[PATCH v3 00/11] Fixes for Rockchip NFC driver part 1
This serie contains fixes for the Rockchip NFC driver, which was ported to U-boot and merged with little review and testing it seems. Part 1 aims at passing the probe function without errors.
Fixed are: 64bit FDT parsing compatible string removal add missing layout structure add missing flash_node pointer add missing chip ID
Changed V3: use dev_read_addr_ptr fix oobfree
Johan Jonker (10): include: fdtdec: decouple fdt_addr_t and phys_addr_t size include: dm: ofnode: fix headers core: remap: convert regmap_init_mem_plat() input to phys_addr_t rockchip: adc: rockchip-saradc: use dev_read_addr_ptr rockchip: timer: dw-apb-timer: convert dev_read_addr output to phys_addr_t mtd: nand: raw: rockchip_nfc: use dev_read_addr_ptr mtd: nand: raw: rockchip_nfc: remove the compatible string "rockchip,rk3308-nfc" mtd: nand: raw: rockchip_nfc: add layout structure mtd: nand: raw: rockchip_nfc: add flash_node to chip structure mtd: nand: raw: rockchip_nfc: fix oobfree offset and description
Paweł Jarosz (1): mtd: nand: add support for the Sandisk SDTNQGAMA chip
Kconfig | 8 +++ drivers/adc/rockchip-saradc.c | 4 +- drivers/core/regmap.c | 2 +- drivers/core/syscon-uclass.c | 2 +- drivers/mtd/nand/raw/nand_ids.c | 3 ++ drivers/mtd/nand/raw/rockchip_nfc.c | 78 ++++++++++------------------- drivers/ram/rockchip/sdram_rk3066.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk322x.c | 2 +- drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- drivers/timer/dw-apb-timer.c | 4 +- include/dm/ofnode.h | 16 +++--- include/fdtdec.h | 13 +++-- include/regmap.h | 2 +- 16 files changed, 68 insertions(+), 76 deletions(-)
-- 2.20.1
The DT specification supports CPUs with both 32-bit and 64-bit addressing capabilities. In U-boot the fdt_addr_t and phys_addr_t size are coupled by a typedef. The MTD NAND drivers for 32-bit CPU's can describe partitions with a 64-bit reg property. These partitions synced from Linux end up with the wrong offset and sizes when only the lower 32-bit is passed. Decouple the fdt_addr_t and phys_addr_t size as they don't necessary match.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com ---
Changed V2: reword
Note: Most drivers still assume that FDT and CPU capabilities are identical. In order to use these variables a cast is needed. --- Kconfig | 8 ++++++++ include/fdtdec.h | 13 +++++++++---- 2 files changed, 17 insertions(+), 4 deletions(-)
diff --git a/Kconfig b/Kconfig index a75cce7e..7697dade 100644 --- a/Kconfig +++ b/Kconfig @@ -422,11 +422,19 @@ endif # EXPERT
config PHYS_64BIT bool "64bit physical address support" + select FDT_64BIT help Say Y here to support 64bit physical memory address. This can be used not only for 64bit SoCs, but also for large physical address extension on 32bit SoCs.
