[U-Boot-Users] Patch: MII support for MPC8260ADS board
12 Jun
2003
12 Jun
'03
1:50 p.m.
I added MII command support to MPC8260ADS U-Boot port. Also on this board, Ethernet PHY is configured by means of configuration pins in such a way that it does not work at 100Mb/s. This patch fixes the problem.
Yuli Barcohen | Phone +972-9-765-1788 | Software Project Leader
yuli@arabellasw.com | Fax +972-9-765-7494 | Arabella Software, Israel
--- board/mpc8260ads/mpc8260ads.c 2003-06-12 12:23:46.000000000 +0300
+++ Arabella/u-boot/board/mpc8260ads/mpc8260ads.c 2003-06-11 16:49:05.000000000 +0300
@@ -9,6 +9,10 @@
* (C) Copyright 2001, Stuart Hughes, Lineo Inc, stuarth@lineo.com
* Added support for the 16M dram simm on the 8260ads boards
+ * (C) Copyright 2003 Arabella Software Ltd.
+ * Yuli Barcohen yuli@arabellasw.com
+ * Added support for SDRAM DIMMs SPD EEPROM, MII, Ethernet PHY init.
* See file CREDITS for list of people who contributed to this
* project.
@@ -33,6 +37,7 @@
#include <mpc8260.h>
#include <i2c.h>
#include <spd.h>
+#include <miiphy.h>
* I/O Port configuration table
@@ -129,8 +134,8 @@ const iop_conf_t iop_conf_tab[4][32] = {
/* PC22 */ { 0, 1, 0, 0, 0, 0 }, /* ATMRFCLK */
/* PC21 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 EN RXCLK */
/* PC20 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 EN TXCLK */
- /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_CLK CLK13 */
- /* PC18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC Tx Clock (CLK14) */
+ /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII Rx Clock (CLK13) */
+ /* PC18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII Tx Clock (CLK14) */
/* PC17 */ { 0, 0, 0, 1, 0, 0 }, /* PC17 */
/* PC16 */ { 0, 1, 0, 0, 0, 0 }, /* FCC Tx Clock (CLK16) */
/* PC15 */ { 0, 0, 0, 1, 0, 0 }, /* PC15 */
@@ -138,8 +143,8 @@ const iop_conf_t iop_conf_tab[4][32] = {
/* PC13 */ { 0, 0, 0, 1, 0, 0 }, /* PC13 */
/* PC12 */ { 0, 1, 0, 1, 0, 0 }, /* PC12 */
/* PC11 */ { 0, 0, 0, 1, 0, 0 }, /* LXT971 transmit control */
- /* PC10 */ { 1, 1, 0, 0, 0, 0 }, /* LXT970 FETHMDC */
- /* PC9 */ { 1, 1, 0, 0, 0, 0 }, /* LXT970 FETHMDIO */
+ /* PC10 */ { 1, 0, 0, 1, 0, 0 }, /* LXT970 FETHMDC */
+ /* PC9 */ { 1, 0, 0, 0, 0, 0 }, /* LXT970 FETHMDIO */
/* PC8 */ { 0, 0, 0, 1, 0, 0 }, /* PC8 */
/* PC7 */ { 0, 0, 0, 1, 0, 0 }, /* PC7 */
/* PC6 */ { 0, 0, 0, 1, 0, 0 }, /* PC6 */
@@ -153,8 +158,8 @@ const iop_conf_t iop_conf_tab[4][32] = {
/* Port D */
{ /* conf ppar psor pdir podr pdat */
- /* PD31 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 EN RxD */
- /* PD30 */ { 1, 1, 1, 1, 0, 0 }, /* SCC1 EN TxD */
+ /* PD31 */ { 1, 1, 0, 0, 0, 0 }, /* SCC1 UART RxD */
+ /* PD30 */ { 1, 1, 1, 1, 0, 0 }, /* SCC1 UART TxD */
/* PD29 */ { 0, 1, 0, 1, 0, 0 }, /* SCC1 EN TENA */
/* PD28 */ { 0, 1, 0, 0, 0, 0 }, /* PD28 */
/* PD27 */ { 0, 1, 1, 1, 0, 0 }, /* PD27 */
@@ -169,14 +174,14 @@ const iop_conf_t iop_conf_tab[4][32] = {
/* PD18 */ { 0, 0, 0, 1, 0, 0 }, /* PD18 */
/* PD17 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 ATMRXPRTY */
/* PD16 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 ATMTXPRTY */
