[PATCH] mmc: sdhci: Setup HS modes based on HISPD bit
There is no reason to setup HS modes by default without checking bit in capability register. Setting up HS mode by default breaks option to disable HS mode via sdhci-caps-mask DT property.
Disabling HS mode can be done via DT as: sdhci-caps-mask = <0 0x200000>;
drivers/mmc/sdhci.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 9af4de84dd6b..2119fdbae840 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -844,7 +844,10 @@ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, if (host->quirks & SDHCI_QUIRK_BROKEN_VOLTAGE) cfg->voltages |= host->voltages;
- cfg->host_caps |= MMC_MODE_HS | MMC_MODE_HS_52MHz | MMC_MODE_4BIT; + if (caps & SDHCI_CAN_DO_HISPD) + cfg->host_caps |= MMC_MODE_HS | MMC_MODE_HS_52MHz; + + cfg->host_caps |= MMC_MODE_4BIT;
/* Since Host Controller Version3.0 */ if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) {
I've already posted this fix here: https://patchwork.ozlabs.org/project/uboot/patch/20200723041219.2438-1-faiz_...
Thanks, Faiz
Wonderful. Please ignore this patch and take Faiz one.
Thanks, Michal
Faiz Abbas
Michal Simek