+config FDT_64BIT + bool "64bit fdt address support" + help + Say Y here to support 64bit fdt addresses. + This can be used not only for 64bit SoCs, but also + for large address extensions on 32bit SoCs. + config HAS_ROM bool select BINMAN diff --git a/include/fdtdec.h b/include/fdtdec.h index 12355afd..af29ac0c 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -18,15 +18,18 @@ #include <pci.h>
/* - * A typedef for a physical address. Note that fdt data is always big + * Support for 64bit fdt addresses. + * This can be used not only for 64bit SoCs, but also + * for large address extensions on 32bit SoCs. + * Note that fdt data is always big * endian even on a litle endian machine. */ -typedef phys_addr_t fdt_addr_t; -typedef phys_size_t fdt_size_t;
#define FDT_SIZE_T_NONE (-1U)
-#ifdef CONFIG_PHYS_64BIT +#ifdef CONFIG_FDT_64BIT +typedef u64 fdt_addr_t; +typedef u64 fdt_size_t; #define FDT_ADDR_T_NONE ((ulong)(-1))
#define fdt_addr_to_cpu(reg) be64_to_cpu(reg) @@ -35,6 +38,8 @@ typedef phys_size_t fdt_size_t; #define cpu_to_fdt_size(reg) cpu_to_be64(reg) typedef fdt64_t fdt_val_t; #else +typedef u32 fdt_addr_t; +typedef u32 fdt_size_t; #define FDT_ADDR_T_NONE (-1U)
#define fdt_addr_to_cpu(reg) be32_to_cpu(reg) -- 2.20.1
When fdt_addr_t and phys_addr_t are split it turns out that the header don't match the functions, so fix the headers.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com --- include/dm/ofnode.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index fa986560..287b0c35 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -678,8 +678,8 @@ int ofnode_read_size(ofnode node, const char *propname); * @size: Pointer to size of the address * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr_size_index(ofnode node, int index, - fdt_size_t *size); +fdt_addr_t ofnode_get_addr_size_index(ofnode node, int index, + fdt_size_t *size);
/** * ofnode_get_addr_size_index_notrans() - get an address/size from a node @@ -695,8 +695,8 @@ phys_addr_t ofnode_get_addr_size_index(ofnode node, int index, * @size: Pointer to size of the address * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, - fdt_size_t *size); +fdt_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, + fdt_size_t *size);
/** * ofnode_get_addr_index() - get an address from a node @@ -707,7 +707,7 @@ phys_addr_t ofnode_get_addr_size_index_notrans(ofnode node, int index, * @index: Index of address to read (0 for first) * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr_index(ofnode node, int index); +fdt_addr_t ofnode_get_addr_index(ofnode node, int index);
/** * ofnode_get_addr() - get an address from a node @@ -717,7 +717,7 @@ phys_addr_t ofnode_get_addr_index(ofnode node, int index); * @node: node to read from * Return: address, or FDT_ADDR_T_NONE if not present or invalid */ -phys_addr_t ofnode_get_addr(ofnode node); +fdt_addr_t ofnode_get_addr(ofnode node);
/** * ofnode_get_size() - get size from a node @@ -1055,8 +1055,8 @@ const void *ofprop_get_property(const struct ofprop *prop, * @sizep: place to put size value (on success) * Return: address value, or FDT_ADDR_T_NONE on error */ -phys_addr_t ofnode_get_addr_size(ofnode node, const char *propname, - phys_size_t *sizep); +fdt_addr_t ofnode_get_addr_size(ofnode node, const char *propname, + fdt_size_t *sizep);
/** * ofnode_read_u8_array_ptr() - find an 8-bit array -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so convert regmap_init_mem_plat() input to phys_addr_t in files that use this function.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/core/regmap.c | 2 +- drivers/core/syscon-uclass.c | 2 +- drivers/ram/rockchip/sdram_rk3066.c | 2 +- drivers/ram/rockchip/sdram_rk3188.c | 2 +- drivers/ram/rockchip/sdram_rk322x.c | 2 +- drivers/ram/rockchip/sdram_rk3288.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- include/regmap.h | 2 +- 9 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/core/regmap.c b/drivers/core/regmap.c index e33bb9d7..37da64b2 100644 --- a/drivers/core/regmap.c +++ b/drivers/core/regmap.c @@ -79,7 +79,7 @@ static struct regmap *regmap_alloc(int count) }
