[U-Boot] [PATCH 0/7] sunxi: a20/r40: Migrate DM_MMC and DM_SCSI
This would Migrate DM_MMC, DM_SCSI for A20 and R40 platforms.
Note: - a20-wits-pro-a20-dkt change would need to send Linux first - BPI-M2-Berry would break, but will import Linux dts once approved.
Andre Przywara (1): sunxi: update SATA driver to always use DM_SCSI
Jagan Teki (6): arm: allwinner: r40: Sync R40 dts(i) files from Linux 5.1-rc2 arm: allwinner: dts: a20: Sync A20 dts(i) files from Linux 5.1-rc2 board: sunxi: Add R40 sata compatible ARM: dts: a20-m5: Enable AHCI ARM: dts: a20-wits-pro-a20-dkt: Enable AHCI arm: sunxi: Enable DM_MMC and DM_SCSI
arch/arm/Kconfig | 2 + arch/arm/dts/sun7i-a20-ainol-aw1.dts | 2 +- arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts | 46 +-- arch/arm/dts/sun7i-a20-bananapi.dts | 49 +-- arch/arm/dts/sun7i-a20-bananapro.dts | 65 +--- arch/arm/dts/sun7i-a20-cubieboard2.dts | 21 +- arch/arm/dts/sun7i-a20-cubietruck.dts | 83 ++-- arch/arm/dts/sun7i-a20-hummingbird.dts | 60 +-- arch/arm/dts/sun7i-a20-i12-tvbox.dts | 47 +-- arch/arm/dts/sun7i-a20-icnova-swac.dts | 10 +- arch/arm/dts/sun7i-a20-itead-ibox.dts | 10 +- arch/arm/dts/sun7i-a20-lamobo-r1.dts | 48 +-- arch/arm/dts/sun7i-a20-m3.dts | 21 +- arch/arm/dts/sun7i-a20-m5.dts | 8 +- arch/arm/dts/sun7i-a20-mk808c.dts | 26 +- .../arm/dts/sun7i-a20-olimex-som-evb-emmc.dts | 35 ++ arch/arm/dts/sun7i-a20-olimex-som-evb.dts | 68 +--- .../dts/sun7i-a20-olimex-som204-evb-emmc.dts | 2 - arch/arm/dts/sun7i-a20-olimex-som204-evb.dts | 36 +- arch/arm/dts/sun7i-a20-olinuxino-lime.dts | 22 +- .../dts/sun7i-a20-olinuxino-lime2-emmc.dts | 11 - arch/arm/dts/sun7i-a20-olinuxino-lime2.dts | 34 +- .../dts/sun7i-a20-olinuxino-micro-emmc.dts | 2 - arch/arm/dts/sun7i-a20-olinuxino-micro.dts | 54 +-- arch/arm/dts/sun7i-a20-orangepi-mini.dts | 52 +-- arch/arm/dts/sun7i-a20-orangepi.dts | 44 +-- arch/arm/dts/sun7i-a20-pcduino3-nano.dts | 31 +- arch/arm/dts/sun7i-a20-pcduino3.dts | 39 +- arch/arm/dts/sun7i-a20-primo73.dts | 4 +- arch/arm/dts/sun7i-a20-wexler-tab7200.dts | 39 +- arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts | 27 +- .../dts/sun7i-a20-yones-toptech-bd1078.dts | 2 +- arch/arm/dts/sun7i-a20.dtsi | 209 ++++++---- arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 91 ++++- arch/arm/dts/sun8i-r40.dtsi | 364 +++++++++++++++++- arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts | 2 +- arch/arm/dts/sunxi-itead-core-common.dtsi | 6 +- arch/arm/mach-sunxi/Kconfig | 13 - board/sunxi/Makefile | 3 - drivers/ata/Kconfig | 8 + drivers/ata/Makefile | 1 + .../sunxi/ahci.c => drivers/ata/ahci_sunxi.c | 11 +- include/configs/sunxi-common.h | 6 - scripts/config_whitelist.txt | 1 - 44 files changed, 838 insertions(+), 877 deletions(-) create mode 100644 arch/arm/dts/sun7i-a20-olimex-som-evb-emmc.dts rename board/sunxi/ahci.c => drivers/ata/ahci_sunxi.c (94%)
Sync sun8i-r40 dts(i) files from Linux 5.1-rc2
Linux commit details about the sun8i-r40* sync: "ARM: dts: sun8i: r40: bananapi-m2-ultra: Add Bluetooth device node" (sha1: 1e5f1db4ccd8348a21da55bff82f4263000879ef)
Linux commit details about the sun8i-v40* sync: "ARM: dts: sunxi: Fix I2C bus warnings" (sha1: 0729b4af5753b65aa031f58c435da53dbbf56d19)
Cc: Pablo Sebastián Greco pgreco@centosproject.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 91 ++++- arch/arm/dts/sun8i-r40.dtsi | 364 ++++++++++++++++++- arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts | 2 +- 3 files changed, 449 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts index 25fb048c7d..c488aaacbd 100644 --- a/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts +++ b/arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts @@ -59,6 +59,17 @@ stdout-path = "serial0:115200n8"; };
+ connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + leds { compatible = "gpio-leds";
@@ -91,9 +102,21 @@ wifi_pwrseq: wifi_pwrseq { compatible = "mmc-pwrseq-simple"; reset-gpios = <&pio 6 10 GPIO_ACTIVE_LOW>; /* PG10 WIFI_EN */ + clocks = <&ccu CLK_OUTA>; + clock-names = "ext_clock"; }; };
+&ahci { + ahci-supply = <®_dldo4>; + phy-supply = <®_eldo3>; + status = "okay"; +}; + +&de { + status = "okay"; +}; + &ehci1 { status = "okay"; }; @@ -118,6 +141,16 @@ }; };
+&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + &i2c0 { status = "okay";
@@ -134,8 +167,7 @@ &mmc0 { vmmc-supply = <®_dcdc1>; bus-width = <4>; - cd-gpios = <&pio 7 13 GPIO_ACTIVE_HIGH>; /* PH13 */ - cd-inverted; + cd-gpios = <&pio 7 13 GPIO_ACTIVE_LOW>; /* PH13 */ status = "okay"; };
@@ -166,6 +198,11 @@ status = "okay"; };
+&pio { + pinctrl-names = "default"; + pinctrl-0 = <&clk_out_a_pin>; +}; + ®_aldo2 { regulator-always-on; regulator-min-microvolt = <2500000>; @@ -220,18 +257,68 @@ regulator-name = "vcc-wifi-io"; };
+/* + * Our WiFi chip needs both DLDO2 and DLDO3 to be powered at the same + * time, with the two being in sync, to be able to meet maximum power + * consumption during transmits. Since this is not really supported + * right now, just use the two as always on, and we will fix it later. + */ + ®_dldo2 { + regulator-always-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc-wifi"; };
+®_dldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi-2"; +}; + +®_dldo4 { + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-name = "vdd2v5-sata"; +}; + +®_eldo3 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vdd1v2-sata"; +}; + +&tcon_tv0 { + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pb_pins>; status = "okay"; };
+&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pg_pins>, <&uart3_rts_cts_pg_pins>; + uart-has-rtscts; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + clocks = <&ccu CLK_OUTA>; + clock-names = "lpo"; + vbat-supply = <®_dldo2>; + vddio-supply = <®_dldo1>; + device-wakeup-gpios = <&pio 6 11 GPIO_ACTIVE_HIGH>; /* PG11 */ + /* TODO host wake line connected to PMIC GPIO pins */ + shutdown-gpios = <&pio 7 12 GPIO_ACTIVE_HIGH>; /* PH12 */ + max-speed = <1500000>; + }; +}; + &usbphy { usb1_vbus-supply = <®_vcc5v0>; usb2_vbus-supply = <®_vcc5v0>; diff --git a/arch/arm/dts/sun8i-r40.dtsi b/arch/arm/dts/sun8i-r40.dtsi index bd97ca3dc2..06b685869f 100644 --- a/arch/arm/dts/sun8i-r40.dtsi +++ b/arch/arm/dts/sun8i-r40.dtsi @@ -42,8 +42,10 @@ */
#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/clock/sun8i-de2.h> #include <dt-bindings/clock/sun8i-r40-ccu.h> #include <dt-bindings/reset/sun8i-r40-ccu.h> +#include <dt-bindings/reset/sun8i-de2.h>
/ { #address-cells = <1>; @@ -59,6 +61,7 @@ #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <24000000>; + clock-accuracy = <50000>; clock-output-names = "osc24M"; };
@@ -66,7 +69,8 @@ #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <32768>; - clock-output-names = "osc32k"; + clock-accuracy = <20000>; + clock-output-names = "ext-osc32k"; }; };
@@ -99,12 +103,75 @@ }; };
+ de: display-engine { + compatible = "allwinner,sun8i-r40-display-engine"; + allwinner,pipelines = <&mixer0>, <&mixer1>; + status = "disabled"; + }; + soc { compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>; ranges;
+ display_clocks: clock@1000000 { + compatible = "allwinner,sun8i-r40-de2-clk", + "allwinner,sun8i-h3-de2-clk"; + reg = <0x01000000 0x100000>; + clocks = <&ccu CLK_DE>, + <&ccu CLK_BUS_DE>; + clock-names = "mod", + "bus"; + resets = <&ccu RST_BUS_DE>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + mixer0: mixer@1100000 { + compatible = "allwinner,sun8i-r40-de2-mixer-0"; + reg = <0x01100000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER0>, + <&display_clocks CLK_MIXER0>; + clock-names = "bus", + "mod"; + resets = <&display_clocks RST_MIXER0>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer0_out: port@1 { + reg = <1>; + mixer0_out_tcon_top: endpoint { + remote-endpoint = <&tcon_top_mixer0_in_mixer0>; + }; + }; + }; + }; + + mixer1: mixer@1200000 { + compatible = "allwinner,sun8i-r40-de2-mixer-1"; + reg = <0x01200000 0x100000>; + clocks = <&display_clocks CLK_BUS_MIXER1>, + <&display_clocks CLK_MIXER1>; + clock-names = "bus", + "mod"; + resets = <&display_clocks RST_WB>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + mixer1_out: port@1 { + reg = <1>; + mixer1_out_tcon_top: endpoint { + remote-endpoint = <&tcon_top_mixer1_in_mixer1>; + }; + }; + }; + }; + nmi_intc: interrupt-controller@1c00030 { compatible = "allwinner,sun7i-a20-sc-nmi"; interrupt-controller; @@ -248,23 +315,38 @@ ccu: clock@1c20000 { compatible = "allwinner,sun8i-r40-ccu"; reg = <0x01c20000 0x400>; - clocks = <&osc24M>, <&osc32k>; + clocks = <&osc24M>, <&rtc 0>; clock-names = "hosc", "losc"; #clock-cells = <1>; #reset-cells = <1>; };
+ rtc: rtc@1c20400 { + compatible = "allwinner,sun8i-r40-rtc", + "allwinner,sun8i-h3-rtc"; + reg = <0x01c20400 0x400>; + interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; + clock-output-names = "osc32k", "osc32k-out"; + clocks = <&osc32k>; + #clock-cells = <1>; + }; + pio: pinctrl@1c20800 { compatible = "allwinner,sun8i-r40-pinctrl"; reg = <0x01c20800 0x400>; interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&osc32k>; + clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&rtc 0>; clock-names = "apb", "hosc", "losc"; gpio-controller; interrupt-controller; #interrupt-cells = <3>; #gpio-cells = <3>;
+ clk_out_a_pin: clk-out-a-pin { + pins = "PI12"; + function = "clk_out_a"; + }; + gmac_rgmii_pins: gmac-rgmii-pins { pins = "PA0", "PA1", "PA2", "PA3", "PA4", "PA5", "PA6", "PA7", @@ -312,6 +394,16 @@ pins = "PB22", "PB23"; function = "uart0"; }; + + uart3_pg_pins: uart3-pg-pins { + pins = "PG6", "PG7"; + function = "uart3"; + }; + + uart3_rts_cts_pg_pins: uart3-rts-cts-pg-pins { + pins = "PG8", "PG9"; + function = "uart3"; + }; };
wdt: watchdog@1c20c90 { @@ -464,6 +556,19 @@ #size-cells = <0>; };
+ ahci: sata@1c18000 { + compatible = "allwinner,sun8i-r40-ahci"; + reg = <0x01c18000 0x1000>; + interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SATA>, <&ccu CLK_SATA>; + resets = <&ccu RST_BUS_SATA>; + resets-name = "ahci"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + }; + gmac: ethernet@1c50000 { compatible = "allwinner,sun8i-r40-gmac"; syscon = <&ccu>; @@ -474,8 +579,6 @@ reset-names = "stmmaceth"; clocks = <&ccu CLK_BUS_GMAC>; clock-names = "stmmaceth"; - #address-cells = <1>; - #size-cells = <0>; status = "disabled";
gmac_mdio: mdio { @@ -485,6 +588,213 @@ }; };
