[U-Boot] [PATCH v2] kconfig: convert Kconfig helper script into a shell script
Commit 51148790 added scripts/multiconfig.py written in Python 2 to adjust Kconfig for U-Boot.
It has been hard for Python 3 users because Python 2 and Python 3 are not compatible with each other.
We are not happy about adding a new host tool dependency (in this case, Python version dependency) for the core build process. After some discussion, we decided to use only basic tools.
The script may get a bit unreadable by shell scripting, but we believe it is worthwhile.
In addition, this commit revives "<board>_config" target that is equivalent to "<board>_defconfig" for backwards compatibility. It is annoying to adjust various projects which use U-Boot.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Suggested-by: Igor Grinberg grinberg@compulab.co.il Cc: Tom Rini trini@ti.com Cc: Jeroen Hofstee jeroen@myspectrum.nl Cc: Simon Glass sjg@chromium.org Cc: Stephen Warren swarren@wwwdotorg.org ---
To apply this patch cleanly, the following is needed: http://patchwork.ozlabs.org/patch/380316/
Changes in v2: - Update git-description to mention the support for "<board>_config"
Makefile | 4 +- scripts/multiconfig.py | 405 ------------------------------------------------- scripts/multiconfig.sh | 251 ++++++++++++++++++++++++++++++ 3 files changed, 253 insertions(+), 407 deletions(-) delete mode 100755 scripts/multiconfig.py create mode 100644 scripts/multiconfig.sh
diff --git a/Makefile b/Makefile index b5d5e01..2938dec 100644 --- a/Makefile +++ b/Makefile @@ -462,10 +462,10 @@ KBUILD_DEFCONFIG := sandbox_defconfig export KBUILD_DEFCONFIG KBUILD_KCONFIG
config: scripts_basic outputmakefile FORCE - +$(Q)$(PYTHON) $(srctree)/scripts/multiconfig.py $@ + (Q)$(MAKE) $(build)=scripts/kconfig $@
%config: scripts_basic outputmakefile FORCE - +$(Q)$(PYTHON) $(srctree)/scripts/multiconfig.py $@ + +$(Q)$(CONFIG_SHELL) $(srctree)/scripts/multiconfig.sh $@
else # =========================================================================== diff --git a/scripts/multiconfig.py b/scripts/multiconfig.py deleted file mode 100755 index 69a470e..0000000 --- a/scripts/multiconfig.py +++ /dev/null @@ -1,405 +0,0 @@ -#!/usr/bin/env python -# -# Copyright (C) 2014, Masahiro Yamada yamada.m@jp.panasonic.com -# -# SPDX-License-Identifier: GPL-2.0+ -# - -""" -A wrapper script to adjust Kconfig for U-Boot - -The biggest difference between Linux Kernel and U-Boot in terms of the -board configuration is that U-Boot has to configure multiple boot images -per board: Normal, SPL, TPL. -We need to expand the functions of Kconfig to handle multiple boot -images. - -Instead of touching various parts under the scripts/kconfig/ directory, -pushing necessary adjustments into this single script would be better -for code maintainance. All the make targets related to the configuration -(make %config) should be invoked via this script. - -Let's see what is different from the original Kconfig. - -- config, menuconfig, etc. - -The commands 'make config', 'make menuconfig', etc. are used to create -or modify the .config file, which stores configs for Normal boot image. - -The location of the one for SPL, TPL image is spl/.config, tpl/.config, -respectively. Use 'make spl/config', 'make spl/menuconfig', etc. -to create or modify the spl/.config file, which contains configs -for SPL image. -Do likewise for the tpl/.config file. -The generic syntax for SPL, TPL configuration is -'make <target_image>/<config_command>'. - -- silentoldconfig - -The command 'make silentoldconfig' updates .config, if necessary, and -additionally updates include/generated/autoconf.h and files under -include/configs/ directory. In U-Boot, it should do the same things for -SPL, TPL images for boards supporting them. -Depending on whether CONFIG_SPL, CONFIG_TPL is defined or not, -'make