#if CONFIG_IS_ENABLED(OF_PLATDATA) -int regmap_init_mem_plat(struct udevice *dev, fdt_val_t *reg, int count, +int regmap_init_mem_plat(struct udevice *dev, phys_addr_t *reg, int count, struct regmap **mapp) { struct regmap_range *range; diff --git a/drivers/core/syscon-uclass.c b/drivers/core/syscon-uclass.c index 25fdb66e..69b66773 100644 --- a/drivers/core/syscon-uclass.c +++ b/drivers/core/syscon-uclass.c @@ -58,7 +58,7 @@ static int syscon_pre_probe(struct udevice *dev) #if CONFIG_IS_ENABLED(OF_PLATDATA) struct syscon_base_plat *plat = dev_get_plat(dev);
- return regmap_init_mem_plat(dev, plat->reg, ARRAY_SIZE(plat->reg), + return regmap_init_mem_plat(dev, (phys_addr_t *)plat->reg, ARRAY_SIZE(plat->reg), &priv->regmap); #else return regmap_init_mem(dev_ofnode(dev), &priv->regmap); diff --git a/drivers/ram/rockchip/sdram_rk3066.c b/drivers/ram/rockchip/sdram_rk3066.c index a2425f22..9bb26b64 100644 --- a/drivers/ram/rockchip/sdram_rk3066.c +++ b/drivers/ram/rockchip/sdram_rk3066.c @@ -801,7 +801,7 @@ static int rk3066_dmc_conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); /* RK3066 supports dual-channel, set default channel num to 2. */ plat->num_channels = 1; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3188.c b/drivers/ram/rockchip/sdram_rk3188.c index 272b1b2d..1838985c 100644 --- a/drivers/ram/rockchip/sdram_rk3188.c +++ b/drivers/ram/rockchip/sdram_rk3188.c @@ -867,7 +867,7 @@ static int conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); /* rk3188 supports dual-channel, set default channel num to 2 */ plat->num_channels = 1; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c index 1b204fb5..33599dc5 100644 --- a/drivers/ram/rockchip/sdram_rk322x.c +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -769,7 +769,7 @@ static int conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base));
plat->num_channels = 1; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3288.c b/drivers/ram/rockchip/sdram_rk3288.c index 83778ad1..1a548da5 100644 --- a/drivers/ram/rockchip/sdram_rk3288.c +++ b/drivers/ram/rockchip/sdram_rk3288.c @@ -1029,7 +1029,7 @@ static int conv_of_plat(struct udevice *dev) memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); /* Rk3288 supports dual-channel, set default channel num to 2 */ plat->num_channels = 2; - ret = regmap_init_mem_plat(dev, of_plat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)of_plat->reg, ARRAY_SIZE(of_plat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c index b511c6bf..2427efe0 100644 --- a/drivers/ram/rockchip/sdram_rk3328.c +++ b/drivers/ram/rockchip/sdram_rk3328.c @@ -54,7 +54,7 @@ static int conv_of_plat(struct udevice *dev) struct dtd_rockchip_rk3328_dmc *dtplat = &plat->dtplat; int ret;
- ret = regmap_init_mem_plat(dev, dtplat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)dtplat->reg, ARRAY_SIZE(dtplat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 136e4ede..c88fdbb3 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -3049,7 +3049,7 @@ static int conv_of_plat(struct udevice *dev) struct dtd_rockchip_rk3399_dmc *dtplat = &plat->dtplat; int ret;
- ret = regmap_init_mem_plat(dev, dtplat->reg, + ret = regmap_init_mem_plat(dev, (phys_addr_t *)dtplat->reg, ARRAY_SIZE(dtplat->reg) / 2, &plat->map); if (ret) return ret; diff --git a/include/regmap.h b/include/regmap.h index e81a3602..a274fb27 100644 --- a/include/regmap.h +++ b/include/regmap.h @@ -388,7 +388,7 @@ int regmap_init_mem(ofnode node, struct regmap **mapp); * Use regmap_uninit() to free it. * */ -int regmap_init_mem_plat(struct udevice *dev, fdt_val_t *reg, int count, +int regmap_init_mem_plat(struct udevice *dev, phys_addr_t *reg, int count, struct regmap **mapp);
int regmap_init_mem_index(ofnode node, struct regmap **mapp, int index); -- 2.20.1
Hi Johan,
That cast does not seem very safe. Should we add a new init function with that type, instead?
