[U-Boot] [PATCH] arm64: zynqmp: Define default SPL_TEXT_BASE address in Kconfig
Define default address via Kconfig. There is no need to change this address for most of the boards but it is also possible. This one line save a lot of lines in defconfigs that's why make sense to do it.
The similar change has been done by commit 9340d8fe8beb ("sunxi: move CONFIG_SPL_TEXT_BASE from *_defconfig to Kconfig")
common/spl/Kconfig | 1 + configs/avnet_ultra96_rev1_defconfig | 1 - configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig | 1 - configs/xilinx_zynqmp_mini_emmc0_defconfig | 1 - configs/xilinx_zynqmp_mini_emmc1_defconfig | 1 - configs/xilinx_zynqmp_mini_qspi_defconfig | 1 - configs/xilinx_zynqmp_zc1232_revA_defconfig | 1 - configs/xilinx_zynqmp_zc1254_revA_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 - configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 - configs/xilinx_zynqmp_zcu100_revC_defconfig | 1 - configs/xilinx_zynqmp_zcu102_rev1_0_defconfig | 1 - configs/xilinx_zynqmp_zcu102_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 - configs/xilinx_zynqmp_zcu104_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu104_revC_defconfig | 1 - configs/xilinx_zynqmp_zcu106_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu111_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu1275_revA_defconfig | 1 - configs/xilinx_zynqmp_zcu1275_revB_defconfig | 1 - 23 files changed, 1 insertion(+), 22 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index f467eca2be72..59a7b200891f 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -138,6 +138,7 @@ config SPL_TEXT_BASE default 0x10060 if MACH_SUN50I || MACH_SUN50I_H5 || MACH_SUN9I default 0x20060 if MACH_SUN50I_H6 default 0x00060 if ARCH_SUNXI + default 0xfffc0000 if ARCH_ZYNQMP default 0x0 help The address in memory that SPL will be running from. diff --git a/configs/avnet_ultra96_rev1_defconfig b/configs/avnet_ultra96_rev1_defconfig index b504332ff006..924153081149 100644 --- a/configs/avnet_ultra96_rev1_defconfig +++ b/configs/avnet_ultra96_rev1_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index b326231b6829..f463318565ff 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTDELAY=0 # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index 0faa3326132d..b4162abdd715 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -12,7 +12,6 @@ CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="ZynqMP> " diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index 867d2e5d9cee..76d5aa6c713b 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -12,7 +12,6 @@ CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="ZynqMP> " diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index b0bc84d55eca..a20534a488ca 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -14,7 +14,6 @@ CONFIG_ZYNQMP_NO_DDR=y # CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/xilinx_zynqmp_zc1232_revA_defconfig b/configs/xilinx_zynqmp_zc1232_revA_defconfig index aa2165f77adb..80a310fb1cee 100644 --- a/configs/xilinx_zynqmp_zc1232_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1232_revA_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1254_revA_defconfig b/configs/xilinx_zynqmp_zc1254_revA_defconfig index 1ab0639eb9e2..75ec572827bf 100644 --- a/configs/xilinx_zynqmp_zc1254_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1254_revA_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 7b1f5e9d0ae3..ce1ea089ce8d 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index ae2554a8eb74..01c29c0e70a3 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig index 559a61e8d020..877f5b230da3 100644 --- a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index cc2af6dce0ac..6f14234a590e 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -12,7 +12,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index bf66171335d2..f1970aadf417 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -12,7 +12,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu100_revC_defconfig b/configs/xilinx_zynqmp_zcu100_revC_defconfig index 4b3f72da7487..cd7d2f5376d2 100644 --- a/configs/xilinx_zynqmp_zcu100_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu100_revC_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index ef291a7d38ef..371e6363db2f 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -16,7 +16,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 975e9f5eb13b..a0fb6c3586cc 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -16,7 +16,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 34918aa17196..db7c093d5ebc 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -16,7 +16,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu104_revA_defconfig b/configs/xilinx_zynqmp_zcu104_revA_defconfig index e4090dc28122..eacf75d9f8e2 100644 --- a/configs/xilinx_zynqmp_zcu104_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revA_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu104_revC_defconfig b/configs/xilinx_zynqmp_zcu104_revC_defconfig index 25a2515d1552..1c9a6d6f1ec4 100644 --- a/configs/xilinx_zynqmp_zcu104_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revC_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu106_revA_defconfig b/configs/xilinx_zynqmp_zcu106_revA_defconfig index 212de924a68a..1b685ca04925 100644 --- a/configs/xilinx_zynqmp_zcu106_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu106_revA_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu111_revA_defconfig b/configs/xilinx_zynqmp_zcu111_revA_defconfig index dec894787e21..74106d7ea8fa 100644 --- a/configs/xilinx_zynqmp_zcu111_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu111_revA_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu1275_revA_defconfig b/configs/xilinx_zynqmp_zcu1275_revA_defconfig index c73a97a050cc..b9110ca3b936 100644 --- a/configs/xilinx_zynqmp_zcu1275_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu1275_revA_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu1275_revB_defconfig b/configs/xilinx_zynqmp_zcu1275_revB_defconfig index 0d4302ea737c..03372c77e637 100644 --- a/configs/xilinx_zynqmp_zcu1275_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu1275_revB_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y
