[U-Boot] [PATCH] drivers:usb: use get|put_unaligned_le16
This patch use get|put_unaligned_le16 to access structure data to avoid data abort on some ARM platforms.
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Marek Vasut marex@denx.de --- drivers/usb/gadget/f_mass_storage.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index c28866f..b7e0df3 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -577,9 +577,9 @@ static int fsg_setup(struct usb_function *f, { struct fsg_dev *fsg = fsg_from_func(f); struct usb_request *req = fsg->common->ep0req; - u16 w_index = le16_to_cpu(ctrl->wIndex); - u16 w_value = le16_to_cpu(ctrl->wValue); - u16 w_length = le16_to_cpu(ctrl->wLength); + u16 w_index = get_unaligned_le16(&ctrl->wIndex); + u16 w_value = get_unaligned_le16(&ctrl->wValue); + u16 w_length = get_unaligned_le16(&ctrl->wLength);
if (!fsg_is_set(fsg->common)) return -EOPNOTSUPP; @@ -617,7 +617,7 @@ static int fsg_setup(struct usb_function *f, "unknown class-specific control req " "%02x.%02x v%04x i%04x l%u\n", ctrl->bRequestType, ctrl->bRequest, - le16_to_cpu(ctrl->wValue), w_index, w_length); + get_unaligned_le16(&ctrl->wValue), w_index, w_length); return -EOPNOTSUPP; }
@@ -2261,7 +2261,7 @@ reset: if (rc) goto reset; fsg->bulk_out_enabled = 1; - common->bulk_out_maxpacket = le16_to_cpu(d->wMaxPacketSize); + common->bulk_out_maxpacket = get_unaligned_le16(&d->wMaxPacketSize); clear_bit(IGNORE_BULK_OUT, &fsg->atomic_bitflags);
/* Allocate the requests */
Dear Piotr Wilczek,
Can you please rebase on top of u-boot-usb/master?
Best regards, Marek Vasut
Signed-off-by: Piotr Wilczek p.wilczek@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Marek Vasut marex@denx.de --- Changes for v2: - rebased on top of u-boot-usb/master
drivers/usb/gadget/f_mass_storage.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/gadget/f_mass_storage.c b/drivers/usb/gadget/f_mass_storage.c index 45bc132..5b348d7 100644 --- a/drivers/usb/gadget/f_mass_storage.c +++ b/drivers/usb/gadget/f_mass_storage.c @@ -577,9 +577,9 @@ static int fsg_setup(struct usb_function *f, { struct fsg_dev *fsg = fsg_from_func(f); struct usb_request *req = fsg->common->ep0req; - u16 w_index = le16_to_cpu(ctrl->wIndex); - u16 w_value = le16_to_cpu(ctrl->wValue); - u16 w_length = le16_to_cpu(ctrl->wLength); + u16 w_index = get_unaligned_le16(&ctrl->wIndex); + u16 w_value = get_unaligned_le16(&ctrl->wValue); + u16 w_length = get_unaligned_le16(&ctrl->wLength);
Dear Piotr Wilczek,
Applied, thanks!
Piotr Wilczek
