLE 155 +#define SCLK_SDIO_DRV 156 +#define SCLK_SDIO_SAMPLE 157 +#define SCLK_VDU_CORE 158 +#define SCLK_VDU_CA 159 +#define SCLK_PCIE_PM 160 +#define SCLK_SPDIF_REC_DPTX 161 +#define SCLK_DPHY_PLL 162 +#define SCLK_DPHY_TX0_CFG 163 +#define SCLK_DPHY_TX1RX1_CFG 164 +#define SCLK_DPHY_RX0_CFG 165 +#define SCLK_RMII_SRC 166 +#define SCLK_PCIEPHY_REF100M 167 + +#define DCLK_VOP0 180 +#define DCLK_VOP1 181 +#define DCLK_VOP0_DIV 182 +#define DCLK_VOP1_DIV 183 +#define DCLK_M0_PERILP 184 + +#define FCLK_CM0S 190 + +/* aclk gates */ +#define ACLK_PERIHP 192 +#define ACLK_PERIHP_NOC 193 +#define ACLK_PERILP0 194 +#define ACLK_PERILP0_NOC 195 +#define ACLK_PERF_PCIE 196 +#define ACLK_PCIE 197 +#define ACLK_INTMEM 198 +#define ACLK_TZMA 199 +#define ACLK_DCF 200 +#define ACLK_CCI 201 +#define ACLK_CCI_NOC0 202 +#define ACLK_CCI_NOC1 203 +#define ACLK_CCI_GRF 204 +#define ACLK_CENTER 205 +#define ACLK_CENTER_MAIN_NOC 206 +#define ACLK_CENTER_PERI_NOC 207 +#define ACLK_GPU 208 +#define ACLK_PERF_GPU 209 +#define ACLK_GPU_GRF 210 +#define ACLK_DMAC0_PERILP 211 +#define ACLK_DMAC1_PERILP 212 +#define ACLK_GMAC 213 +#define ACLK_GMAC_NOC 214 +#define ACLK_PERF_GMAC 215 +#define ACLK_VOP0_NOC 216 +#define ACLK_VOP0 217 +#define ACLK_VOP1_NOC 218 +#define ACLK_VOP1 219 +#define ACLK_RGA 220 +#define ACLK_RGA_NOC 221 +#define ACLK_HDCP 222 +#define ACLK_HDCP_NOC 223 +#define ACLK_HDCP22 224 +#define ACLK_IEP 225 +#define ACLK_IEP_NOC 226 +#define ACLK_VIO 227 +#define ACLK_VIO_NOC 228 +#define ACLK_ISP0 229 +#define ACLK_ISP1 230 +#define ACLK_ISP0_NOC 231 +#define ACLK_ISP1_NOC 232 +#define ACLK_ISP0_WRAPPER 233 +#define ACLK_ISP1_WRAPPER 234 +#define ACLK_VCODEC 235 +#define ACLK_VCODEC_NOC 236 +#define ACLK_VDU 237 +#define ACLK_VDU_NOC 238 +#define ACLK_PERI 239 +#define ACLK_EMMC 240 +#define ACLK_EMMC_CORE 241 +#define ACLK_EMMC_NOC 242 +#define ACLK_EMMC_GRF 243 +#define ACLK_USB3 244 +#define ACLK_USB3_NOC 245 +#define ACLK_USB3OTG0 246 +#define ACLK_USB3OTG1 247 +#define ACLK_USB3_RKSOC_AXI_PERF 248 +#define ACLK_USB3_GRF 249 +#define ACLK_GIC 250 +#define ACLK_GIC_NOC 251 +#define ACLK_GIC_ADB400_CORE_L_2_GIC 252 +#define ACLK_GIC_ADB400_CORE_B_2_GIC 253 +#define ACLK_GIC_ADB400_GIC_2_CORE_L 254 +#define ACLK_GIC_ADB400_GIC_2_CORE_B 255 +#define ACLK_CORE_ADB400_CORE_L_2_CCI500 256 +#define ACLK_CORE_ADB400_CORE_B_2_CCI500 257 +#define ACLK_ADB400M_PD_CORE_L 258 +#define ACLK_ADB400M_PD_CORE_B 259 +#define ACLK_PERF_CORE_L 260 +#define ACLK_PERF_CORE_B 261 +#define ACLK_GIC_PRE 262 +#define ACLK_VOP0_PRE 263 +#define ACLK_VOP1_PRE 264 + +/* pclk gates */ +#define PCLK_PERIHP 320 +#define PCLK_PERIHP_NOC 321 +#define PCLK_PERILP0 322 +#define PCLK_PERILP1 323 +#define PCLK_PERILP1_NOC 324 +#define PCLK_PERILP_SGRF 325 +#define PCLK_PERIHP_GRF 326 +#define PCLK_PCIE 327 +#define PCLK_SGRF 328 +#define PCLK_INTR_ARB 329 +#define PCLK_CENTER_MAIN_NOC 330 +#define PCLK_CIC 331 +#define PCLK_COREDBG_B 332 +#define PCLK_COREDBG_L 333 +#define PCLK_DBG_CXCS_PD_CORE_B 334 +#define PCLK_DCF 335 +#define PCLK_GPIO2 336 +#define PCLK_GPIO3 337 +#define PCLK_GPIO4 338 +#define PCLK_GRF 339 +#define PCLK_HSICPHY 340 +#define PCLK_I2C1 341 +#define PCLK_I2C2 342 +#define PCLK_I2C3 343 +#define PCLK_I2C5 344 +#define PCLK_I2C6 345 +#define PCLK_I2C7 346 +#define