silentoldconfig' iterates three times at most changing the target -directory. - -To sum up, 'make silentoldconfig' possibly updates - - .config, include/generated/autoconf.h, include/config/* - - spl/.config, spl/include/generated/autoconf.h, spl/include/config/* - (in case CONFIG_SPL=y) - - tpl/.config, tpl/include/generated/autoconf.h, tpl/include/config/* - (in case CONFIG_TPL=y) - -- defconfig, <board>_defconfig - -The command 'make <board>_defconfig' creates a new .config based on the -file configs/<board>_defconfig. The command 'make defconfig' is the same -but the difference is it uses the file specified with KBUILD_DEFCONFIG -environment. - -We need to create .config, spl/.config, tpl/.config for boards where SPL -and TPL images are supported. One possible solution for that is to have -multiple defconfig files per board, but it would produce duplication -among the defconfigs. -The approach chosen here is to expand the feature and support -conditional definition in defconfig, that is, each line in defconfig -files has the form of: -<condition>:<macro definition> - -The '<condition>:' prefix specifies which image the line is valid for. -The '<condition>:' is one of: - None - the line is valid only for Normal image - S: - the line is valid only for SPL image - T: - the line is valid only for TPL image - ST: - the line is valid for SPL and TPL images - +S: - the line is valid for Normal and SPL images - +T: - the line is valid for Normal and TPL images - +ST: - the line is valid for Normal, SPL and SPL images - -So, if neither CONFIG_SPL nor CONFIG_TPL is defined, the defconfig file -has no '<condition>:' part and therefore has the same form of that of -Linux Kernel. - -In U-Boot, for example, a defconfig file can be written like this: - - CONFIG_FOO=100 - S:CONFIG_FOO=200 - T:CONFIG_FOO=300 - ST:CONFIG_BAR=y - +S:CONFIG_BAZ=y - +T:CONFIG_QUX=y - +ST:CONFIG_QUUX=y - -The defconfig above is parsed by this script and internally divided into -three temporary defconfig files. - - - Temporary defconfig for Normal image - CONFIG_FOO=100 - CONFIG_BAZ=y - CONFIG_QUX=y - CONFIG_QUUX=y - - - Temporary defconfig for SPL image - CONFIG_FOO=200 - CONFIG_BAR=y - CONFIG_BAZ=y - CONFIG_QUUX=y - - - Temporary defconfig for TPL image - CONFIG_FOO=300 - CONFIG_BAR=y - CONFIG_QUX=y - CONFIG_QUUX=y - -They are passed to scripts/kconfig/conf, each is used for generating -.config, spl/.config, tpl/.config, respectively. - -- savedefconfig - -This is the reverse operation of 'make defconfig'. -If neither CONFIG_SPL nor CONFIG_TPL is defined in the .config file, -it works as 'make savedefconfig' in Linux Kernel: create the minimal set -of config based on the .config and save it into 'defconfig' file. - -If CONFIG_SPL or CONFIG_TPL is defined, the common lines among .config, -spl/.config, tpl/.config are coalesced together and output to the file -'defconfig' in the form like: - - CONFIG_FOO=100 - S:CONFIG_FOO=200 - T:CONFIG_FOO=300 - ST:CONFIG_BAR=y - +S:CONFIG_BAZ=y - +T:CONFIG_QUX=y - +ST:CONFIG_QUUX=y - -This can be used as an input of 'make <board>_defconfig' command. -""" - -import errno -import os -import re -import subprocess -import sys - -# Constant variables -SUB_IMAGES = ('spl', 'tpl') -IMAGES = ('',) + SUB_IMAGES -SYMBOL_MAP = {'': '+', 'spl': 'S', 'tpl': 'T'} -PATTERN_SYMBOL = re.compile(r'(+?)(S?)(T?):(.