[PATCH] board_init: Convert CONFIG_MALLOC_F_ADDR to Kconfig
Convert CONFIG_MALLOC_F_ADDR to Kconfig.
The CL IoT gate board used MALLOC_F_ADDR 0x912000 on i.MX8M Mini unlike all the other platforms which use 0x930000 . This has been aligned with the other i.MX8M Mini platforms.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@denx.de Cc: Kirill Kapranov kirill.kapranov@compulab.co.il Cc: Peng Fan peng.fan@nxp.com Cc: Peter Robinson pbrobinson@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com Cc: Uri Mashiach uri.mashiach@compulab.co.il Cc: Valentin Raevsky valentin@compulab.co.il Cc: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org --- Kconfig | 44 +++++++++++++++++++++ arch/sandbox/cpu/start.c | 4 +- common/init/board_init.c | 4 +- common/spl/spl.c | 4 +- include/configs/capricorn-common.h | 2 - include/configs/cgtqmx8.h | 1 - include/configs/imx8mm-cl-iot-gate.h | 7 ---- include/configs/imx8mm_beacon.h | 7 ---- include/configs/imx8mm_data_modul_edm_sbc.h | 7 ---- include/configs/imx8mm_evk.h | 7 ---- include/configs/imx8mm_icore_mx8mm.h | 6 --- include/configs/imx8mm_venice.h | 7 ---- include/configs/imx8mn_beacon.h | 8 ---- include/configs/imx8mp_rsb3720.h | 5 --- include/configs/imx8mq_cm.h | 5 --- include/configs/imx8mq_evk.h | 4 -- include/configs/imx8mq_phanbell.h | 4 -- include/configs/imx8qm_mek.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/imx8ulp_evk.h | 6 --- include/configs/kontron-sl-mx8mm.h | 5 --- include/configs/kontron_pitx_imx8m.h | 5 --- include/configs/kontron_sl28.h | 5 --- include/configs/phycore_imx8mm.h | 6 --- include/configs/pico-imx8mq.h | 4 -- include/configs/sandbox.h | 2 - include/configs/verdin-imx8mm.h | 6 --- include/configs/verdin-imx8mp.h | 6 --- scripts/config_whitelist.txt | 1 - 29 files changed, 47 insertions(+), 127 deletions(-)
diff --git a/Kconfig b/Kconfig index 991b260182e..495a560d6bc 100644 --- a/Kconfig +++ b/Kconfig @@ -286,6 +286,23 @@ config SYS_MALLOC_F particular needs this to operate, so that it can allocate the initial serial device and any others that are needed.
+config MALLOC_F_ADDR + hex "Address of malloc() pool before relocation" + depends on SYS_MALLOC_F + default 0x120000 if ARCH_IMX8 + default 0x182000 if ARCH_IMX8M && IMX8MQ + default 0x930000 if ARCH_IMX8M && IMX8MM + default 0x184000 if ARCH_IMX8M && IMX8MN + default 0x184000 if ARCH_IMX8M && IMX8MP + default 0x22040000 if ARCH_IMX8ULP + default 0x18000000 if ARCH_LS1028A + default 0x10000 if SANDBOX + default 0x0 + help + Before relocation, memory is very limited on many platforms. Still, + we can provide a small malloc() pool if needed. This option selects + placement of early malloc pool. + config SYS_MALLOC_F_LEN hex "Size of malloc() pool before relocation" depends on SYS_MALLOC_F @@ -320,6 +337,15 @@ config SYS_MALLOC_LEN This defines memory to be allocated for Dynamic allocation TODO: Use for other architectures
+config SPL_MALLOC_F_ADDR + hex "Address of malloc() pool before relocation in SPL" + depends on SYS_MALLOC_F && SPL + default MALLOC_F_ADDR + help + Before relocation, memory is very limited on many platforms. Still, + we can provide a small malloc() pool if needed. This option selects + placement of early malloc pool in SPL. + config SPL_SYS_MALLOC_F_LEN hex "Size of malloc() pool in SPL" depends on SYS_MALLOC_F && SPL @@ -335,6 +361,15 @@ config SPL_SYS_MALLOC_F_LEN It is possible to enable CONFIG_SYS_SPL_MALLOC_START to start a new malloc() region in SDRAM once it is inited.