PCLK_SPI0 347 +#define PCLK_SPI1 348 +#define PCLK_SPI2 349 +#define PCLK_SPI4 350 +#define PCLK_SPI5 351 +#define PCLK_UART0 352 +#define PCLK_UART1 353 +#define PCLK_UART2 354 +#define PCLK_UART3 355 +#define PCLK_TSADC 356 +#define PCLK_SARADC 357 +#define PCLK_GMAC 358 +#define PCLK_GMAC_NOC 359 +#define PCLK_TIMER0 360 +#define PCLK_TIMER1 361 +#define PCLK_EDP 362 +#define PCLK_EDP_NOC 363 +#define PCLK_EDP_CTRL 364 +#define PCLK_VIO 365 +#define PCLK_VIO_NOC 366 +#define PCLK_VIO_GRF 367 +#define PCLK_MIPI_DSI0 368 +#define PCLK_MIPI_DSI1 369 +#define PCLK_HDCP 370 +#define PCLK_HDCP_NOC 371 +#define PCLK_HDMI_CTRL 372 +#define PCLK_DP_CTRL 373 +#define PCLK_HDCP22 374 +#define PCLK_GASKET 375 +#define PCLK_DDR 376 +#define PCLK_DDR_MON 377 +#define PCLK_DDR_SGRF 378 +#define PCLK_ISP1_WRAPPER 379 +#define PCLK_WDT 380 +#define PCLK_EFUSE1024NS 381 +#define PCLK_EFUSE1024S 382 +#define PCLK_PMU_INTR_ARB 383 +#define PCLK_MAILBOX0 384 +#define PCLK_USBPHY_MUX_G 385 +#define PCLK_UPHY0_TCPHY_G 386 +#define PCLK_UPHY0_TCPD_G 387 +#define PCLK_UPHY1_TCPHY_G 388 +#define PCLK_UPHY1_TCPD_G 389 +#define PCLK_ALIVE 390 + +/* hclk gates */ +#define HCLK_PERIHP 448 +#define HCLK_PERILP0 449 +#define HCLK_PERILP1 450 +#define HCLK_PERILP0_NOC 451 +#define HCLK_PERILP1_NOC 452 +#define HCLK_M0_PERILP 453 +#define HCLK_M0_PERILP_NOC 454 +#define HCLK_AHB1TOM 455 +#define HCLK_HOST0 456 +#define HCLK_HOST0_ARB 457 +#define HCLK_HOST1 458 +#define HCLK_HOST1_ARB 459 +#define HCLK_HSIC 460 +#define HCLK_SD 461 +#define HCLK_SDMMC 462 +#define HCLK_SDMMC_NOC 463 +#define HCLK_M_CRYPTO0 464 +#define HCLK_M_CRYPTO1 465 +#define HCLK_S_CRYPTO0 466 +#define HCLK_S_CRYPTO1 467 +#define HCLK_I2S0_8CH 468 +#define HCLK_I2S1_8CH 469 +#define HCLK_I2S2_8CH 470 +#define HCLK_SPDIF 471 +#define HCLK_VOP0_NOC 472 +#define HCLK_VOP0 473 +#define HCLK_VOP1_NOC 474 +#define HCLK_VOP1 475 +#define HCLK_ROM 476 +#define HCLK_IEP 477 +#define HCLK_IEP_NOC 478 +#define HCLK_ISP0 479 +#define HCLK_ISP1 480 +#define HCLK_ISP0_NOC 481 +#define HCLK_ISP1_NOC 482 +#define HCLK_ISP0_WRAPPER 483 +#define HCLK_ISP1_WRAPPER 484 +#define HCLK_RGA 485 +#define HCLK_RGA_NOC 486 +#define HCLK_HDCP 487 +#define HCLK_HDCP_NOC 488 +#define HCLK_HDCP22 489 +#define HCLK_VCODEC 490 +#define HCLK_VCODEC_NOC 491 +#define HCLK_VDU 492 +#define HCLK_VDU_NOC 493 +#define HCLK_SDIO 494 +#define HCLK_SDIO_NOC 495 +#define HCLK_SDIOAUDIO_NOC 496 + +#define CLK_NR_CLKS (HCLK_SDIOAUDIO_NOC + 1) + +/* pmu-clocks indices */ + +#define PLL_PPLL 1 + +#define SCLK_32K_SUSPEND_PMU 2 +#define SCLK_SPI3_PMU 3 +#define SCLK_TIMER12_PMU 4 +#define SCLK_TIMER13_PMU 5 +#define SCLK_UART4_PMU 6 +#define SCLK_PVTM_PMU 7 +#define SCLK_WIFI_PMU 8 +#define SCLK_I2C0_PMU 9 +#define SCLK_I2C4_PMU 10 +#define SCLK_I2C8_PMU 11 + +#define PCLK_SRC_PMU 19 +#define PCLK_PMU 20 +#define PCLK_PMUGRF_PMU 21 +#define PCLK_INTMEM1_PMU 22 +#define PCLK_GPIO0_PMU 23 +#define PCLK_GPIO1_PMU 24 +#define PCLK_SGRF_PMU 25 +#define PCLK_NOC_PMU 26 +#define PCLK_I2C0_PMU 27 +#define PCLK_I2C4_PMU 28 +#define PCLK_I2C8_PMU 29 +#define PCLK_RKPWM_PMU 30 +#define PCLK_SPI3_PMU 31 +#define PCLK_TIMER_PMU 32 +#define PCLK_MAILBOX_PMU 33 +#define PCLK_UART4_PMU 34 +#define PCLK_WDT_M0_PMU 35 + +#define FCLK_CM0S_SRC_PMU 44 +#define FCLK_CM0S_PMU 