- /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */
- /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */
+ /* PD15 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SDA */
+ /* PD14 */ { 1, 1, 1, 0, 1, 0 }, /* I2C SCL */
/* PD13 */ { 0, 0, 0, 0, 0, 0 }, /* PD13 */
/* PD12 */ { 0, 0, 0, 0, 0, 0 }, /* PD12 */
/* PD11 */ { 0, 0, 0, 0, 0, 0 }, /* PD11 */
/* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */
- /* PD9 */ { 1, 1, 0, 1, 0, 0 }, /* SMC1 TXD */
- /* PD8 */ { 1, 1, 0, 0, 0, 0 }, /* SMC1 RXD */
+ /* PD9 */ { 0, 1, 0, 1, 0, 0 }, /* SMC1 TXD */
+ /* PD8 */ { 0, 1, 0, 0, 0, 0 }, /* SMC1 RXD */
/* PD7 */ { 0, 0, 0, 1, 0, 1 }, /* PD7 */
/* PD6 */ { 0, 0, 0, 1, 0, 1 }, /* PD6 */
/* PD5 */ { 0, 0, 0, 1, 0, 1 }, /* PD5 */
@@ -188,32 +193,33 @@ const iop_conf_t iop_conf_tab[4][32] = {
-typedef struct bscr_ {
- unsigned long bcsr0;
- unsigned long bcsr1;
- unsigned long bcsr2;
- unsigned long bcsr3;
- unsigned long bcsr4;
- unsigned long bcsr5;
- unsigned long bcsr6;
- unsigned long bcsr7;
-} bcsr_t;
void reset_phy (void)
- volatile bcsr_t *bcsr = (bcsr_t *) CFG_BCSR;
+ vu_long *bcsr = (vu_long *)CFG_BCSR;
/* reset the FEC port */
- bcsr->bcsr1 &= ~FETH_RST;
- bcsr->bcsr1 |= FETH_RST;
+ bcsr[1] &= ~FETH_RST;
+ udelay(2);
+ bcsr[1] |= FETH_RST;
+ udelay(1000);
+#ifdef CONFIG_MII
+ * Ethernet PHY is configured (by means of configuration pins)
+ * to work at 10Mb/s only. We reconfigure it using MII
+ * to advertise all capabilities, including 100Mb/s, and
+ * restart autonegotiation.
+ miiphy_write(0, PHY_ANAR, 0x01E1); /* Advertise all capabilities */
+ miiphy_write(0, PHY_DCR, 0x0000); /* Do not bypass Rx/Tx (de)scrambler */
+ miiphy_write(0, PHY_BMCR, PHY_BMCR_AUTON | PHY_BMCR_RST_NEG);
+#endif /* CONFIG_MII */
int board_pre_init (void)
- bcsr->bcsr1 = ~FETHIEN & ~RS232EN_1;
+ bcsr[1] = ~FETHIEN & ~RS232EN_1;
* Stuart Hughes stuarth@lineo.com
* This file is based on similar values for other boards found in other
* U-Boot config files, and some that I found in the mpc8260ads manual.
* Note: my board is a PILOT rev.
* Note: the mpc8260ads doesn't come with a proper Ethernet MAC address.
* project.
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston,
* MA 02111-1307 USA
* Config header file for a MPC8260ADS Pilot 16M Ram Simm, 8Mbytes Flash Simm
#ifndef __CONFIG_H
#define __CONFIG_H
* High Level Configuration Options
* (easy to change)
#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */
#define CONFIG_MPC8260ADS 1 /* ...on motorola ads board */
#define CONFIG_BOARD_PRE_INIT 1 /* Call board_pre_init */
/* allow serial and ethaddr to be overwritten */
#define CONFIG_ENV_OVERWRITE
* select serial console configuration
* if either CONFIG_CONS_ON_SMC or CONFIG_CONS_ON_SCC is selected, then
* CONFIG_CONS_INDEX must be set to the channel number (1-2 for SMC, 1-4
* for SCC).
* if CONFIG_CONS_NONE is defined, then the serial console routines must
* defined elsewhere (for example, on the cogent platform, there are serial
* ports on the motherboard which are used for the serial console - see
* cogent/cma101/serial.[ch]).