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expext 64-bit data from the device tree parser, so use dev_read_addr_ptr in the rockchip-saradc.c file.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- drivers/adc/rockchip-saradc.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/adc/rockchip-saradc.c b/drivers/adc/rockchip-saradc.c index 760f8fe6..de9298a2 100644 --- a/drivers/adc/rockchip-saradc.c +++ b/drivers/adc/rockchip-saradc.c @@ -145,8 +145,8 @@ int rockchip_saradc_of_to_plat(struct udevice *dev) struct rockchip_saradc_data *data;
data = (struct rockchip_saradc_data *)dev_get_driver_data(dev); - priv->regs = (struct rockchip_saradc_regs *)dev_read_addr(dev); - if (priv->regs == (struct rockchip_saradc_regs *)FDT_ADDR_T_NONE) { + priv->regs = (struct rockchip_saradc_regs *)dev_read_addr_ptr(dev); + if (!priv->regs) { pr_err("Dev: %s - can't get address!", dev->name); return -ENODATA; } -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expect 64-bit data from the device tree parser, so convert dev_read_addr output to phys_addr_t in the dw-apb-timer.c file.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/timer/dw-apb-timer.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/timer/dw-apb-timer.c b/drivers/timer/dw-apb-timer.c index 10f0a9f6..f55a3c54 100644 --- a/drivers/timer/dw-apb-timer.c +++ b/drivers/timer/dw-apb-timer.c @@ -23,7 +23,7 @@ #define DW_APB_CTRL 0x8
struct dw_apb_timer_priv { - fdt_addr_t regs; + phys_addr_t regs; struct reset_ctl_bulk resets; };
@@ -92,7 +92,7 @@ static int dw_apb_timer_of_to_plat(struct udevice *dev) if (CONFIG_IS_ENABLED(OF_REAL)) { struct dw_apb_timer_priv *priv = dev_get_priv(dev);
- priv->regs = dev_read_addr(dev); + priv->regs = (phys_addr_t)dev_read_addr(dev); }
return 0; -- 2.20.1
The fdt_addr_t and phys_addr_t size have been decoupled. A 32bit CPU can expext 64-bit data from the device tree parser, so use dev_read_addr_ptr in the rockchip_nfc.c file.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index d016d255..5d444133 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -1180,9 +1180,9 @@ static int rk_nfc_probe(struct udevice *dev) nfc->cfg = (void *)dev_get_driver_data(dev); nfc->dev = dev;
- nfc->regs = (void *)dev_read_addr(dev); - if (IS_ERR(nfc->regs)) { - ret = PTR_ERR(nfc->regs); + nfc->regs = dev_read_addr_ptr(dev); + if (!nfc->regs) { + ret = -ENODATA; goto release_nfc; }
-- 2.20.1
Reviewed-By: Michael Trimarchi michael@amarulasolutions.com
if (!nfc->regs) {
-- 2.20.1
The compatible string for rk3308 has as fallback string "rockchip,rv1108-nfc". As there is no logic in probe priority between the SoC orientated string and the fall back, so remove the compatible string "rockchip,rk3308-nfc" from the driver.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index 5d444133..a8ec6bfc 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -1165,10 +1165,6 @@ static const struct udevice_id rk_nfc_id_table[] = { .compatible = "rockchip,rv1108-nfc", .data = (unsigned long)&nfc_v8_cfg }, - { - .compatible = "rockchip,rk3308-nfc", - .data = (unsigned long)&nfc_v8_cfg - }, { /* sentinel */ } };
-- 2.20.1