45 +#define SCLK_CM0S_PMU 46 +#define HCLK_CM0S_PMU 47 +#define DCLK_CM0S_PMU 48 +#define PCLK_INTR_ARB_PMU 49 +#define HCLK_NOC_PMU 50 + +#define CLKPMU_NR_CLKS (HCLK_NOC_PMU + 1) + +/* soft-reset indices */ + +/* cru_softrst_con0 */ +#define SRST_CORE_L0 0 +#define SRST_CORE_B0 1 +#define SRST_CORE_PO_L0 2 +#define SRST_CORE_PO_B0 3 +#define SRST_L2_L 4 +#define SRST_L2_B 5 +#define SRST_ADB_L 6 +#define SRST_ADB_B 7 +#define SRST_A_CCI 8 +#define SRST_A_CCIM0_NOC 9 +#define SRST_A_CCIM1_NOC 10 +#define SRST_DBG_NOC 11 + +/* cru_softrst_con1 */ +#define SRST_CORE_L0_T 16 +#define SRST_CORE_L1 17 +#define SRST_CORE_L2 18 +#define SRST_CORE_L3 19 +#define SRST_CORE_PO_L0_T 20 +#define SRST_CORE_PO_L1 21 +#define SRST_CORE_PO_L2 22 +#define SRST_CORE_PO_L3 23 +#define SRST_A_ADB400_GIC2COREL 24 +#define SRST_A_ADB400_COREL2GIC 25 +#define SRST_P_DBG_L 26 +#define SRST_L2_L_T 28 +#define SRST_ADB_L_T 29 +#define SRST_A_RKPERF_L 30 +#define SRST_PVTM_CORE_L 31 + +/* cru_softrst_con2 */ +#define SRST_CORE_B0_T 32 +#define SRST_CORE_B1 33 +#define SRST_CORE_PO_B0_T 36 +#define SRST_CORE_PO_B1 37 +#define SRST_A_ADB400_GIC2COREB 40 +#define SRST_A_ADB400_COREB2GIC 41 +#define SRST_P_DBG_B 42 +#define SRST_L2_B_T 43 +#define SRST_ADB_B_T 45 +#define SRST_A_RKPERF_B 46 +#define SRST_PVTM_CORE_B 47 + +/* cru_softrst_con3 */ +#define SRST_A_CCI_T 50 +#define SRST_A_CCIM0_NOC_T 51 +#define SRST_A_CCIM1_NOC_T 52 +#define SRST_A_ADB400M_PD_CORE_B_T 53 +#define SRST_A_ADB400M_PD_CORE_L_T 54 +#define SRST_DBG_NOC_T 55 +#define SRST_DBG_CXCS 56 +#define SRST_CCI_TRACE 57 +#define SRST_P_CCI_GRF 58 + +/* cru_softrst_con4 */ +#define SRST_A_CENTER_MAIN_NOC 64 +#define SRST_A_CENTER_PERI_NOC 65 +#define SRST_P_CENTER_MAIN 66 +#define SRST_P_DDRMON 67 +#define SRST_P_CIC 68 +#define SRST_P_CENTER_SGRF 69 +#define SRST_DDR0_MSCH 70 +#define SRST_DDRCFG0_MSCH 71 +#define SRST_DDR0 72 +#define SRST_DDRPHY0 73 +#define SRST_DDR1_MSCH 74 +#define SRST_DDRCFG1_MSCH 75 +#define SRST_DDR1 76 +#define SRST_DDRPHY1 77 +#define SRST_DDR_CIC 78 +#define SRST_PVTM_DDR 79 + +/* cru_softrst_con5 */ +#define SRST_A_VCODEC_NOC 80 +#define SRST_A_VCODEC 81 +#define SRST_H_VCODEC_NOC 82 +#define SRST_H_VCODEC 83 +#define SRST_A_VDU_NOC 88 +#define SRST_A_VDU 89 +#define SRST_H_VDU_NOC 90 +#define SRST_H_VDU 91 +#define SRST_VDU_CORE 92 +#define SRST_VDU_CA 93 + +/* cru_softrst_con6 */ +#define SRST_A_IEP_NOC 96 +#define SRST_A_VOP_IEP 97 +#define SRST_A_IEP 98 +#define SRST_H_IEP_NOC 99 +#define SRST_H_IEP 100 +#define SRST_A_RGA_NOC 102 +#define SRST_A_RGA 103 +#define SRST_H_RGA_NOC 104 +#define SRST_H_RGA 105 +#define SRST_RGA_CORE 106 +#define SRST_EMMC_NOC 108 +#define SRST_EMMC 109 +#define SRST_EMMC_GRF 110 + +/* cru_softrst_con7 */ +#define SRST_A_PERIHP_NOC 112 +#define SRST_P_PERIHP_GRF 113 +#define SRST_H_PERIHP_NOC 114 +#define SRST_USBHOST0 115 +#define SRST_HOSTC0_AUX 116 +#define SRST_HOST0_ARB 117 +#define SRST_USBHOST1 118 +#define SRST_HOSTC1_AUX 119 +#define SRST_HOST1_ARB 120 +#define SRST_SDIO0 121 +#define SRST_SDMMC 122 +#define SRST_HSIC 123 +#define SRST_HSIC_AUX 124 +#define SRST_AHB1TOM 125 +#define SRST_P_PERIHP_NOC 126 +#define SRST_HSICPHY 127 + +/* cru_softrst_con8 */ +#define SRST_A_PCIE 128 +#define SRST_P_PCIE 129 +#define SRST_PCIE_CORE 130 +#define