+config TPL_MALLOC_F_ADDR + hex "Address of malloc() pool before relocation in TPL" + depends on SYS_MALLOC_F && TPL + default SPL_MALLOC_F_ADDR + help + Before relocation, memory is very limited on many platforms. Still, + we can provide a small malloc() pool if needed. This option selects + placement of early malloc pool in TPL. + config TPL_SYS_MALLOC_F_LEN hex "Size of malloc() pool in TPL" depends on SYS_MALLOC_F && TPL @@ -360,6 +395,15 @@ config VALGRIND it can be handled accurately by Valgrind. If you aren't planning on using valgrind to debug U-Boot, say 'n'.
+config VPL_MALLOC_F_ADDR + hex "Address of malloc() pool before relocation in VPL" + depends on SYS_MALLOC_F && VPL + default MALLOC_F_ADDR + help + Before relocation, memory is very limited on many platforms. Still, + we can provide a small malloc() pool if needed. This option selects + placement of early malloc pool in VPL. + config VPL_SYS_MALLOC_F_LEN hex "Size of malloc() pool in VPL before relocation" depends on SYS_MALLOC_F && VPL diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 90a84e93c79..aad983d7b78 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -506,9 +506,7 @@ int sandbox_main(int argc, char *argv[]) goto err; }
-#if CONFIG_VAL(SYS_MALLOC_F_LEN) - gd->malloc_base = CONFIG_MALLOC_F_ADDR; -#endif + gd->malloc_base = CONFIG_VAL(MALLOC_F_ADDR); #if CONFIG_IS_ENABLED(LOG) gd->default_log_level = state->default_log_level; #endif diff --git a/common/init/board_init.c b/common/init/board_init.c index 6a550261778..35506f2ed35 100644 --- a/common/init/board_init.c +++ b/common/init/board_init.c @@ -78,10 +78,8 @@ __weak void board_init_f_init_stack_protection(void) ulong board_init_f_alloc_reserve(ulong top) { /* Reserve early malloc arena */ -#ifndef CONFIG_MALLOC_F_ADDR -#if CONFIG_VAL(SYS_MALLOC_F_LEN) +#if CONFIG_VAL(MALLOC_F_ADDR) && CONFIG_VAL(SYS_MALLOC_F_LEN) top -= CONFIG_VAL(SYS_MALLOC_F_LEN); -#endif #endif /* LAST : reserve GD (rounded up to a multiple of 16 bytes) */ top = rounddown(top-sizeof(struct global_data), 16); diff --git a/common/spl/spl.c b/common/spl/spl.c index 29e0898f03d..2b0b6584924 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -503,9 +503,7 @@ static int spl_common_init(bool setup_malloc)
#if CONFIG_VAL(SYS_MALLOC_F_LEN) if (setup_malloc) { -#ifdef CONFIG_MALLOC_F_ADDR - gd->malloc_base = CONFIG_MALLOC_F_ADDR; -#endif + gd->malloc_base = CONFIG_VAL(MALLOC_F_ADDR); gd->malloc_limit = CONFIG_VAL(SYS_MALLOC_F_LEN); gd->malloc_ptr = 0; } diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index 6b1e82ad3b1..0de739c0013 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -17,8 +17,6 @@
#define CONFIG_SYS_MONITOR_LEN (1024 * 1024)
-#define CONFIG_MALLOC_F_ADDR 0x00120000 - #endif /* CONFIG_SPL_BUILD */
/* ENET1 connects to base board and MUX with ESAI */ diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h index 6ac84878519..5dede78bc48 100644 --- a/include/configs/cgtqmx8.h +++ b/include/configs/cgtqmx8.h @@ -15,7 +15,6 @@ #define CONFIG_SYS_MONITOR_LEN (1024 * 1024)
#define CONFIG_SERIAL_LPUART_BASE 0x5a060000 -#define CONFIG_MALLOC_F_ADDR 0x00120000
#endif
diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index c69f2fa19f3..58687bc311f 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -15,13 +15,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x912000 -/* For RAW image gives a error info not panic */ - -#endif - /* GUIDs for capsule updatable firmware images */ #define IMX8MM_CL_IOT_GATE_FIT_IMAGE_GUID \ EFI_GUID(0x7a32a939, 0xab92, 0x467b, 0x91, 0x52, \ diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 79ed3971225..71ca414bc01 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -13,13 +13,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ - -#endif - /* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h index fb05958bdc8..69efab257dc 100644 --- a/include/configs/imx8mm_data_modul_edm_sbc.h +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -12,13 +12,6 @@
#define CONFIG_SYS_MONITOR_LEN SZ_1M