#undef CONFIG_CONS_ON_SMC /* define if console on SMC */
#define CONFIG_CONS_ON_SCC /* define if console on SCC */
#undef CONFIG_CONS_NONE /* define if console on something else */
#define CONFIG_CONS_INDEX 1 /* which serial channel for console */
* select ethernet configuration
* if either CONFIG_ETHER_ON_SCC or CONFIG_ETHER_ON_FCC is selected, then
* CONFIG_ETHER_INDEX must be set to the channel number (1-4 for SCC, 1-3
* for FCC)
* if CONFIG_ETHER_NONE is defined, then either the ethernet routines must be
* defined elsewhere (as for the console), or CFG_CMD_NET must be removed
* from CONFIG_COMMANDS to remove support for networking.
#undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */
#define CONFIG_ETHER_ON_FCC /* define if ether on FCC */
#undef CONFIG_ETHER_NONE /* define if ether on something else */
#define CONFIG_ETHER_INDEX 2 /* which channel for ether */
#if (CONFIG_ETHER_INDEX == 2)
* - Rx-CLK is CLK13
* - Tx-CLK is CLK14
* - Select bus for bd/buffers (see 28-13)
* - Half duplex
# define CFG_CMXFCR_MASK (CMXFCR_FC2 | CMXFCR_RF2CS_MSK | CMXFCR_TF2CS_MSK)
# define CFG_CMXFCR_VALUE (CMXFCR_RF2CS_CLK13 | CMXFCR_TF2CS_CLK14)
# define CFG_CPMFCR_RAMTYPE 0
# define CFG_FCC_PSMR 0
#endif /* CONFIG_ETHER_INDEX */
/* other options */
#define CONFIG_HARD_I2C 1 /* To enable I2C support */
#define CFG_I2C_SPEED 400000 /* I2C speed and slave address */
#define CFG_I2C_SLAVE 0x7F
#if defined(CONFIG_SPD_EEPROM) && !defined(CONFIG_SPD_ADDR)
#define CONFIG_SPD_ADDR 0x50
#endif
#ifndef CONFIG_SDRAM_PBI
#define CONFIG_SDRAM_PBI 1 /* By default, use page-based interleaving */
#endif
#ifndef CONFIG_8260_CLKIN
#define CONFIG_8260_CLKIN 66666666 /* in Hz */
#endif
#define CONFIG_BAUDRATE 115200
#define CONFIG_COMMANDS (CFG_CMD_ALL & ~( \
CFG_CMD_BEDBUG | \
CFG_CMD_BMP | \
CFG_CMD_BSP | \
CFG_CMD_DATE | \
CFG_CMD_DOC | \
CFG_CMD_DTT | \
CFG_CMD_EEPROM | \
CFG_CMD_ELF | \
CFG_CMD_FDC | \
CFG_CMD_FDOS | \
CFG_CMD_HWFLOW | \
CFG_CMD_IDE | \
CFG_CMD_JFFS2 | \
CFG_CMD_KGDB | \
CFG_CMD_NAND | \
CFG_CMD_MII | \
CFG_CMD_PCI | \
CFG_CMD_PCMCIA | \
CFG_CMD_SCSI | \
CFG_CMD_SPI | \
CFG_CMD_VFD | \
CFG_CMD_USB ) )
/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */
#include <cmd_confdefs.h>
#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */
#define CONFIG_BOOTCOMMAND "bootm 100000" /* autoboot command */
#define CONFIG_BOOTARGS "root=/dev/ram rw"
#if (CONFIG_COMMANDS & CFG_CMD_KGDB)
#undef CONFIG_KGDB_ON_SMC /* define if kgdb on SMC */
#define CONFIG_KGDB_ON_SCC /* define if kgdb on SCC */
#undef CONFIG_KGDB_NONE /* define if kgdb on something else */
#define CONFIG_KGDB_INDEX 2 /* which serial channel for kgdb */
#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port at */
#endif
#undef CONFIG_WATCHDOG /* disable platform specific watchdog */
* Miscellaneous configurable options
#define CFG_LONGHELP /* undef to save memory */
#define CFG_PROMPT "=> " /* Monitor Command Prompt */
#define CFG_CBSIZE 1024 /* Console I/O Buffer Size */
#else
#define CFG_CBSIZE 256 /* Console I/O Buffer Size */
#endif
#define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */
#define CFG_MAXARGS 16 /* max number of command args */
#define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */
#define CFG_MEMTEST_START 0x00100000 /* memtest works on */
#define CFG_MEMTEST_END 0x00f00000 /* 1 ... 15 MB in DRAM */
#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */
/* for versions < 2.4.5-pre5 */