SRST_PCIE_MGMT 131 +#define SRST_PCIE_MGMT_STICKY 132 +#define SRST_PCIE_PIPE 133 +#define SRST_PCIE_PM 134 +#define SRST_PCIEPHY 135 +#define SRST_A_GMAC_NOC 136 +#define SRST_A_GMAC 137 +#define SRST_P_GMAC_NOC 138 +#define SRST_P_GMAC_GRF 140 +#define SRST_HSICPHY_POR 142 +#define SRST_HSICPHY_UTMI 143 + +/* cru_softrst_con9 */ +#define SRST_USB2PHY0_POR 144 +#define SRST_USB2PHY0_UTMI_PORT0 145 +#define SRST_USB2PHY0_UTMI_PORT1 146 +#define SRST_USB2PHY0_EHCIPHY 147 +#define SRST_UPHY0_PIPE_L00 148 +#define SRST_UPHY0 149 +#define SRST_UPHY0_TCPDPWRUP 150 +#define SRST_USB2PHY1_POR 152 +#define SRST_USB2PHY1_UTMI_PORT0 153 +#define SRST_USB2PHY1_UTMI_PORT1 154 +#define SRST_USB2PHY1_EHCIPHY 155 +#define SRST_UPHY1_PIPE_L00 156 +#define SRST_UPHY1 157 +#define SRST_UPHY1_TCPDPWRUP 158 + +/* cru_softrst_con10 */ +#define SRST_A_PERILP0_NOC 160 +#define SRST_A_DCF 161 +#define SRST_GIC500 162 +#define SRST_DMAC0_PERILP0 163 +#define SRST_DMAC1_PERILP0 164 +#define SRST_TZMA 165 +#define SRST_INTMEM 166 +#define SRST_ADB400_MST0 167 +#define SRST_ADB400_MST1 168 +#define SRST_ADB400_SLV0 169 +#define SRST_ADB400_SLV1 170 +#define SRST_H_PERILP0 171 +#define SRST_H_PERILP0_NOC 172 +#define SRST_ROM 173 +#define SRST_CRYPTO_S 174 +#define SRST_CRYPTO_M 175 + +/* cru_softrst_con11 */ +#define SRST_P_DCF 176 +#define SRST_CM0S_NOC 177 +#define SRST_CM0S 178 +#define SRST_CM0S_DBG 179 +#define SRST_CM0S_PO 180 +#define SRST_CRYPTO 181 +#define SRST_P_PERILP1_SGRF 182 +#define SRST_P_PERILP1_GRF 183 +#define SRST_CRYPTO1_S 184 +#define SRST_CRYPTO1_M 185 +#define SRST_CRYPTO1 186 +#define SRST_GIC_NOC 188 +#define SRST_SD_NOC 189 +#define SRST_SDIOAUDIO_BRG 190 + +/* cru_softrst_con12 */ +#define SRST_H_PERILP1 192 +#define SRST_H_PERILP1_NOC 193 +#define SRST_H_I2S0_8CH 194 +#define SRST_H_I2S1_8CH 195 +#define SRST_H_I2S2_8CH 196 +#define SRST_H_SPDIF_8CH 197 +#define SRST_P_PERILP1_NOC 198 +#define SRST_P_EFUSE_1024 199 +#define SRST_P_EFUSE_1024S 200 +#define SRST_P_I2C0 201 +#define SRST_P_I2C1 202 +#define SRST_P_I2C2 203 +#define SRST_P_I2C3 204 +#define SRST_P_I2C4 205 +#define SRST_P_I2C5 206 +#define SRST_P_MAILBOX0 207 + +/* cru_softrst_con13 */ +#define SRST_P_UART0 208 +#define SRST_P_UART1 209 +#define SRST_P_UART2 210 +#define SRST_P_UART3 211 +#define SRST_P_SARADC 212 +#define SRST_P_TSADC 213 +#define SRST_P_SPI0 214 +#define SRST_P_SPI1 215 +#define SRST_P_SPI2 216 +#define SRST_P_SPI3 217 +#define SRST_P_SPI4 218 +#define SRST_SPI0 219 +#define SRST_SPI1 220 +#define SRST_SPI2 221 +#define SRST_SPI3 222 +#define SRST_SPI4 223 + +/* cru_softrst_con14 */ +#define SRST_I2S0_8CH 224 +#define SRST_I2S1_8CH 225 +#define SRST_I2S2_8CH 226 +#define SRST_SPDIF_8CH 227 +#define SRST_UART0 228 +#define SRST_UART1 229 +#define SRST_UART2 230 +#define SRST_UART3 231 +#define SRST_TSADC 232 +#define SRST_I2C0 233 +#define SRST_I2C1 234 +#define SRST_I2C2 235 +#define SRST_I2C3 236 +#define SRST_I2C4 237 +#define SRST_I2C5 238 +#define SRST_SDIOAUDIO_NOC 239 + +/* cru_softrst_con15 */ +#define SRST_A_VIO_NOC 240 +#define SRST_A_HDCP_NOC 241 +#define SRST_A_HDCP 242 +#define SRST_H_HDCP_NOC 243 +#define SRST_H_HDCP 244 +#define SRST_P_HDCP_NOC 245 +#define SRST_P_HDCP 246 +#define SRST_P_HDMI_CTRL 247 +#define SRST_P_DP_CTRL 248 +#define