[U-Boot] [PATCH] serial: lpc32xx hsuart: port driver to driver model
The change ports NXP LPC32xx 14-clock UART device driver to driver model.
Signed-off-by: Vladimir Zapolskiy vz@mleia.com --- drivers/serial/lpc32xx_hsuart.c | 103 +++++++++++++++++++----------- include/dm/platform_data/lpc32xx_hsuart.h | 18 ++++++ 2 files changed, 82 insertions(+), 39 deletions(-) create mode 100644 include/dm/platform_data/lpc32xx_hsuart.h
diff --git a/drivers/serial/lpc32xx_hsuart.c b/drivers/serial/lpc32xx_hsuart.c index c8926a8..c199c9b 100644 --- a/drivers/serial/lpc32xx_hsuart.c +++ b/drivers/serial/lpc32xx_hsuart.c @@ -1,89 +1,114 @@ /* - * Copyright (C) 2011 Vladimir Zapolskiy vz@mleia.com + * Copyright (C) 2011-2015 Vladimir Zapolskiy vz@mleia.com * * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> -#include <asm/arch/cpu.h> -#include <asm/arch/clk.h> -#include <asm/arch/uart.h> -#include <asm/io.h> +#include <dm.h> +#include <dm/platform_data/lpc32xx_hsuart.h> #include <serial.h> + +#include <asm/arch/uart.h> #include <linux/compiler.h>
DECLARE_GLOBAL_DATA_PTR;
-static struct hsuart_regs *hsuart = (struct hsuart_regs *)HS_UART_BASE; +struct lpc32xx_hsuart_priv { + struct hsuart_regs *hsuart; +};
-static void lpc32xx_serial_setbrg(void) +static int lpc32xx_serial_setbrg(struct udevice *dev, int baudrate) { + struct lpc32xx_hsuart_priv *priv = dev_get_priv(dev); + struct hsuart_regs *hsuart = priv->hsuart; u32 div;
/* UART rate = PERIPH_CLK / ((HSU_RATE + 1) x 14) */ - div = (get_serial_clock() / 14 + gd->baudrate / 2) / gd->baudrate - 1; + div = (get_serial_clock() / 14 + baudrate / 2) / baudrate - 1; if (div > 255) div = 255;
writel(div, &hsuart->rate); + + return 0; }
-static int lpc32xx_serial_getc(void) +static int lpc32xx_serial_getc(struct udevice *dev) { - while (!(readl(&hsuart->level) & HSUART_LEVEL_RX)) - /* NOP */; + struct lpc32xx_hsuart_priv *priv = dev_get_priv(dev); + struct hsuart_regs *hsuart = priv->hsuart; + + if (!(readl(&hsuart->level) & HSUART_LEVEL_RX)) + return -EAGAIN;
return readl(&hsuart->rx) & HSUART_RX_DATA; }
-static void lpc32xx_serial_putc(const char c) +static int lpc32xx_serial_putc(struct udevice *dev, const char c) { - if (c == '\n') - serial_putc('\r'); + struct lpc32xx_hsuart_priv *priv = dev_get_priv(dev); + struct hsuart_regs *hsuart = priv->hsuart; + + /* Wait for empty FIFO */ + if (readl(&hsuart->level) & HSUART_LEVEL_TX) + return -EAGAIN;
writel(c, &hsuart->tx);
- /* Wait for character to be sent */ - while (readl(&hsuart->level) & HSUART_LEVEL_TX) - /* NOP */; + return 0; }
-static int lpc32xx_serial_tstc(void) +static int lpc32xx_serial_pending(struct udevice *dev, bool input) { - if (readl(&hsuart->level) & HSUART_LEVEL_RX) - return 1; + struct lpc32xx_hsuart_priv *priv = dev_get_priv(dev); + struct hsuart_regs *hsuart = priv->hsuart; + + if (input) { + if (readl(&hsuart->level) & HSUART_LEVEL_RX) + return 1; + } else { + if (readl(&hsuart->level) & HSUART_LEVEL_TX) + return 1; + }
return 0; }
-static int lpc32xx_serial_init(void) +static int lpc32xx_serial_init(struct hsuart_regs *hsuart) { - lpc32xx_serial_setbrg(); - /* Disable hardware RTS and CTS flow control, set up RX and TX FIFO */ writel(HSUART_CTRL_TMO_16 | HSUART_CTRL_HSU_OFFSET(20) | HSUART_CTRL_HSU_RX_TRIG_32 | HSUART_CTRL_HSU_TX_TRIG_0, &hsuart->ctrl); + return 0; }
-static struct serial_device lpc32xx_serial_drv = { - .name = "lpc32xx_serial", - .start = lpc32xx_serial_init, - .stop = NULL, +static int lpc32xx_hsuart_probe(struct udevice *dev) +{ + struct lpc32xx_hsuart_platdata *platdata = dev_get_platdata(dev); + struct lpc32xx_hsuart_priv *priv = dev_get_priv(dev); + + priv->hsuart = (struct hsuart_regs *)platdata->base; + + lpc32xx_serial_init(priv->hsuart); + + return 0; +} + +static const struct dm_serial_ops lpc32xx_hsuart_ops = { .setbrg = lpc32xx_serial_setbrg, - .putc = lpc32xx_serial_putc, - .puts = default_serial_puts, .getc = lpc32xx_serial_getc, - .tstc = lpc32xx_serial_tstc, + .putc = lpc32xx_serial_putc, + .pending = lpc32xx_serial_pending, };
-void lpc32xx_serial_initialize(void) -{ - serial_register(&lpc32xx_serial_drv); -} - -__weak struct serial_device *default_serial_console(void) -{ - return &lpc32xx_serial_drv; -} +U_BOOT_DRIVER(lpc32xx_hsuart) = { + .name = "lpc32xx_hsuart", + .id = UCLASS_SERIAL, + .probe = lpc32xx_hsuart_probe, + .ops = &lpc32xx_hsuart_ops, + .priv_auto_alloc_size = sizeof(struct lpc32xx_hsuart_priv), + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/dm/platform_data/lpc32xx_hsuart.h b/include/dm/platform_data/lpc32xx_hsuart.h new file mode 100644 index 0000000..fd191b5 --- /dev/null +++ b/include/dm/platform_data/lpc32xx_hsuart.h @@ -0,0 +1,18 @@ +/* + * Copyright (c) 2015 Vladimir Zapolskiy vz@mleia.com + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _LPC32XX_HSUART_PLAT_H +#define _LPC32XX_HSUART_PLAT_H + +/** + * struct lpc32xx_hsuart_platdata - NXP LPC32xx HSUART platform data + * + * @base: Base register address + */ +struct lpc32xx_hsuart_platdata { + unsigned long base; +}; + +#endif
Hi Vladimir,
I'm going to hold off applying this for -next right now. Can you please resend it along with the related patches once you update them?
Hi Simon,
On 19.12.2015 22:30, Simon Glass wrote:
Hi Vladimir,
do you want to see the driver update with the mach changes in one series?
FWIW I think this serial driver change is independent and can be applied first, but for your convenience I'll gather the changes together.
With best wishes, Vladimir
Vladimir Zapolskiy
