[U-Boot] [PATCH atmel/next 0/7] replace at91rm9200_usart by atmel_usart
This series is an RFC for atmel/next!
It should replace the current at91rm9200_usart driver by the common atmel_usart driver. This is tested on at91rm9200ek, there are patches included for the two other arm920t/at91 boards currently supported by u-boot. Jens, Eric feel free to test this stuff.
Some of the patches where submitted before in another structure (move arm926ejs/at91/clock.c to arm/lib/at91 and use the API) -> see http://patchwork.ozlabs.org/patch/99344/ and http://patchwork.ozlabs.org/patch/99550/ They both are superseded by this series.
There may be some issues with one of the patches in this series if you reorder the patches. Therefore I would like to squash some of them together, if the review process shows that there are no other issues with it. There also might be some unnecessary reorering in some of the defines. This is subject to next version, but feel free to point them out.
Andreas Bießmann (7): arm920t/at91: add clock.c arm920t/at91: use new clock.c features arm920t/at91: add at91rm9200_devices.c at91rm9200ek: use atmel_usart eb_cpux9k2: use atmel_usart cpuat91: use atmel_usart driver/serial: delete at91rm9200_usart
arch/arm/cpu/arm920t/at91/Makefile | 3 + arch/arm/cpu/arm920t/at91/at91rm9200_devices.c | 85 +++++++++++++ arch/arm/cpu/arm920t/at91/clock.c | 160 ++++++++++++++++++++++++ arch/arm/cpu/arm920t/at91/cpu.c | 43 +++++++ arch/arm/cpu/arm926ejs/at91/clock.c | 35 +----- arch/arm/include/asm/arch-at91/at91rm9200.h | 10 ++- arch/arm/include/asm/arch-at91/clk.h | 42 ++++++- board/BuS/eb_cpux9k2/cpux9k2.c | 7 + board/atmel/at91rm9200ek/at91rm9200ek.c | 7 + board/eukrea/cpuat91/cpuat91.c | 8 ++ drivers/serial/Makefile | 1 - drivers/serial/at91rm9200_usart.c | 126 ------------------- include/configs/at91rm9200ek.h | 10 ++- include/configs/cpuat91.h | 12 +- include/configs/eb_cpux9k2.h | 10 +- 15 files changed, 379 insertions(+), 180 deletions(-) create mode 100644 arch/arm/cpu/arm920t/at91/at91rm9200_devices.c create mode 100644 arch/arm/cpu/arm920t/at91/clock.c create mode 100644 arch/arm/cpu/arm920t/at91/cpu.c delete mode 100644 drivers/serial/at91rm9200_usart.c
regards
Andreas Bießmann
This patch adds an copy of arm926ejs/at91/clock.c to arm920t/at91. The arm926ejs specialities are removed from arm920t version and vice versa.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- arch/arm/cpu/arm920t/at91/Makefile | 1 + arch/arm/cpu/arm920t/at91/clock.c | 160 ++++++++++++++++++++++++++++++++++ arch/arm/cpu/arm926ejs/at91/clock.c | 35 +------- arch/arm/include/asm/arch-at91/clk.h | 42 ++++++++-- 4 files changed, 198 insertions(+), 40 deletions(-) create mode 100644 arch/arm/cpu/arm920t/at91/clock.c