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_MALLOC_F_ADDR 0x930000 - -/* For RAW image gives a error info not panic */ - -#endif - /* Link Definitions */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x200000 diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 5e9e3e800d8..06d9837d39e 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -14,13 +14,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ - -#endif - #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 2) \ diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h index 6b7f3af53a2..46971bdbf81 100644 --- a/include/configs/imx8mm_icore_mx8mm.h +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -14,12 +14,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -# define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#endif /* CONFIG_SPL_BUILD */ - #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 2) \ func(MMC, mmc, 0) diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 13015604509..e61bc304310 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -13,13 +13,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ - -#endif - #define MEM_LAYOUT_ENV_SETTINGS \ "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "fdt_addr_r=0x50200000\0" \ diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h index 6faecbde776..930b11b75e7 100644 --- a/include/configs/imx8mn_beacon.h +++ b/include/configs/imx8mn_beacon.h @@ -13,14 +13,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x184000 - -/* For RAW image gives a error info not panic */ - -#endif /* CONFIG_SPL_BUILD */ - /* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ diff --git a/include/configs/imx8mp_rsb3720.h b/include/configs/imx8mp_rsb3720.h index 17e00f958b6..a7d5c85e856 100644 --- a/include/configs/imx8mp_rsb3720.h +++ b/include/configs/imx8mp_rsb3720.h @@ -25,11 +25,6 @@ 0x5f, 0xd3, 0x6b, 0x9b, 0xe5, 0xb9)
#ifdef CONFIG_SPL_BUILD -#define CONFIG_MALLOC_F_ADDR 0x184000 /* malloc f used before \ - * GD_FLG_FULL_MALLOC_INIT \ - * set \ - */ -
#if defined(CONFIG_NAND_BOOT) #define CONFIG_SPL_NAND_MXS diff --git a/include/configs/imx8mq_cm.h b/include/configs/imx8mq_cm.h index ab74d5b26b6..e914cfc01a0 100644 --- a/include/configs/imx8mq_cm.h +++ b/include/configs/imx8mq_cm.h @@ -14,11 +14,6 @@
#ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ - #endif
/* ENET Config */ diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index ea4305667f2..48a50544040 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -16,10 +16,6 @@ /*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ #define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000
-/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ - #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 #endif diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index 97bd5044501..28add2025b0 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -14,10 +14,6 @@ #ifdef CONFIG_SPL_BUILD /*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ #define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ #endif
/* ENET Config */ diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index 5f9d06e0f6f..100873de58b 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -14,7 +14,6 @@ #define CONFIG_SYS_MONITOR_LEN (1024 * 1024)
#endif
diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index f8ec16ebb19..cb7c6fa6f5d 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -14,7 +14,6 @@ #define CONFIG_SYS_MONITOR_LEN (1024 * 1024)
#endif
diff --git a/include/configs/imx8ulp_evk.h b/include/configs/imx8ulp_evk.h index ebfc166b4d4..a1eac5cad58 100644 --- a/include/configs/imx8ulp_evk.h +++ b/include/configs/imx8ulp_evk.h @@ -12,12 +12,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_MALLOC_F_ADDR 0x22040000 - - -#endif - /* ENET Config */ #if defined(CONFIG_FEC_MXC) #define PHY_ANEG_TIMEOUT 20000 diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index 622ab597624..3ae3e83a867 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -45,11 +45,6 @@ #undef BOOTENV_RUN_NET_USB_START #define BOOTENV_RUN_NET_USB_START
-#ifdef CONFIG_SPL_BUILD -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -#endif - #define ENV_MEM_LAYOUT_SETTINGS \ "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "kernel_addr_r=0x42000000\0" \ diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h index d77e4b4e100..c7ba1e90898 100644 --- a/include/configs/kontron_pitx_imx8m.h +++ b/include/configs/kontron_pitx_imx8m.h @@ -17,11 +17,6 @@ #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000
