[U-Boot-Users] RE: New NAND code draft
Pantelis Antoniou wrote:
In the attached patch you can see the progress of my work in the NAND rewrite.
This is not suitable for inclusion yet.
I tried it with a flash with no bad blocks. With the attached patch it worked for booting from JFFS2, and erasing/writing new JFFS2 images. My system copies the boot partition to RAM and U-Boot's JFFS2 uses the RAM copy.
The patch just fixes my configuration file and makes cmd_nand.c build when CONFIG_MTD_NAND_UNSAFE is not defined.
Things that work now:
- Correct handling of bad blocks.
I only tried a nand with no bad blocks. I'll simulate some bad blocks when the read.jffs2 support is added.
- NAND boot works
not tried
- Direct to NAND tftp/nfs support.
not tried
Things that are probably borked:
- Multiple chip support (I don't have such hardware available and the previous code was kinda of unclear.
not tried (I don't have the hardware either.)
- JFFS2 support although there is probably b0rken.
- The read.xxx/write.xxx support is just not there yet.
I need to be able to specify the range of NAND to read from (like read.jffs2 does), then I will test the JFFS2 read/write with bad blocks.
Dave Ellis
Dave Ellis