+ tcon_top: tcon-top@1c70000 { + compatible = "allwinner,sun8i-r40-tcon-top"; + reg = <0x01c70000 0x1000>; + clocks = <&ccu CLK_BUS_TCON_TOP>, + <&ccu CLK_TCON_TV0>, + <&ccu CLK_TVE0>, + <&ccu CLK_TCON_TV1>, + <&ccu CLK_TVE1>, + <&ccu CLK_DSI_DPHY>; + clock-names = "bus", + "tcon-tv0", + "tve0", + "tcon-tv1", + "tve1", + "dsi"; + clock-output-names = "tcon-top-tv0", + "tcon-top-tv1", + "tcon-top-dsi"; + resets = <&ccu RST_BUS_TCON_TOP>; + #clock-cells = <1>; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon_top_mixer0_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + tcon_top_mixer0_in_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&mixer0_out_tcon_top>; + }; + }; + + tcon_top_mixer0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + tcon_top_mixer0_out_tcon_lcd0: endpoint@0 { + reg = <0>; + }; + + tcon_top_mixer0_out_tcon_lcd1: endpoint@1 { + reg = <1>; + }; + + tcon_top_mixer0_out_tcon_tv0: endpoint@2 { + reg = <2>; + remote-endpoint = <&tcon_tv0_in_tcon_top_mixer0>; + }; + + tcon_top_mixer0_out_tcon_tv1: endpoint@3 { + reg = <3>; + remote-endpoint = <&tcon_tv1_in_tcon_top_mixer0>; + }; + }; + + tcon_top_mixer1_in: port@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + + tcon_top_mixer1_in_mixer1: endpoint@1 { + reg = <1>; + remote-endpoint = <&mixer1_out_tcon_top>; + }; + }; + + tcon_top_mixer1_out: port@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + + tcon_top_mixer1_out_tcon_lcd0: endpoint@0 { + reg = <0>; + }; + + tcon_top_mixer1_out_tcon_lcd1: endpoint@1 { + reg = <1>; + }; + + tcon_top_mixer1_out_tcon_tv0: endpoint@2 { + reg = <2>; + remote-endpoint = <&tcon_tv0_in_tcon_top_mixer1>; + }; + + tcon_top_mixer1_out_tcon_tv1: endpoint@3 { + reg = <3>; + remote-endpoint = <&tcon_tv1_in_tcon_top_mixer1>; + }; + }; + + tcon_top_hdmi_in: port@4 { + #address-cells = <1>; + #size-cells = <0>; + reg = <4>; + + tcon_top_hdmi_in_tcon_tv0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon_tv0_out_tcon_top>; + }; + + tcon_top_hdmi_in_tcon_tv1: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_tv1_out_tcon_top>; + }; + }; + + tcon_top_hdmi_out: port@5 { + reg = <5>; + + tcon_top_hdmi_out_hdmi: endpoint { + remote-endpoint = <&hdmi_in_tcon_top>; + }; + }; + }; + }; + + tcon_tv0: lcd-controller@1c73000 { + compatible = "allwinner,sun8i-r40-tcon-tv"; + reg = <0x01c73000 0x1000>; + interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON_TV0>, <&tcon_top 0>; + clock-names = "ahb", "tcon-ch1"; + resets = <&ccu RST_BUS_TCON_TV0>; + reset-names = "lcd"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon_tv0_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + tcon_tv0_in_tcon_top_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon_top_mixer0_out_tcon_tv0>; + }; + + tcon_tv0_in_tcon_top_mixer1: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_top_mixer1_out_tcon_tv0>; + }; + }; + + tcon_tv0_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + tcon_tv0_out_tcon_top: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_top_hdmi_in_tcon_tv0>; + }; + }; + }; + }; + + tcon_tv1: lcd-controller@1c74000 { + compatible = "allwinner,sun8i-r40-tcon-tv"; + reg = <0x01c74000 0x1000>; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_TCON_TV1>, <&tcon_top 1>; + clock-names = "ahb", "tcon-ch1"; + resets = <&ccu RST_BUS_TCON_TV1>; + reset-names = "lcd"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + tcon_tv1_in: port@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + + tcon_tv1_in_tcon_top_mixer0: endpoint@0 { + reg = <0>; + remote-endpoint = <&tcon_top_mixer0_out_tcon_tv1>; + }; + + tcon_tv1_in_tcon_top_mixer1: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_top_mixer1_out_tcon_tv1>; + }; + }; + + tcon_tv1_out: port@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + tcon_tv1_out_tcon_top: endpoint@1 { + reg = <1>; + remote-endpoint = <&tcon_top_hdmi_in_tcon_tv1>; + }; + }; + }; + }; + gic: interrupt-controller@1c81000 { compatible = "arm,gic-400"; reg = <0x01c81000 0x1000>, @@ -495,6 +805,50 @@ #interrupt-cells = <3>; interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; }; + + hdmi: hdmi@1ee0000 { + compatible = "allwinner,sun8i-r40-dw-hdmi", + "allwinner,sun8i-a83t-dw-hdmi"; + reg = <0x01ee0000 0x10000>; + reg-io-width = <1>; + interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_HDMI0>, <&ccu CLK_HDMI_SLOW>, + <&ccu CLK_HDMI>; + clock-names = "iahb", "isfr", "tmds"; + resets = <&ccu RST_BUS_HDMI1>; + reset-names = "ctrl"; + phys = <&hdmi_phy>; + phy-names = "hdmi-phy"; + status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + hdmi_in: port@0 { + reg = <0>; + + hdmi_in_tcon_top: endpoint { + remote-endpoint = <&tcon_top_hdmi_out_hdmi>; + }; + }; + + hdmi_out: port@1 { + reg = <1>; + }; + }; + }; + + hdmi_phy: hdmi-phy@1ef0000 { + compatible = "allwinner,sun8i-r40-hdmi-phy"; + reg = <0x01ef0000 0x10000>; + clocks = <&ccu CLK_BUS_HDMI1>, <&ccu CLK_HDMI_SLOW>, + <&ccu 7>, <&ccu 16>; + clock-names = "bus", "mod", "pll-0", "pll-1"; + resets = <&ccu RST_BUS_HDMI0>; + reset-names = "phy"; + #phy-cells = <0>; + }; };
timer { diff --git a/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts b/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts index 35859d8f32..bf97f6244c 100644 --- a/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts +++ b/arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts @@ -95,7 +95,7 @@ &i2c0 { status = "okay";
- axp22x: pmic@68 { + axp22x: pmic@34 { compatible = "x-powers,axp221"; reg = <0x34>; interrupt-parent = <&nmi_intc>;
Sync sun7i-a20 dts(i) files from Linux 5.1-rc2
Linux commit details about the sun7i-a20* sync: "ARM: dts: sun7i: bananapi: Add GPIO banks regulators" (sha1: 09c6572290f018d73ec2e812e28bada34d41815f)
Here are U-Boot specific dts changes.
- s/uart0_pins_a/uart0_pb_pins for sun7i-a20-ainol-aw1.dts sun7i-a20-m5.dts sun7i-a20-primo73.dts sun7i-a20-yones-toptech-bd1078.dts sunxi-itead-core-common.dtsi - s/gmac_pins_mii_a/gmac_rgmii_pins for sun7i-a20-m5.dts - drop i2c0, i2c1 pins from sunxi-itead-core-common.dtsi - drop mmc0 pins from sun7i-a20-primo73.dts
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun7i-a20-ainol-aw1.dts | 2 +- arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts | 46 +--- arch/arm/dts/sun7i-a20-bananapi.dts | 49 ++-- arch/arm/dts/sun7i-a20-bananapro.dts | 65 +----- arch/arm/dts/sun7i-a20-cubieboard2.dts | 21 +- arch/arm/dts/sun7i-a20-cubietruck.dts | 83 +++---- arch/arm/dts/sun7i-a20-hummingbird.dts | 60 +---- arch/arm/dts/sun7i-a20-i12-tvbox.dts | 47 +--- arch/arm/dts/sun7i-a20-icnova-swac.dts | 10 +- arch/arm/dts/sun7i-a20-itead-ibox.dts | 10 +- arch/arm/dts/sun7i-a20-lamobo-r1.dts | 48 +--- arch/arm/dts/sun7i-a20-m3.dts | 21 +- arch/arm/dts/sun7i-a20-m5.dts | 4 +- arch/arm/dts/sun7i-a20-mk808c.dts | 26 +-- .../arm/dts/sun7i-a20-olimex-som-evb-emmc.dts | 35 +++ arch/arm/dts/sun7i-a20-olimex-som-evb.dts | 68 ++---- .../dts/sun7i-a20-olimex-som204-evb-emmc.dts | 2 - arch/arm/dts/sun7i-a20-olimex-som204-evb.dts | 36 ++- arch/arm/dts/sun7i-a20-olinuxino-lime.dts | 22 +- .../dts/sun7i-a20-olinuxino-lime2-emmc.dts | 11 - arch/arm/dts/sun7i-a20-olinuxino-lime2.dts | 34 +-- .../dts/sun7i-a20-olinuxino-micro-emmc.dts | 2 - arch/arm/dts/sun7i-a20-olinuxino-micro.dts | 54 ++--- arch/arm/dts/sun7i-a20-orangepi-mini.dts | 52 +---- arch/arm/dts/sun7i-a20-orangepi.dts | 44 +--- arch/arm/dts/sun7i-a20-pcduino3-nano.dts | 31 +-- arch/arm/dts/sun7i-a20-pcduino3.dts | 39 +--- arch/arm/dts/sun7i-a20-primo73.dts | 4 +- arch/arm/dts/sun7i-a20-wexler-tab7200.dts | 39 +--- arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts | 23 +- .../dts/sun7i-a20-yones-toptech-bd1078.dts | 2 +- arch/arm/dts/sun7i-a20.dtsi | 209 ++++++++++++------ arch/arm/dts/sunxi-itead-core-common.dtsi | 6 +- 33 files changed, 369 insertions(+), 836 deletions(-) create mode 100644 arch/arm/dts/sun7i-a20-olimex-som-evb-emmc.dts
diff --git a/arch/arm/dts/sun7i-a20-ainol-aw1.dts b/arch/arm/dts/sun7i-a20-ainol-aw1.dts index 57fe0066cb..5914c919d4 100644 --- a/arch/arm/dts/sun7i-a20-ainol-aw1.dts +++ b/arch/arm/dts/sun7i-a20-ainol-aw1.dts @@ -23,6 +23,6 @@
&uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; }; diff --git a/arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts b/arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts index 763cb03033..e2bfe00588 100644 --- a/arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts +++ b/arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts @@ -73,8 +73,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_bpi_m1p>;
green { label = "bananapi-m1-plus:green:usr"; @@ -90,15 +88,11 @@
mmc3_pwrseq: mmc3_pwrseq { compatible = "mmc-pwrseq-simple"; - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pwrseq_pin_bpi_m1p>; reset-gpios = <&pio 7 22 GPIO_ACTIVE_LOW>; /* PH22 WL-PMU-EN */ };
reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac_power_pin_bpi_m1p>; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -134,7 +128,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; phy-supply = <®_gmac_3v3>; @@ -156,8 +150,6 @@ };
&i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_pins_a>; status = "okay";
axp209: pmic@34 { @@ -175,13 +167,11 @@
&ir0 { pinctrl-names = "default"; - pinctrl-0 = <&ir0_rx_pins_a>; + pinctrl-0 = <&ir0_rx_pin>; status = "okay"; };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_bpi_m1p>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 10 GPIO_ACTIVE_LOW>; /* PH10 */ @@ -191,8 +181,6 @@ &mmc3 { #address-cells = <1>; #size-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pins_a>; vmmc-supply = <®_vcc3v3>; mmc-pwrseq = <&mmc3_pwrseq>; bus-width = <4>; @@ -209,11 +197,6 @@ }; };
-&mmc3_pins_a { - /* AP6210 requires pull-up */ - bias-pull-up; -}; - &ohci0 { status = "okay"; }; @@ -226,29 +209,6 @@ status = "okay"; };
-&pio { - gmac_power_pin_bpi_m1p: gmac_power_pin@0 { - pins = "PH23"; - function = "gpio_out"; - }; - - led_pins_bpi_m1p: led_pins@0 { - pins = "PH24", "PH25"; - function = "gpio_out"; - }; - - mmc0_cd_pin_bpi_m1p: mmc0_cd_pin@0 { - pins = "PH10"; - function = "gpio_in"; - bias-pull-up; - }; - - mmc3_pwrseq_pin_bpi_m1p: mmc3_pwrseq_pin@0 { - pins = "PH22"; - function = "gpio_out"; - }; -}; - ®_dcdc2 { regulator-always-on; regulator-min-microvolt = <1000000>; @@ -280,7 +240,7 @@
diff --git a/arch/arm/dts/sun7i-a20-bananapi.dts b/arch/arm/dts/sun7i-a20-bananapi.dts index 70dfc4ac0b..81bc85d398 100644 --- a/arch/arm/dts/sun7i-a20-bananapi.dts +++ b/arch/arm/dts/sun7i-a20-bananapi.dts @@ -76,8 +76,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_bananapi>;
green { label = "bananapi:green:usr"; @@ -87,8 +85,6 @@
reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac_power_pin_bananapi>; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -134,7 +130,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; phy-supply = <®_gmac_3v3>; @@ -156,8 +152,6 @@ };
axp209: pmic@34 { @@ -168,20 +162,16 @@ };
&i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_a>; status = "okay"; };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_bananapi>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 10 GPIO_ACTIVE_LOW>; /* PH10 */ @@ -201,6 +191,11 @@ };
&pio { + vcc-pa-supply = <®_vcc3v3>; + vcc-pc-supply = <®_vcc3v3>; + vcc-pe-supply = <®_vcc3v3>; + vcc-pf-supply = <®_vcc3v3>; + vcc-pg-supply = <®_vcc3v3>; gpio-line-names = /* PA */ "ERXD3", "ERXD2", "ERXD1", "ERXD0", "ETXD3", @@ -252,27 +247,11 @@ "IO-6", "IO-3", "IO-2", "IO-0", "", "", "", "", "", "", "", "", "", "", "", "";
- usb0_id_detect_pin: usb0_id_detect_pin@0 { + usb0_id_detect_pin: usb0-id-detect-pin { pins = "PH4"; function = "gpio_in"; bias-pull-up; }; - - mmc0_cd_pin_bananapi: mmc0_cd_pin@0 { - pins = "PH10"; - function = "gpio_in"; - bias-pull-up; - }; - - gmac_power_pin_bananapi: gmac_power_pin@0 { - pins = "PH23"; - function = "gpio_out"; - }; - - led_pins_bananapi: led_pins@0 { - pins = "PH24"; - function = "gpio_out"; - }; };
#include "axp209.dtsi" @@ -316,27 +295,27 @@
&spi0 { pinctrl-names = "default"; - pinctrl-0 = <&spi0_pins_a>, - <&spi0_cs0_pins_a>, - <&spi0_cs1_pins_a>; + pinctrl-0 = <&spi0_pi_pins>, + <&spi0_cs0_pi_pin>, + <&spi0_cs1_pi_pin>; status = "okay"; };
&uart3 { pinctrl-names = "default"; - pinctrl-0 = <&uart3_pins_b>; + pinctrl-0 = <&uart3_ph_pins>; status = "okay"; };
&uart7 { pinctrl-names = "default"; - pinctrl-0 = <&uart7_pins_a>; + pinctrl-0 = <&uart7_pi_pins>; status = "okay"; };
diff --git a/arch/arm/dts/sun7i-a20-bananapro.dts b/arch/arm/dts/sun7i-a20-bananapro.dts index 0898eb6162..0176e9de01 100644 --- a/arch/arm/dts/sun7i-a20-bananapro.dts +++ b/arch/arm/dts/sun7i-a20-bananapro.dts @@ -62,8 +62,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_bananapro>;
blue { label = "bananapro:blue:usr"; @@ -78,15 +76,11 @@
wifi_pwrseq: wifi-pwrseq { compatible = "mmc-pwrseq-simple"; - pinctrl-names = "default"; - pinctrl-0 = <&vmmc3_pin_bananapro>; reset-gpios = <&pio 7 22 GPIO_ACTIVE_LOW>; };
reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac_power_pin_bananapro>; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -114,7 +108,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; phy-supply = <®_gmac_3v3>; @@ -126,8 +120,6 @@ };
axp209: pmic@34 { @@ -142,20 +134,16 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_bananapro>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 10 GPIO_ACTIVE_LOW>; /* PH10 */ @@ -163,8 +151,6 @@ };
&mmc3 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pins_a>; vmmc-supply = <®_vcc3v3>; mmc-pwrseq = <&wifi_pwrseq>; bus-width = <4>; @@ -188,74 +174,39 @@ status = "okay"; };
-&pio { - gmac_power_pin_bananapro: gmac_power_pin@0 { - pins = "PH23"; - function = "gpio_out"; - }; - - led_pins_bananapro: led_pins@0 { - pins = "PH24", "PG2"; - function = "gpio_out"; - }; - - mmc0_cd_pin_bananapro: mmc0_cd_pin@0 { - pins = "PH10"; - function = "gpio_in"; - bias-pull-up; - }; - - usb1_vbus_pin_bananapro: usb1_vbus_pin@0 { - pins = "PH0"; - function = "gpio_out"; - }; - - usb2_vbus_pin_bananapro: usb2_vbus_pin@0 { - pins = "PH1"; - function = "gpio_out"; - }; - - vmmc3_pin_bananapro: vmmc3_pin@0 { - pins = "PH22"; - function = "gpio_out"; - }; -}; - ®_usb1_vbus { - pinctrl-0 = <&usb1_vbus_pin_bananapro>; gpio = <&pio 7 0 GPIO_ACTIVE_HIGH>; /* PH0 */ status = "okay"; };
®_usb2_vbus { - pinctrl-0 = <&usb2_vbus_pin_bananapro>; gpio = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */ status = "okay"; };
&uart4 { pinctrl-names = "default"; - pinctrl-0 = <&uart4_pins_b>; + pinctrl-0 = <&uart4_ph_pins>; status = "okay"; };
diff --git a/arch/arm/dts/sun7i-a20-cubieboard2.dts b/arch/arm/dts/sun7i-a20-cubieboard2.dts index 942ac9dfd4..200685b0b1 100644 --- a/arch/arm/dts/sun7i-a20-cubieboard2.dts +++ b/arch/arm/dts/sun7i-a20-cubieboard2.dts @@ -74,8 +74,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_cubieboard2>;
blue { label = "cubieboard2:blue:usr"; @@ -116,7 +114,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_mii_a>; + pinctrl-0 = <&gmac_mii_pins>; phy = <&phy1>; phy-mode = "mii"; status = "okay"; @@ -137,8 +135,6 @@ };
axp209: pmic@34 { @@ -149,20 +145,16 @@ };
&i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins_a>; status = "okay"; };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -182,12 +174,7 @@ };
&pio { - led_pins_cubieboard2: led_pins@0 { - pins = "PH20", "PH21"; - function = "gpio_out"; - }; - - usb0_id_detect_pin: usb0_id_detect_pin@0 { + usb0_id_detect_pin: usb0-id-detect-pin { pins = "PH4"; function = "gpio_in"; bias-pull-up; @@ -239,7 +226,7 @@
diff --git a/arch/arm/dts/sun7i-a20-cubietruck.dts b/arch/arm/dts/sun7i-a20-cubietruck.dts index 5649161de1..99f531b8d2 100644 --- a/arch/arm/dts/sun7i-a20-cubietruck.dts +++ b/arch/arm/dts/sun7i-a20-cubietruck.dts @@ -74,8 +74,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_cubietruck>;
blue { label = "cubietruck:blue:usr"; @@ -100,9 +98,9 @@
mmc3_pwrseq: mmc3_pwrseq { compatible = "mmc-pwrseq-simple"; - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pwrseq_pin_cubietruck>; reset-gpios = <&pio 7 9 GPIO_ACTIVE_LOW>; /* PH9 WIFI_EN */ + clocks = <&ccu CLK_OUT_A>; + clock-names = "ext_clock"; };
sound { @@ -151,7 +149,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; status = "okay"; @@ -172,8 +170,6 @@ };
axp209: pmic@34 { @@ -185,25 +181,20 @@
&i2c1 { pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins_a>; status = "okay"; };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -211,8 +202,6 @@ };
&mmc3 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pins_a>; vmmc-supply = <®_vcc3v3>; mmc-pwrseq = <&mmc3_pwrseq>; bus-width = <4>; @@ -228,11 +217,6 @@ }; };
-&mmc3_pins_a { - /* AP6210 requires pull-up */ - bias-pull-up; -}; - &ohci0 { status = "okay"; }; @@ -246,45 +230,18 @@ };
&pio { - ahci_pwr_pin_cubietruck: ahci_pwr_pin@1 { - pins = "PH12"; - function = "gpio_out"; - }; - - led_pins_cubietruck: led_pins@0 { - pins = "PH7", "PH11", "PH20", "PH21"; - function = "gpio_out"; - }; - - mmc3_pwrseq_pin_cubietruck: mmc3_pwrseq_pin@0 { - pins = "PH9"; - function = "gpio_out"; - }; - - usb0_vbus_pin_a: usb0_vbus_pin@0 { - pins = "PH17"; - function = "gpio_out"; - }; - - usb0_id_detect_pin: usb0_id_detect_pin@0 { - pins = "PH19"; - function = "gpio_in"; - }; - - usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { - pins = "PH22"; - function = "gpio_in"; - }; + /* Pin outputs low power clock for WiFi and BT */ + pinctrl-0 = <&clk_out_a_pin>; + pinctrl-names = "default"; };
&pwm { pinctrl-names = "default"; - pinctrl-0 = <&pwm0_pins_a>, <&pwm1_pins_a>; + pinctrl-0 = <&pwm0_pin>, <&pwm1_pin>; status = "okay"; };
®_ahci_5v { - pinctrl-0 = <&ahci_pwr_pin_cubietruck>; gpio = <&pio 7 12 GPIO_ACTIVE_HIGH>; status = "okay"; }; @@ -325,7 +282,6 @@ };
®_usb0_vbus { - pinctrl-0 = <&usb0_vbus_pin_a>; gpio = <&pio 7 17 GPIO_ACTIVE_HIGH>; status = "okay"; }; @@ -340,14 +296,31 @@
&spdif { pinctrl-names = "default"; - pinctrl-0 = <&spdif_tx_pins_a>; + pinctrl-0 = <&spdif_tx_pin>; status = "okay"; };
&uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pi_pins>, <&uart2_cts_rts_pi_pins>; + uart-has-rtscts; status = "okay"; + + bluetooth { + compatible = "brcm,bcm20702a1"; + clocks = <&ccu CLK_OUT_A>; + clock-names = "lpo"; + device-wakeup-gpios = <&pio 7 24 GPIO_ACTIVE_LOW>; /* PH24 */ + host-wakeup-gpios = <&pio 7 25 GPIO_ACTIVE_LOW>; /* PH25 */ + shutdown-gpios = <&pio 7 18 GPIO_ACTIVE_HIGH>; /* PH18 */ + max-speed = <1500000>; + }; };
&usb_otg { @@ -360,8 +333,6 @@ };
&usbphy { - pinctrl-names = "default"; - pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; usb0_id_det-gpios = <&pio 7 19 GPIO_ACTIVE_HIGH>; /* PH19 */ usb0_vbus_det-gpios = <&pio 7 22 GPIO_ACTIVE_HIGH>; /* PH22 */ usb0_vbus_power-supply = <&usb_power_supply>; diff --git a/arch/arm/dts/sun7i-a20-hummingbird.dts b/arch/arm/dts/sun7i-a20-hummingbird.dts index 1f0e5ecbf0..fd0153f656 100644 --- a/arch/arm/dts/sun7i-a20-hummingbird.dts +++ b/arch/arm/dts/sun7i-a20-hummingbird.dts @@ -67,8 +67,6 @@
reg_mmc3_vdd: mmc3_vdd { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_vdd_pin_a20_hummingbird>; regulator-name = "mmc3_vdd"; regulator-min-microvolt = <3000000>; regulator-max-microvolt = <3000000>; @@ -78,8 +76,6 @@
reg_gmac_vdd: gmac_vdd { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac_vdd_pin_a20_hummingbird>; regulator-name = "gmac_vdd"; regulator-min-microvolt = <3000000>; regulator-max-microvolt = <3000000>; @@ -103,7 +99,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; phy-supply = <®_gmac_vdd>; @@ -120,8 +116,6 @@ };
axp209: pmic@34 { @@ -135,32 +129,24 @@ };
&i2c3 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c3_pins_a>; status = "okay"; };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v0>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -168,8 +154,6 @@ };
&mmc3 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pins_a>; vmmc-supply = <®_mmc3_vdd>; bus-width = <4>; non-removable; @@ -184,42 +168,18 @@ status = "okay"; };
-&pio { - ahci_pwr_pin_a20_hummingbird: ahci_pwr_pin@0 { - pins = "PH15"; - function = "gpio_out"; - }; - - usb1_vbus_pin_a20_hummingbird: usb1_vbus_pin@0 { - pins = "PH2"; - function = "gpio_out"; - }; - - mmc3_vdd_pin_a20_hummingbird: mmc3_vdd_pin@0 { - pins = "PH9"; - function = "gpio_out"; - }; - - gmac_vdd_pin_a20_hummingbird: gmac_vdd_pin@0 { - pins = "PH16"; - function = "gpio_out"; - }; -}; - &pwm { pinctrl-names = "default"; - pinctrl-0 = <&pwm0_pins_a>; + pinctrl-0 = <&pwm0_pin>; status = "okay"; };
®_ahci_5v { - pinctrl-0 = <&ahci_pwr_pin_a20_hummingbird>; gpio = <&pio 7 15 GPIO_ACTIVE_HIGH>; /* PH15 */ status = "okay"; };
®_usb1_vbus { - pinctrl-0 = <&usb1_vbus_pin_a20_hummingbird>; gpio = <&pio 7 2 GPIO_ACTIVE_HIGH>; /* PH2 */ status = "okay"; }; @@ -230,38 +190,38 @@
&spi2 { pinctrl-names = "default"; - pinctrl-0 = <&spi2_pins_b>, - <&spi2_cs0_pins_b>; + pinctrl-0 = <&spi2_pb_pins>, + <&spi2_cs0_pb_pin>; status = "okay"; };
&uart2 { pinctrl-names = "default"; - pinctrl-0 = <&uart2_pins_a>; + pinctrl-0 = <&uart2_pi_pins>, <&uart2_cts_rts_pi_pins>; status = "okay"; };