diff --git a/arch/arm/cpu/arm920t/at91/Makefile b/arch/arm/cpu/arm920t/at91/Makefile index 5c71b77..8258ecd 100644 --- a/arch/arm/cpu/arm920t/at91/Makefile +++ b/arch/arm/cpu/arm920t/at91/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)lib$(SOC).o SOBJS += lowlevel_init.o COBJS += reset.o COBJS += timer.o +COBJS += clock.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/arm920t/at91/clock.c b/arch/arm/cpu/arm920t/at91/clock.c new file mode 100644 index 0000000..02318b3 --- /dev/null +++ b/arch/arm/cpu/arm920t/at91/clock.c @@ -0,0 +1,160 @@ +/* + * [origin: Linux kernel linux/arch/arm/mach-at91/clock.c] + * + * Copyright (C) 2011 Andreas Bießmann + * Copyright (C) 2005 David Brownell + * Copyright (C) 2005 Ivan Kokshaysky + * Copyright (C) 2009 Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ +#include <common.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> + +#if !defined(CONFIG_AT91FAMILY) +# error You need to define CONFIG_AT91FAMILY in your board config! +#endif + +DECLARE_GLOBAL_DATA_PTR; + +static unsigned long at91_css_to_rate(unsigned long css) +{ + switch (css) { + case AT91_PMC_MCKR_CSS_SLOW: + return CONFIG_SYS_AT91_SLOW_CLOCK; + case AT91_PMC_MCKR_CSS_MAIN: + return gd->main_clk_rate_hz; + case AT91_PMC_MCKR_CSS_PLLA: + return gd->plla_rate_hz; + case AT91_PMC_MCKR_CSS_PLLB: + return gd->pllb_rate_hz; + } + + return 0; +} + +#ifdef CONFIG_USB_ATMEL +static unsigned at91_pll_calc(unsigned main_freq, unsigned out_freq) +{ + unsigned i, div = 0, mul = 0, diff = 1 << 30; + unsigned ret = (out_freq > 155000000) ? 0xbe00 : 0x3e00; + + /* PLL output max 240 MHz (or 180 MHz per errata) */ + if (out_freq > 240000000) + goto fail; + + for (i = 1; i < 256; i++) { + int diff1; + unsigned input, mul1; + + /* + * PLL input between 1MHz and 32MHz per spec, but lower + * frequences seem necessary in some cases so allow 100K. + * Warning: some newer products need 2MHz min. + */ + input = main_freq / i; + if (input < 100000) + continue; + if (input > 32000000) + continue; + + mul1 = out_freq / input; + if (mul1 > 2048) + continue; + if (mul1 < 2) + goto fail; + + diff1 = out_freq - input * mul1; + if (diff1 < 0) + diff1 = -diff1; + if (diff > diff1) { + diff = diff1; + div = i; + mul = mul1; + if (diff == 0) + break; + } + } + if (i == 256 && diff > (out_freq >> 5)) + goto fail; + return ret | ((mul - 1) << 16) | div; +fail: + return 0; +} +#endif + +static u32 at91_pll_rate(u32 freq, u32 reg) +{ + unsigned mul, div; + + div = reg & 0xff; + mul = (reg >> 16) & 0x7ff; + if (div && mul) { + freq /= div; + freq *= mul + 1; + } else + freq = 0; + + return freq; +} + + +int at91_clock_init(unsigned long main_clock) +{ + unsigned freq, mckr; + at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; +#ifndef CONFIG_SYS_AT91_MAIN_CLOCK + unsigned tmp; + /* + * When the bootloader initialized the main oscillator correctly, + * there's no problem using the cycle counter. But if it didn't, + * or when using oscillator bypass mode, we must be told the speed + * of the main clock. + */ + if (!main_clock) { + do { + tmp = readl(&pmc->mcfr); + } while (!(tmp & AT91_PMC_MCFR_MAINRDY)); + tmp &= AT91_PMC_MCFR_MAINF_MASK; + main_clock = tmp * (CONFIG_SYS_AT91_SLOW_CLOCK / 16); + } +#endif + gd->main_clk_rate_hz = main_clock; + + /* report if PLLA is more than mildly overclocked */ + gd->plla_rate_hz = at91_pll_rate(main_clock, readl(&pmc->pllar)); + +#ifdef CONFIG_USB_ATMEL + /* + * USB clock init: choose 48 MHz PLLB value, + * disable 48MHz clock during usb peripheral suspend. + * + * REVISIT: assumes MCK doesn't derive from PLLB! + */ + gd->at91_pllb_usb_init = at91_pll_calc(main_clock, 48000000 * 2) | + AT91_PMC_PLLBR_USBDIV_2; + gd->pllb_rate_hz = at91_pll_rate(main_clock, gd->at91_pllb_usb_init); +#endif + + /* + * MCK and CPU derive from one of those primary clocks. + * For now, assume this parentage won't change. + */ + mckr = readl(&pmc->mckr); + gd->mck_rate_hz = at91_css_to_rate(mckr & AT91_PMC_MCKR_CSS_MASK); + freq = gd->mck_rate_hz; + + freq /= (1 << ((mckr & AT91_PMC_MCKR_PRES_MASK) >> 2)); /* prescale */ + /* mdiv */ + gd->mck_rate_hz = freq / (1 + ((mckr & AT91_PMC_MCKR_MDIV_MASK) >> 8)); + gd->cpu_clk_rate_hz = freq; + + return 0; +} + diff --git a/arch/arm/cpu/arm926ejs/at91/clock.c b/arch/arm/cpu/arm926ejs/at91/clock.c index 608af2c..a7085de 100644 --- a/arch/arm/cpu/arm926ejs/at91/clock.c +++ b/arch/arm/cpu/arm926ejs/at91/clock.c @@ -23,36 +23,6 @@
-unsigned long get_cpu_clk_rate(void) -{ - return gd->cpu_clk_rate_hz; -} - -unsigned long get_main_clk_rate(void) -{ - return gd->main_clk_rate_hz; -} - -unsigned long get_mck_clk_rate(void) -{ - return gd->mck_rate_hz; -} - -unsigned long get_plla_clk_rate(void) -{ - return gd->plla_rate_hz; -} - -unsigned long get_pllb_clk_rate(void) -{ - return gd->pllb_rate_hz; -} - -u32 get_pllb_init(void) -{ - return gd->at91_pllb_usb_init; -} - static unsigned long at91_css_to_rate(unsigned long css) { switch (css) { @@ -192,10 +162,7 @@ int at91_clock_init(unsigned long main_clock) freq = gd->mck_rate_hz;
freq /= (1 << ((mckr & AT91_PMC_MCKR_PRES_MASK) >> 2)); /* prescale */ -#if defined(CONFIG_AT91RM9200) - /* mdiv */ - gd->mck_rate_hz = freq / (1 + ((mckr & AT91_PMC_MCKR_MDIV_MASK) >> 8)); -#elif defined(CONFIG_AT91SAM9G20) +#if defined(CONFIG_AT91SAM9G20) /* mdiv ; (x >> 7) = ((x >> 8) * 2) */ gd->mck_rate_hz = (mckr & AT91_PMC_MCKR_MDIV_MASK) ? freq / ((mckr & AT91_PMC_MCKR_MDIV_MASK) >> 7) : freq; diff --git a/arch/arm/include/asm/arch-at91/clk.h b/arch/arm/include/asm/arch-at91/clk.h index 457e6c9..f645327 100644 --- a/arch/arm/include/asm/arch-at91/clk.h +++ b/arch/arm/include/asm/arch-at91/clk.h @@ -26,13 +26,43 @@ #define __ASM_ARM_ARCH_CLK_H__
#include <asm/arch/hardware.h> +#include <asm/global_data.h>
-unsigned long get_cpu_clk_rate(void); -unsigned long get_main_clk_rate(void); -unsigned long get_mck_clk_rate(void); -unsigned long get_plla_clk_rate(void); -unsigned long get_pllb_clk_rate(void); -unsigned int get_pllb_init(void); +static inline unsigned long get_cpu_clk_rate(void) +{ + DECLARE_GLOBAL_DATA_PTR; + return gd->cpu_clk_rate_hz; +} + +static inline unsigned long get_main_clk_rate(void) +{ + DECLARE_GLOBAL_DATA_PTR; + return gd->main_clk_rate_hz; +} + +static inline unsigned long get_mck_clk_rate(void) +{ + DECLARE_GLOBAL_DATA_PTR; + return gd->mck_rate_hz; +} + +static inline unsigned long get_plla_clk_rate(void) +{ + DECLARE_GLOBAL_DATA_PTR; + return gd->plla_rate_hz; +} + +static inline unsigned long get_pllb_clk_rate(void) +{ + DECLARE_GLOBAL_DATA_PTR; + return gd->pllb_rate_hz; +} + +static inline u32 get_pllb_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + return gd->at91_pllb_usb_init; +}
static inline unsigned long get_macb_pclk_rate(unsigned int dev_id) {
