[U-Boot] [PATCH v2] power: extend prefix match to regulator-name property
This patch extends pmic_bind_children prefix matching. In addition to the node name the property regulator-name is used while trying to match prefixes. This allows assigning different drivers to regulator nodes named regulator@1 and regulator@10 for example. I have discarded the idea of using other properties then regulator-name as I do not see any benefit in using property compatible or even regulator-compatible. Of course I am open to change this if there are good reasons to do so.
Signed-off-by: Felix Brack fb@ltec.ch ---
Changes in v2: - add documentation - add a regulator to the sandbox for testing - extend the test for the new sandbox regulator
arch/sandbox/dts/sandbox_pmic.dtsi | 6 ++++++ doc/device-tree-bindings/regulator/regulator.txt | 16 ++++++++++++++-- drivers/power/pmic/pmic-uclass.c | 15 +++++++++++++-- include/power/sandbox_pmic.h | 5 ++++- test/dm/regulator.c | 2 ++ 5 files changed, 39 insertions(+), 5 deletions(-)
diff --git a/arch/sandbox/dts/sandbox_pmic.dtsi b/arch/sandbox/dts/sandbox_pmic.dtsi index ce261b9..acb4799 100644 --- a/arch/sandbox/dts/sandbox_pmic.dtsi +++ b/arch/sandbox/dts/sandbox_pmic.dtsi @@ -75,4 +75,10 @@ regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; }; + + no_match_by_nodename { + regulator-name = "buck_SUPPLY_1.5V"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + }; }; diff --git a/doc/device-tree-bindings/regulator/regulator.txt b/doc/device-tree-bindings/regulator/regulator.txt index 918711e..65b69c4 100644 --- a/doc/device-tree-bindings/regulator/regulator.txt +++ b/doc/device-tree-bindings/regulator/regulator.txt @@ -2,7 +2,8 @@ Voltage/Current regulator
Binding: The regulator devices don't use the "compatible" property. The binding is done -by the prefix of regulator node's name. Usually the pmic I/O driver will provide +by the prefix of regulator node's name, or, if this fails, by the prefix of the +regulator's "regulator-name" property. Usually the pmic I/O driver will provide the array of 'struct pmic_child_info' with the prefixes and compatible drivers. The bind is done by calling function: pmic_bind_childs(). Example drivers: @@ -15,8 +16,19 @@ For the node name e.g.: "prefix[:alpha:]num { ... }":
Example the prefix "ldo" will pass for: "ldo1", "ldo@1", "ldoreg@1, ...
+Binding by means of the node's name is preferred. However if the node names +would produce ambiguous prefixes (like "regulator@1" and "regualtor@11") and you +can't or do not want to change them then binding against the "regulator-name" +property is possible. The syntax for the prefix of the "regulator-name" property +is the same as the one for the regulator's node name. +Use case: a regulator named "regulator@1" to be bound to a driver named +"LDO_DRV" and a regulator named "regualator@11" to be bound to an other driver +named "BOOST_DRV". Using prefix "regualtor@1" for driver matching would load +the same driver for both regulators, hence the prefix is ambiguous. + Optional properties: -- regulator-name: a string, required by the regulator uclass +- regulator-name: a string, required by the regulator uclass, used for driver + binding if binding by node's name prefix fails - regulator-min-microvolt: a minimum allowed Voltage value - regulator-max-microvolt: a maximum allowed Voltage value - regulator-min-microamp: a minimum allowed Current value diff --git a/drivers/power/pmic/pmic-uclass.c b/drivers/power/pmic/pmic-uclass.c index 64964e4..5a034f0 100644 --- a/drivers/power/pmic/pmic-uclass.c +++ b/drivers/power/pmic/pmic-uclass.c @@ -26,6 +26,7 @@ int pmic_bind_children(struct udevice *pmic, ofnode parent, struct driver *drv; struct udevice *child; const char *node_name; + const char *reg_name; int bind_count = 0; ofnode node; int prefix_len; @@ -44,8 +45,18 @@ int pmic_bind_children(struct udevice *pmic, ofnode parent, debug(" - compatible prefix: '%s'\n", info->prefix);
