[U-Boot] [PATCH 1/3] net: eth-uclass: Write MAC address to hardware after probe
In order for the device to use the proper MAC address, which can have been configured in the environment prior to the device being registered, ensure that the MAC address is written after the device has been probed. For devices that are registered before the network stack is initialized, this is already done during eth_initialize(). If the Ethernet device is on a bus that is not initialized on early boot, such as PCI, the device is not available at the time eth_initialize() is called, so we need the MAC address programming to also happen after probe.
Signed-off-by: Thierry Reding treding@nvidia.com --- net/eth-uclass.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 2ef20df19203..4225aabf1fa1 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -524,6 +524,8 @@ static int eth_post_probe(struct udevice *dev) #endif }
+ eth_write_hwaddr(dev); + return 0; }
Implement this callback that allows the MAC address to be set for the Ethernet card. This is necessary in order for the device to be able to receive packets for the MAC address that U-Boot advertises.
Signed-off-by: Thierry Reding treding@nvidia.com --- drivers/net/rtl8169.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index a78f3d233f1a..27e27b34176b 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -941,6 +941,23 @@ static void rtl_halt(struct eth_device *dev) } #endif
+#ifdef CONFIG_DM_ETH +static int rtl8169_write_hwaddr(struct udevice *dev) +{ + struct eth_pdata *plat = dev_get_platdata(dev); + unsigned int i; + + RTL_W8(Cfg9346, Cfg9346_Unlock); + + for (i = 0; i < MAC_ADDR_LEN; i++) + RTL_W8(MAC0 + i, plat->enetaddr[i]); + + RTL_W8(Cfg9346, Cfg9346_Lock); + + return 0; +} +#endif + /************************************************************************** INIT - Look for an adapter, this routine's visible to the outside ***************************************************************************/ @@ -1195,6 +1212,7 @@ static const struct eth_ops rtl8169_eth_ops = { .send = rtl8169_eth_send, .recv = rtl8169_eth_recv, .stop = rtl8169_eth_stop, + .write_hwaddr = rtl8169_write_hwaddr, };
static const struct udevice_id rtl8169_eth_ids[] = {
This version of the RTL-8168 is present on some development boards and is compatible with this driver. Add support for identifying this version of the chip so that U-Boot won't complain about it being unknown.
Signed-off-by: Thierry Reding treding@nvidia.com --- drivers/net/rtl8169.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index 27e27b34176b..bc052e72564b 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -257,6 +257,7 @@ static struct { {"RTL-8168/8111g", 0x4c, 0xff7e1880,}, {"RTL-8101e", 0x34, 0xff7e1880,}, {"RTL-8100e", 0x32, 0xff7e1880,}, + {"RTL-8168h/8111h", 0x54, 0xff7e1880,}, };
enum _DescStatusBit {
Thierry Reding
