[U-Boot] [PATCH] am57xx: Remove unused variable warnings
Starting with the changes to fix USB host on am57xx/am43xx we stopped using usb_otg_ss1/related stuff and but we hadn't been enabling the relevant options to cause the warnings until just recently.
Fixes: 55efadde7ede (ARM: AM57xx: AM43xx: Fix USB host) Fixes: a48d687c575f (configs: am57xx: Enable download gadget) Signed-off-by: Tom Rini trini@konsulko.com --- board/ti/am57xx/board.c | 20 -------------------- 1 file changed, 20 deletions(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 64de60254136..f3e3f0bd3d60 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -447,26 +447,6 @@ int spl_start_uboot(void) #endif
#ifdef CONFIG_USB_DWC3 -static struct dwc3_device usb_otg_ss1 = { - .maximum_speed = USB_SPEED_SUPER, - .base = DRA7_USB_OTG_SS1_BASE, - .tx_fifo_resize = false, - .index = 0, -}; - -static struct dwc3_omap_device usb_otg_ss1_glue = { - .base = (void *)DRA7_USB_OTG_SS1_GLUE_BASE, - .utmi_mode = DWC3_OMAP_UTMI_MODE_SW, - .index = 0, -}; - -static struct ti_usb_phy_device usb_phy1_device = { - .pll_ctrl_base = (void *)DRA7_USB3_PHY1_PLL_CTRL, - .usb2_phy_power = (void *)DRA7_USB2_PHY1_POWER, - .usb3_phy_power = (void *)DRA7_USB3_PHY1_POWER, - .index = 0, -}; - static struct dwc3_device usb_otg_ss2 = { .maximum_speed = USB_SPEED_HIGH, .base = DRA7_USB_OTG_SS2_BASE,
