[U-Boot] [PATCH v3] spi: Add SPI driver for MT76xx SoCs
This patch adds the SPI driver for the MediaTek MT7688 SoC (and derivates). Its been tested on the LinkIt Smart 7688 and the Gardena Smart Gateway with and SPI NOR on CS0 and on the Gardena Smart Gateway additionally with an SPI NAND on CS1.
Note that the SPI controller only supports a max transfer size of 32 bytes. This driver implementes a workaround to enable bigger xfer sizes to speed up the transfer especially for the SPI NAND support.
Signed-off-by: Stefan Roese sr@denx.de Cc: Jagan Teki jagan@openedev.com Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Reviewed-by: Jagan Teki jagan@openedev.com --- v3: - Drop IO wrappers completely as suggested by Daniel - Read "clock-frequency" DT property instead of using CONFIG_SYS_MIPS_TIMER_FREQ
v2: - Add some macros instead of hardcoded numbers - Move compatible DT struct down in the file
drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/mt76xx_spi.c | 312 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 321 insertions(+) create mode 100644 drivers/spi/mt76xx_spi.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 9fbd26740d..6c4e50d3e9 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -116,6 +116,14 @@ config ICH_SPI access the SPI NOR flash on platforms embedding this Intel ICH IP core.
+config MT76XX_SPI + bool "MediaTek MT76XX SPI driver" + depends on ARCH_MT7620 + help + Enable the MT76XX SPI driver. This driver can be used to access + the SPI NOR flash on platforms embedding these MediaTek + SPI cores. + config MVEBU_A3700_SPI bool "Marvell Armada 3700 SPI driver" select CLK_ARMADA_3720 diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index bdb5b5a02f..3d13ba1b21 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -33,6 +33,7 @@ obj-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o obj-$(CONFIG_LPC32XX_SSP) += lpc32xx_ssp.o obj-$(CONFIG_MPC8XX_SPI) += mpc8xx_spi.o obj-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o +obj-$(CONFIG_MT76XX_SPI) += mt76xx_spi.o obj-$(CONFIG_MVEBU_A3700_SPI) += mvebu_a3700_spi.o obj-$(CONFIG_MXC_SPI) += mxc_spi.o obj-$(CONFIG_MXS_SPI) += mxs_spi.o diff --git a/drivers/spi/mt76xx_spi.c b/drivers/spi/mt76xx_spi.c new file mode 100644 index 0000000000..094a5756eb --- /dev/null +++ b/drivers/spi/mt76xx_spi.c @@ -0,0 +1,312 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Stefan Roese sr@denx.de + * + * Derived from the Linux driver version drivers/spi/spi-mt7621.c + * Copyright (C) 2011 Sergiy piratfm@gmail.com + * Copyright (C) 2011-2013 Gabor Juhos juhosg@openwrt.org + * Copyright (C) 2014-2015 Felix Fietkau nbd@nbd.name + */ + +#include <common.h> +#include <dm.h> +#include <spi.h> +#include <wait_bit.h> +#include <linux/io.h> + +#define SPI_MSG_SIZE_MAX 32 /* SPI message chunk size */ +/* Enough for SPI NAND page read / write with page size 2048 bytes */ +#define SPI_MSG_SIZE_OVERALL (2048 + 16) + +#define MT7621_SPI_TRANS 0x00 +#define MT7621_SPI_TRANS_START BIT(8) +#define MT7621_SPI_TRANS_BUSY BIT(16) + +#define MT7621_SPI_OPCODE 0x04 +#define MT7621_SPI_DATA0 0x08 +#define MT7621_SPI_DATA4 0x18 +#define MT7621_SPI_MASTER 0x28 +#define MT7621_SPI_MOREBUF 0x2c +#define MT7621_SPI_POLAR 0x38 + +#define MT7621_LSB_FIRST BIT(3) +#define MT7621_CPOL