[PATCH] video: rockchip: fix HDMI 4K resolution
3480 is not valid XRES, use 3840 as default.
Fixes: 05c65a82c3c1 ("video: rockchip: Support 4K resolution for rk3399, HDMI") Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Jagan Teki jagan@amarulasolutions.com --- drivers/video/rockchip/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/video/rockchip/Kconfig b/drivers/video/rockchip/Kconfig index cfd774ead6..5215a71f99 100644 --- a/drivers/video/rockchip/Kconfig +++ b/drivers/video/rockchip/Kconfig @@ -22,7 +22,7 @@ menuconfig VIDEO_ROCKCHIP config VIDEO_ROCKCHIP_MAX_XRES int "Maximum horizontal resolution (for memory allocation purposes)" depends on VIDEO_ROCKCHIP - default 3480 if ROCKCHIP_RK3399 && DISPLAY_ROCKCHIP_HDMI + default 3840 if ROCKCHIP_RK3399 && DISPLAY_ROCKCHIP_HDMI default 1920 help The maximum horizontal resolution to support for the framebuffer.
Thanks for the patch I was miss reading 3480 as 3840 before.
Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com # roc-rk3399-pc
Applied to u-boot-video/master.
-- Anatolij
Anatolij Gustschin
Jagan Teki