&uart3 { pinctrl-names = "default"; - pinctrl-0 = <&uart3_pins_a>; + pinctrl-0 = <&uart3_pg_pins>, <&uart3_cts_rts_pg_pins>; status = "okay"; };
&uart4 { pinctrl-names = "default"; - pinctrl-0 = <&uart4_pins_a>; + pinctrl-0 = <&uart4_pg_pins>; status = "okay"; };
&uart5 { pinctrl-names = "default"; - pinctrl-0 = <&uart5_pins_a>; + pinctrl-0 = <&uart5_pi_pins>; status = "okay"; };
diff --git a/arch/arm/dts/sun7i-a20-i12-tvbox.dts b/arch/arm/dts/sun7i-a20-i12-tvbox.dts index 2e3f2f29d1..5f1c4f573d 100644 --- a/arch/arm/dts/sun7i-a20-i12-tvbox.dts +++ b/arch/arm/dts/sun7i-a20-i12-tvbox.dts @@ -61,8 +61,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_i12_tvbox>;
red { label = "i12_tvbox:red:usr"; @@ -77,8 +75,6 @@
reg_vmmc3: vmmc3 { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&vmmc3_pin_i12_tvbox>; regulator-name = "vmmc3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -88,8 +84,6 @@
reg_vmmc3_io: vmmc3-io { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&vmmc3_io_pin_i12_tvbox>; regulator-name = "vmmc3-io"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -101,8 +95,6 @@
reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac_power_pin_i12_tvbox>; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -122,7 +114,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_mii_a>; + pinctrl-0 = <&gmac_mii_pins>; phy = <&phy1>; phy-mode = "mii"; phy-supply = <®_gmac_3v3>; @@ -134,8 +126,6 @@ };
axp209: pmic@34 { @@ -151,13 +141,11 @@
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -165,8 +153,6 @@ };
&mmc3 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pins_a>; vmmc-supply = <®_vmmc3>; bus-width = <4>; non-removable; @@ -181,11 +167,6 @@ }; };
-&mmc3_pins_a { - /* AP6210 / AP6330 requires pull-up */ - bias-pull-up; -}; - &ohci0 { status = "okay"; }; @@ -194,28 +175,6 @@ status = "okay"; };
-&pio { - vmmc3_pin_i12_tvbox: vmmc3_pin@0 { - pins = "PH2"; - function = "gpio_out"; - }; - - vmmc3_io_pin_i12_tvbox: vmmc3_io_pin@0 { - pins = "PH12"; - function = "gpio_out"; - }; - - gmac_power_pin_i12_tvbox: gmac_power_pin@0 { - pins = "PH21"; - function = "gpio_out"; - }; - - led_pins_i12_tvbox: led_pins@0 { - pins = "PH9", "PH20"; - function = "gpio_out"; - }; -}; - ®_usb1_vbus { status = "okay"; }; @@ -226,7 +185,7 @@
diff --git a/arch/arm/dts/sun7i-a20-icnova-swac.dts b/arch/arm/dts/sun7i-a20-icnova-swac.dts index 926fa194eb..949494730a 100644 --- a/arch/arm/dts/sun7i-a20-icnova-swac.dts +++ b/arch/arm/dts/sun7i-a20-icnova-swac.dts @@ -74,7 +74,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_mii_a>; + pinctrl-0 = <&gmac_mii_pins>; phy = <&phy1>; phy-mode = "mii"; status = "okay"; @@ -85,8 +85,6 @@ };
axp209: pmic@34 { @@ -97,14 +95,10 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 8 5 GPIO_ACTIVE_LOW>; /* PI5 */ @@ -156,7 +150,7 @@
diff --git a/arch/arm/dts/sun7i-a20-itead-ibox.dts b/arch/arm/dts/sun7i-a20-itead-ibox.dts index 1b05ba466e..b90a7607d0 100644 --- a/arch/arm/dts/sun7i-a20-itead-ibox.dts +++ b/arch/arm/dts/sun7i-a20-itead-ibox.dts @@ -96,7 +96,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_mii_a>; + pinctrl-0 = <&gmac_mii_pins>; phy = <&phy1>; phy-mode = "mii"; status = "okay"; @@ -115,13 +115,11 @@
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -129,7 +127,7 @@ };
&pio { - led_pins_itead_core: led_pins@0 { + led_pins_itead_core: led-pins { pins = "PH20","PH21"; function = "gpio_out"; drive-strength = <20>; @@ -142,6 +140,6 @@
&spdif { pinctrl-names = "default"; - pinctrl-0 = <&spdif_tx_pins_a>; + pinctrl-0 = <&spdif_tx_pin>; status = "okay"; }; diff --git a/arch/arm/dts/sun7i-a20-lamobo-r1.dts b/arch/arm/dts/sun7i-a20-lamobo-r1.dts index b1ab7c1c33..f91e1bee44 100644 --- a/arch/arm/dts/sun7i-a20-lamobo-r1.dts +++ b/arch/arm/dts/sun7i-a20-lamobo-r1.dts @@ -74,8 +74,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_lamobo_r1>;
green { label = "lamobo_r1:green:usr"; @@ -85,8 +83,6 @@
reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac_power_pin_lamobo_r1>; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -123,10 +119,12 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy-mode = "rgmii"; phy-supply = <®_gmac_3v3>; status = "okay"; + /delete-property/#address-cells; + /delete-property/#size-cells;
fixed-link { speed = <1000>; @@ -141,8 +139,6 @@ switch: ethernet-switch@1e { compatible = "brcm,bcm53125"; reg = <30>; - #address-cells = <1>; - #size-cells = <0>;
ports { #address-cells = <1>; @@ -199,8 +195,6 @@ };
axp209: pmic@34 { @@ -211,20 +205,16 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_lamobo_r1>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 10 GPIO_ACTIVE_LOW>; /* PH10 */ @@ -240,27 +230,11 @@ };
&pio { - usb0_id_detect_pin: usb0_id_detect_pin@0 { + usb0_id_detect_pin: usb0-id-detect-pin { pins = "PH4"; function = "gpio_in"; bias-pull-up; }; - - mmc0_cd_pin_lamobo_r1: mmc0_cd_pin@0 { - pins = "PH10"; - function = "gpio_in"; - bias-pull-up; - }; - - gmac_power_pin_lamobo_r1: gmac_power_pin@0 { - pins = "PH23"; - function = "gpio_out"; - }; - - led_pins_lamobo_r1: led_pins@0 { - pins = "PH24"; - function = "gpio_out"; - }; };
#include "axp209.dtsi" @@ -314,27 +288,27 @@
diff --git a/arch/arm/dts/sun7i-a20-m3.dts b/arch/arm/dts/sun7i-a20-m3.dts index e91a209850..b8a1aaaf39 100644 --- a/arch/arm/dts/sun7i-a20-m3.dts +++ b/arch/arm/dts/sun7i-a20-m3.dts @@ -63,8 +63,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_m3>;
blue { label = "m3:blue:usr"; @@ -83,7 +81,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_mii_a>; + pinctrl-0 = <&gmac_mii_pins>; phy = <&phy1>; phy-mode = "mii"; status = "okay"; @@ -94,8 +92,6 @@ };
axp209: pmic@34 { @@ -111,13 +107,11 @@
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -125,8 +119,6 @@ };
&mmc2 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc2_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; non-removable; @@ -141,13 +133,6 @@ status = "okay"; };
-&pio { - led_pins_m3: led_pins@0 { - pins = "PH20"; - function = "gpio_out"; - }; -}; - ®_usb1_vbus { status = "okay"; }; @@ -158,7 +143,7 @@
diff --git a/arch/arm/dts/sun7i-a20-m5.dts b/arch/arm/dts/sun7i-a20-m5.dts index 00c3ffd323..65930cc6ee 100644 --- a/arch/arm/dts/sun7i-a20-m5.dts +++ b/arch/arm/dts/sun7i-a20-m5.dts @@ -31,7 +31,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_mii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "mii"; status = "okay"; @@ -51,6 +51,6 @@
&uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; }; diff --git a/arch/arm/dts/sun7i-a20-mk808c.dts b/arch/arm/dts/sun7i-a20-mk808c.dts index 6109f794a9..1491c603f6 100644 --- a/arch/arm/dts/sun7i-a20-mk808c.dts +++ b/arch/arm/dts/sun7i-a20-mk808c.dts @@ -106,8 +106,6 @@ };
axp209: pmic@34 { @@ -121,20 +119,14 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v0>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -153,18 +145,6 @@ status = "okay"; };
-&pio { - usb0_id_detect_pin: usb0_id_detect_pin@0 { - pins = "PH4"; - function = "gpio_in"; - }; - - usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { - pins = "PH5"; - function = "gpio_in"; - }; -}; - ®_usb0_vbus { status = "okay"; }; @@ -179,13 +159,13 @@
@@ -195,8 +175,6 @@ };
&usbphy { - pinctrl-names = "default"; - pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; usb0_id_det-gpios = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ usb0_vbus_det-gpios = <&pio 7 5 GPIO_ACTIVE_HIGH>; /* PH5 */ usb0_vbus-supply = <®_usb0_vbus>; diff --git a/arch/arm/dts/sun7i-a20-olimex-som-evb-emmc.dts b/arch/arm/dts/sun7i-a20-olimex-som-evb-emmc.dts new file mode 100644 index 0000000000..20bf09b222 --- /dev/null +++ b/arch/arm/dts/sun7i-a20-olimex-som-evb-emmc.dts @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree Source for A20-Olimex-SOM-EVB-eMMC Board + * + * Copyright (C) 2018 Olimex Ltd. + * Author: Stefan Mavrodiev stefan@olimex.com + */ + +/dts-v1/; +#include "sun7i-a20-olimex-som-evb.dts" + +/ { + + model = "Olimex A20-Olimex-SOM-EVB-eMMC"; + compatible = "olimex,a20-olimex-som-evb-emmc", "allwinner,sun7i-a20"; + + mmc2_pwrseq: mmc2_pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&pio 2 18 GPIO_ACTIVE_LOW>; + }; +}; + +&mmc2 { + vmmc-supply = <®_vcc3v3>; + mmc-pwrseq = <&mmc2_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + emmc: emmc@0 { + reg = <0>; + compatible = "mmc-card"; + broken-hpi; + }; +}; diff --git a/arch/arm/dts/sun7i-a20-olimex-som-evb.dts b/arch/arm/dts/sun7i-a20-olimex-som-evb.dts index f080f82b58..f0e6a96e57 100644 --- a/arch/arm/dts/sun7i-a20-olimex-som-evb.dts +++ b/arch/arm/dts/sun7i-a20-olimex-som-evb.dts @@ -74,8 +74,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_olimex_som_evb>;
green { label = "a20-olimex-som-evb:green:usr"; @@ -112,7 +110,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; status = "okay"; @@ -133,8 +131,6 @@ };
axp209: pmic@34 { @@ -145,14 +141,10 @@ };
@@ -160,49 +152,49 @@ vref-supply = <®_vcc3v0>; status = "okay";
- button@190 { + button-190 { label = "Volume Up"; linux,code = <KEY_VOLUMEUP>; channel = <0>; voltage = <190000>; };
- button@390 { + button-390 { label = "Volume Down"; linux,code = <KEY_VOLUMEDOWN>; channel = <0>; voltage = <390000>; };
- button@600 { + button-600 { label = "Menu"; linux,code = <KEY_MENU>; channel = <0>; voltage = <600000>; };
- button@800 { + button-800 { label = "Search"; linux,code = <KEY_SEARCH>; channel = <0>; voltage = <800000>; };
- button@980 { + button-980 { label = "Home"; linux,code = <KEY_HOMEPAGE>; channel = <0>; voltage = <980000>; };
- button@1180 { + button-1180 { label = "Esc"; linux,code = <KEY_ESC>; channel = <0>; voltage = <1180000>; };
- button@1400 { + button-1400 { label = "Enter"; linux,code = <KEY_ENTER>; channel = <0>; @@ -211,8 +203,6 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -220,8 +210,6 @@ };
&mmc3 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pins_a>, <&mmc3_cd_pin_olimex_som_evb>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 0 GPIO_ACTIVE_LOW>; /* PH0 */ @@ -241,36 +229,14 @@ };
&pio { - ahci_pwr_pin_olimex_som_evb: ahci_pwr_pin@1 { - pins = "PC3"; - function = "gpio_out"; - }; - - led_pins_olimex_som_evb: led_pins@0 { + led_pins_olimex_som_evb: led-pins { pins = "PH2"; function = "gpio_out"; drive-strength = <20>; }; - - mmc3_cd_pin_olimex_som_evb: mmc3_cd_pin@0 { - pins = "PH0"; - function = "gpio_in"; - bias-pull-up; - }; - - usb0_id_detect_pin: usb0_id_detect_pin@0 { - pins = "PH4"; - function = "gpio_in"; - }; - - usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { - pins = "PH5"; - function = "gpio_in"; - }; };
