[U-Boot] [PATCH V2 1/2] pinctrl: imx: Introduce pinctrl driver for i.MX6
Introduce pinctrl for i.MX6 1. pinctrl-imx.c is for common usage. It's used by i.MX6/7. 2. Add PINCTRL_IMX PINCTRL_IMX6 Kconfig entry. 3. To the pinctrl_ops implementation, only set_state is implemented. To i.MX6/7, the pinctrl dts entry is as following: &iomuxc { pinctrl-names = "default";
pinctrl_csi1: csi1grp { fsl,pins = < MX6UL_PAD_CSI_MCLK__CSI_MCLK 0x1b088 MX6UL_PAD_CSI_PIXCLK__CSI_PIXCLK 0x1b088 MX6UL_PAD_CSI_VSYNC__CSI_VSYNC 0x1b088 >; };
[.....] }; there is no property named function or groups. So pinctrl_generic_set_state can not be used here. 5. This driver is a simple implementation for i.mx iomux controller, only parse the fsl,pins property and write value to registers. 6. With DEBUG enabled, we can see log when "i2c bus 0": " set_state_simple op missing imx_pinctrl_set_state: i2c1grp mux_reg 0x14c, conf_reg 0x3bc, input_reg 0x5d8, mux_mode 0x0, input_val 0x1, config_val 0x4000007f write mux: offset 0x14c val 0x10 select_input: offset 0x5d8 val 0x1 write config: offset 0x3bc val 0x7f mux_reg 0x148, conf_reg 0x3b8, input_reg 0x5d4, mux_mode 0x0, input_val 0x1, config_val 0x4000007f write mux: offset 0x148 val 0x10 select_input: offset 0x5d4 val 0x1 write config: offset 0x3b8 val 0x7f " this means imx6 pinctrl driver works as expected.
Signed-off-by: Peng Fan van.freenix@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
V2: Add more details in Kconfig entry Use fdt_getprop and fdtdec_get_int_array as suggested by Simon Add reviewed-by Simon Refer linux binding doc in code.
drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/nxp/Kconfig | 16 +++ drivers/pinctrl/nxp/Makefile | 2 + drivers/pinctrl/nxp/pinctrl-imx.c | 241 +++++++++++++++++++++++++++++++++++++ drivers/pinctrl/nxp/pinctrl-imx.h | 50 ++++++++ drivers/pinctrl/nxp/pinctrl-imx6.c | 41 +++++++ 7 files changed, 352 insertions(+) create mode 100644 drivers/pinctrl/nxp/Kconfig create mode 100644 drivers/pinctrl/nxp/Makefile create mode 100644 drivers/pinctrl/nxp/pinctrl-imx.c create mode 100644 drivers/pinctrl/nxp/pinctrl-imx.h create mode 100644 drivers/pinctrl/nxp/pinctrl-imx6.c
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 57e6142..9fd8f62 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -133,6 +133,7 @@ config PINCTRL_SANDBOX
endif
+source "drivers/pinctrl/nxp/Kconfig" source "drivers/pinctrl/uniphier/Kconfig"
endmenu diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 70d25dc..dcd20bf 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -5,6 +5,7 @@ obj-y += pinctrl-uclass.o obj-$(CONFIG_$(SPL_)PINCTRL_GENERIC) += pinctrl-generic.o
+obj-y += nxp/ obj-$(CONFIG_ARCH_ROCKCHIP) += rockchip/ obj-$(CONFIG_PINCTRL_SANDBOX) += pinctrl-sandbox.o
diff --git a/drivers/pinctrl/nxp/Kconfig b/drivers/pinctrl/nxp/Kconfig new file mode 100644 index 0000000..f1c9b92 --- /dev/null +++ b/drivers/pinctrl/nxp/Kconfig @@ -0,0 +1,16 @@ +config PINCTRL_IMX + bool + +config PINCTRL_IMX6 + bool "IMX6 pinctrl driver" + depends on ARCH_MX6 && PINCTRL_FULL + select DEVRES + select PINCTRL_IMX + help + Say Y here to enable the imx6 pinctrl driver + + This provides a simple pinctrl driver for i.MX6 SoC familiy, + i.MX6DQ/SL/SX/UL/DQP. This feature depends on device tree + configuration. This driver is different from the linux one, + this is a simple implementation, only parses the 'fsl,pins' + property and configure related registers. diff --git a/drivers/pinctrl/nxp/Makefile b/drivers/pinctrl/nxp/Makefile new file mode 100644 index 0000000..7fd9850 --- /dev/null +++ b/drivers/pinctrl/nxp/Makefile @@ -0,0 +1,2 @@ +obj-$(CONFIG_PINCTRL_IMX) += pinctrl-imx.o +obj-$(CONFIG_PINCTRL_IMX6) += pinctrl-imx6.o diff --git a/drivers/pinctrl/nxp/pinctrl-imx.c b/drivers/pinctrl/nxp/pinctrl-imx.c new file mode 100644 index 0000000..40b0616 --- /dev/null +++ b/drivers/pinctrl/nxp/pinctrl-imx.c @@ -0,0 +1,241 @@ +/* + * Copyright (C) 2016 Peng Fan van.freenix@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <mapmem.h> +#include <linux/io.h> +#include <linux/err.h> +#include <dm/device.h> +#include <dm/pinctrl.h> + +#include "pinctrl-imx.h" + +DECLARE_GLOBAL_DATA_PTR; + +static int imx_pinctrl_set_state(struct udevice *dev, struct udevice *config) +{ + struct imx_pinctrl_priv *priv = dev_get_priv(dev); + struct imx_pinctrl_soc_info *info = priv->info; + int node = config->of_offset; + const struct fdt_property *prop; + u32 *pin_data; + int npins, size, pin_size; + int mux_reg, conf_reg, input_reg, input_val, mux_mode, config_val; + int i, j = 0; + + dev_dbg(dev, "%s: %s\n", __func__, config->name); + + if (info->flags & SHARE_MUX_CONF_REG) + pin_size = SHARE_FSL_PIN_SIZE; + else + pin_size = FSL_PIN_SIZE; + + prop = fdt_getprop(gd->fdt_blob, node, "fsl,pins", &size); + if (!prop) { + dev_err(dev, "No fsl,pins property in node %s\n", config->name); + return -EINVAL; + } + + if (!size || size % pin_size) { + dev_err(dev, "Invalid fsl,pins property in node %s\n", + config->name); + return -EINVAL; + } + + pin_data = devm_kzalloc(dev, size, 0); + if (!pin_data) + return -ENOMEM; + + if (fdtdec_get_int_array(gd->fdt_blob, node, "fsl,pins", + pin_data, size >> 2)) { + dev_err(dev, "Error reading pin data.\n"); + return -EINVAL; + } + + npins = size / pin_size; + + /* + * Refer to linux documentation for details: + * Documentation/devicetree/bindings/pinctrl/fsl,imx-pinctrl.txt + */ + for (i = 0; i < npins; i++) { + mux_reg = pin_data[j++]; + + if (!(info->flags & ZERO_OFFSET_VALID) && !mux_reg) + mux_reg = -1; + + if (info->flags & SHARE_MUX_CONF_REG) { + conf_reg = mux_reg; + } else { + conf_reg = pin_data[j++]; + if (!(info->flags & ZERO_OFFSET_VALID) && !conf_reg) + conf_reg = -1; + } + + if ((mux_reg == -1) || (conf_reg == -1)) { + dev_err(dev, "Error mux_reg or conf_reg\n"); + return -EINVAL; + } + + input_reg = pin_data[j++]; + mux_mode = pin_data[j++]; + input_val = pin_data[j++]; + config_val = pin_data[j++]; + + dev_dbg(dev, "mux_reg 0x%x, conf_reg 0x%x, input_reg 0x%x, " + "mux_mode 0x%x, input_val 0x%x, config_val 0x%x\n", + mux_reg, conf_reg, input_reg, mux_mode, input_val, + config_val); + + if (config_val & IMX_PAD_SION) + mux_mode |= IOMUXC_CONFIG_SION; + + config_val &= ~IMX_PAD_SION; + + /* Set Mux */ + if (info->flags & SHARE_MUX_CONF_REG) { + clrsetbits_le32(info->base + mux_reg, 0x7 << 20, + mux_mode << 20); + } else { + writel(mux_mode, info->base + mux_reg); + } + + dev_dbg(dev, "write mux: offset 0x%x val 0x%x\n", mux_reg, + mux_mode); + + /* + * Set select input + * + * If the select input value begins with 0xff, it's a quirky + * select input and the value should be interpreted as below. + * 31 23 15 7 0 + * | 0xff | shift | width | select | + * It's used to work around the problem that the select + * input for some pin is not implemented in the select + * input register but in some general purpose register. + * We encode the select input value, width and shift of + * the bit field into input_val cell of pin function ID + * in device tree, and then decode them here for setting + * up the select input bits in general purpose register. + */ + + if (input_val >> 24 == 0xff) { + u32 val = input_val; + u8 select = val & 0xff; + u8 width = (val >> 8) & 0xff; + u8 shift = (val >> 16) & 0xff; + u32 mask = ((1 << width) - 1) << shift; + /* + * The input_reg[i] here is actually some IOMUXC general + * purpose register, not regular select input register. + */ + val = readl(info->base + input_reg); + val &= ~mask; + val |= select << shift; + writel(val, info->base + input_reg); + } else if (input_reg) { + /* + * Regular select input register can never be at offset + * 0, and we only print register value for regular case. + */ + if (info->input_sel_base) + writel(input_val, info->input_sel_base + + input_reg); + else + writel(input_val, info->base + input_reg); + + dev_dbg(dev, "select_input: offset 0x%x val 0x%x\n", + input_reg, input_val); + } + + /* Set config */ + if (!(config_val & IMX_NO_PAD_CTL)) { + if (info->flags & SHARE_MUX_CONF_REG) { + clrsetbits_le32(info->base + conf_reg, 0xffff, + config_val); + } else { + writel(config_val, info->base + conf_reg); + } + + dev_dbg(dev, "write config: offset 0x%x val 0x%x\n", + conf_reg, config_val); + } + } + + return 0; +} + +const struct pinctrl_ops imx_pinctrl_ops = { + .set_state = imx_pinctrl_set_state, +}; + +int imx_pinctrl_probe(struct udevice *dev, + struct imx_pinctrl_soc_info *info) +{ + struct imx_pinctrl_priv *priv = dev_get_priv(dev); + int node = dev->of_offset, ret; + struct fdtdec_phandle_args arg; + fdt_addr_t addr; + fdt_size_t size; + + if (!info) { + dev_err(dev, "wrong pinctrl info\n"); + return -EINVAL; + } + + priv->dev = dev; + priv->info = info; + + addr = fdtdec_get_addr_size(gd->fdt_blob, dev->of_offset, "reg", &size); + + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + info->base = map_sysmem(addr, size); + if (!info->base) + return -ENOMEM; + priv->info = info; + + /* + * Refer to linux documentation for details: + * Documentation/devicetree/bindings/pinctrl/fsl,imx7d-pinctrl.txt + */ + if (fdtdec_get_bool(gd->fdt_blob, node, "fsl,input-sel")) { + ret = fdtdec_parse_phandle_with_args(gd->fdt_blob, + node, "fsl,input-sel", + NULL, 0, 0, &arg); + if (ret) { + dev_err(dev, "iomuxc fsl,input-sel property not found\n"); + return -EINVAL; + } + + addr = fdtdec_get_addr_size(gd->fdt_blob, arg.node, "reg", + &size); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + info->input_sel_base = map_sysmem(addr, size); + if (!info->input_sel_base) + return -ENOMEM; + } + + dev_info(dev, "initialized IMX pinctrl driver\n"); + + return 0; +} + +int imx_pinctrl_remove(struct udevice *dev) +{ + struct imx_pinctrl_priv *priv = dev_get_priv(dev); + struct imx_pinctrl_soc_info *info = priv->info; + + if (info->input_sel_base) + unmap_sysmem(info->input_sel_base); + if (info->base) + unmap_sysmem(info->base); + + return 0; +} diff --git a/drivers/pinctrl/nxp/pinctrl-imx.h b/drivers/pinctrl/nxp/pinctrl-imx.h new file mode 100644 index 0000000..037c491 --- /dev/null +++ b/drivers/pinctrl/nxp/pinctrl-imx.h @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2016 Peng Fan van.freenix@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __DRIVERS_PINCTRL_IMX_H +#define __DRIVERS_PINCTRL_IMX_H + +/** + * @base: the address to the controller in virtual memory + * @input_sel_base: the address of the select input in virtual memory. + * @flags: flags specific for each soc + */ +struct imx_pinctrl_soc_info { + void __iomem *base; + void __iomem *input_sel_base; + unsigned int flags; +}; + +/** + * @dev: a pointer back to containing device + * @info: the soc info + */ +struct imx_pinctrl_priv { + struct udevice *dev; + struct imx_pinctrl_soc_info *info; +}; + +extern const struct pinctrl_ops imx_pinctrl_ops; + +#define IMX_NO_PAD_CTL 0x80000000 /* no pin config need */ +#define IMX_PAD_SION 0x40000000 /* set SION */ + +/* + * Each pin represented in fsl,pins consists of 5 u32 PIN_FUNC_ID and + * 1 u32 CONFIG, so 24 types in total for each pin. + */ +#define FSL_PIN_SIZE 24 +#define SHARE_FSL_PIN_SIZE 20 + +#define SHARE_MUX_CONF_REG 0x1 +#define ZERO_OFFSET_VALID 0x2 + +#define IOMUXC_CONFIG_SION (0x1 << 4) + +int imx_pinctrl_probe(struct udevice *dev, struct imx_pinctrl_soc_info *info); + +int imx_pinctrl_remove(struct udevice *dev); +#endif /* __DRIVERS_PINCTRL_IMX_H */ diff --git a/drivers/pinctrl/nxp/pinctrl-imx6.c b/drivers/pinctrl/nxp/pinctrl-imx6.c new file mode 100644 index 0000000..24f139e --- /dev/null +++ b/drivers/pinctrl/nxp/pinctrl-imx6.c @@ -0,0 +1,41 @@ + +/* + * Copyright (C) 2016 Peng Fan van.freenix@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dm/device.h> +#include <dm/pinctrl.h> + +#include "pinctrl-imx.h" + +static struct imx_pinctrl_soc_info imx6_pinctrl_soc_info; + +static int imx6_pinctrl_probe(struct udevice *dev) +{ + struct imx_pinctrl_soc_info *info = + (struct imx_pinctrl_soc_info *)dev_get_driver_data(dev); + + return imx_pinctrl_probe(dev, info); +} + +static const struct udevice_id imx6_pinctrl_match[] = { + { .compatible = "fsl,imx6q-iomuxc", .data = (ulong)&imx6_pinctrl_soc_info }, + { .compatible = "fsl,imx6dl-iomuxc", .data = (ulong)&imx6_pinctrl_soc_info }, + { .compatible = "fsl,imx6sl-iomuxc", .data = (ulong)&imx6_pinctrl_soc_info }, + { .compatible = "fsl,imx6sx-iomuxc", .data = (ulong)&imx6_pinctrl_soc_info }, + { .compatible = "fsl,imx6ul-iomuxc", .data = (ulong)&imx6_pinctrl_soc_info }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(imx6_pinctrl) = { + .name = "imx6-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(imx6_pinctrl_match), + .probe = imx6_pinctrl_probe, + .remove = imx_pinctrl_remove, + .priv_auto_alloc_size = sizeof(struct imx_pinctrl_priv), + .ops = &imx_pinctrl_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Introudce i.MX7 pinctrl driver support. For now only i.MX7D supported. There are two iomux controllers in i.MX7D, iomuxc and iomuxc_lpsr. To iomuxc_lpsr, ZERO_OFFSET_VALID is set, means offset of mux_reg and conf_reg can begin at 0.
