[U-Boot] [PATCH] Fix some obvious typoes across multiple subsystems.
Typoes fixed:
"partion" -> "partition" "retrive", "retreive" -> "retrieve" "th" -> "to"
Signed-off-by: Robert P. J. Day rpjday@crashcourse.ca
just my pedantic nature getting the best of me, not sure if folks preferred i submit these on a per-subsystem basis and CC all relevant maintainers. if so, i can resubmit.
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index 06767aa..a46f5cc 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -161,7 +161,7 @@ static int set_gpt_info(block_dev_desc_t *dev_desc, /* allocate memory for partitions */ parts = calloc(sizeof(disk_partition_t), p_count);
- /* retrive partions data from string */ + /* retrieve partitions data from string */ for (i = 0; i < p_count; i++) { tok = strsep(&s, ";");
@@ -316,7 +316,7 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
U_BOOT_CMD(gpt, CONFIG_SYS_MAXARGS, 1, do_gpt, "GUID Partition Table", - "<command> <interface> <dev> <partions_list>\n" + "<command> <interface> <dev> <partitions_list>\n" " - GUID partition table restoration\n" " Restore GPT information on a device connected\n" " to interface\n" diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index 1cdeb44..67a94a7 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -260,7 +260,7 @@ static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (!ret) mmc->part_num = part;
- printf("switch to partions #%d, %s\n", + printf("switch to partitions #%d, %s\n", part, (!ret) ? "OK" : "ERROR"); } } @@ -421,7 +421,7 @@ U_BOOT_CMD( "mmc close <dev> <boot_partition>\n" " - Enable boot_part for booting and disable access to boot_part\n" "mmc bootpart <device num> <boot part size MB> <RPMB part size MB>\n" - " - change sizes of boot and RPMB partions of specified device\n" + " - change sizes of boot and RPMB partitions of specified device\n" #endif ); #endif /* !CONFIG_GENERIC_MMC */ diff --git a/common/cmd_mtdparts.c b/common/cmd_mtdparts.c index 3023479..38a6e6d 100644 --- a/common/cmd_mtdparts.c +++ b/common/cmd_mtdparts.c @@ -420,7 +420,7 @@ static int part_validate(struct mtdids *id, struct part_info *part) }
/** - * Delete selected partition from the partion list of the specified device. + * Delete selected partition from the partition list of the specified device. * * @param dev device to delete partition from * @param part partition to delete diff --git a/common/image-fit.c b/common/image-fit.c index 199b4ed..7647515 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1331,7 +1331,7 @@ int fit_conf_find_compat(const void *fit, const void *fdt) * * When NULL is provided in second argument fit_conf_get_node() will search * for a default configuration node instead. Default configuration node unit - * name is retrived from FIT_DEFAULT_PROP property of the '/configurations' + * name is retrieved from FIT_DEFAULT_PROP property of the '/configurations' * node. * * returns: diff --git a/drivers/block/sym53c8xx.c b/drivers/block/sym53c8xx.c index c538e37..6f1ac85 100644 --- a/drivers/block/sym53c8xx.c +++ b/drivers/block/sym53c8xx.c @@ -248,7 +248,7 @@ void scsi_print_error (ccb * pccb)
/****************************************************************************** * sets-up the SCSI controller - * the base memory address is retrived via the pci_read_config_dword + * the base memory address is retrieved via the pci_read_config_dword */ void scsi_low_level_init(int busdevfunc) { diff --git a/include/libfdt.h b/include/libfdt.h index 765d84f..9eefaaf 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -596,9 +596,9 @@ const char *fdt_get_alias_namelen(const void *fdt, const char *name, int namelen);
/** - * fdt_get_alias - retreive the path referenced by a given alias + * fdt_get_alias - retrieve the path referenced by a given alias * @fdt: pointer to the device tree blob - * @name: name of the alias th look up + * @name: name of the alias to look up * * fdt_get_alias() retrieves the value of a given alias. That is, the * value of the property named 'name' in the node /aliases.
On Wed, Aug 21, 2013 at 11:39:19AM -0400, Robert P. J. Day wrote:
Typoes fixed:
Robert P. J. Day