®_ahci_5v { - pinctrl-0 = <&ahci_pwr_pin_olimex_som_evb>; gpio = <&pio 2 3 GPIO_ACTIVE_HIGH>; status = "okay"; }; @@ -316,33 +282,33 @@
&spi1 { pinctrl-names = "default"; - pinctrl-0 = <&spi1_pins_a>, - <&spi1_cs0_pins_a>; + pinctrl-0 = <&spi1_pi_pins>, + <&spi1_cs0_pi_pin>; status = "okay"; };
&spi2 { pinctrl-names = "default"; - pinctrl-0 = <&spi2_pins_a>, - <&spi2_cs0_pins_a>; + pinctrl-0 = <&spi2_pc_pins>, + <&spi2_cs0_pc_pin>; status = "okay"; };
&uart6 { pinctrl-names = "default"; - pinctrl-0 = <&uart6_pins_a>; + pinctrl-0 = <&uart6_pi_pins>; status = "okay"; };
@@ -352,8 +318,6 @@ };
&usbphy { - pinctrl-names = "default"; - pinctrl-0 = <&usb0_id_detect_pin>, <&usb0_vbus_detect_pin>; usb0_id_det-gpios = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH04 */ usb0_vbus_det-gpios = <&pio 7 5 GPIO_ACTIVE_HIGH>; /* PH05 */ usb0_vbus-supply = <®_usb0_vbus>; diff --git a/arch/arm/dts/sun7i-a20-olimex-som204-evb-emmc.dts b/arch/arm/dts/sun7i-a20-olimex-som204-evb-emmc.dts index c56620a8fb..a59755a2e7 100644 --- a/arch/arm/dts/sun7i-a20-olimex-som204-evb-emmc.dts +++ b/arch/arm/dts/sun7i-a20-olimex-som204-evb-emmc.dts @@ -20,8 +20,6 @@ };
&mmc2 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc2_pins_a>; vmmc-supply = <®_vcc3v3>; mmc-pwrseq = <&mmc2_pwrseq>; bus-width = <4>; diff --git a/arch/arm/dts/sun7i-a20-olimex-som204-evb.dts b/arch/arm/dts/sun7i-a20-olimex-som204-evb.dts index 3d7b5c848f..823aabce04 100644 --- a/arch/arm/dts/sun7i-a20-olimex-som204-evb.dts +++ b/arch/arm/dts/sun7i-a20-olimex-som204-evb.dts @@ -78,7 +78,7 @@
&can0 { pinctrl-names = "default"; - pinctrl-0 = <&can0_pins_a>; + pinctrl-0 = <&can_ph_pins>; status = "okay"; };
@@ -104,7 +104,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy3>; phy-mode = "rgmii"; phy-supply = <®_vcc3v3>; @@ -130,8 +130,6 @@ };
axp209: pmic@34 { @@ -143,8 +141,6 @@
/* Exposed to UEXT1 */ &i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins_a>; status = "okay";
eeprom: eeprom@50 { @@ -156,20 +152,16 @@
/* Exposed to UEXT2 */ &i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_a>; status = "okay"; };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; @@ -177,8 +169,6 @@ };
&mmc3 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pins_a>; vmmc-supply = <®_vcc3v3>; mmc-pwrseq = <&rtl_pwrseq>; bus-width = <4>; @@ -203,8 +193,8 @@ };
&pio { - bt_uart_pins: bt_uart_pins@0 { - pins = "PG6", "PG7", "PG8"; + uart3_rts_pin: uart3-rts-pin { + pins = "PG8"; function = "uart3"; }; }; @@ -274,43 +264,43 @@ /* Exposed to UEXT1 */ &spi1 { pinctrl-names = "default"; - pinctrl-0 = <&spi1_pins_a>, - <&spi1_cs0_pins_a>; + pinctrl-0 = <&spi1_pi_pins>, + <&spi1_cs0_pi_pin>; status = "okay"; };
/* Exposed to UEXT2 */ &spi2 { pinctrl-names = "default"; - pinctrl-0 = <&spi2_pins_a>, - <&spi2_cs0_pins_a>; + pinctrl-0 = <&spi2_pc_pins>, + <&spi2_cs0_pc_pin>; status = "okay"; };
/* Used for RTL8723BS bluetooth */ &uart3 { pinctrl-names = "default"; - pinctrl-0 = <&bt_uart_pins>; + pinctrl-0 = <&uart3_pg_pins>, <&uart3_rts_pin>; status = "okay"; };
/* Exposed to UEXT1 */ &uart4 { pinctrl-names = "default"; - pinctrl-0 = <&uart4_pins_a>; + pinctrl-0 = <&uart4_pg_pins>; status = "okay"; };
/* Exposed to UEXT2 */ &uart7 { pinctrl-names = "default"; - pinctrl-0 = <&uart7_pins_a>; + pinctrl-0 = <&uart7_pi_pins>; status = "okay"; };
diff --git a/arch/arm/dts/sun7i-a20-olinuxino-lime.dts b/arch/arm/dts/sun7i-a20-olinuxino-lime.dts index d20fd03596..5e411194bf 100644 --- a/arch/arm/dts/sun7i-a20-olinuxino-lime.dts +++ b/arch/arm/dts/sun7i-a20-olinuxino-lime.dts @@ -105,7 +105,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_mii_a>; + pinctrl-0 = <&gmac_mii_pins>; phy = <&phy1>; phy-mode = "mii"; status = "okay"; @@ -126,8 +126,6 @@ };
axp209: pmic@34 { @@ -142,8 +140,6 @@ };
eeprom: eeprom@50 { @@ -154,8 +150,6 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -175,24 +169,19 @@ };
&pio { - ahci_pwr_pin_olinuxinolime: ahci_pwr_pin@1 { - pins = "PC3"; - function = "gpio_out"; - }; - - led_pins_olinuxinolime: led_pins@0 { + led_pins_olinuxinolime: led-pins { pins = "PH2"; function = "gpio_out"; drive-strength = <20>; };
- usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + usb0_vbus_detect_pin: usb0-vbus-detect-pin { pins = "PH5"; function = "gpio_in"; bias-pull-down; @@ -200,7 +189,6 @@ };
®_ahci_5v { - pinctrl-0 = <&ahci_pwr_pin_olinuxinolime>; gpio = <&pio 2 3 GPIO_ACTIVE_HIGH>; status = "okay"; }; @@ -219,7 +207,7 @@
diff --git a/arch/arm/dts/sun7i-a20-olinuxino-lime2-emmc.dts b/arch/arm/dts/sun7i-a20-olinuxino-lime2-emmc.dts index 81f376f2a4..decb014a38 100644 --- a/arch/arm/dts/sun7i-a20-olinuxino-lime2-emmc.dts +++ b/arch/arm/dts/sun7i-a20-olinuxino-lime2-emmc.dts @@ -48,23 +48,12 @@ compatible = "olimex,a20-olinuxino-lime2-emmc", "allwinner,sun7i-a20";
mmc2_pwrseq: pwrseq { - pinctrl-0 = <&mmc2_pins_nrst>; - pinctrl-names = "default"; compatible = "mmc-pwrseq-emmc"; reset-gpios = <&pio 2 16 GPIO_ACTIVE_LOW>; }; };
-&pio { - mmc2_pins_nrst: mmc2-rst-pin { - pins = "PC16"; - function = "gpio_out"; - }; -}; - &mmc2 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc2_pins_a>; vmmc-supply = <®_vcc3v3>; vqmmc-supply = <®_vcc3v3>; bus-width = <4>; diff --git a/arch/arm/dts/sun7i-a20-olinuxino-lime2.dts b/arch/arm/dts/sun7i-a20-olinuxino-lime2.dts index b828677f33..4e1c590eb0 100644 --- a/arch/arm/dts/sun7i-a20-olinuxino-lime2.dts +++ b/arch/arm/dts/sun7i-a20-olinuxino-lime2.dts @@ -110,7 +110,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; status = "okay"; @@ -131,8 +131,6 @@ };
axp209: pmic@34 { @@ -143,8 +141,6 @@ };
eeprom: eeprom@50 { @@ -154,9 +150,11 @@ }; };
+&lradc { + vref-supply = <®_vcc3v0>; +}; + &mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -176,37 +174,26 @@ };
- usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + usb0_vbus_detect_pin: usb0-vbus-detect-pin { pins = "PH5"; function = "gpio_in"; bias-pull-down; }; - - usb0_vbus_pin_lime2: usb0_vbus_pin@0 { - pins = "PC17"; - function = "gpio_out"; - }; };
®_ahci_5v { - pinctrl-0 = <&ahci_pwr_pin_olinuxinolime>; gpio = <&pio 2 3 GPIO_ACTIVE_HIGH>; status = "okay"; }; @@ -245,6 +232,8 @@ regulator-min-microvolt = <2800000>; regulator-max-microvolt = <2800000>; regulator-name = "vddio-csi0"; + regulator-soft-start; + regulator-ramp-delay = <1600>; };
®_ldo4 { @@ -254,7 +243,6 @@ };
®_usb0_vbus { - pinctrl-0 = <&usb0_vbus_pin_lime2>; gpio = <&pio 2 17 GPIO_ACTIVE_HIGH>; status = "okay"; }; @@ -269,7 +257,7 @@
diff --git a/arch/arm/dts/sun7i-a20-olinuxino-micro-emmc.dts b/arch/arm/dts/sun7i-a20-olinuxino-micro-emmc.dts index d99e7b193e..2337b44a88 100644 --- a/arch/arm/dts/sun7i-a20-olinuxino-micro-emmc.dts +++ b/arch/arm/dts/sun7i-a20-olinuxino-micro-emmc.dts @@ -54,8 +54,6 @@ };
&mmc2 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc2_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; non-removable; diff --git a/arch/arm/dts/sun7i-a20-olinuxino-micro.dts b/arch/arm/dts/sun7i-a20-olinuxino-micro.dts index 866d230593..840ae1194a 100644 --- a/arch/arm/dts/sun7i-a20-olinuxino-micro.dts +++ b/arch/arm/dts/sun7i-a20-olinuxino-micro.dts @@ -117,7 +117,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_mii_a>, <&gmac_txerr>; + pinctrl-0 = <&gmac_mii_pins>, <&gmac_txerr>; phy = <&phy1>; phy-mode = "mii"; status = "okay"; @@ -138,8 +138,6 @@ };
axp209: pmic@34 { @@ -150,8 +148,6 @@ };
eeprom: eeprom@50 { @@ -162,8 +158,6 @@ };
@@ -171,49 +165,49 @@ vref-supply = <®_vcc3v0>; status = "okay";
- button@191 { + button-191 { label = "Volume Up"; linux,code = <KEY_VOLUMEUP>; channel = <0>; voltage = <191274>; };
- button@392 { + button-392 { label = "Volume Down"; linux,code = <KEY_VOLUMEDOWN>; channel = <0>; voltage = <392644>; };
- button@601 { + button-601 { label = "Menu"; linux,code = <KEY_MENU>; channel = <0>; voltage = <601151>; };
- button@795 { + button-795 { label = "Search"; linux,code = <KEY_SEARCH>; channel = <0>; voltage = <795090>; };
- button@987 { + button-987 { label = "Home"; linux,code = <KEY_HOMEPAGE>; channel = <0>; voltage = <987387>; };
- button@1184 { + button-1184 { label = "Esc"; linux,code = <KEY_ESC>; channel = <0>; voltage = <1184678>; };
- button@1398 { + button-1398 { label = "Enter"; linux,code = <KEY_ENTER>; channel = <0>; @@ -222,8 +216,6 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -231,8 +223,6 @@ };
&mmc3 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pins_a>, <&mmc3_cd_pin_olinuxinom>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 11 GPIO_ACTIVE_LOW>; /* PH11 */ @@ -252,30 +242,24 @@ };
&pio { - gmac_txerr: gmac_txerr@0 { + gmac_txerr: gmac-txerr-pin { pins = "PA17"; function = "gmac"; };
- mmc3_cd_pin_olinuxinom: mmc3_cd_pin@0 { - pins = "PH11"; - function = "gpio_in"; - bias-pull-up; - }; - - led_pins_olinuxino: led_pins@0 { + led_pins_olinuxino: led-pins { pins = "PH2"; function = "gpio_out"; drive-strength = <20>; };
- usb0_vbus_detect_pin: usb0_vbus_detect_pin@0 { + usb0_vbus_detect_pin: usb0-vbus-detect-pin { pins = "PH5"; function = "gpio_in"; bias-pull-down; @@ -331,33 +315,33 @@
diff --git a/arch/arm/dts/sun7i-a20-orangepi-mini.dts b/arch/arm/dts/sun7i-a20-orangepi-mini.dts index f5c7178eb0..15881081ca 100644 --- a/arch/arm/dts/sun7i-a20-orangepi-mini.dts +++ b/arch/arm/dts/sun7i-a20-orangepi-mini.dts @@ -74,8 +74,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_orangepi>;
green { label = "orangepi:green:usr"; @@ -90,8 +88,6 @@
reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac_power_pin_orangepi>; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -123,7 +119,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; phy-supply = <®_gmac_3v3>; @@ -145,8 +141,6 @@ };
axp209: pmic@34 { @@ -160,13 +154,11 @@
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_orangepi>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 10 GPIO_ACTIVE_LOW>; /* PH10 */ @@ -174,8 +166,6 @@ };
&mmc3 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pins_a>, <&mmc3_cd_pin_orangepi>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 11 GPIO_ACTIVE_LOW>; /* PH11 */ @@ -187,43 +177,11 @@ };
&pio { - usb0_id_detect_pin: usb0_id_detect_pin@0 { + usb0_id_detect_pin: usb0-id-detect-pin { pins = "PH4"; function = "gpio_in"; bias-pull-up; }; - - mmc0_cd_pin_orangepi: mmc0_cd_pin@0 { - pins = "PH10"; - function = "gpio_in"; - bias-pull-up; - }; - - mmc3_cd_pin_orangepi: mmc3_cd_pin@0 { - pins = "PH11"; - function = "gpio_in"; - bias-pull-up; - }; - - usb2_vbus_pin_bananapro: usb2_vbus_pin@0 { - pins = "PH22"; - function = "gpio_out"; - }; - - gmac_power_pin_orangepi: gmac_power_pin@0 { - pins = "PH23"; - function = "gpio_out"; - }; - - led_pins_orangepi: led_pins@0 { - pins = "PH24", "PH25"; - function = "gpio_out"; - }; - - usb1_vbus_pin_bananapro: usb1_vbus_pin@0 { - pins = "PH26"; - function = "gpio_out"; - }; };