This patch enables the new clock features from arm920t/at91/clock.c. This is an required step to get at91rm9200_usart replaced by atmel_usart driver.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Jens Scharsig js_at_ng@scharsoft.de Cc: Eric Bénard eric@eukrea.com --- arch/arm/cpu/arm920t/at91/Makefile | 1 + arch/arm/cpu/arm920t/at91/cpu.c | 43 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-at91/at91rm9200.h | 1 + include/configs/at91rm9200ek.h | 3 ++ include/configs/cpuat91.h | 5 ++- include/configs/eb_cpux9k2.h | 4 +- 6 files changed, 53 insertions(+), 4 deletions(-) create mode 100644 arch/arm/cpu/arm920t/at91/cpu.c
diff --git a/arch/arm/cpu/arm920t/at91/Makefile b/arch/arm/cpu/arm920t/at91/Makefile index 8258ecd..4417dfe 100644 --- a/arch/arm/cpu/arm920t/at91/Makefile +++ b/arch/arm/cpu/arm920t/at91/Makefile @@ -29,6 +29,7 @@ SOBJS += lowlevel_init.o COBJS += reset.o COBJS += timer.o COBJS += clock.o +COBJS += cpu.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/arm920t/at91/cpu.c b/arch/arm/cpu/arm920t/at91/cpu.c new file mode 100644 index 0000000..74a1158 --- /dev/null +++ b/arch/arm/cpu/arm920t/at91/cpu.c @@ -0,0 +1,43 @@ +/* + * [origin: arch/arm/cpu/arm926ejs/at91/cpu.c] + * + * (C) Copyright 2011 + * Andreas Bießmann, andreas.devel@googlemail.com + * (C) Copyright 2010 + * Reinhard Meyer, reinhard.meyer@emk-elektronik.de + * (C) Copyright 2009 + * Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/clk.h> + +#ifndef CONFIG_SYS_AT91_MAIN_CLOCK +#define CONFIG_SYS_AT91_MAIN_CLOCK 0 +#endif + +int arch_cpu_init(void) +{ + return at91_clock_init(CONFIG_SYS_AT91_MAIN_CLOCK); +} + diff --git a/arch/arm/include/asm/arch-at91/at91rm9200.h b/arch/arm/include/asm/arch-at91/at91rm9200.h index f1912e2..fd774b4 100644 --- a/arch/arm/include/asm/arch-at91/at91rm9200.h +++ b/arch/arm/include/asm/arch-at91/at91rm9200.h @@ -22,6 +22,7 @@ #define __AT91RM9200_H__
#define CONFIG_AT91FAMILY /* it's a member of AT91 */ +#define CONFIG_ARCH_CPU_INIT /* we need arch_cpu_init() for hw timers */ #define CONFIG_ARM920T /* This is an ARM920T Core */
/* Periperial Identifiers */ diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 16cd214..ee199ab 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -55,6 +55,7 @@ * CONFIG_SYS_HZ is the tick rate for timer tc0 */ #define AT91C_XTAL_CLOCK 18432000 +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define AT91C_MAIN_CLOCK ((AT91C_XTAL_CLOCK / 4) * 39) #define AT91C_MASTER_CLOCK (AT91C_MAIN_CLOCK / 3 ) #define CONFIG_SYS_HZ_CLOCK (AT91C_MASTER_CLOCK / 2) @@ -66,6 +67,8 @@ #define CONFIG_CPUAT91 #define USE_920T_MMU
+#include <asm/hardware.h> /* needed for port definitions */ + #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG diff --git a/include/configs/cpuat91.h b/include/configs/cpuat91.h index cfaef15..2bda72b 100644 --- a/include/configs/cpuat91.h +++ b/include/configs/cpuat91.h @@ -37,6 +37,7 @@ #endif
#define AT91C_XTAL_CLOCK 18432000 +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 #define AT91C_MAIN_CLOCK ((AT91C_XTAL_CLOCK / 4) * 39) #define AT91C_MASTER_CLOCK (AT91C_MAIN_CLOCK / 3) #define CONFIG_SYS_HZ_CLOCK (AT91C_MASTER_CLOCK / 2) @@ -45,11 +46,11 @@ #define CONFIG_ARM920T #define CONFIG_AT91RM9200 #define CONFIG_CPUAT91 -#define CONFIG_AT91FAMILY - #undef CONFIG_USE_IRQ #define USE_920T_MMU