Hi Michal,
Reviewed-by: Luca Ceresoli luca@lucaceresoli.net
st 11. 9. 2019 v 8:54 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
diff --git a/configs/avnet_ultra96_rev1_defconfig b/configs/avnet_ultra96_rev1_defconfig index b504332ff006..924153081149 100644 --- a/configs/avnet_ultra96_rev1_defconfig +++ b/configs/avnet_ultra96_rev1_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig index b326231b6829..f463318565ff 100644 --- a/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig +++ b/configs/avnet_ultrazedev_cc_v1_0_ultrazedev_som_v1_0_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y CONFIG_BOOTDELAY=0 # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y diff --git a/configs/xilinx_zynqmp_mini_emmc0_defconfig b/configs/xilinx_zynqmp_mini_emmc0_defconfig index 0faa3326132d..b4162abdd715 100644 --- a/configs/xilinx_zynqmp_mini_emmc0_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc0_defconfig @@ -12,7 +12,6 @@ CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="ZynqMP> " diff --git a/configs/xilinx_zynqmp_mini_emmc1_defconfig b/configs/xilinx_zynqmp_mini_emmc1_defconfig index 867d2e5d9cee..76d5aa6c713b 100644 --- a/configs/xilinx_zynqmp_mini_emmc1_defconfig +++ b/configs/xilinx_zynqmp_mini_emmc1_defconfig @@ -12,7 +12,6 @@ CONFIG_SUPPORT_RAW_INITRD=y # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="ZynqMP> " diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index b0bc84d55eca..a20534a488ca 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -14,7 +14,6 @@ CONFIG_ZYNQMP_NO_DDR=y # CONFIG_LEGACY_IMAGE_FORMAT is not set # CONFIG_BOARD_LATE_INIT is not set # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 # CONFIG_CMDLINE_EDITING is not set # CONFIG_AUTO_COMPLETE is not set # CONFIG_SYS_LONGHELP is not set diff --git a/configs/xilinx_zynqmp_zc1232_revA_defconfig b/configs/xilinx_zynqmp_zc1232_revA_defconfig index aa2165f77adb..80a310fb1cee 100644 --- a/configs/xilinx_zynqmp_zc1232_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1232_revA_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1254_revA_defconfig b/configs/xilinx_zynqmp_zc1254_revA_defconfig index 1ab0639eb9e2..75ec572827bf 100644 --- a/configs/xilinx_zynqmp_zc1254_revA_defconfig +++ b/configs/xilinx_zynqmp_zc1254_revA_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 7b1f5e9d0ae3..ce1ea089ce8d 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index ae2554a8eb74..01c29c0e70a3 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig index 559a61e8d020..877f5b230da3 100644 --- a/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm017_dc3_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index cc2af6dce0ac..6f14234a590e 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -12,7 +12,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index bf66171335d2..f1970aadf417 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -12,7 +12,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu100_revC_defconfig b/configs/xilinx_zynqmp_zcu100_revC_defconfig index 4b3f72da7487..cd7d2f5376d2 100644 --- a/configs/xilinx_zynqmp_zcu100_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu100_revC_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig index ef291a7d38ef..371e6363db2f 100644 --- a/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig +++ b/configs/xilinx_zynqmp_zcu102_rev1_0_defconfig @@ -16,7 +16,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu102_revA_defconfig b/configs/xilinx_zynqmp_zcu102_revA_defconfig index 975e9f5eb13b..a0fb6c3586cc 100644 --- a/configs/xilinx_zynqmp_zcu102_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revA_defconfig @@ -16,7 +16,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 34918aa17196..db7c093d5ebc 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -16,7 +16,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu104_revA_defconfig b/configs/xilinx_zynqmp_zcu104_revA_defconfig index e4090dc28122..eacf75d9f8e2 100644 --- a/configs/xilinx_zynqmp_zcu104_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revA_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu104_revC_defconfig b/configs/xilinx_zynqmp_zcu104_revC_defconfig index 25a2515d1552..1c9a6d6f1ec4 100644 --- a/configs/xilinx_zynqmp_zcu104_revC_defconfig +++ b/configs/xilinx_zynqmp_zcu104_revC_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu106_revA_defconfig b/configs/xilinx_zynqmp_zcu106_revA_defconfig index 212de924a68a..1b685ca04925 100644 --- a/configs/xilinx_zynqmp_zcu106_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu106_revA_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu111_revA_defconfig b/configs/xilinx_zynqmp_zcu111_revA_defconfig index dec894787e21..74106d7ea8fa 100644 --- a/configs/xilinx_zynqmp_zcu111_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu111_revA_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu1275_revA_defconfig b/configs/xilinx_zynqmp_zcu1275_revA_defconfig index c73a97a050cc..b9110ca3b936 100644 --- a/configs/xilinx_zynqmp_zcu1275_revA_defconfig +++ b/configs/xilinx_zynqmp_zcu1275_revA_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/xilinx_zynqmp_zcu1275_revB_defconfig b/configs/xilinx_zynqmp_zcu1275_revB_defconfig index 0d4302ea737c..03372c77e637 100644 --- a/configs/xilinx_zynqmp_zcu1275_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu1275_revB_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_DISPLAY_CPUINFO is not set -CONFIG_SPL_TEXT_BASE=0xfffc0000 CONFIG_SPL_OS_BOOT=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y -- 2.17.1
Applied. M
Luca Ceresoli
Michal Simek
Michal Simek