The MTD framework in U-boot is not identical for drivers ported from Linux. The rockchip_nfc driver was ported with OOB ops functions while the framework expects a layout structure per chip. Fix by adding a structure with OOB data and remove unused functions.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 61 ++++++++++------------------- 1 file changed, 20 insertions(+), 41 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index a8ec6bfc..ab13e52c 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -814,47 +814,9 @@ static void rk_nfc_disable_clks(struct rk_nfc *nfc) clk_disable_unprepare(nfc->ahb_clk); }
-static int rk_nfc_ooblayout_free(struct mtd_info *mtd, int section, - struct mtd_oob_region *oob_region) -{ - struct nand_chip *chip = mtd_to_nand(mtd); - struct rk_nfc_nand_chip *rknand = rk_nfc_to_rknand(chip); - - if (section) - return -ERANGE; - - /* - * The beginning of the OOB area stores the reserved data for the NFC, - * the size of the reserved data is NFC_SYS_DATA_SIZE bytes. - */ - oob_region->length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; - oob_region->offset = NFC_SYS_DATA_SIZE + 2; - - return 0; -} - -static int rk_nfc_ooblayout_ecc(struct mtd_info *mtd, int section, - struct mtd_oob_region *oob_region) -{ - struct nand_chip *chip = mtd_to_nand(mtd); - struct rk_nfc_nand_chip *rknand = rk_nfc_to_rknand(chip); - - if (section) - return -ERANGE; - - oob_region->length = mtd->oobsize - rknand->metadata_size; - oob_region->offset = rknand->metadata_size; - - return 0; -} - -static const struct mtd_ooblayout_ops rk_nfc_ooblayout_ops = { - .rfree = rk_nfc_ooblayout_free, - .ecc = rk_nfc_ooblayout_ecc, -}; - static int rk_nfc_ecc_init(struct rk_nfc *nfc, struct nand_chip *chip) { + struct rk_nfc_nand_chip *rknand = rk_nfc_to_rknand(chip); const u8 *strengths = nfc->cfg->ecc_strengths; struct mtd_info *mtd = nand_to_mtd(chip); struct nand_ecc_ctrl *ecc = &chip->ecc; @@ -892,6 +854,21 @@ static int rk_nfc_ecc_init(struct rk_nfc *nfc, struct nand_chip *chip) ecc->steps = mtd->writesize / ecc->size; ecc->bytes = DIV_ROUND_UP(ecc->strength * fls(8 * chip->ecc.size), 8);
+ if (ecc->bytes * ecc->steps > mtd->oobsize - rknand->metadata_size) + return -EINVAL; + + ecc->layout = kzalloc(sizeof(*ecc->layout), GFP_KERNEL); + if (!ecc->layout) + return -ENOMEM; + + ecc->layout->eccbytes = ecc->bytes * ecc->steps; + + for (i = 0; i < ecc->layout->eccbytes; i++) + ecc->layout->eccpos[i] = rknand->metadata_size + i; + + ecc->layout->oobfree[0].length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; + ecc->layout->oobfree[0].offset = NFC_SYS_DATA_SIZE + 2; + return 0; }
@@ -969,7 +946,6 @@ static int rk_nfc_nand_chip_init(ofnode node, struct rk_nfc *nfc, int devnum) chip->bbt_options = NAND_BBT_USE_FLASH | NAND_BBT_NO_OOB; chip->options |= NAND_NO_SUBPAGE_WRITE | NAND_USE_BOUNCE_BUFFER;
- mtd_set_ooblayout(mtd, &rk_nfc_ooblayout_ops); rk_nfc_hw_init(nfc); ret = nand_scan_ident(mtd, nsels, NULL); if (ret) @@ -998,13 +974,16 @@ static int rk_nfc_nand_chip_init(ofnode node, struct rk_nfc *nfc, int devnum)
if (!nfc->page_buf) { nfc->page_buf = kzalloc(NFC_MAX_PAGE_SIZE, GFP_KERNEL); - if (!nfc->page_buf) + if (!nfc->page_buf) { + kfree(ecc->layout); return -ENOMEM; + } }
if (!nfc->oob_buf) { nfc->oob_buf = kzalloc(NFC_MAX_OOB_SIZE, GFP_KERNEL); if (!nfc->oob_buf) { + kfree(ecc->layout); kfree(nfc->page_buf); nfc->page_buf = NULL; return -ENOMEM; -- 2.20.1
Add flash_node to the rockchip_nfc driver chip structure in order to find the partitions in the add_mtd_partitions_of() function.
Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index ab13e52c..ca5e7313 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -934,6 +934,7 @@ static int rk_nfc_nand_chip_init(ofnode node, struct rk_nfc *nfc, int devnum)
nand_set_controller_data(chip, nfc);
+ chip->flash_node = node; chip->chip_delay = NFC_RB_DELAY_US; chip->select_chip = rk_nfc_select_chip; chip->cmd_ctrl = rk_nfc_cmd; -- 2.20.1
Sandisk SDTNQGAMA is a 8GB size, 3.3V 8 bit chip with 16KB page size, 1KB write size and 40 bit ecc support
Signed-off-by: Paweł Jarosz paweljarosz3691@gmail.com Signed-off-by: Johan Jonker jbx6244@gmail.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/mtd/nand/raw/nand_ids.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mtd/nand/raw/nand_ids.c b/drivers/mtd/nand/raw/nand_ids.c index d0cfacc6..22ea5e2f 100644 --- a/drivers/mtd/nand/raw/nand_ids.c +++ b/drivers/mtd/nand/raw/nand_ids.c @@ -48,6 +48,9 @@ struct nand_flash_dev nand_flash_ids[] = { {"TC58NVG6D2 64G 3.3V 8-bit", { .id = {0x98, 0xde, 0x94, 0x82, 0x76, 0x56, 0x04, 0x20} }, SZ_8K, SZ_8K, SZ_2M, 0, 8, 640, NAND_ECC_INFO(40, SZ_1K) }, + {"SDTNQGAMA 64G 3.3V 8-bit", + { .id = {0x45, 0xde, 0x94, 0x93, 0x76, 0x57} }, + SZ_16K, SZ_8K, SZ_4M, 0, 6, 1280, NAND_ECC_INFO(40, SZ_1K) }, {"SDTNRGAMA 64G 3.3V 8-bit", { .id = {0x45, 0xde, 0x94, 0x93, 0x76, 0x50} }, SZ_16K, SZ_8K, SZ_4M, 0, 6, 1280, NAND_ECC_INFO(40, SZ_1K) }, -- 2.20.1
The MTD framework reserves 1 or 2 bytes for the bad block marker depending on the bus size. The rockchip_nfc driver currently only supports a 8 bit bus, but reserves standard 2 bytes for the BBM. The first free OOB byte is therefore OOB2 at offset 2. Page address(PA) bytes are moved to the last 4 positions before ECC. Update the description for U-boot.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- drivers/mtd/nand/raw/rockchip_nfc.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/raw/rockchip_nfc.c b/drivers/mtd/nand/raw/rockchip_nfc.c index ca5e7313..5ca7eeb8 100644 --- a/drivers/mtd/nand/raw/rockchip_nfc.c +++ b/drivers/mtd/nand/raw/rockchip_nfc.c @@ -487,10 +487,10 @@ static int rk_nfc_write_page_raw(struct mtd_info *mtd, * * BBM OOB1 OOB2 OOB3 |......| PA0 PA1 PA2 PA3 * - * The rk_nfc_ooblayout_free() function already has reserved - * these 4 bytes with: + * The oobfree structure already has reserved these 4 bytes + * together with 2 bytes for BBM by reducing it's length: * - * oob_region->offset = NFC_SYS_DATA_SIZE + 2; + * oobfree[0].length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; */ if (!i) memcpy(rk_nfc_oob_ptr(chip, i), @@ -867,7 +867,7 @@ static int rk_nfc_ecc_init(struct rk_nfc *nfc, struct nand_chip *chip) ecc->layout->eccpos[i] = rknand->metadata_size + i;
ecc->layout->oobfree[0].length = rknand->metadata_size - NFC_SYS_DATA_SIZE - 2; - ecc->layout->oobfree[0].offset = NFC_SYS_DATA_SIZE + 2; + ecc->layout->oobfree[0].offset = 2;
return 0; } -- 2.20.1
Johan Jonker
Michael Nazzareno Trimarchi