+#include <asm/hardware.h> /* needed for port definitions */ + #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index e12770a..25b28f5 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -36,7 +36,7 @@ #define CONFIG_VERSION_VARIABLE #define CONFIG_IDENT_STRING " on EB+CPUx9K2"
-#include <asm/arch/hardware.h> /* needed for port definitions */ +#include <asm/hardware.h> /* needed for port definitions */
#define CONFIG_MISC_INIT_R
@@ -69,7 +69,7 @@ #define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_HZ_CLOCK (AT91C_MASTER_CLOCK / 2)
-#define AT91_SLOW_CLOCK 32768 /* slow clock */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 /* slow clock */
#define CONFIG_CMDLINE_TAG 1 #define CONFIG_SETUP_MEMORY_TAGS 1
This is a copy of arm926ejs/at91 api for perpherial initialisation. At the moment we just need the usart part of the api.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- arch/arm/cpu/arm920t/at91/Makefile | 1 + arch/arm/cpu/arm920t/at91/at91rm9200_devices.c | 85 ++++++++++++++++++++++++ arch/arm/include/asm/arch-at91/at91rm9200.h | 9 ++- 3 files changed, 93 insertions(+), 2 deletions(-) create mode 100644 arch/arm/cpu/arm920t/at91/at91rm9200_devices.c
diff --git a/arch/arm/cpu/arm920t/at91/Makefile b/arch/arm/cpu/arm920t/at91/Makefile index 4417dfe..309bcd6 100644 --- a/arch/arm/cpu/arm920t/at91/Makefile +++ b/arch/arm/cpu/arm920t/at91/Makefile @@ -30,6 +30,7 @@ COBJS += reset.o COBJS += timer.o COBJS += clock.o COBJS += cpu.o +COBJS += at91rm9200_devices.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/arm920t/at91/at91rm9200_devices.c b/arch/arm/cpu/arm920t/at91/at91rm9200_devices.c new file mode 100644 index 0000000..f610a1e --- /dev/null +++ b/arch/arm/cpu/arm920t/at91/at91rm9200_devices.c @@ -0,0 +1,85 @@ +/* + * [partely copied from arch/arm/cpu/arm926ejs/at91/arm9260_devices.c] + * + * (C) Copyright 2011 + * Andreas Bießmann andreas.devel@googlemail.com + * + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/gpio.h> + +/* + * if CONFIG_AT91_GPIO_PULLUP ist set, keep pullups on on all + * peripheral pins. Good to have if hardware is soldered optionally + * or in case of SPI no slave is selected. Avoid lines to float + * needlessly. Use a short local PUP define. + * + * Due to errata "TXD floats when CTS is inactive" pullups are always + * on for TXD pins. + */ +#ifdef CONFIG_AT91_GPIO_PULLUP +# define PUP CONFIG_AT91_GPIO_PULLUP +#else +# define PUP 0 +#endif + +void at91_serial0_hw_init(void) +{ + at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 17, 1); /* TXD0 */ + at91_set_a_periph(AT91_PIO_PORTA, 18, PUP); /* RXD0 */ + writel(1 << ATMEL_ID_USART0, &pmc->pcer); +} + +void at91_serial1_hw_init(void) +{ + at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTB, 20, PUP); /* RXD1 */ + at91_set_a_periph(AT91_PIO_PORTB, 21, 1); /* TXD1 */ + writel(1 << ATMEL_ID_USART1, &pmc->pcer); +} + +void at91_serial2_hw_init(void) +{ + at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 22, PUP); /* RXD2 */ + at91_set_a_periph(AT91_PIO_PORTA, 23, 1); /* TXD2 */ + writel(1 << ATMEL_ID_USART2, &pmc->pcer); +} + + +void at91_seriald_hw_init(void) +{ + at91_set_a_periph(AT91_PIO_PORTA, 30, PUP); /* DRXD */ + at91_set_a_periph(AT91_PIO_PORTA, 31, 1); /* DTXD */ + /* writing SYS to PCER has no effect on AT91RM9200 */ +} + diff --git a/arch/arm/include/asm/arch-at91/at91rm9200.h b/arch/arm/include/asm/arch-at91/at91rm9200.h index fd774b4..42a32d3 100644 --- a/arch/arm/include/asm/arch-at91/at91rm9200.h +++ b/arch/arm/include/asm/arch-at91/at91rm9200.h @@ -21,9 +21,10 @@ #ifndef __AT91RM9200_H__ #define __AT91RM9200_H__
-#define CONFIG_AT91FAMILY /* it's a member of AT91 */ +#define CONFIG_AT91FAMILY /* it's a member of AT91 family */ +#define CONFIG_ARM920T /* it's an ARM920T Core */ #define CONFIG_ARCH_CPU_INIT /* we need arch_cpu_init() for hw timers */ -#define CONFIG_ARM920T /* This is an ARM920T Core */ +#define CONFIG_AT91_GPIO /* and require always gpio features */
@@ -78,6 +79,10 @@ #define ATMEL_BASE_AIC 0xFFFFF000 #define ATMEL_BASE_DBGU 0xFFFFF200 #define ATMEL_BASE_PIO 0xFFFFF400 /* 4x 0x200 Offset */ +#define ATMEL_BASE_PIOA 0xFFFFF400 +#define ATMEL_BASE_PIOB 0xFFFFF600 +#define ATMEL_BASE_PIOC 0xFFFFF800 +#define ATMEL_BASE_PIOD 0xFFFFFA00 #define ATMEL_BASE_PMC 0xFFFFFC00 #define ATMEL_BASE_ST 0xFFFFFD00 #define ATMEL_BASE_RTC 0xFFFFFE00
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- board/atmel/at91rm9200ek/at91rm9200ek.c | 7 +++++++ include/configs/at91rm9200ek.h | 7 +++++-- 2 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/board/atmel/at91rm9200ek/at91rm9200ek.c b/board/atmel/at91rm9200ek/at91rm9200ek.c index 5ebc24d..ec0daba 100644 --- a/board/atmel/at91rm9200ek/at91rm9200ek.c +++ b/board/atmel/at91rm9200ek/at91rm9200ek.c @@ -31,6 +31,7 @@ #include <asm/arch/hardware.h> #include <asm/arch/at91_pio.h> #include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_common.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR; @@ -54,6 +55,12 @@ int board_init(void) return 0; }
+int board_early_init_f(void) +{ + at91_seriald_hw_init(); + return 0; +} + int dram_init (void) { /* dram_init must store complete ramsize in gd->ram_size */ diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index ee199ab..b847798 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -73,6 +73,8 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
+#define CONFIG_BOARD_EARLY_INIT_F + /* * Memory Configuration */ @@ -123,8 +125,9 @@ * CONFIG_DBGU is DBGU unit on J10 * CONFIG_USART1 is USART1 on J14 */ -#define CONFIG_AT91RM9200_USART -#define CONFIG_DBGU +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID 0/* ignored in arm */
#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } #define CONFIG_BAUDRATE 115200
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com CC: Jens Scharsig js_at_ng@scharsoft.de --- board/BuS/eb_cpux9k2/cpux9k2.c | 7 +++++++ include/configs/eb_cpux9k2.h | 6 ++++-- 2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/board/BuS/eb_cpux9k2/cpux9k2.c b/board/BuS/eb_cpux9k2/cpux9k2.c index e9a1cb2..a918b04 100644 --- a/board/BuS/eb_cpux9k2/cpux9k2.c +++ b/board/BuS/eb_cpux9k2/cpux9k2.c @@ -33,6 +33,7 @@ #include <asm/arch/at91_pio.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_mc.h> +#include <asm/arch/at91_common.h>
