Re: [U-Boot] V2 of OMAP3 USB device Support
2009/9/28 y@windriver.com:
What is the difference between sender 'y' and 'Tom Rix'? I guess I can safely ignore the 'y' sender...?
Remy
The technical change is better handling of address setting on the usb handshaking setup phase.
Other changes from Jean's comments
2/8 USB add macros for debugging usb device setup.
static inline function replacing debug macros
3/8 TWL4030 Add usb PHY support
add empty lines between variables and statements other empty lines added for readablity
4/8 OMAP3 Add usb device support
80+ char lines reduced Used MUSB_FLAGS_PRINT macro suggestion lowercased function names multi-lined ep0_state_enum Used suggestion on udelay to 1000 * 1000 add empty lines between variables and statements inverted check of ep0_urb->device_request.wLength other empty lines added for readablity
5/8 OMAP3 zoom1 Add usbtty configuration
This was ack-ed by Jean
6/8 OMAP3 beagle Add usbtty configuration
8/8 OMAP3 zoom2 Use usbtty if the debug board
cleanup using usbtty_* functions or their stubs without #define's _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Remy
Yes ignore the 'y' sender I bungled the git send-email. I tapped 'y' twice on the send-email command.
I will also look into changing my mailing id to just 'y'. :P
Tom
Remy Bohmer
Tom