BIT(4) +#define MT7621_CPHA BIT(5) + +#define MASTER_MORE_BUFMODE BIT(2) +#define MASTER_RS_CLK_SEL GENMASK(27, 16) +#define MASTER_RS_CLK_SEL_SHIFT 16 +#define MASTER_RS_SLAVE_SEL GENMASK(31, 29) + +struct mt7621_spi { + void __iomem *base; + unsigned int sys_freq; + u32 data[(SPI_MSG_SIZE_OVERALL / 4) + 1]; + int tx_len; +}; + +static void mt7621_spi_reset(struct mt7621_spi *rs, int duplex) +{ + setbits_le32(rs->base + MT7621_SPI_MASTER, + MASTER_RS_SLAVE_SEL | MASTER_MORE_BUFMODE); +} + +static void mt7621_spi_set_cs(struct mt7621_spi *rs, int cs, int enable) +{ + u32 val = 0; + + debug("%s: cs#%d -> %s\n", __func__, cs, enable ? "enable" : "disable"); + if (enable) + val = BIT(cs); + iowrite32(val, rs->base + MT7621_SPI_POLAR); +} + +static int mt7621_spi_set_mode(struct udevice *bus, uint mode) +{ + struct mt7621_spi *rs = dev_get_priv(bus); + u32 reg; + + debug("%s: mode=0x%08x\n", __func__, mode); + reg = ioread32(rs->base + MT7621_SPI_MASTER); + + reg &= ~MT7621_LSB_FIRST; + if (mode & SPI_LSB_FIRST) + reg |= MT7621_LSB_FIRST; + + reg &= ~(MT7621_CPHA | MT7621_CPOL); + switch (mode & (SPI_CPOL | SPI_CPHA)) { + case SPI_MODE_0: + break; + case SPI_MODE_1: + reg |= MT7621_CPHA; + break; + case SPI_MODE_2: + reg |= MT7621_CPOL; + break; + case SPI_MODE_3: + reg |= MT7621_CPOL | MT7621_CPHA; + break; + } + iowrite32(reg, rs->base + MT7621_SPI_MASTER); + + return 0; +} + +static int mt7621_spi_set_speed(struct udevice *bus, uint speed) +{ + struct mt7621_spi *rs = dev_get_priv(bus); + u32 rate; + u32 reg; + + debug("%s: speed=%d\n", __func__, speed); + rate = DIV_ROUND_UP(rs->sys_freq, speed); + debug("rate:%u\n", rate); + + if (rate > 4097) + return -EINVAL; + + if (rate < 2) + rate = 2; + + reg = ioread32(rs->base + MT7621_SPI_MASTER); + reg &= ~MASTER_RS_CLK_SEL; + reg |= (rate - 2) << MASTER_RS_CLK_SEL_SHIFT; + iowrite32(reg, rs->base + MT7621_SPI_MASTER); + + return 0; +} + +static inline int mt7621_spi_wait_till_ready(struct mt7621_spi *rs) +{ + int ret; + + ret = wait_for_bit_le32(rs->base + MT7621_SPI_TRANS, + MT7621_SPI_TRANS_BUSY, 0, 10, 0); + if (ret) + pr_err("Timeout in %s!\n", __func__); + + return ret; +} + +static int mt7621_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct mt7621_spi *rs = dev_get_priv(bus); + const u8 *tx_buf = dout; + u8 *ptr = (u8 *)dout; + u8 *rx_buf = din; + int total_size = bitlen >> 3; + int chunk_size; + int rx_len = 0; + u32 data[(SPI_MSG_SIZE_MAX / 4) + 1] = { 0 }; + u32 val; + int i; + + debug("%s: dout=%p, din=%p, len=%x, flags=%lx\n", __func__, dout, din, + total_size, flags); + + /* + * This driver only supports half-duplex, so complain and bail out + * upon full-duplex messages + */ + if (dout && din) { + printf("Only half-duplex SPI transfer supported\n"); + return -EIO; + } + + if (dout) { + debug("TX-DATA: "); + for (i = 0; i < total_size; i++) + debug("%02x ", *ptr++); + debug("\n"); + } + + mt7621_spi_wait_till_ready(rs); + + /* + * Set CS active upon start of SPI message. This message can + * be split upon multiple calls to this xfer function + */ + if (flags & SPI_XFER_BEGIN) + mt7621_spi_set_cs(rs, spi_chip_select(dev), 1); + + while (total_size > 0) { + /* Don't exceed the max xfer size */ + chunk_size = min_t(int, total_size, SPI_MSG_SIZE_MAX); + + /* + * We