[U-Boot] [PATCH v2 14/18] rockchip: pinctrl: rk322x: Move the iomux definitions into pinctrl-driver
Spam detection software, running on the system "lists.denx.de", has identified this incoming email as possible spam. The original message has been attached to this so you can view it or label similar future email. If you have any questions, see @@CONTACT_ADDRESS@@ for details.
Content preview: Clean the iomux definitions at grf_rk322x.h, and move them into pinctrl-driver for resolving the compiling error of redefinition. After that, define the uart2 iomux at rk322x-board file. Signed-off-by: David Wu david.wu@rock-chips.com --- [...]
Content analysis details: (6.5 points, 5.0 required)
pts rule name description ---- ---------------------- -------------------------------------------------- 0.6 RCVD_IN_SORBS_WEB RBL: SORBS: sender is an abusable web server [58.22.7.114 listed in dnsbl.sorbs.net] 2.7 RCVD_IN_PSBL RBL: Received via a relay in PSBL [211.157.147.133 listed in psbl.surriel.com] 2.4 RCVD_IN_MSPIKE_L5 RBL: Very bad reputation (-5) [211.157.147.133 listed in bl.mailspike.net] 0.8 UPPERCASE_50_75 message body is 50-75% uppercase 0.0 RCVD_IN_MSPIKE_BL Mailspike blacklisted
0.6 RCVD_IN_SORBS_WEB RBL: SORBS: sender is an abusable web server [58.22.7.114 listed in dnsbl.sorbs.net] 2.7 RCVD_IN_PSBL RBL: Received via a relay in PSBL [211.157.147.133 listed in psbl.surriel.com] 2.4 RCVD_IN_MSPIKE_L5 RBL: Very bad reputation (-5) [211.157.147.133 listed in bl.mailspike.net] 0.8 UPPERCASE_50_75 message body is 50-75% uppercase 0.0 RCVD_IN_MSPIKE_BL Mailspike blacklisted Clean the iomux definitions at grf_rk322x.h, and move them into pinctrl-driver for resolving the compiling error of redefinition. After that, define the uart2 iomux at rk322x-board file.
Changes in v2:
- New patch
arch/arm/include/asm/arch-rockchip/grf_rk322x.h | 455 ------------------------ arch/arm/mach-rockchip/rk322x-board-spl.c | 20 +- arch/arm/mach-rockchip/rk322x-board.c | 16 + drivers/pinctrl/rockchip/pinctrl_rk322x.c | 453 +++++++++++++++++++++++ 4 files changed, 488 insertions(+), 456 deletions(-)
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: David Wu david.wu@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v2:
- New patch
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Hi David,
Am Donnerstag, 9. November 2017, 17:24:58 CET schrieb David Wu:
diff --git a/arch/arm/mach-rockchip/rk322x-board-spl.c b/arch/arm/mach-rockchip/rk322x-board-spl.c index 35f4f97..f7c6045 100644 --- a/arch/arm/mach-rockchip/rk322x-board-spl.c +++ b/arch/arm/mach-rockchip/rk322x-board-spl.c @@ -30,7 +30,25 @@ DECLARE_GLOBAL_DATA_PTR;
void board_debug_uart_init(void) { -static struct rk322x_grf * const grf = (void *)GRF_BASE;
enum {
GPIO1B2_SHIFT = 4,
GPIO1B2_MASK = 3 << GPIO1B2_SHIFT,
GPIO1B2_UART1_SIN,
GPIO1B2_UART21_SIN,
GPIO1B1_SHIFT = 2,
GPIO1B1_MASK = 3 << GPIO1B1_SHIFT,
GPIO1B1_UART1_SOUT,
GPIO1B1_UART21_SOUT,
You seem to drop the GPIO1B1_GPIO = 0, line, so the enum counting wil get jumbled, because GPIO1B1_UART1_SOUT for example will get to be 4 instead of the 1 it needs to be.
This may be true for the other patches for the other socs as well, so you may want to double check?
Heiko
Hi Heiko
在 2017/12/26 2:59, Heiko Stuebner 写道:
Hi David,
enum {
GPIO1B2_SHIFT = 4,
GPIO1B2_UART1_SIN,
GPIO1B2_UART21_SIN,
GPIO1B1_SHIFT = 2,
GPIO1B1_UART1_SOUT,
Yes, they are needed to check again.
Heiko
David Wu
David.Wu
Heiko Stuebner
Philipp Tomsich