®_dcdc2 { @@ -256,20 +214,18 @@ };
®_usb1_vbus { - pinctrl-0 = <&usb1_vbus_pin_bananapro>; gpio = <&pio 7 26 GPIO_ACTIVE_HIGH>; /* PH26 */ status = "okay"; };
®_usb2_vbus { - pinctrl-0 = <&usb2_vbus_pin_bananapro>; gpio = <&pio 7 22 GPIO_ACTIVE_HIGH>; /* PH22 */ status = "okay"; };
diff --git a/arch/arm/dts/sun7i-a20-orangepi.dts b/arch/arm/dts/sun7i-a20-orangepi.dts index 7a4244e575..d64de2e73a 100644 --- a/arch/arm/dts/sun7i-a20-orangepi.dts +++ b/arch/arm/dts/sun7i-a20-orangepi.dts @@ -63,8 +63,6 @@
green { label = "orangepi:green:usr"; @@ -74,8 +72,6 @@
reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac_power_pin_orangepi>; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -99,7 +95,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; phy-supply = <®_gmac_3v3>; @@ -111,8 +107,6 @@ };
axp209: pmic@34 { @@ -126,13 +120,11 @@
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_orangepi>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 10 GPIO_ACTIVE_LOW>; /* PH10 */ @@ -144,37 +136,11 @@ };
&pio { - usb0_id_detect_pin: usb0_id_detect_pin@0 { + usb0_id_detect_pin: usb0-id-detect-pin { pins = "PH4"; function = "gpio_in"; bias-pull-up; }; - - mmc0_cd_pin_orangepi: mmc0_cd_pin@0 { - pins = "PH10"; - function = "gpio_in"; - bias-pull-up; - }; - - usb2_vbus_pin_bananapro: usb2_vbus_pin@0 { - pins = "PH22"; - function = "gpio_out"; - }; - - gmac_power_pin_orangepi: gmac_power_pin@0 { - pins = "PH23"; - function = "gpio_out"; - }; - - led_pins_orangepi: led_pins@0 { - pins = "PH24"; - function = "gpio_out"; - }; - - usb1_vbus_pin_bananapro: usb1_vbus_pin@0 { - pins = "PH26"; - function = "gpio_out"; - }; };
®_dcdc2 { @@ -207,20 +173,18 @@ };
diff --git a/arch/arm/dts/sun7i-a20-pcduino3-nano.dts b/arch/arm/dts/sun7i-a20-pcduino3-nano.dts index bfca960b03..538ea15fa3 100644 --- a/arch/arm/dts/sun7i-a20-pcduino3-nano.dts +++ b/arch/arm/dts/sun7i-a20-pcduino3-nano.dts @@ -71,8 +71,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_pcduino3_nano>;
/* Marked "LED3" on the PCB. */ usr1 { @@ -115,7 +113,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; status = "okay"; @@ -136,8 +134,6 @@ };
axp209: pmic@34 { @@ -149,13 +145,11 @@
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -175,30 +169,14 @@ };
&pio { - ahci_pwr_pin_pcduino3_nano: ahci_pwr_pin@0 { - pins = "PH2"; - function = "gpio_out"; - }; - - led_pins_pcduino3_nano: led_pins@0 { - pins = "PH16", "PH15"; - function = "gpio_out"; - }; - - usb0_id_detect_pin: usb0_id_detect_pin@0 { + usb0_id_detect_pin: usb0-id-detect-pin { pins = "PH4"; function = "gpio_in"; bias-pull-up; }; - - usb1_vbus_pin_pcduino3_nano: usb1_vbus_pin@0 { - pins = "PD2"; - function = "gpio_out"; - }; };
®_ahci_5v { - pinctrl-0 = <&ahci_pwr_pin_pcduino3_nano>; gpio = <&pio 7 2 GPIO_ACTIVE_HIGH>; /* PH2 */ status = "okay"; }; @@ -232,14 +210,13 @@
/* A single regulator (U24) powers both USB host ports. */ ®_usb1_vbus { - pinctrl-0 = <&usb1_vbus_pin_pcduino3_nano>; gpio = <&pio 3 2 GPIO_ACTIVE_HIGH>; /* PD2 */ status = "okay"; };
diff --git a/arch/arm/dts/sun7i-a20-pcduino3.dts b/arch/arm/dts/sun7i-a20-pcduino3.dts index c576f101fb..a72ed4318d 100644 --- a/arch/arm/dts/sun7i-a20-pcduino3.dts +++ b/arch/arm/dts/sun7i-a20-pcduino3.dts @@ -63,8 +63,6 @@
leds { compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins_pcduino3>;
tx { label = "pcduino3:green:tx"; @@ -77,23 +75,22 @@ }; };
- gpio_keys { + gpio-keys { compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&key_pins_pcduino3>; - #address-cells = <1>; - #size-cells = <0>; - button@0 { + + back { label = "Key Back"; linux,code = <KEY_BACK>; gpios = <&pio 7 17 GPIO_ACTIVE_LOW>; }; - button@1 { + + home { label = "Key Home"; linux,code = <KEY_HOME>; gpios = <&pio 7 18 GPIO_ACTIVE_LOW>; }; - button@2 { + + menu { label = "Key Menu"; linux,code = <KEY_MENU>; gpios = <&pio 7 19 GPIO_ACTIVE_LOW>; @@ -124,7 +121,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_mii_a>; + pinctrl-0 = <&gmac_mii_pins>; phy = <&phy1>; phy-mode = "mii"; status = "okay"; @@ -135,8 +132,6 @@ };
axp209: pmic@34 { @@ -150,13 +145,11 @@
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -176,17 +169,7 @@ };
&pio { - led_pins_pcduino3: led_pins@0 { - pins = "PH15", "PH16"; - function = "gpio_out"; - }; - - key_pins_pcduino3: key_pins@0 { - pins = "PH17", "PH18", "PH19"; - function = "gpio_in"; - }; - - usb0_id_detect_pin: usb0_id_detect_pin@0 { + usb0_id_detect_pin: usb0-id-detect-pin { pins = "PH4"; function = "gpio_in"; bias-pull-up; @@ -233,7 +216,7 @@
diff --git a/arch/arm/dts/sun7i-a20-primo73.dts b/arch/arm/dts/sun7i-a20-primo73.dts index b7294e0348..ac0175f795 100644 --- a/arch/arm/dts/sun7i-a20-primo73.dts +++ b/arch/arm/dts/sun7i-a20-primo73.dts @@ -67,8 +67,6 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -82,7 +80,7 @@
diff --git a/arch/arm/dts/sun7i-a20-wexler-tab7200.dts b/arch/arm/dts/sun7i-a20-wexler-tab7200.dts index 8202c87ca6..ffade253d1 100644 --- a/arch/arm/dts/sun7i-a20-wexler-tab7200.dts +++ b/arch/arm/dts/sun7i-a20-wexler-tab7200.dts @@ -63,8 +63,6 @@ pwms = <&pwm 0 50000 PWM_POLARITY_INVERTED>; brightness-levels = <0 10 20 30 40 50 60 70 80 90 100>; default-brightness-level = <8>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_enable_pin>; enable-gpios = <&pio 7 7 GPIO_ACTIVE_HIGH>; /* PH7 */ };
@@ -74,8 +72,6 @@ };
&codec { - pinctrl-names = "default"; - pinctrl-0 = <&codec_pa_pin>; allwinner,pa-gpios = <&pio 7 15 GPIO_ACTIVE_HIGH>; /* PH15 */ status = "okay"; }; @@ -93,8 +89,6 @@ };
axp209: pmic@34 { @@ -107,14 +101,10 @@ #include "axp209.dtsi"
gt911: touchscreen@5d { @@ -122,8 +112,6 @@ reg = <0x5d>; interrupt-parent = <&pio>; interrupts = <7 21 IRQ_TYPE_EDGE_FALLING>; /* EINT21 (PH21) */ - pinctrl-names = "default"; - pinctrl-0 = <&ts_reset_pin>; irq-gpios = <&pio 7 21 GPIO_ACTIVE_HIGH>; /* INT (PH21) */ reset-gpios = <&pio 1 13 GPIO_ACTIVE_HIGH>; /* RST (PB13) */ touchscreen-swapped-x-y; @@ -134,14 +122,14 @@ vref-supply = <®_vcc3v0>; status = "okay";
- button@571 { + button-571 { label = "Volume Up"; linux,code = <KEY_VOLUMEUP>; channel = <0>; voltage = <571428>; };
- button@761 { + button-761 { label = "Volume Down"; linux,code = <KEY_VOLUMEDOWN>; channel = <0>; @@ -150,8 +138,6 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -171,22 +157,7 @@ };
&pio { - bl_enable_pin: bl_enable_pin@0 { - pins = "PH7"; - function = "gpio_out"; - }; - - codec_pa_pin: codec_pa_pin@0 { - pins = "PH15"; - function = "gpio_out"; - }; - - ts_reset_pin: ts_reset_pin@0 { - pins = "PB13"; - function = "gpio_out"; - }; - - usb0_id_detect_pin: usb0_id_detect_pin@0 { + usb0_id_detect_pin: usb0-id-detect-pin { pins = "PH4"; function = "gpio_in"; bias-pull-up; @@ -195,7 +166,7 @@
@@ -238,7 +209,7 @@
diff --git a/arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts b/arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts index ff5c108658..c27e56091f 100644 --- a/arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts +++ b/arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts @@ -62,8 +62,6 @@
mmc3_pwrseq: mmc3_pwrseq { compatible = "mmc-pwrseq-simple"; - pinctrl-names = "default"; - pinctrl-0 = <&vmmc3_pin_ap6xxx_wl_regon>; reset-gpios = <&pio 7 9 GPIO_ACTIVE_LOW>; /* PH9 WIFI_EN */ }; }; @@ -82,7 +80,7 @@
&gmac { pinctrl-names = "default"; - pinctrl-0 = <&gmac_pins_rgmii_a>; + pinctrl-0 = <&gmac_rgmii_pins>; phy = <&phy1>; phy-mode = "rgmii"; status = "okay"; @@ -93,8 +91,6 @@ };
axp209: pmic@34 { @@ -105,22 +101,16 @@ };
&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; cd-gpios = <&pio 7 1 GPIO_ACTIVE_LOW>; /* PH1 */ @@ -128,8 +118,6 @@ };
&mmc3 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc3_pins_a>; vmmc-supply = <®_vcc3v3>; mmc-pwrseq = <&mmc3_pwrseq>; bus-width = <4>; @@ -158,12 +146,7 @@ };
&pio { - vmmc3_pin_ap6xxx_wl_regon: vmmc3_pin@0 { - pins = "PH9"; - function = "gpio_out"; - }; - - usb0_id_detect_pin: usb0_id_detect_pin@0 { + usb0_id_detect_pin: usb0-id-detect-pin { pins = "PH4"; function = "gpio_in"; bias-pull-up; @@ -209,7 +192,7 @@
diff --git a/arch/arm/dts/sun7i-a20-yones-toptech-bd1078.dts b/arch/arm/dts/sun7i-a20-yones-toptech-bd1078.dts index f1fb97d3fb..11142ae6e7 100644 --- a/arch/arm/dts/sun7i-a20-yones-toptech-bd1078.dts +++ b/arch/arm/dts/sun7i-a20-yones-toptech-bd1078.dts @@ -23,6 +23,6 @@
&uart0 { pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; + pinctrl-0 = <&uart0_pb_pins>; status = "okay"; }; diff --git a/arch/arm/dts/sun7i-a20.dtsi b/arch/arm/dts/sun7i-a20.dtsi index e529e4ff21..641a8fa6d4 100644 --- a/arch/arm/dts/sun7i-a20.dtsi +++ b/arch/arm/dts/sun7i-a20.dtsi @@ -42,8 +42,6 @@ * OTHER DEALINGS IN THE SOFTWARE. */
-#include "skeleton.dtsi" - #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/thermal/thermal.h> #include <dt-bindings/dma/sun4i-a10.h> @@ -52,6 +50,8 @@
/ { interrupt-parent = <&gic>; + #address-cells = <1>; + #size-cells = <1>;
aliases { ethernet0 = &gmac; @@ -62,7 +62,7 @@ #size-cells = <1>; ranges;
- framebuffer@0 { + framebuffer-lcd0-hdmi { compatible = "allwinner,simple-framebuffer", "simple-framebuffer"; allwinner,pipeline = "de_be0-lcd0-hdmi"; @@ -73,7 +73,7 @@ status = "disabled"; };
- framebuffer@1 { + framebuffer-lcd0 { compatible = "allwinner,simple-framebuffer", "simple-framebuffer"; allwinner,pipeline = "de_be0-lcd0"; @@ -83,7 +83,7 @@ status = "disabled"; };
- framebuffer@2 { + framebuffer-lcd0-tve0 { compatible = "allwinner,simple-framebuffer", "simple-framebuffer"; allwinner,pipeline = "de_be0-lcd0-tve0"; @@ -118,10 +118,23 @@ #cooling-cells = <2>; };
- cpu@1 { + cpu1: cpu@1 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <1>; + clocks = <&ccu CLK_CPU>; + clock-latency = <244144>; /* 8 32k periods */ + operating-points = < + /* kHz uV */ + 960000 1400000 + 912000 1400000 + 864000 1300000 + 720000 1200000 + 528000 1100000 + 312000 1000000 + 144000 1000000 + >; + #cooling-cells = <2>; }; };
@@ -135,7 +148,8 @@ cooling-maps { map0 { trip = <&cpu_alert0>; - cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; }; };
@@ -157,8 +171,19 @@ }; };