SRST_S_DP_CTRL 249 +#define SRST_C_DP_CTRL 250 +#define SRST_P_MIPI_DSI0 251 +#define SRST_P_MIPI_DSI1 252 +#define SRST_DP_CORE 253 +#define SRST_DP_I2S 254 + +/* cru_softrst_con16 */ +#define SRST_GASKET 256 +#define SRST_VIO_GRF 258 +#define SRST_DPTX_SPDIF_REC 259 +#define SRST_HDMI_CTRL 260 +#define SRST_HDCP_CTRL 261 +#define SRST_A_ISP0_NOC 262 +#define SRST_A_ISP1_NOC 263 +#define SRST_H_ISP0_NOC 266 +#define SRST_H_ISP1_NOC 267 +#define SRST_H_ISP0 268 +#define SRST_H_ISP1 269 +#define SRST_ISP0 270 +#define SRST_ISP1 271 + +/* cru_softrst_con17 */ +#define SRST_A_VOP0_NOC 272 +#define SRST_A_VOP1_NOC 273 +#define SRST_A_VOP0 274 +#define SRST_A_VOP1 275 +#define SRST_H_VOP0_NOC 276 +#define SRST_H_VOP1_NOC 277 +#define SRST_H_VOP0 278 +#define SRST_H_VOP1 279 +#define SRST_D_VOP0 280 +#define SRST_D_VOP1 281 +#define SRST_VOP0_PWM 282 +#define SRST_VOP1_PWM 283 +#define SRST_P_EDP_NOC 284 +#define SRST_P_EDP_CTRL 285 + +/* cru_softrst_con18 */ +#define SRST_A_GPU 288 +#define SRST_A_GPU_NOC 289 +#define SRST_A_GPU_GRF 290 +#define SRST_PVTM_GPU 291 +#define SRST_A_USB3_NOC 292 +#define SRST_A_USB3_OTG0 293 +#define SRST_A_USB3_OTG1 294 +#define SRST_A_USB3_GRF 295 +#define SRST_PMU 296 + +/* cru_softrst_con19 */ +#define SRST_P_TIMER0_5 304 +#define SRST_TIMER0 305 +#define SRST_TIMER1 306 +#define SRST_TIMER2 307 +#define SRST_TIMER3 308 +#define SRST_TIMER4 309 +#define SRST_TIMER5 310 +#define SRST_P_TIMER6_11 311 +#define SRST_TIMER6 312 +#define SRST_TIMER7 313 +#define SRST_TIMER8 314 +#define SRST_TIMER9 315 +#define SRST_TIMER10 316 +#define SRST_TIMER11 317 +#define SRST_P_INTR_ARB_PMU 318 +#define SRST_P_ALIVE_SGRF 319 + +/* cru_softrst_con20 */ +#define SRST_P_GPIO2 320 +#define SRST_P_GPIO3 321 +#define SRST_P_GPIO4 322 +#define SRST_P_GRF 323 +#define SRST_P_ALIVE_NOC 324 +#define SRST_P_WDT0 325 +#define SRST_P_WDT1 326 +#define SRST_P_INTR_ARB 327 +#define SRST_P_UPHY0_DPTX 328 +#define SRST_P_UPHY0_APB 330 +#define SRST_P_UPHY0_TCPHY 332 +#define SRST_P_UPHY1_TCPHY 333 +#define SRST_P_UPHY0_TCPDCTRL 334 +#define SRST_P_UPHY1_TCPDCTRL 335 + +/* pmu soft-reset indices */ + +/* pmu_cru_softrst_con0 */ +#define SRST_P_NOC 0 +#define SRST_P_INTMEM 1 +#define SRST_H_CM0S 2 +#define SRST_H_CM0S_NOC 3 +#define SRST_DBG_CM0S 4 +#define SRST_PO_CM0S 5 +#define SRST_P_SPI6 6 +#define SRST_SPI6 7 +#define SRST_P_TIMER_0_1 8 +#define SRST_P_TIMER_0 9 +#define SRST_P_TIMER_1 10 +#define SRST_P_UART4 11 +#define SRST_UART4 12 +#define SRST_P_WDT 13 + +/* pmu_cru_softrst_con1 */ +#define SRST_P_I2C6 16 +#define SRST_P_I2C7 17 +#define SRST_P_I2C8 18 +#define SRST_P_MAILBOX 19 +#define SRST_P_RKPWM 20 +#define SRST_P_PMUGRF 21 +#define SRST_P_SGRF 22 +#define SRST_P_GPIO0 23 +#define SRST_P_GPIO1 24 +#define SRST_P_CRU 25 +#define SRST_P_INTR 26 +#define SRST_PVTM 27 +#define SRST_I2C6 28 +#define SRST_I2C7 29 +#define SRST_I2C8 30 + +#endif
Applied to u-boot-rockchip, thanks!
Am 18.07.2016 um 10:46 schrieb Kever Yang:
Changes in v4: None
Commit message not extended as requested!
Further I notice that arason is not in linux.git, so it would be good to further clarify which tree that came from or whether that is a U-Boot-local change as well.
Andreas
Hi Kever,
Changes in v4: None
Andreas
Unfortunately it seems I merged these patches too soon.