#define CFG_LOAD_ADDR 0x100000 /* default load address */
#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */
#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
#define CFG_FLASH_BASE 0xff800000
#define FLASH_BASE 0xff800000
#define CFG_MAX_FLASH_BANKS 1 /* max num of memory banks */
#define CFG_MAX_FLASH_SECT 32 /* max num of sects on one chip */
#define CFG_FLASH_SIZE 8
#define CFG_FLASH_ERASE_TOUT 8000 /* Timeout for Flash Erase (in ms) */
#define CFG_FLASH_WRITE_TOUT 5 /* Timeout for Flash Write (in ms) */
/* this is stuff came out of the Motorola docs */
#define CFG_DEFAULT_IMMR 0x0F010000
#define CFG_IMMR 0xF0000000
#define CFG_BCSR 0x04500000
#define CFG_SDRAM_BASE 0x00000000
#define CFG_LSDRAM_BASE 0x04000000
#define RS232EN_1 0x02000002
#define RS232EN_2 0x01000001
#define FETHIEN 0x08000008
#define FETH_RST 0x04000004
#define CFG_INIT_RAM_ADDR CFG_IMMR
#define CFG_INIT_RAM_END 0x4000 /* End of used area in DPRAM */
#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */
#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE)
#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET
/* 0x0EA28205 */
#define CFG_HRCW_MASTER ( ( HRCW_BPS11 | HRCW_CIP ) |\
( HRCW_L2CPC10 | HRCW_DPPC10 | HRCW_ISB010 ) |\
( HRCW_BMS | HRCW_APPC10 ) |\
( HRCW_MODCK_H0101 ) \
/* no slaves */
#define CFG_HRCW_SLAVE1 0
#define CFG_HRCW_SLAVE2 0
#define CFG_HRCW_SLAVE3 0
#define CFG_HRCW_SLAVE4 0
#define CFG_HRCW_SLAVE5 0
#define CFG_HRCW_SLAVE6 0
#define CFG_HRCW_SLAVE7 0
#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */
#define BOOTFLAG_WARM 0x02 /* Software reboot */
#define CFG_MONITOR_BASE TEXT_BASE
#if (CFG_MONITOR_BASE < CFG_FLASH_BASE)
# define CFG_RAMBOOT
#endif
#define CFG_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */
#define CFG_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */
#define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
#ifndef CFG_RAMBOOT
# define CFG_ENV_IS_IN_FLASH 1
# define CFG_ENV_ADDR (CFG_MONITOR_BASE + 0x40000)
# define CFG_ENV_SECT_SIZE 0x40000
#else
# define CFG_ENV_IS_IN_NVRAM 1
# define CFG_ENV_ADDR (CFG_MONITOR_BASE - 0x1000)
# define CFG_ENV_SIZE 0x200
#endif /* CFG_RAMBOOT */
#define CFG_CACHELINE_SIZE 32 /* For MPC8260 CPU */
# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */
#endif
#define CFG_HID0_INIT 0
#define CFG_HID0_FINAL (HID0_ICE | HID0_IFEM | HID0_ABE )
#define CFG_HID2 0
#define CFG_SYPCR 0xFFFFFFC3
#define CFG_BCR 0x100C0000
#define CFG_SIUMCR 0x0A200000
#define CFG_SCCR 0x00000000
#define CFG_BR0_PRELIM 0xFF801801
#define CFG_OR0_PRELIM 0xFF800836
#define CFG_BR1_PRELIM 0x04501801
#define CFG_OR1_PRELIM 0xFFFF8010
#define CFG_RMR 0
#define CFG_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE)
#define CFG_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE)
#define CFG_RCCR 0
#define CFG_PSDMR 0x016EB452
#define CFG_MPTPR 0x00001900
#define CFG_PSRT 0x00000021
#define CFG_RESET_ADDRESS 0x04400000
#endif /* __CONFIG_H */
- Add MII support for MPC8260ADS board
- Fix Ethernet PHY initialisation for MPC8260ADS board to allow 100Mb/s
full-duplex work
19 Jun
19 Jun
9:22 p.m.
Thanks, added.
Software Engineering: Embedded and Realtime Systems, Embedded Linux
Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de
No question is too silly to ask. Of course, some questions are too
silly to to answer... - L. Wall & R. L. Schwartz, _Programming Perl_
7994
1 comments
2 participants
Yuli Barcohen