- memory { - reg = <0x40000000 0x80000000>; + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + /* Address must be kept in the lower 256 MiBs of DRAM for VE. */ + default-pool { + compatible = "shared-dma-pool"; + size = <0x6000000>; + alloc-ranges = <0x4a000000 0x6000000>; + reusable; + linux,cma-default; + }; };
timer { @@ -170,7 +195,7 @@ };
pmu { - compatible = "arm,cortex-a7-pmu", "arm,cortex-a15-pmu"; + compatible = "arm,cortex-a7-pmu"; interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; }; @@ -180,14 +205,14 @@ #size-cells = <1>; ranges;
- osc24M: clk@1c20050 { + osc24M: clk-24M { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <24000000>; clock-output-names = "osc24M"; };
- osc32k: clk@0 { + osc32k: clk-32k { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <32768>; @@ -203,14 +228,14 @@ * The actual TX clock rate is not controlled by the * gmac_tx clock. */ - mii_phy_tx_clk: clk@1 { + mii_phy_tx_clk: clk-mii-phy-tx { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <25000000>; clock-output-names = "mii_phy_tx"; };
- gmac_int_tx_clk: clk@2 { + gmac_int_tx_clk: clk-gmac-int-tx { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <125000000>; @@ -233,14 +258,15 @@ status = "disabled"; };
- soc@1c00000 { + soc { compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>; ranges;
- sram-controller@1c00000 { - compatible = "allwinner,sun4i-a10-sram-controller"; + system-control@1c00000 { + compatible = "allwinner,sun7i-a20-system-control", + "allwinner,sun4i-a10-system-control"; reg = <0x01c00000 0x30>; #address-cells = <1>; #size-cells = <1>; @@ -254,7 +280,8 @@ ranges = <0 0x00000000 0xc000>;
emac_sram: sram-section@8000 { - compatible = "allwinner,sun4i-a10-sram-a3-a4"; + compatible = "allwinner,sun7i-a20-sram-a3-a4", + "allwinner,sun4i-a10-sram-a3-a4"; reg = <0x8000 0x4000>; status = "disabled"; }; @@ -268,11 +295,26 @@ ranges = <0 0x00010000 0x1000>;
otg_sram: sram-section@0 { - compatible = "allwinner,sun4i-a10-sram-d"; + compatible = "allwinner,sun7i-a20-sram-d", + "allwinner,sun4i-a10-sram-d"; reg = <0x0000 0x1000>; status = "disabled"; }; }; + + sram_c: sram@1d00000 { + compatible = "mmio-sram"; + reg = <0x01d00000 0xd0000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x01d00000 0xd0000>; + + ve_sram: sram-section@0 { + compatible = "allwinner,sun7i-a20-sram-c1", + "allwinner,sun4i-a10-sram-c1"; + reg = <0x000000 0x80000>; + }; + }; };
nmi_intc: interrupt-controller@1c00030 { @@ -449,6 +491,17 @@ }; };
+ video-codec@1c0e000 { + compatible = "allwinner,sun7i-a20-video-engine"; + reg = <0x01c0e000 0x1000>; + clocks = <&ccu CLK_AHB_VE>, <&ccu CLK_VE>, + <&ccu CLK_DRAM_VE>; + clock-names = "ahb", "mod", "ram"; + resets = <&ccu RST_VE>; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + allwinner,sram = <&ve_sram 1>; + }; + mmc0: mmc@1c0f000 { compatible = "allwinner,sun7i-a20-mmc"; reg = <0x01c0f000 0x1000>; @@ -461,6 +514,8 @@ "output", "sample"; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -495,6 +550,8 @@ "output", "sample"; interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -512,6 +569,8 @@ "output", "sample"; interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc3_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -609,8 +668,6 @@ };
hdmi_out: port@1 { - #address-cells = <1>; - #size-cells = <0>; reg = <1>; }; }; @@ -694,22 +751,22 @@ #interrupt-cells = <3>; #gpio-cells = <3>;
- can0_pins_a: can0@0 { + can_ph_pins: can-ph-pins { pins = "PH20", "PH21"; function = "can"; };
- clk_out_a_pins_a: clk_out_a@0 { + clk_out_a_pin: clk-out-a-pin { pins = "PI12"; function = "clk_out_a"; };
- clk_out_b_pins_a: clk_out_b@0 { + clk_out_b_pin: clk-out-b-pin { pins = "PI13"; function = "clk_out_b"; };
- emac_pins_a: emac0@0 { + emac_pa_pins: emac-pa-pins { pins = "PA0", "PA1", "PA2", "PA3", "PA4", "PA5", "PA6", "PA7", "PA8", "PA9", "PA10", @@ -718,7 +775,7 @@ function = "emac"; };
- gmac_pins_mii_a: gmac_mii@0 { + gmac_mii_pins: gmac-mii-pins { pins = "PA0", "PA1", "PA2", "PA3", "PA4", "PA5", "PA6", "PA7", "PA8", "PA9", "PA10", @@ -727,7 +784,7 @@ function = "gmac"; };
- gmac_pins_rgmii_a: gmac_rgmii@0 { + gmac_rgmii_pins: gmac-rgmii-pins { pins = "PA0", "PA1", "PA2", "PA3", "PA4", "PA5", "PA6", "PA7", "PA8", "PA10", @@ -741,47 +798,47 @@ drive-strength = <40>; };
- i2c0_pins_a: i2c0@0 { + i2c0_pins: i2c0-pins { pins = "PB0", "PB1"; function = "i2c0"; };
- i2c1_pins_a: i2c1@0 { + i2c1_pins: i2c1-pins { pins = "PB18", "PB19"; function = "i2c1"; };
- i2c2_pins_a: i2c2@0 { + i2c2_pins: i2c2-pins { pins = "PB20", "PB21"; function = "i2c2"; };
- i2c3_pins_a: i2c3@0 { + i2c3_pins: i2c3-pins { pins = "PI0", "PI1"; function = "i2c3"; };
- ir0_rx_pins_a: ir0@0 { + ir0_rx_pin: ir0-rx-pin { pins = "PB4"; function = "ir0"; };
- ir0_tx_pins_a: ir0@1 { + ir0_tx_pin: ir0-tx-pin { pins = "PB3"; function = "ir0"; };
- ir1_rx_pins_a: ir1@0 { + ir1_rx_pin: ir1-rx-pin { pins = "PB23"; function = "ir1"; };
- ir1_tx_pins_a: ir1@1 { + ir1_tx_pin: ir1-tx-pin { pins = "PB22"; function = "ir1"; };
- mmc0_pins_a: mmc0@0 { + mmc0_pins: mmc0-pins { pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; function = "mmc0"; @@ -789,7 +846,7 @@ bias-pull-up; };
- mmc2_pins_a: mmc2@0 { + mmc2_pins: mmc2-pins { pins = "PC6", "PC7", "PC8", "PC9", "PC10", "PC11"; function = "mmc2"; @@ -797,7 +854,7 @@ bias-pull-up; };
- mmc3_pins_a: mmc3@0 { + mmc3_pins: mmc3-pins { pins = "PI4", "PI5", "PI6", "PI7", "PI8", "PI9"; function = "mmc3"; @@ -805,118 +862,128 @@ bias-pull-up; };
- ps20_pins_a: ps20@0 { + ps2_0_pins: ps2-0-pins { pins = "PI20", "PI21"; function = "ps2"; };
- ps21_pins_a: ps21@0 { + ps2_1_ph_pins: ps2-1-ph-pins { pins = "PH12", "PH13"; function = "ps2"; };
- pwm0_pins_a: pwm0@0 { + pwm0_pin: pwm0-pin { pins = "PB2"; function = "pwm"; };
- pwm1_pins_a: pwm1@0 { + pwm1_pin: pwm1-pin { pins = "PI3"; function = "pwm"; };
- spdif_tx_pins_a: spdif@0 { + spdif_tx_pin: spdif-tx-pin { pins = "PB13"; function = "spdif"; bias-pull-up; };
- spi0_pins_a: spi0@0 { + spi0_pi_pins: spi0-pi-pins { pins = "PI11", "PI12", "PI13"; function = "spi0"; };
- spi0_cs0_pins_a: spi0_cs0@0 { + spi0_cs0_pi_pin: spi0-cs0-pi-pin { pins = "PI10"; function = "spi0"; };
- spi0_cs1_pins_a: spi0_cs1@0 { + spi0_cs1_pi_pin: spi0-cs1-pi-pin { pins = "PI14"; function = "spi0"; };
- spi1_pins_a: spi1@0 { + spi1_pi_pins: spi1-pi-pins { pins = "PI17", "PI18", "PI19"; function = "spi1"; };
- spi1_cs0_pins_a: spi1_cs0@0 { + spi1_cs0_pi_pin: spi1-cs0-pi-pin { pins = "PI16"; function = "spi1"; };
- spi2_pins_a: spi2@0 { - pins = "PC20", "PC21", "PC22"; + spi2_pb_pins: spi2-pb-pins { + pins = "PB15", "PB16", "PB17"; function = "spi2"; };
- spi2_pins_b: spi2@1 { - pins = "PB15", "PB16", "PB17"; + spi2_cs0_pb_pin: spi2-cs0-pb-pin { + pins = "PB14"; function = "spi2"; };
- spi2_cs0_pins_a: spi2_cs0@0 { - pins = "PC19"; + spi2_pc_pins: spi2-pc-pins { + pins = "PC20", "PC21", "PC22"; function = "spi2"; };
- spi2_cs0_pins_b: spi2_cs0@1 { - pins = "PB14"; + spi2_cs0_pc_pin: spi2-cs0-pc-pin { + pins = "PC19"; function = "spi2"; };
- uart0_pins_a: uart0@0 { + uart0_pb_pins: uart0-pb-pins { pins = "PB22", "PB23"; function = "uart0"; };
- uart2_pins_a: uart2@0 { - pins = "PI16", "PI17", "PI18", "PI19"; + uart2_pi_pins: uart2-pi-pins { + pins = "PI18", "PI19"; function = "uart2"; };
- uart3_pins_a: uart3@0 { - pins = "PG6", "PG7", "PG8", "PG9"; + uart2_cts_rts_pi_pins: uart2-cts-rts-pi-pins { + pins = "PI16", "PI17"; + function = "uart2"; + }; + + uart3_pg_pins: uart3-pg-pins { + pins = "PG6", "PG7"; + function = "uart3"; + }; + + uart3_cts_rts_pg_pins: uart3-cts-rts-pg-pins { + pins = "PG8", "PG9"; function = "uart3"; };
- uart3_pins_b: uart3@1 { + uart3_ph_pins: uart3-ph-pins { pins = "PH0", "PH1"; function = "uart3"; };
- uart4_pins_a: uart4@0 { + uart4_pg_pins: uart4-pg-pins { pins = "PG10", "PG11"; function = "uart4"; };
- uart4_pins_b: uart4@1 { + uart4_ph_pins: uart4-ph-pins { pins = "PH4", "PH5"; function = "uart4"; };
- uart5_pins_a: uart5@0 { + uart5_pi_pins: uart5-pi-pins { pins = "PI10", "PI11"; function = "uart5"; };
- uart6_pins_a: uart6@0 { + uart6_pi_pins: uart6-pi-pins { pins = "PI12", "PI13"; function = "uart6"; };
- uart7_pins_a: uart7@0 { + uart7_pi_pins: uart7-pi-pins { pins = "PI20", "PI21"; function = "uart7"; }; @@ -1157,6 +1224,8 @@ reg = <0x01c2ac00 0x400>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_APB1_I2C0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -1168,6 +1237,8 @@ reg = <0x01c2b000 0x400>; interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_APB1_I2C1>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -1179,6 +1250,8 @@ reg = <0x01c2b400 0x400>; interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_APB1_I2C2>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -1190,6 +1263,8 @@ reg = <0x01c2b800 0x400>; interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; clocks = <&ccu CLK_APB1_I2C3>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c3_pins>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; diff --git a/arch/arm/dts/sunxi-itead-core-common.dtsi b/arch/arm/dts/sunxi-itead-core-common.dtsi index 2565d5137a..0d002f83a2 100644 --- a/arch/arm/dts/sunxi-itead-core-common.dtsi +++ b/arch/arm/dts/sunxi-itead-core-common.dtsi @@ -65,8 +65,6 @@ };
axp209: pmic@34 { @@ -75,8 +73,6 @@ };
@@ -125,7 +121,7 @@
Add sata compatible for R40.
Cc: Pablo Sebastián Greco pgreco@centosproject.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/sunxi/ahci.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/sunxi/ahci.c b/board/sunxi/ahci.c index a79b80ca1e..9b03013667 100644 --- a/board/sunxi/ahci.c +++ b/board/sunxi/ahci.c @@ -121,6 +121,7 @@ static int sunxi_sata_bind(struct udevice *dev)
static const struct udevice_id sunxi_ahci_ids[] = { { .compatible = "allwinner,sun4i-a10-ahci" }, + { .compatible = "allwinner,sun8i-r40-ahci" }, { } };
Enable ahci node for sun7i-a20-m5.dts, this would require since we have DM_SCSI enabled on the respective SoC.
No need to send patch to Linux for this change, since this dts is U-Boot specific.
Cc: Ian Campbell ijc@hellion.org.uk Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/sun7i-a20-m5.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/sun7i-a20-m5.dts b/arch/arm/dts/sun7i-a20-m5.dts index 65930cc6ee..6de52c7c31 100644 --- a/arch/arm/dts/sun7i-a20-m5.dts +++ b/arch/arm/dts/sun7i-a20-m5.dts @@ -21,6 +21,10 @@ }; };
+&ahci { + status = "okay"; +}; + &ehci0 { status = "okay"; };
Enable ahci node for a20-wits-pro-a20-dkt, this would require since we have DM_SCSI enabled on the respective SoC.