For this and any other comments, please either resend the patches or send fix-up patches and I will tidy this up.
But note that I am away this week so may not get to it until I return.
RK3399 is a SoC from Rockchip with dual-core Cortex-A72 and quad-core Cortex-A53 CPU. It supports two USB3.0 type-C ports and two USB2.0 EHCI ports. Other interfaces are very much like RK3288, the DRAM are 32bit width address and support address from 0 to 4GB-128MB range.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v4: remove extra blank line in evb_rk3399.h, remove unnecessary including file in rk3399_common.h, fix base on commend from Andreas, Rebase to U-Boot ToT.
arch/arm/Kconfig | 2 - arch/arm/mach-rockchip/Kconfig | 18 +++++++++ arch/arm/mach-rockchip/rk3399/Kconfig | 18 +++++++++ board/rockchip/evb_rk3399/Kconfig | 15 +++++++ board/rockchip/evb_rk3399/MAINTAINERS | 0 board/rockchip/evb_rk3399/Makefile | 7 ++++ board/rockchip/evb_rk3399/evb-rk3399.c | 40 +++++++++++++++++++ include/configs/evb_rk3399.h | 24 ++++++++++++ include/configs/rk3399_common.h | 71 ++++++++++++++++++++++++++++++++++ 9 files changed, 193 insertions(+), 2 deletions(-) create mode 100644 arch/arm/mach-rockchip/rk3399/Kconfig create mode 100644 board/rockchip/evb_rk3399/Kconfig create mode 100644 board/rockchip/evb_rk3399/MAINTAINERS create mode 100644 board/rockchip/evb_rk3399/Makefile create mode 100644 board/rockchip/evb_rk3399/evb-rk3399.c create mode 100644 include/configs/evb_rk3399.h create mode 100644 include/configs/rk3399_common.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f9fddad..fee6a1c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -838,8 +838,6 @@ config STM32
config ARCH_ROCKCHIP bool "Support Rockchip SoCs" - select SUPPORT_SPL - select SPL select OF_CONTROL select BLK select DM diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 12415fc..4a4b6ee 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -9,6 +9,9 @@ config ROCKCHIP_RK3288 video interfaces supporting HDMI and eDP, several DDR3 options and video codec support. Peripherals include Gigabit Ethernet, USB2 host and OTG, SDIO, I2S, UART,s, SPI, I2C and PWMs. + select CPU_V7 + select SUPPORT_SPL + select SPL
config ROCKCHIP_RK3036 bool "Support Rockchip RK3036" @@ -18,7 +21,22 @@ config ROCKCHIP_RK3036 including NEON and GPU, Mali-400 graphics, several DDR3 options and video codec support. Peripherals include Gigabit Ethernet, USB2 host and OTG, SDIO, I2S, UART, SPI, I2C and PWMs. + select CPU_V7 + select SUPPORT_SPL + select SPL + +config ROCKCHIP_RK3399 + bool "Support Rockchip RK3399" + help + The Rockchip RK3399 is a ARM-based SoC with a dual-core Cortex-A72 + and quad-core Cortex-A53. + including NEON and GPU, 1MB L2 cache, Mali-T7 graphics, two + video interfaces supporting HDMI and eDP, several DDR3 options + and video codec support. Peripherals include Gigabit Ethernet, + USB2 host and OTG, SDIO, I2S, UARTs, SPI, I2C and PWMs. + select ARM64
source "arch/arm/mach-rockchip/rk3288/Kconfig" source "arch/arm/mach-rockchip/rk3036/Kconfig" +source "arch/arm/mach-rockchip/rk3399/Kconfig" endif diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig new file mode 100644 index 0000000..d15bb40 --- /dev/null +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -0,0 +1,18 @@ +if ROCKCHIP_RK3399 + +config TARGET_EVB_RK3399 + bool "RK3399 evaluation board" + help + RK3399evb is a evaluation board for Rockchp rk3399, + with full function and phisical connectors support like type-C ports, + usb2.0 host ports, LVDS, JTAG, MAC, SDcard, HDMI, USB-2-serial... + +config SYS_SOC + default "rockchip" + +config SYS_MALLOC_F_LEN + default 0x0800 + +source "board/rockchip/evb_rk3399/Kconfig" + +endif diff --git a/board/rockchip/evb_rk3399/Kconfig b/board/rockchip/evb_rk3399/Kconfig new file mode 100644 index 0000000..412b81c --- /dev/null +++ b/board/rockchip/evb_rk3399/Kconfig @@ -0,0 +1,15 @@ +if TARGET_EVB_RK3399 + +config SYS_BOARD + default "evb_rk3399" + +config SYS_VENDOR + default "rockchip" + +config SYS_CONFIG_NAME + default "evb_rk3399" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS new file mode 100644 index 0000000..e69de29 diff --git a/board/rockchip/evb_rk3399/Makefile b/board/rockchip/evb_rk3399/Makefile new file mode 100644 index 0000000..aaa51c2 --- /dev/null +++ b/board/rockchip/evb_rk3399/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2016 Rockchip Electronics Co., Ltd +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += evb-rk3399.o diff --git a/board/rockchip/evb_rk3399/evb-rk3399.c b/board/rockchip/evb_rk3399/evb-rk3399.c new file mode 100644 index 0000000..cabdda1 --- /dev/null +++ b/board/rockchip/evb_rk3399/evb-rk3399.c @@ -0,0 +1,40 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <asm/armv8/mmu.