V2: Add more details in Kconfig entry Add Simon's reviewed-by
drivers/pinctrl/nxp/Kconfig | 14 +++++++++++++ drivers/pinctrl/nxp/Makefile | 1 + drivers/pinctrl/nxp/pinctrl-imx7.c | 41 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 56 insertions(+) create mode 100644 drivers/pinctrl/nxp/pinctrl-imx7.c
diff --git a/drivers/pinctrl/nxp/Kconfig b/drivers/pinctrl/nxp/Kconfig index f1c9b92..35640f0 100644 --- a/drivers/pinctrl/nxp/Kconfig +++ b/drivers/pinctrl/nxp/Kconfig @@ -14,3 +14,17 @@ config PINCTRL_IMX6 configuration. This driver is different from the linux one, this is a simple implementation, only parses the 'fsl,pins' property and configure related registers. + +config PINCTRL_IMX7 + bool "IMX7 pinctrl driver" + depends on ARCH_MX7 && PINCTRL_FULL + select DEVRES + select PINCTRL_IMX + help + Say Y here to enable the imx7 pinctrl driver + + This provides a simple pinctrl driver for i.MX7 SoC familiy, + i.MX7D. This feature depends on device tree + configuration. This driver is different from the linux one, + this is a simple implementation, only parses the 'fsl,pins' + property and configure related registers. diff --git a/drivers/pinctrl/nxp/Makefile b/drivers/pinctrl/nxp/Makefile index 7fd9850..0ee7f2f 100644 --- a/drivers/pinctrl/nxp/Makefile +++ b/drivers/pinctrl/nxp/Makefile @@ -1,2 +1,3 @@ obj-$(CONFIG_PINCTRL_IMX) += pinctrl-imx.o obj-$(CONFIG_PINCTRL_IMX6) += pinctrl-imx6.o +obj-$(CONFIG_PINCTRL_IMX7) += pinctrl-imx7.o diff --git a/drivers/pinctrl/nxp/pinctrl-imx7.c b/drivers/pinctrl/nxp/pinctrl-imx7.c new file mode 100644 index 0000000..eeb7942 --- /dev/null +++ b/drivers/pinctrl/nxp/pinctrl-imx7.c @@ -0,0 +1,41 @@ +/* + * Copyright (C) 2016 Peng Fan van.freenix@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dm/device.h> +#include <dm/pinctrl.h> + +#include "pinctrl-imx.h" + +static struct imx_pinctrl_soc_info imx7_pinctrl_soc_info; + +static struct imx_pinctrl_soc_info imx7_lpsr_pinctrl_soc_info = { + .flags = ZERO_OFFSET_VALID, +}; + +static int imx7_pinctrl_probe(struct udevice *dev) +{ + struct imx_pinctrl_soc_info *info = + (struct imx_pinctrl_soc_info *)dev_get_driver_data(dev); + + return imx_pinctrl_probe(dev, info); +} + +static const struct udevice_id imx7_pinctrl_match[] = { + { .compatible = "fsl,imx7d-iomuxc", .data = (ulong)&imx7_pinctrl_soc_info }, + { .compatible = "fsl,imx7d-iomuxc-lpsr", .data = (ulong)&imx7_lpsr_pinctrl_soc_info }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(imx7_pinctrl) = { + .name = "imx7-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(imx7_pinctrl_match), + .probe = imx7_pinctrl_probe, + .remove = imx_pinctrl_remove, + .priv_auto_alloc_size = sizeof(struct imx_pinctrl_priv), + .ops = &imx_pinctrl_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Hi Simon,
Gentle ping..
Thanks, Peng.
- pinctrl-imx.c is for common usage. It's used by i.MX6/7.
- Add PINCTRL_IMX PINCTRL_IMX6 Kconfig entry.
