[U-Boot] [PATCH] usb gadget ether: Fix warning in is_eth_addr_valid()
The gadget ethernet driver needs to keep copies of the MAC address (at both endpoints) as strings so it needs a custom function for validation of the MAC. It was not however performing a totally correct check and also was emitting a warning about a set but unused variable. The solution to both is that after checking the string contents we use the standard test for a valid MAC.
Cc: Joe Hershberger joe.hershberger@ni.com Cc: Marek Vasut marex@denx.de Signed-off-by: Tom Rini trini@ti.com --- drivers/usb/gadget/ether.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 6f7e4cd..7444c1e 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -1968,8 +1968,8 @@ static int is_eth_addr_valid(char *str) p = q; }
- if (i == 6) /* it looks ok */ - return 1; + /* Now check the contents. */ + return is_valid_ether_addr(ea); } return 0; }
Hi Tom,
On Wed, Oct 31, 2012 at 07:31:12PM -0500, Joe Hershberger wrote:
Hi Tom,
Joe Hershberger
