[U-Boot-Users] [PATCH 15/17] Create new fdt boardsetup command, fix bug parsing [] form of set values.
Previously ft_board_setup() was called by fdt_chosen() which was not really correctly structured. This splits ft_board_setup() out by creating a new fdt boardsetup command.
Fix a bug when parsing fdt set command values which have the square bracket form [00 11 22 33] - the length was updated incorrectly in when parsing that form.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com --- common/cmd_fdt.c | 31 +++++++++++++++++++++---------- common/fdt_support.c | 15 --------------- 2 files changed, 21 insertions(+), 25 deletions(-)
diff --git a/common/cmd_fdt.c b/common/cmd_fdt.c index aa65297..2da1d72 100644 --- a/common/cmd_fdt.c +++ b/common/cmd_fdt.c @@ -37,7 +37,7 @@ #include <fdt_support.h>
#define MAX_LEVEL 32 /* how deeply nested we will go */ -#define SCRATCHPAD 1024 /* bytes of scratchpad memory */ +#define SCRATCHPAD 1024 /* bytes of scratchpad memory */
/* * Global data (for the gd->bd) @@ -47,6 +47,10 @@ DECLARE_GLOBAL_DATA_PTR; /* * Function prototypes/declarations. */ +#ifdef CONFIG_OF_BOARD_SETUP +void ft_board_setup(void *blob, bd_t *bd); +#endif + static int fdt_valid(void); static int fdt_parse_prop(char *pathp, char *prop, char *newval, char *data, int *len); @@ -297,6 +301,13 @@ int do_fdt (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) } }
+#ifdef CONFIG_OF_BOARD_SETUP + /******************************************************************** + * Call the board-specific fixup routine + ********************************************************************/ + } else if (argv[1][0] == 'b') { + ft_board_setup(fdt, gd->bd); +#endif /******************************************************************** * Create a chosen node ********************************************************************/ @@ -429,7 +440,7 @@ static int fdt_parse_prop(char *pathp, char *prop, char *newval, while ((*newval != ']') && (*newval != '\0')) { tmp = simple_strtoul(newval, &newval, 16); *data++ = tmp & 0xFF; - *len++; + *len = *len + 1; while (*newval == ' ') newval++; } @@ -673,25 +684,25 @@ U_BOOT_CMD( fdt, 5, 0, do_fdt, "fdt - flattened device tree utility commands\n", "addr <addr> [<length>] - Set the fdt location to <addr>\n" +#ifdef CONFIG_OF_BOARD_SETUP + "fdt boardsetup - Do board-specific set up\n" +#endif "fdt move <fdt> <newaddr> <length> - Copy the fdt to <addr>\n" "fdt print <path> [<prop>] - Recursive print starting at <path>\n" "fdt list <path> [<prop>] - Print one level starting at <path>\n" "fdt set <path> <prop> [<val>] - Set <property> [to <val>]\n" "fdt mknode <path> <node> - Create a new node after <path>\n" "fdt rm <path> [<prop>] - Delete the node or <property>\n" - "fdt chosen - Add/update the "/chosen" branch in the tree\n" + "fdt chosen - Add/update the /chosen branch in the tree\n" #ifdef CONFIG_OF_HAS_UBOOT_ENV - "fdt env - Add/replace the "/u-boot-env" branch in the tree\n" + "fdt env - Add/replace the /u-boot-env branch in the tree\n" #endif #ifdef CONFIG_OF_HAS_BD_T - "fdt bd_t - Add/replace the "/bd_t" branch in the tree\n" + "fdt bd_t - Add/replace the /bd_t branch in the tree\n" #endif "Hints:\n" - " * If the property you are setting/printing has a '#' character,\n" - " you MUST escape it with a \ character or quote it with " or\n" - " it will be ignored as a comment.\n" - " * If the value has spaces in it, you MUST escape the spaces with\n" - " \ characters or quote it with ""\n" + " If the property you are setting/printing has a '#' character or spaces,\n" + " you MUST escape it with a \ character or quote it with ".\n" "Examples: fdt print / # print the whole tree\n" " fdt print /cpus "#address-cells"\n" " fdt set /cpus "#address-cells" "[00 00 00 01]"\n" diff --git a/common/fdt_support.c b/common/fdt_support.c index ec04a63..259bd42 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -32,10 +32,6 @@ #include <libfdt.h> #include <fdt_support.h>
-#ifdef CONFIG_OF_BOARD_SETUP -void ft_board_setup(void *blob, bd_t *bd); -#endif - /* * Global data (for the gd->bd) */ @@ -62,17 +58,6 @@ int fdt_chosen(void *fdt, ulong initrd_start, ulong initrd_end, int force) return err; }
-#ifdef CONFIG_OF_BOARD_SETUP - /* - * ft_board_setup() sets various board-specific properties to - * the proper values. - * - * STRICTLY SPEAKING, this is out of place, but it isn't clear - * where a better place would be. - */ - ft_board_setup(fdt, bd); -#endif - if (initrd_start && initrd_end) { struct fdt_reserve_entry re; int used;
-#endif
Wasn't this code just added in an earlier patch in this series? :-)
Cheers, g.
-#endif
Cheers, g.
Yes, I took two steps - one to make it work and one to do it right and didn't go back and consolidate the two in the patches. Patch 15/17 adds the "fdt boardsetup" command which allowed me to remove this ugly.
Best regards, gvb
Grant Likely
Jerry Van Baren