- To the pinctrl_ops implementation, only set_state is implemented.
pinctrl_csi1: csi1grp { fsl,pins = < MX6UL_PAD_CSI_MCLK__CSI_MCLK 0x1b088 MX6UL_PAD_CSI_PIXCLK__CSI_PIXCLK 0x1b088 MX6UL_PAD_CSI_VSYNC__CSI_VSYNC 0x1b088 >; }; [.....]
endif
- bool
- bool "IMX6 pinctrl driver"
- depends on ARCH_MX6 && PINCTRL_FULL
- select DEVRES
- select PINCTRL_IMX
- help
- Copyright (C) 2016 Peng Fan van.freenix@gmail.com
- struct imx_pinctrl_priv *priv = dev_get_priv(dev);
- struct imx_pinctrl_soc_info *info = priv->info;
- int node = config->of_offset;
- const struct fdt_property *prop;
- u32 *pin_data;
- int npins, size, pin_size;
- int mux_reg, conf_reg, input_reg, input_val, mux_mode, config_val;
- int i, j = 0;
- dev_dbg(dev, "%s: %s\n", __func__, config->name);
- if (info->flags & SHARE_MUX_CONF_REG)
- else
- prop = fdt_getprop(gd->fdt_blob, node, "fsl,pins", &size);
- if (!prop) {
return -EINVAL;
- if (!size || size % pin_size) {
config->name);
return -EINVAL;
- pin_data = devm_kzalloc(dev, size, 0);
- if (!pin_data)
return -ENOMEM;
- if (fdtdec_get_int_array(gd->fdt_blob, node, "fsl,pins",
return -EINVAL;
- npins = size / pin_size;
- for (i = 0; i < npins; i++) {
mux_reg = -1;
conf_reg = mux_reg;
} else {
conf_reg = -1;
return -EINVAL;
config_val);
/* Set Mux */
mux_mode << 20);
} else {
mux_mode);
* Set select input
* 31 23 15 7 0
val &= ~mask;
input_reg);
else
/* Set config */
config_val);
} else {
- .set_state = imx_pinctrl_set_state,
- int node = dev->of_offset, ret;
- struct fdtdec_phandle_args arg;
- fdt_addr_t addr;
- fdt_size_t size;
- if (!info) {
return -EINVAL;
- priv->dev = dev;
- priv->info = info;
- addr = fdtdec_get_addr_size(gd->fdt_blob, dev->of_offset, "reg", &size);
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- info->base = map_sysmem(addr, size);
- if (!info->base)
return -ENOMEM;
- if (fdtdec_get_bool(gd->fdt_blob, node, "fsl,input-sel")) {
NULL, 0, 0, &arg);
if (ret) {
return -EINVAL;
&size);
return -EINVAL;
return -ENOMEM;
- dev_info(dev, "initialized IMX pinctrl driver\n");
- if (info->input_sel_base)
- if (info->base)
- @base: the address to the controller in virtual memory
- @input_sel_base: the address of the select input in virtual memory.
- @flags: flags specific for each soc
- void __iomem *base;
- void __iomem *input_sel_base;
- unsigned int flags;
- @dev: a pointer back to containing device
- @info: the soc info
- struct udevice *dev;
- struct imx_pinctrl_soc_info *info;
- Each pin represented in fsl,pins consists of 5 u32 PIN_FUNC_ID and
- 1 u32 CONFIG, so 24 types in total for each pin.
- return imx_pinctrl_probe(dev, info);
- { .compatible = "fsl,imx6q-iomuxc", .data = (ulong)&imx6_pinctrl_soc_info },
- { .compatible = "fsl,imx6dl-iomuxc", .data = (ulong)&imx6_pinctrl_soc_info },
- { .compatible = "fsl,imx6sl-iomuxc", .data = (ulong)&imx6_pinctrl_soc_info },
- { .compatible = "fsl,imx6sx-iomuxc", .data = (ulong)&imx6_pinctrl_soc_info },
- { .compatible = "fsl,imx6ul-iomuxc", .data = (ulong)&imx6_pinctrl_soc_info },
- { /* sentinel */ }
- .name = "imx6-pinctrl",
- .id = UCLASS_PINCTRL,
- .of_match = of_match_ptr(imx6_pinctrl_match),
- .probe = imx6_pinctrl_probe,
- .remove = imx_pinctrl_remove,
- .priv_auto_alloc_size = sizeof(struct imx_pinctrl_priv),
- .ops = &imx_pinctrl_ops,
- .flags = DM_FLAG_PRE_RELOC,
2.6.2
Hi Peng,
On 15 February 2016 at 01:33, Peng Fan van.freenix@gmail.com wrote:
Hi Simon,
Gentle ping..