*)') - -# Environment variables (should be defined in the top Makefile) -# .get('key', 'default_value') method is useful for standalone testing. -MAKE = os.environ.get('MAKE', 'make') -srctree = os.environ.get('srctree', '.') -KCONFIG_CONFIG = os.environ.get('KCONFIG_CONFIG', '.config') - -# Useful shorthand -build = '%s -f %s/scripts/Makefile.build obj=scripts/kconfig %%s' % (MAKE, srctree) -autoconf = '%s -f %s/scripts/Makefile.autoconf obj=%%s %%s' % (MAKE, srctree) - -### helper functions ### -def mkdirs(*dirs): - """Make directories ignoring 'File exists' error.""" - for d in dirs: - try: - os.makedirs(d) - except OSError as exception: - # Ignore 'File exists' error - if exception.errno != errno.EEXIST: - raise - -def rmfiles(*files): - """Remove files ignoring 'No such file or directory' error.""" - for f in files: - try: - os.remove(f) - except OSError as exception: - # Ignore 'No such file or directory' error - if exception.errno != errno.ENOENT: - raise - -def rmdirs(*dirs): - """Remove directories ignoring 'No such file or directory' - and 'Directory not empty' error. - """ - for d in dirs: - try: - os.rmdir(d) - except OSError as exception: - # Ignore 'No such file or directory' - # and 'Directory not empty' error - if exception.errno != errno.ENOENT and \ - exception.errno != errno.ENOTEMPTY: - raise - -def run_command(command, callback_on_error=None): - """Run the given command in a sub-shell (and exit if it fails). - - Arguments: - command: A string of the command - callback_on_error: Callback handler invoked just before exit - when the command fails (Default=None) - """ - retcode = subprocess.call(command, shell=True) - if retcode: - if callback_on_error: - callback_on_error() - sys.exit("'%s' Failed" % command) - -def run_make_config(cmd, objdir, callback_on_error=None): - """Run the make command in a sub-shell (and exit if it fails). - - Arguments: - cmd: Make target such as 'config', 'menuconfig', 'defconfig', etc. - objdir: Target directory where the make command is run. - Typically '', 'spl', 'tpl' for Normal, SPL, TPL image, - respectively. - callback_on_error: Callback handler invoked just before exit - when the command fails (Default=None) - """ - # Linux expects defconfig files in arch/$(SRCARCH)/configs/ directory, - # but U-Boot puts them in configs/ directory. - # Give SRCARCH=.. to fake scripts/kconfig/Makefile. - options = 'SRCARCH=.. KCONFIG_OBJDIR=%s' % objdir - if objdir: - options += ' KCONFIG_CONFIG=%s/%s' % (objdir, KCONFIG_CONFIG) - mkdirs(objdir) - run_command(build % cmd + ' ' + options, callback_on_error) - -def get_enabled_subimages(ignore_error=False): - """Parse .config file to detect if CONFIG_SPL, CONFIG_TPL is enabled - and return a tuple of enabled subimages. - - Arguments: - ignore_error: Specify the behavior when '.config' is not found; - Raise an exception if this flag is False. - Return a null tuple if this flag is True. - - Returns: - A tuple of enabled subimages as follows: - () if neither CONFIG_SPL nor CONFIG_TPL is defined - ('spl',) if CONFIG_SPL is defined but CONFIG_TPL is not - ('spl', 'tpl') if both CONFIG_SPL and CONFIG_TPL are defined - """ - enabled = () - match_patterns = [ (img, 'CONFIG_' + img.upper() + '=y\n') - for img in SUB_IMAGES ] - try: - f = open(KCONFIG_CONFIG) - except IOError as exception: - if not ignore_error or exception.errno != errno.ENOENT: - raise - return enabled - with f: - for line in f: - for img, pattern in match_patterns: - if line == pattern: - enabled += (img,) - return enabled - -def do_silentoldconfig(cmd): - """Run 'make silentoldconfig' for all the enabled images. - - Arguments: - cmd: should always be a string 'silentoldconfig' - """ - run_make_config(cmd, '') - subimages = get_enabled_subimages() - for obj in subimages: - mkdirs(os.path.join(obj, 'include', 'config'), - os.path.join(obj, 'include', 'generated')) - run_make_config(cmd, obj) - remove_auto_conf = lambda : rmfiles('include/config/auto.conf') - # If the following part failed, include/config/auto.conf should be deleted - # so 'make silentoldconfig' will be re-run on the next build. - run_command(autoconf % - ('include', 'include/autoconf.mk include/autoconf.mk.dep'), - remove_auto_conf) - # include/config.h has been updated after 'make silentoldconfig'. - # We need to touch include/config/auto.conf so it gets newer - # than