prefix_len = strlen(info->prefix); - if (strncmp(info->prefix, node_name, prefix_len)) - continue; + if (strncmp(info->prefix, node_name, prefix_len)) { + reg_name = ofnode_read_string(node, + "regulator-name"); + if (reg_name) { + if (strncmp(info->prefix, reg_name, + prefix_len)) { + continue; + } + } else { + continue; + } + }
drv = lists_driver_lookup_name(info->driver); if (!drv) { diff --git a/include/power/sandbox_pmic.h b/include/power/sandbox_pmic.h index 7fdbfb9..da2c296 100644 --- a/include/power/sandbox_pmic.h +++ b/include/power/sandbox_pmic.h @@ -13,7 +13,7 @@ #define SANDBOX_BUCK_DRIVER "sandbox_buck" #define SANDBOX_OF_BUCK_PREFIX "buck"
-#define SANDBOX_BUCK_COUNT 2 +#define SANDBOX_BUCK_COUNT 3 #define SANDBOX_LDO_COUNT 2 /* * Sandbox PMIC registers: @@ -114,6 +114,9 @@ enum { #define SANDBOX_LDO1_PLATNAME "VDD_EMMC_1.8V" #define SANDBOX_LDO2_DEVNAME "ldo2" #define SANDBOX_LDO2_PLATNAME "VDD_LCD_3.3V" +/* BUCK3: for testing fallback regulator prefix matching during bind */ +#define SANDBOX_BUCK3_DEVNAME "no_match_by_nodename" +#define SANDBOX_BUCK3_PLATNAME "buck_SUPPLY_1.5V"
/* * Expected regulators setup after call of: diff --git a/test/dm/regulator.c b/test/dm/regulator.c index 3d0056f..395381d 100644 --- a/test/dm/regulator.c +++ b/test/dm/regulator.c @@ -27,6 +27,7 @@ DECLARE_GLOBAL_DATA_PTR; enum { BUCK1, BUCK2, + BUCK3, LDO1, LDO2, OUTPUT_COUNT, @@ -42,6 +43,7 @@ static const char *regulator_names[OUTPUT_COUNT][OUTPUT_NAME_COUNT] = { /* devname, platname */ { SANDBOX_BUCK1_DEVNAME, SANDBOX_BUCK1_PLATNAME }, { SANDBOX_BUCK2_DEVNAME, SANDBOX_BUCK2_PLATNAME }, + { SANDBOX_BUCK3_DEVNAME, SANDBOX_BUCK3_PLATNAME }, { SANDBOX_LDO1_DEVNAME, SANDBOX_LDO1_PLATNAME}, { SANDBOX_LDO2_DEVNAME, SANDBOX_LDO2_PLATNAME}, };
Changes in v2:
- add documentation
- no_match_by_nodename {
- const char *reg_name; int bind_count = 0; ofnode node; int prefix_len;
continue;
"regulator-name");
if (reg_name) {
prefix_len)) {
continue;
} else {
continue;
}The below code is more readable?
if (!reg_name) continue;
if (strncmp()) continue;
how about?
} drv = lists_driver_lookup_name(info->driver); if (!drv) {
- Sandbox PMIC registers:
These defined might be located on above point. (SANDBOX_BUCK2_xxxx)
Best Regards, Jaehoon Chung
- Expected regulators setup after call of:
- BUCK3, LDO1, LDO2, OUTPUT_COUNT,
- { SANDBOX_BUCK3_DEVNAME, SANDBOX_BUCK3_PLATNAME }, { SANDBOX_LDO1_DEVNAME, SANDBOX_LDO1_PLATNAME}, { SANDBOX_LDO2_DEVNAME, SANDBOX_LDO2_PLATNAME},
Changes in v2:
- add documentation
continue;
"regulator-name");
if (reg_name) {
prefix_len)) {
continue;
} else {
continue;
how about?
Agreed. Looks much better and is simpler to read. If somebody insists on this modification that's fine with me and I will present a v3 patch.
Yes of course. But the idea of putting them here is to emphasize the special name due to binding against regulator-name property, kind of separating this BUCK regulator from 'normal' BUCK regulators.
regards, Felix
Changes in v2:
- add documentation
Felix Brack
Jaehoon Chung