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct mm_region rk3399_mem_map[] = { + { + .base = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .base = 0xf0000000UL, + .size = 0x10000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = rk3399_mem_map; + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ + gd->ram_size = 0x80000000; + return 0; +} diff --git a/include/configs/evb_rk3399.h b/include/configs/evb_rk3399.h new file mode 100644 index 0000000..988b158 --- /dev/null +++ b/include/configs/evb_rk3399.h @@ -0,0 +1,24 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __EVB_RK3399_H +#define __EVB_RK3399_H + +#include <configs/rk3399_common.h> + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +/* + * SPL @ 32k for ~36k + * ENV @ 96k + * u-boot @ 128K + */ +#define CONFIG_ENV_OFFSET (96 * 1024) + +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_CONSOLE_SCROLL_LINES 10 + +#endif diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h new file mode 100644 index 0000000..e4248c6 --- /dev/null +++ b/include/configs/rk3399_common.h @@ -0,0 +1,71 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_RK3399_COMMON_H +#define __CONFIG_RK3399_COMMON_H + +#define CONFIG_SYS_CACHELINE_SIZE 64 + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_BAUDRATE 1500000 +#define CONFIG_SYS_MALLOC_LEN (32 << 20) +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_SYS_NS16550_MEM32 + +#define CONFIG_SYS_TEXT_BASE 0x00200000 +#define CONFIG_SYS_INIT_SP_ADDR 0x00300000 +#define CONFIG_SYS_LOAD_ADDR 0x00800800 + +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */ + +/* MMC/SD IP block */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_SDHCI +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_ROCKCHIP_SDHCI_MAX_FREQ 200000000 + +#define CONFIG_FAT_WRITE + +/* RAW SD card / eMMC locations. */ +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 256 +#define CONFIG_SYS_SPI_U_BOOT_OFFS (128 << 10) + +/* FAT sd card locations. */ +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SYS_SDRAM_BASE 0 +#define CONFIG_NR_DRAM_BANKS 1 +#define SDRAM_BANK_SIZE (2UL << 30) + +#define CONFIG_SPI_FLASH +#define CONFIG_SPI +#define CONFIG_SF_DEFAULT_SPEED 20000000 + +#ifndef CONFIG_SPL_BUILD +#include <config_distro_defaults.h> + +#define ENV_MEM_LAYOUT_SETTINGS \ + "scriptaddr=0x00000000\0" \ + "pxefile_addr_r=0x00100000\0" \ + "fdt_addr_r=0x01f00000\0" \ + "kernel_addr_r=0x02000000\0" \ + "ramdisk_addr_r=0x04000000\0" + +/* First try to boot from SD (index 0), then eMMC (index 1) */ +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) + +#include <config_distro_bootcmd.h> +#endif + +#endif
Added 'if SPL' conditions in ARCH_ROCKCHIP, and
Most of my review comments are still unresolved...
Here and below we seemed to get a merge conflict with Heiko's patch - he added ifs instead, but still they selects got added below. I don't care which way we do it, but it should be consistent please.
- select CPU_V7
Still duplicate.
- select SPL
Still below help.
- select CPU_V7
- select SPL
Ditto.
- bool "Support Rockchip RK3399"
- help
- select ARM64
Still below help.
Note that in Simon's tree this slipped below the new BROM option, it should logically be above and after RK3288.
In Simon's tree this option accidentally got dropped in this patch!
- bool "RK3399 evaluation board"
- help
No choice - intentional or forgotten?
+config SYS_SOC
- default "rockchip"
- default 0x0800
+config SYS_BOARD
- default "evb_rk3399"
+config SYS_VENDOR
- def_bool y
- (C) Copyright 2016 Rockchip Electronics Co., Ltd
.base = 0x0UL,
0,
Still in the board instead of the SoC - compare my rk3368 patch and the in-tree, e.g., fsl implementations.
- gd->ram_size = 0x80000000;
- SPL @ 32k for ~36k
- ENV @ 96k
- u-boot @ 128K
- "scriptaddr=0x00000000\0" \
- "pxefile_addr_r=0x00100000\0" \
- "fdt_addr_r=0x01f00000\0" \
- "kernel_addr_r=0x02000000\0" \
- "ramdisk_addr_r=0x04000000\0"
- func(MMC, mmc, 0) \
- func(MMC, mmc, 1)
BOOTENV still missing.
Please go through all my previous review mails (4 for this patch alone) to see if there's more remaining issues I don't spot right now. It took me time to do the review, so no reason to let nits slip in despite a respin.
Also it would be fair to CC me on resends after I've had comments so I can re-review them - I did CC you on mine.
Regards, Andreas
Hi Andreas,
I will reply your comments one by one this time, I make a mistake because I didn't rebase to ToT of u-boot-rockchip, but rebase to ToT of U-Boot, and also didn't spend enough time on Heiko's and your patch set.
Will using what Simon do when he apply this patch.
- select CPU_V7
Still duplicate.
will fix in V5.
- select SPL
Still below help.
will fix in V5.
- select CPU_V7
- select SPL
Ditto.
will fix in V5.
- help
- select ARM64
Still below help.
will fix in V5.
will fix in V5.
- help
Will fix in V5. I do not understand what to do here last time, there is no choice in rk3288/rk3036.
+config SYS_SOC
- default 0x0800
+config SYS_BOARD
+config SYS_VENDOR
- def_bool y
.base = 0x0UL,
0,
I use hikey board implementation as reference, that's why it's here, Will add a soc file to include this table.