Do you mean Stefan? I reviewed the previous so did not think it necessary to look again.
Thanks, Peng.
endif
bool
select DEVRES
select PINCTRL_IMX
help
u32 *pin_data;
int i, j = 0;
else
if (!prop) {
return -EINVAL;
config->name);
return -EINVAL;
if (!pin_data)
return -ENOMEM;
return -EINVAL;
mux_reg = -1;
conf_reg = mux_reg;
} else {
conf_reg = -1;
return -EINVAL;
config_val);
/* Set Mux */
mux_mode << 20);
} else {
mux_mode);
* Set select input
* 31 23 15 7 0
val &= ~mask;
input_reg);
else
/* Set config */
config_val);
} else {
fdt_addr_t addr;
fdt_size_t size;
if (!info) {
return -EINVAL;
priv->dev = dev;
priv->info = info;
return -EINVAL;
if (!info->base)
return -ENOMEM;
priv->info = info;
NULL, 0, 0, &arg);
if (ret) {
return -EINVAL;
&size);
return -EINVAL;
return -ENOMEM;
if (info->base)
void __iomem *base;
unsigned int flags;
{ /* sentinel */ }
2.6.2
Hi Simon,
On Tue, Feb 16, 2016 at 09:00:55AM -0700, Simon Glass wrote:
Hi Peng,
Hi Simon,
Gentle ping..
In this V2 version, I addressed your comments for V1. Not sure whether it's ok from your side :). This patch set was here for nearly two weeks. If it's ok for you, please merge this patch set :).
Thanks, Peng.
Thanks, Peng.
endif
bool
select DEVRES
select PINCTRL_IMX
help
u32 *pin_data;
int i, j = 0;
else
if (!prop) {
return -EINVAL;
config->name);
return -EINVAL;
if (!pin_data)
return -ENOMEM;
return -EINVAL;
mux_reg = -1;
conf_reg = mux_reg;
} else {
conf_reg = -1;
return -EINVAL;
config_val);
/* Set Mux */
mux_mode << 20);
} else {
mux_mode);
* Set select input
* 31 23 15 7 0
val &= ~mask;
input_reg);
else
/* Set config */
config_val);
} else {
fdt_addr_t addr;
fdt_size_t size;
if (!info) {
return -EINVAL;
priv->dev = dev;
priv->info = info;
return -EINVAL;
if (!info->base)
return -ENOMEM;
priv->info = info;
NULL, 0, 0, &arg);
if (ret) {
return -EINVAL;
&size);
return -EINVAL;
return -ENOMEM;
if (info->base)
void __iomem *base;
unsigned int flags;
{ /* sentinel */ }
2.6.2
Hi Peng,
On 16 February 2016 at 19:45, Peng Fan van.freenix@gmail.com wrote:
Hi Simon,
Hi Peng,
Hi Simon,
Gentle ping..
I can certainly do this, but shouldn't it go through the freescale tree?
[snip]
Hi Simon,
On Tue, Feb 16, 2016 at 07:50:25PM -0700, Simon Glass wrote:
Hi Peng,
Hi Simon,
Hi Peng,
Hi Simon,
Gentle ping..
I just think you are the owner of driver model tree :) imx tree or your tree, both are ok for me.
Stefano, do you have time to review the patch set and merge?
Thanks, Peng.
[snip]
On 17/02/2016 06:23, Peng Fan wrote:
Hi Simon,
Hi Peng,
Hi Simon,
Hi Peng,
Hi Simon,
Gentle ping..
Thanks, Peng.
Fine with me - I apply it to u-boot-imx, thanks !
Best regards, Stefano Babic
Peng Fan
Stefano Babic