might have some TX data buffered from the last xfer + * message. Make sure, that this does not exceed the max + * xfer size + */ + if (rs->tx_len > 4) + chunk_size -= rs->tx_len; + if (din) + rx_len = chunk_size; + + if (tx_buf) { + /* Check if this message does not exceed the buffer */ + if ((chunk_size + rs->tx_len) > SPI_MSG_SIZE_OVERALL) { + printf("TX message size too big (%d)\n", + chunk_size + rs->tx_len); + return -EMSGSIZE; + } + + /* + * Write all TX data into internal buffer to collect + * all TX messages into one buffer (might be split into + * multiple calls to this function) + */ + for (i = 0; i < chunk_size; i++, rs->tx_len++) { + rs->data[rs->tx_len / 4] |= + tx_buf[i] << (8 * (rs->tx_len & 3)); + } + } + + if (flags & SPI_XFER_END) { + /* Write TX data into controller */ + if (rs->tx_len) { + rs->data[0] = swab32(rs->data[0]); + if (rs->tx_len < 4) + rs->data[0] >>= (4 - rs->tx_len) * 8; + + for (i = 0; i < rs->tx_len; i += 4) { + iowrite32(rs->data[i / 4], rs->base + + MT7621_SPI_OPCODE + i); + } + } + + /* Write length into controller */ + val = (min_t(int, rs->tx_len, 4) * 8) << 24; + if (rs->tx_len > 4) + val |= (rs->tx_len - 4) * 8; + val |= (rx_len * 8) << 12; + iowrite32(val, rs->base + MT7621_SPI_MOREBUF); + + /* Start the xfer */ + setbits_le32(rs->base + MT7621_SPI_TRANS, + MT7621_SPI_TRANS_START); + + /* Wait until xfer is finished on bus */ + mt7621_spi_wait_till_ready(rs); + + /* Reset TX length and TX buffer for next xfer */ + rs->tx_len = 0; + memset(rs->data, 0, sizeof(rs->data)); + } + + for (i = 0; i < rx_len; i += 4) + data[i / 4] = ioread32(rs->base + MT7621_SPI_DATA0 + i); + + if (rx_len) { + debug("RX-DATA: "); + for (i = 0; i < rx_len; i++) { + rx_buf[i] = data[i / 4] >> (8 * (i & 3)); + debug("%02x ", rx_buf[i]); + } + debug("\n"); + } + + if (tx_buf) + tx_buf += chunk_size; + if (rx_buf) + rx_buf += chunk_size; + total_size -= chunk_size; + } + + /* Wait until xfer is finished on bus and de-assert CS */ + mt7621_spi_wait_till_ready(rs); + if (flags & SPI_XFER_END) + mt7621_spi_set_cs(rs, spi_chip_select(dev), 0); + + return 0; +} + +static int mt76xx_spi_probe(struct udevice *dev) +{ + struct mt7621_spi *rs = dev_get_priv(dev); + + rs->base = dev_remap_addr(dev); + if (!rs->base) + return -EINVAL; + + /* + * Read input clock via DT for now. At some point this should be + * replaced by implementing a clock driver for this SoC and getting + * the SPI frequency via this clock driver. + */ + rs->sys_freq = dev_read_u32_default(dev, "clock-frequency", 0); + if (!rs->sys_freq) { + printf("Please provide clock-frequency!\n"); + return -EINVAL; + } + + mt7621_spi_reset(rs, 0); + + return 0; +} + +static const struct dm_spi_ops mt7621_spi_ops = { + .set_mode = mt7621_spi_set_mode, + .set_speed = mt7621_spi_set_speed, + .xfer = mt7621_spi_xfer, + /* + * cs_info is not needed, since we require all chip selects to be + * in the device tree explicitly + */ +}; + +static const struct udevice_id mt76xx_spi_ids[] = { + { .compatible = "ralink,mt7621-spi" }, + { } +}; + +U_BOOT_DRIVER(mt76xx_spi) = { + .name = "mt76xx_spi", + .id = UCLASS_SPI, + .of_match = mt76xx_spi_ids, + .ops = &mt7621_spi_ops, + .priv_auto_alloc_size = sizeof(struct mt7621_spi), + .probe = mt76xx_spi_probe, +};
Stefan Roese