- ENV @ 96k
- u-boot @ 128K
- func(MMC, mmc, 1)
Will add BOOTENV, I didn't care about this because I haven't start my work on loading next stage image.
I apologize for didn't CC you in this patchset, I do appreciate your help and review. I think I have replay all your comments and apply most of change except that I don't accept to add "select SYS_NS16550" in Kconfig because people add "CONFIG_SYS_NS16550=y" in defconfig.
Thanks, - Kever
Regards, Andreas
This patch add basic config option for evb-rk3399 board.
Changes in v4: move config CONFIG_SYS_NS16550 from chip common to defconfig
configs/evb-rk3399_defconfig | 33 +++++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+) create mode 100644 configs/evb-rk3399_defconfig
diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig new file mode 100644 index 0000000..3f9b47e --- /dev/null +++ b/configs/evb-rk3399_defconfig @@ -0,0 +1,33 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_EVB_RK3399=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-evb" +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_CMD_GPT=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK=y +CONFIG_FIT=y +CONFIG_SYSRESET=y +CONFIG_DM_MMC=y +CONFIG_ROCKCHIP_SDHCI=y +CONFIG_PINCTRL=y +CONFIG_RAM=y +CONFIG_SYS_NS16550=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Add a README to guide people flash the ATF and U-Boot with rockchip tools to bring up to board.
Changes in v4: None Changes in v3: None Changes in v2: fix a binary path error
board/rockchip/evb_rk3399/README | 73 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 73 insertions(+) create mode 100644 board/rockchip/evb_rk3399/README
diff --git a/board/rockchip/evb_rk3399/README b/board/rockchip/evb_rk3399/README new file mode 100644 index 0000000..af4e45e --- /dev/null +++ b/board/rockchip/evb_rk3399/README @@ -0,0 +1,73 @@ +Introduction +============ + +RK3399 key feature we might use in u-boot: +* CPU: ARMv8 64bit Big-Little architecture, +* Big: dual-core Cortex-A72 +* Little: quad-core Cortex-A53 +* IRAM: 200KB +* DRAM: 4GB-128MB dual-channel +* eMMC: support eMMC 5.0/5.1, suport HS400, HS200, DDR50 +* SD/MMC: support SD 3.0, MMC 4.51 +* USB: USB3.0 typc-C port *2 with dwc3 controller +* USB2.0 EHCI host port *2 +* Display: RGB/HDMI/DP/MIPI/EDP + +evb feature: +* regulator: pwm regulator for CPU B/L +* PMIC: rk808 +* debug console: UART2 + +In order to support Arm Trust Firmware, we need to use the +miniloader from rockchip which: +* do DRAM init +* load&verify ATF image +* load&verify u-boot image + +Here is the step by step to boot to U-boot on rk3399. + +Get the Source and prebuild binary +================================== + + > mkdir ~/evb_rk3399 + > cd ~/evb_rk3399 + > git clone https://github.com/ARM-software/arm-trusted-firmware.git + > git clone https://github.com/rockchip-linux/rkbin + > git clone https://github.com/rockchip-linux/rkflashtool + +Compile the ATF +=============== + + > cd arm-trusted-firmware + > make realclean + > make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 bl31 + +Compile the u-boot +================== + + > cd ../u-boot + > make CROSS_COMPILE=aarch64-linux-gnu- evb-rk3399_defconfig all + +Compile the rkflashtool +======================= + + > cd ../rkflashtool + > make + +Package the image for miniloader +================================ + > cd .. + > cp arm-trusted-firmware/build/rk3399/release/bl31.bin rkbin/rk33 + > ./rkbin/tools/trust_merger rkbin/tools/RK3399TRUST.ini + > ./rkbin/tools/loaderimage --pack --uboot u-boot/u-boot-dtb.bin uboot.img + > mkdir image + > mv trust.img ./image/ + > mv uboot.img ./image/rk3399evb-uboot.bin + +Flash the image +=============== +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + + > ./rkflashtool/rkflashloader rk3399evb + +You should be able to get U-boot log message in console/UART2 now.
Looks good, but please see nits below.
features
Arm Trust Firmware (ATF)
load and verify ATF image
load and verify U-Boot image
step-by-step
Please use 'U-Boot' consistently - check below also.
mkdir ~/evb_rk3399 cd ~/evb_rk3399 git clone https://github.com/ARM-software/arm-trusted-firmware.git git clone https://github.com/rockchip-linux/rkbin git clone https://github.com/rockchip-linux/rkflashtool+Compile the ATF +===============
cd arm-trusted-firmware make realclean make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 bl31+Compile the u-boot +==================
cd ../u-boot make CROSS_COMPILE=aarch64-linux-gnu- evb-rk3399_defconfig all+Compile the rkflashtool +=======================
cd ../rkflashtool make+Package the image for miniloader +================================
cd .. cp arm-trusted-firmware/build/rk3399/release/bl31.bin rkbin/rk33 ./rkbin/tools/trust_merger rkbin/tools/RK3399TRUST.ini ./rkbin/tools/loaderimage --pack --uboot u-boot/u-boot-dtb.bin uboot.img mkdir image mv trust.img ./image/ mv uboot.img ./image/rk3399evb-uboot.bin+Flash the image +=============== +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then:
./rkflashtool/rkflashloader rk3399evb+You should be able to get U-boot log message in console/UART2 now.
1.9.1
Andreas Färber
Kever Yang