Cc: Hans de Goede hdegoede@redhat.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Note: This change would need to send Linux first.
arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts b/arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts index c27e56091f..352fc4040e 100644 --- a/arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts +++ b/arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts @@ -133,6 +133,10 @@ }; };
+&ahci { + status = "okay"; +}; + &ohci0 { status = "okay"; };
Hi Hans,
Would you able to do this change for Linux, since I don't have any hardware to do the same?
- Enable DM_MMC if MMC defined - Enable DM_SCSI if SCSI defined
globally through Allwinner platform, the effected SoC families and boards will make use of MMC and SCSI subsystems in driver-model.
Tested DM_MMC in one board from A64, H6, H5, H3, R40, A83T, A20, A10 SoCs.
Cc: Pablo Sebastián Greco pgreco@centosproject.org Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/Kconfig | 2 ++ arch/arm/mach-sunxi/Kconfig | 13 ------------- 2 files changed, 2 insertions(+), 13 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 4a23e327df..7deae931b1 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -857,6 +857,8 @@ config ARCH_SUNXI select DM_ETH select DM_GPIO select DM_KEYBOARD + select DM_MMC if MMC + select DM_SCSI if SCSI select DM_SERIAL select DM_USB if DISTRO_DEFAULTS select OF_BOARD_SETUP diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 8110f23ff6..1669e62a6d 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -154,8 +154,6 @@ config MACH_SUN4I bool "sun4i (Allwinner A10)" select CPU_V7A select ARM_CORTEX_CPU_IS_UP - select DM_MMC if MMC - select DM_SCSI if SCSI select PHY_SUN4I_USB select DRAM_SUN4I select SUNXI_GEN_SUN4I @@ -165,7 +163,6 @@ config MACH_SUN5I bool "sun5i (Allwinner A13)" select CPU_V7A select ARM_CORTEX_CPU_IS_UP - select DM_MMC if MMC select DRAM_SUN4I select PHY_SUN4I_USB select SUNXI_GEN_SUN4I @@ -178,7 +175,6 @@ config MACH_SUN6I select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI - select DM_MMC if MMC select DRAM_SUN6I select PHY_SUN4I_USB select SUN6I_P2WI @@ -205,7 +201,6 @@ config MACH_SUN8I_A23 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI - select DM_MMC if MMC select DRAM_SUN8I_A23 select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -219,7 +214,6 @@ config MACH_SUN8I_A33 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI - select DM_MMC if MMC select DRAM_SUN8I_A33 select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -230,7 +224,6 @@ config MACH_SUN8I_A33 config MACH_SUN8I_A83T bool "sun8i (Allwinner A83T)" select CPU_V7A - select DM_MMC if MMC select DRAM_SUN8I_A83T select PHY_SUN4I_USB select SUNXI_GEN_SUN6I @@ -246,7 +239,6 @@ config MACH_SUN8I_H3 select ARCH_SUPPORT_PSCI select MACH_SUNXI_H3_H5 select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT - select DM_MMC if MMC
config MACH_SUN8I_R40 bool "sun8i (Allwinner R40)" @@ -265,7 +257,6 @@ config MACH_SUN8I_V3S select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select ARCH_SUPPORT_PSCI - select DM_MMC if MMC select SUNXI_GEN_SUN6I select SUNXI_DRAM_DW select SUNXI_DRAM_DW_16BIT @@ -280,13 +271,11 @@ config MACH_SUN9I select SUNXI_GEN_SUN6I select SUN8I_RSB select SUPPORT_SPL - select DM_MMC if MMC
config MACH_SUN50I bool "sun50i (Allwinner A64)" select ARM64 select DM_I2C - select DM_MMC if MMC select PHY_SUN4I_USB select SUN6I_PRCM select SUNXI_DE2 @@ -303,7 +292,6 @@ config MACH_SUN50I_H5 bool "sun50i (Allwinner H5)" select ARM64 select MACH_SUNXI_H3_H5 - select DM_MMC if MMC select FIT select SPL_LOAD_FIT
@@ -311,7 +299,6 @@ config MACH_SUN50I_H6 bool "sun50i (Allwinner H6)" select ARM64 select SUPPORT_SPL - select DM_MMC if MMC select FIT select SPL_LOAD_FIT select DRAM_SUN50I_H6
It seems like the Allwinner SATA driver is already quite capable of using the driver model, so we can force this on all boards and can remove support for a non-DM_SCSI build. This removes the warning about boards with SATA ports not being DM_SCSI compliant.
It also takes the opportunity to move the driver out of the board/sunxi directory to join its siblings in drivers/ata, and to make it a proper Kconfig citizen.
The board defconfigs stay untouched.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jagan Teki jagan@openedev.com [jagan: select DM_SCSI separately] Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- board/sunxi/Makefile | 3 --- drivers/ata/Kconfig | 8 ++++++++ drivers/ata/Makefile | 1 + board/sunxi/ahci.c => drivers/ata/ahci_sunxi.c | 10 ---------- include/configs/sunxi-common.h | 6 ------ scripts/config_whitelist.txt | 1 - 6 files changed, 9 insertions(+), 20 deletions(-) rename board/sunxi/ahci.c => drivers/ata/ahci_sunxi.c (94%)
diff --git a/board/sunxi/Makefile b/board/sunxi/Makefile index 4d6258d932..c4e13f8c38 100644 --- a/board/sunxi/Makefile +++ b/board/sunxi/Makefile @@ -8,9 +8,6 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de. obj-y += board.o obj-$(CONFIG_SUN7I_GMAC) += gmac.o -ifndef CONFIG_SPL_BUILD -obj-$(CONFIG_SUNXI_AHCI) += ahci.o -endif obj-$(CONFIG_MACH_SUN4I) += dram_sun4i_auto.o obj-$(CONFIG_MACH_SUN5I) += dram_sun5i_auto.o obj-$(CONFIG_MACH_SUN7I) += dram_sun5i_auto.o diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index 49a056e941..b7addaf785 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -99,6 +99,14 @@ config SATA_SIL3114 help Enable this driver to support the SIL3114 SATA controllers.
+config SUNXI_AHCI + bool "Enable Allwinner SATA driver support" + depends on AHCI + default y if ARCH_SUNXI + help + Enable this driver to support the SATA controllers found in the + Allwinner A10, A20 and R40 SoCs. + config AHCI_MVEBU bool "Marvell EBU AHCI SATA support" depends on ARCH_MVEBU diff --git a/drivers/ata/Makefile b/drivers/ata/Makefile index 10bed53bb3..a69edb10f7 100644 --- a/drivers/ata/Makefile +++ b/drivers/ata/Makefile @@ -18,3 +18,4 @@ obj-$(CONFIG_SATA_SIL3114) += sata_sil3114.o obj-$(CONFIG_SATA_SIL) += sata_sil.o obj-$(CONFIG_SANDBOX) += sata_sandbox.o obj-$(CONFIG_AHCI_MVEBU) += ahci_mvebu.o +obj-$(CONFIG_SUNXI_AHCI) += ahci_sunxi.o diff --git a/board/sunxi/ahci.c b/drivers/ata/ahci_sunxi.c similarity index 94% rename from board/sunxi/ahci.c rename to drivers/ata/ahci_sunxi.c index 9b03013667..77b932aa03 100644 --- a/board/sunxi/ahci.c +++ b/drivers/ata/ahci_sunxi.c @@ -70,15 +70,6 @@ static int sunxi_ahci_phy_init(u8 *reg_base) return 0; }
-#ifndef CONFIG_DM_SCSI -void scsi_init(void) -{ - if (sunxi_ahci_phy_init((u8 *)SUNXI_SATA_BASE) < 0) - return; - - ahci_init((void __iomem *)SUNXI_SATA_BASE); -} -#else static int sunxi_sata_probe(struct udevice *dev) { ulong base; @@ -132,4 +123,3 @@ U_BOOT_DRIVER(ahci_sunxi_drv) = { .bind = sunxi_sata_bind, .probe = sunxi_sata_probe, }; -#endif diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b01d1c3c84..bc30994029 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -104,13 +104,7 @@ #define PHYS_SDRAM_0_SIZE 0x80000000 /* 2 GiB */
#ifdef CONFIG_AHCI -#define CONFIG_SCSI_AHCI_PLAT -#define CONFIG_SUNXI_AHCI #define CONFIG_SYS_64BIT_LBA -#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 -#define CONFIG_SYS_SCSI_MAX_LUN 1 -#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ - CONFIG_SYS_SCSI_MAX_LUN) #endif
#define CONFIG_SETUP_MEMORY_TAGS diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 8c7c1592a5..c58b964065 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1939,7 +1939,6 @@ CONFIG_STV0991 CONFIG_STV0991_HZ CONFIG_STV0991_HZ_CLOCK CONFIG_ST_SMI -CONFIG_SUNXI_AHCI CONFIG_SUNXI_GPIO CONFIG_SUNXI_MAX_FB_SIZE CONFIG_SUPERH_ON_CHIP_R8A66597
El 12/4/19 a las 09:52, Jagan Teki escribió:
This would Migrate DM_MMC, DM_SCSI for A20 and R40 platforms.
Note:
- a20-wits-pro-a20-dkt change would need to send Linux first
- BPI-M2-Berry would break, but will import Linux dts once approved.
Andre Przywara (1): sunxi: update SATA driver to always use DM_SCSI
Jagan Teki (6): arm: allwinner: r40: Sync R40 dts(i) files from Linux 5.1-rc2 arm: allwinner: dts: a20: Sync A20 dts(i) files from Linux 5.1-rc2 board: sunxi: Add R40 sata compatible ARM: dts: a20-m5: Enable AHCI ARM: dts: a20-wits-pro-a20-dkt: Enable AHCI arm: sunxi: Enable DM_MMC and DM_SCSI
arch/arm/Kconfig | 2 + arch/arm/dts/sun7i-a20-ainol-aw1.dts | 2 +- arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts | 46 +-- arch/arm/dts/sun7i-a20-bananapi.dts | 49 +-- arch/arm/dts/sun7i-a20-bananapro.dts | 65 +--- arch/arm/dts/sun7i-a20-cubieboard2.dts | 21 +- arch/arm/dts/sun7i-a20-cubietruck.dts | 83 ++-- arch/arm/dts/sun7i-a20-hummingbird.dts | 60 +-- arch/arm/dts/sun7i-a20-i12-tvbox.dts | 47 +-- arch/arm/dts/sun7i-a20-icnova-swac.dts | 10 +- arch/arm/dts/sun7i-a20-itead-ibox.dts | 10 +- arch/arm/dts/sun7i-a20-lamobo-r1.dts | 48 +-- arch/arm/dts/sun7i-a20-m3.dts | 21 +- arch/arm/dts/sun7i-a20-m5.dts | 8 +- arch/arm/dts/sun7i-a20-mk808c.dts | 26 +- .../arm/dts/sun7i-a20-olimex-som-evb-emmc.dts | 35 ++ arch/arm/dts/sun7i-a20-olimex-som-evb.dts | 68 +--- .../dts/sun7i-a20-olimex-som204-evb-emmc.dts | 2 - arch/arm/dts/sun7i-a20-olimex-som204-evb.dts | 36 +- arch/arm/dts/sun7i-a20-olinuxino-lime.dts | 22 +- .../dts/sun7i-a20-olinuxino-lime2-emmc.dts | 11 - arch/arm/dts/sun7i-a20-olinuxino-lime2.dts | 34 +- .../dts/sun7i-a20-olinuxino-micro-emmc.dts | 2 - arch/arm/dts/sun7i-a20-olinuxino-micro.dts | 54 +-- arch/arm/dts/sun7i-a20-orangepi-mini.dts | 52 +-- arch/arm/dts/sun7i-a20-orangepi.dts | 44 +-- arch/arm/dts/sun7i-a20-pcduino3-nano.dts | 31 +- arch/arm/dts/sun7i-a20-pcduino3.dts | 39 +- arch/arm/dts/sun7i-a20-primo73.dts | 4 +- arch/arm/dts/sun7i-a20-wexler-tab7200.dts | 39 +- arch/arm/dts/sun7i-a20-wits-pro-a20-dkt.dts | 27 +- .../dts/sun7i-a20-yones-toptech-bd1078.dts | 2 +- arch/arm/dts/sun7i-a20.dtsi | 209 ++++++---- arch/arm/dts/sun8i-r40-bananapi-m2-ultra.dts | 91 ++++- arch/arm/dts/sun8i-r40.dtsi | 364 +++++++++++++++++- arch/arm/dts/sun8i-v40-bananapi-m2-berry.dts | 2 +- arch/arm/dts/sunxi-itead-core-common.dtsi | 6 +- arch/arm/mach-sunxi/Kconfig | 13 - board/sunxi/Makefile | 3 - drivers/ata/Kconfig | 8 + drivers/ata/Makefile | 1 + .../sunxi/ahci.c => drivers/ata/ahci_sunxi.c | 11 +- include/configs/sunxi-common.h | 6 - scripts/config_whitelist.txt | 1 - 44 files changed, 838 insertions(+), 877 deletions(-) create mode 100644 arch/arm/dts/sun7i-a20-olimex-som-evb-emmc.dts rename board/sunxi/ahci.c => drivers/ata/ahci_sunxi.c (94%)
On the r40 bits Tested-by: Pablo Sebastián Greco pgreco@centosproject.org
Jagan Teki