-/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ - - #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 #endif diff --git a/include/configs/kontron_sl28.h b/include/configs/kontron_sl28.h index 2373abf3e31..558774d9644 100644 --- a/include/configs/kontron_sl28.h +++ b/include/configs/kontron_sl28.h @@ -30,11 +30,6 @@ /* SMP */ #define CPU_RELEASE_ADDR secondary_boot_addr
-/* generic timer */ - -/* early heap for SPL DM */ -#define CONFIG_MALLOC_F_ADDR CONFIG_SYS_FSL_OCRAM_BASE - /* serial port */ #define CONFIG_SYS_NS16550_CLK (get_bus_freq(0) / 2)
diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index 049d1d74345..94bb71355e0 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -15,12 +15,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#endif - #define CONFIG_EXTRA_ENV_SETTINGS \ "image=Image\0" \ "console=ttymxc2,115200\0" \ diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index d1cc1b9d63f..905d84066b8 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -14,10 +14,6 @@ #ifdef CONFIG_SPL_BUILD /*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ #define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ #endif
/* ENET Config */ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 5168e2fa353..38c8337164f 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -8,8 +8,6 @@
#define CONFIG_IO_TRACE
-#define CONFIG_MALLOC_F_ADDR 0x0010000 - /* GUIDs for capsule updatable firmware images */ #define SANDBOX_UBOOT_IMAGE_GUID \ EFI_GUID(0x09d7cf52, 0x0720, 0x4710, 0x91, 0xd1, \ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 5b5fce9bda1..f4289d2cf78 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -13,12 +13,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#endif - #define MEM_LAYOUT_ENV_SETTINGS \ "fdt_addr_r=0x44000000\0" \ "kernel_addr_r=0x42000000\0" \ diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index fca40beba18..0aa61735284 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -14,12 +14,6 @@ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
#ifdef CONFIG_SPL_BUILD -/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ - -/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ -#define CONFIG_MALLOC_F_ADDR 0x184000 -/* For RAW image gives a error info not panic */ - #define CONFIG_POWER_PCA9450
#define CONFIG_SYS_I2C diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 0a2b8179d49..f02f546d942 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -298,7 +298,6 @@ CONFIG_LPC32XX_NAND_SLC_WSETUP CONFIG_LPC32XX_NAND_SLC_WWIDTH CONFIG_LS102XA_STREAM_ID CONFIG_MACB_SEARCH_PHY -CONFIG_MALLOC_F_ADDR CONFIG_MALTA CONFIG_MAX_DSP_CPUS CONFIG_MAX_MEM_MAPPED
[snip]
This isn't equivalent. It was "if we don't have MALLOC_F_ADDR but do have SYS_MALLOC_F_LEN ..." and now is "if we have MALLOC_F_ADDR and SYS_MALLOC_F_LEN ...". I changed this, and then nokia_rx51 passed in CI again (it was failing to boot at all). But still riscv and qemux86-64 and evb-ast2600 still fail to boot: https://source.denx.de/u-boot/u-boot/-/pipelines/13296
Please re-check the migration, thanks.
[snip]
But this is not correct. It was
if CONFIG_MALLOC_F_ADDR is not declared and CONFIG_{SPL,TPL,...}SYS_MALLOC_F_LEN is non-zero
With the switch to Kconfig, the MALLOC_F_ADDR is always declared, except for the cases where it was not declared before, it is set to 0. So the change to:
if CONFIG_{SPL,TPL,...}MALLOC_F_ADDR is non-zero and CONFIG_{SPL,TPL,...}SYS_MALLOC_F_LEN is non-zero
seems equivalent to me, except of course for the handling of SPL/TPL part, which is done in the Kconfig
[snip]
This is an annoying symbol to convert. With the exception of sandbox and kontron_sl28 (which I believe to be in error, no other imx boards do this, and it is an anti-pattern to set this symbol the way it's been set), this is only defined when CONFIG_SPL_BUILD is true. So we need to rename it to CONFIG_SPL_MALLOC_F_ADDR and then use it. And then yes, we need to switch to testing with CONFIG_VAL() and it being non-zero. I know I didn't take your original patch, and dug in more here because some platforms had binary size change here.
