[U-Boot] [U-Boot v3] usb: xhci: Fix vendor command error if the request type is USB_REQ_SET_ADDRESS or USB_REQ_SET_CONFIGURATION.
Add test into xhci_submit_control_message for usb requesttype in USB vendor request being of standardized type. This fixes detection of certain USB fixes, for example Ethernet, USB 3.0 port. Non standardized requesttype in USB vendor request will be ignored.
Signed-off-by: Ted Chen tedchen@realtek.com Tested-by: Anand Moon linux.amoon@gmail.com --- Changes logs: v3: Fixed the commit message and bad format of the patch. core changes none. v2: Resend this patch it some how got missed. core changes none.
Tested on Odroid-XU4 with R8153 Ethernet port. --- drivers/usb/host/xhci.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/xhci.c b/drivers/usb/host/xhci.c index ca598aa..cb8a04b 100644 --- a/drivers/usb/host/xhci.c +++ b/drivers/usb/host/xhci.c @@ -941,10 +941,12 @@ static int _xhci_submit_control_msg(struct usb_device *udev, unsigned long pipe, if (usb_pipedevice(pipe) == ctrl->rootdev) return xhci_submit_root(udev, pipe, buffer, setup);
- if (setup->request == USB_REQ_SET_ADDRESS) + if (setup->request == USB_REQ_SET_ADDRESS && + (setup->requesttype & USB_TYPE_MASK) == USB_TYPE_STANDARD) return xhci_address_device(udev, root_portnr);
- if (setup->request == USB_REQ_SET_CONFIGURATION) { + if (setup->request == USB_REQ_SET_CONFIGURATION && + (setup->requesttype & USB_TYPE_MASK) == USB_TYPE_STANDARD) { ret = xhci_set_configuration(udev); if (ret) { puts("Failed to configure xHCI endpoint\n");
Applied, thanks!
Best regards, Marek Vasut
Anand Moon