#ifdef CONFIG_STATUS_LED #include <status_led.h> @@ -77,6 +78,12 @@ int board_init(void) return 0; }
+int board_early_init_f(void) +{ + at91_seriald_hw_init(); + return 0; +} + #ifdef CONFIG_MISC_INIT_R
int misc_init_r(void) diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index 25b28f5..c4b1e65 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -39,6 +39,7 @@ #include <asm/hardware.h> /* needed for port definitions */
#define CONFIG_MISC_INIT_R +#define CONFIG_BOARD_EARLY_INIT_F
/*--------------------------------------------------------------------------*/ #define CONFIG_SYS_TEXT_BASE 0x00000000 @@ -174,8 +175,9 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 115200, 19200, 38400, 57600, 9600 }
#define CONFIG_BAUDRATE 115200 -#define CONFIG_AT91RM9200_USART -#define CONFIG_DBGU /* define DBGU as console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID 0/* ignored in arm */
/* * network
Am 12.06.2011 13:49, schrieb Andreas Bießmann:
Signed-off-by: Andreas Bießmannandreas.devel@googlemail.com CC: Jens Scharsigjs_at_ng@scharsoft.de
Acked-by: Jens Scharsigjs_at_ng@scharsoft.de Tested-by: Jens Scharsigjs_at_ng@scharsoft.de (for eb_cpux9k2 board)
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Cc: Eric Bénard eric@eukrea.com --- board/eukrea/cpuat91/cpuat91.c | 8 ++++++++ include/configs/cpuat91.h | 7 ++++--- 2 files changed, 12 insertions(+), 3 deletions(-)
diff --git a/board/eukrea/cpuat91/cpuat91.c b/board/eukrea/cpuat91/cpuat91.c index fa4b25b..5d05414 100644 --- a/board/eukrea/cpuat91/cpuat91.c +++ b/board/eukrea/cpuat91/cpuat91.c @@ -32,6 +32,7 @@ #include <asm/arch/hardware.h> #include <asm/arch/at91_pio.h> #include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_common.h>
@@ -52,6 +53,13 @@ int board_init(void) return 0; }
+int board_early_init_f(void) +{ + at91_seriald_hw_init(); + return 0; +} + + int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ diff --git a/include/configs/cpuat91.h b/include/configs/cpuat91.h index 2bda72b..75b881c 100644 --- a/include/configs/cpuat91.h +++ b/include/configs/cpuat91.h @@ -54,6 +54,7 @@ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG +#define CONFIG_BOARD_EARLY_INIT_F
#ifndef CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_SYS_USE_MAIN_OSCILLATOR @@ -87,9 +88,9 @@ #define CONFIG_SYS_SDRC_TR_VAL 0x000002E0 /* Write refresh rate */ #endif /* CONFIG_SKIP_LOWLEVEL_INIT */
-/* define one of these to choose the DBGU, USART0 or USART1 as console */ -#define CONFIG_AT91RM9200_USART -#define CONFIG_DBGU +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID 0/* ignored in arm */
#undef CONFIG_HARD_I2C #undef CONFIG_SOFT_I2C
The at91rm9200_usart driver could be fully replaced by atmel_usart driver.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- drivers/serial/Makefile | 1 - drivers/serial/at91rm9200_usart.c | 126 ------------------------------------- 2 files changed, 0 insertions(+), 127 deletions(-) delete mode 100644 drivers/serial/at91rm9200_usart.c
diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 5a6011e..0e171b6 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -28,7 +28,6 @@ LIB := $(obj)libserial.o COBJS-$(CONFIG_ALTERA_UART) += altera_uart.o COBJS-$(CONFIG_ALTERA_JTAG_UART) += altera_jtag_uart.o COBJS-$(CONFIG_ARM_DCC) += arm_dcc.o -COBJS-$(CONFIG_AT91RM9200_USART) += at91rm9200_usart.o COBJS-$(CONFIG_ATMEL_USART) += atmel_usart.o COBJS-$(CONFIG_MCFUART) += mcfuart.o COBJS-$(CONFIG_NS9750_UART) += ns9750_serial.o diff --git a/drivers/serial/at91rm9200_usart.c b/drivers/serial/at91rm9200_usart.c deleted file mode 100644 index 05ebbc3..0000000 --- a/drivers/serial/at91rm9200_usart.c +++ /dev/null @@ -1,126 +0,0 @@ -/* - * (C) Copyright 2002 - * Lineo, Inc <www.lineo.com> - * Bernhard Kuhn bkuhn@lineo.com - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Alex Zuepke azu@sysgo.de - * - * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * - */ - -#include <common.h> - -#ifndef CONFIG_AT91_LEGACY -#include <asm/io.h> -#include <asm/arch/hardware.h> -#define CONFIG_AT91_LEGACY -#include <asm/arch-at91rm9200/AT91RM9200.h> -#warning Please update to use C structur SoC access ! -#else -#include <asm/arch/AT91RM9200.h> -#endif - -DECLARE_GLOBAL_DATA_PTR; - -#if !defined(CONFIG_DBGU) && !defined(CONFIG_USART0) && !defined(CONFIG_USART1) -#error must define one of CONFIG_DBGU or CONFIG_USART0 or CONFIG_USART1 -#endif - -/* ggi thunder */ -#ifdef CONFIG_DBGU -AT91PS_USART us = (AT91PS_USART) AT91C_BASE_DBGU; -#endif -#ifdef CONFIG_USART0 -AT91PS_USART us = (AT91PS_USART) AT91C_BASE_US0; -#endif -#ifdef CONFIG_USART1 -AT91PS_USART us = (AT91PS_USART) AT91C_BASE_US1; -#endif - -void serial_setbrg (void) -{ - int baudrate; - - if ((baudrate = gd->baudrate) <= 0) - baudrate = CONFIG_BAUDRATE; - /* MASTER_CLOCK/(16 * baudrate) */ - us->US_BRGR = (AT91C_MASTER_CLOCK >> 4) / (unsigned)baudrate; -} - -int serial_init (void) -{ - /* make any port initializations specific to this port */ -#ifdef CONFIG_DBGU - *AT91C_PIOA_PDR = AT91C_PA31_DTXD | AT91C_PA30_DRXD; /* PA 31 & 30 */ - *AT91C_PMC_PCER = 1 << AT91C_ID_SYS; /* enable clock */ -#endif -#ifdef CONFIG_USART0 - *AT91C_PIOA_PDR = AT91C_PA17_TXD0 | AT91C_PA18_RXD0; - *AT91C_PMC_PCER |= 1 << AT91C_ID_USART0; /* enable clock */ -#endif -#ifdef CONFIG_USART1 - *AT91C_PIOB_PDR = AT91C_PB21_TXD1 | AT91C_PB20_RXD1; - *AT91C_PMC_PCER |= 1 << AT91C_ID_USART1; /* enable clock */ -#endif - serial_setbrg (); - - us->US_CR = AT91C_US_RSTRX | AT91C_US_RSTTX; - us->US_CR = AT91C_US_RXEN | AT91C_US_TXEN; - us->US_MR = - (AT91C_US_CLKS_CLOCK | AT91C_US_CHRL_8_BITS | - AT91C_US_PAR_NONE | AT91C_US_NBSTOP_1_BIT); - us->US_IMR = ~0ul; - return (0); -} - -void serial_exit (void) -{ - us->US_CR = (AT91C_US_RSTRX | AT91C_US_RSTTX); -} - -void serial_putc (const char c) -{ - if (c == '\n') - serial_putc ('\r'); - while ((us->US_CSR & AT91C_US_TXRDY) == 0); - us->US_THR = c; -} - -void serial_puts (const char *s) -{ - while (*s) { - serial_putc (*s++); - } -} - -int serial_getc (void) -{ - while ((us->US_CSR & AT91C_US_RXRDY) == 0); - return us->US_RHR; -} - -int serial_tstc (void) -{ - return ((us->US_CSR & AT91C_US_RXRDY) == AT91C_US_RXRDY); -}
Dear Andreas Bießmann,
Applied to u-boot-atmel/master. Thanks, Reinhard
Andreas Bießmann
Jens Scharsig
Reinhard Meyer