include/config.h. - # Otherwise, 'make silentoldconfig' would be invoked twice. - os.utime('include/config/auto.conf', None) - for obj in subimages: - run_command(autoconf % (obj + '/include', - obj + '/include/autoconf.mk'), - remove_auto_conf) - -def do_tmp_defconfig(output_lines, img): - """Helper function for do_board_defconfig(). - - Write the defconfig contents into a file '.tmp_defconfig' and - invoke 'make .tmp_defconfig'. - - Arguments: - output_lines: A sequence of defconfig lines of each image - img: Target image. Typically '', 'spl', 'tpl' for - Normal, SPL, TPL images, respectively. - """ - TMP_DEFCONFIG = '.tmp_defconfig' - TMP_DIRS = ('arch', 'configs') - defconfig_path = os.path.join('configs', TMP_DEFCONFIG) - mkdirs(*TMP_DIRS) - with open(defconfig_path, 'w') as f: - f.write(''.join(output_lines[img])) - cleanup = lambda: (rmfiles(defconfig_path), rmdirs(*TMP_DIRS)) - run_make_config(TMP_DEFCONFIG, img, cleanup) - cleanup() - -def do_board_defconfig(cmd): - """Run 'make <board>_defconfig'. - - Arguments: - cmd: should be a string '<board>_defconfig' - """ - defconfig_path = os.path.join(srctree, 'configs', cmd) - output_lines = dict([ (img, []) for img in IMAGES ]) - with open(defconfig_path) as f: - for line in f: - m = PATTERN_SYMBOL.match(line) - if m: - for idx, img in enumerate(IMAGES): - if m.group(idx + 1): - output_lines[img].append(m.group(4) + '\n') - continue - output_lines[''].append(line) - do_tmp_defconfig(output_lines, '') - for img in get_enabled_subimages(): - do_tmp_defconfig(output_lines, img) - -def do_defconfig(cmd): - """Run 'make defconfig'. - - Arguments: - cmd: should always be a string 'defconfig' - """ - KBUILD_DEFCONFIG = os.environ['KBUILD_DEFCONFIG'] - print "*** Default configuration is based on '%s'" % KBUILD_DEFCONFIG - do_board_defconfig(KBUILD_DEFCONFIG) - -def do_savedefconfig(cmd): - """Run 'make savedefconfig'. - - Arguments: - cmd: should always be a string 'savedefconfig' - """ - DEFCONFIG = 'defconfig' - # Continue even if '.config' does not exist - subimages = get_enabled_subimages(True) - run_make_config(cmd, '') - output_lines = [] - prefix = {} - with open(DEFCONFIG) as f: - for line in f: - output_lines.append(line) - prefix[line] = '+' - for img in subimages: - run_make_config(cmd, img) - unmatched_lines = [] - with open(DEFCONFIG) as f: - for line in f: - if line in output_lines: - index = output_lines.index(line) - output_lines[index:index] = unmatched_lines - unmatched_lines = [] - prefix[line] += SYMBOL_MAP[img] - else: - ummatched_lines.append(line) - prefix[line] = SYMBOL_MAP[img] - with open(DEFCONFIG, 'w') as f: - for line in output_lines: - if prefix[line] == '+': - f.write(line) - else: - f.write(prefix[line] + ':' + line) - -def do_others(cmd): - """Run the make command other than 'silentoldconfig', 'defconfig', - '<board>_defconfig' and 'savedefconfig'. - - Arguments: - cmd: Make target in the form of '<target_image>/<config_command>' - The field '<target_image>/' is typically empty, 'spl/', 'tpl/' - for Normal, SPL, TPL images, respectively. - The field '<config_command>' is make target such as 'config', - 'menuconfig', etc. - """ - objdir, _, cmd = cmd.rpartition('/') - run_make_config(cmd, objdir) - -cmd_list = {'silentoldconfig': do_silentoldconfig, - 'defconfig': do_defconfig, - 'savedefconfig': do_savedefconfig} - -def main(): - cmd = sys.argv[1] - if cmd.endswith('_defconfig'): - do_board_defconfig(cmd) - else: - func = cmd_list.get(cmd, do_others) - func(cmd) - -if __name__ == '__main__': - main() diff --git a/scripts/multiconfig.sh b/scripts/multiconfig.sh new file mode 100644 index 0000000..e831428 --- /dev/null +++ b/scripts/multiconfig.sh @@ -0,0 +1,251 @@ +#!/bin/sh +# +# A wrapper script to adjust Kconfig for U-Boot +# +# Instead of touching various parts under the scripts/kconfig/ directory, +# pushing necessary adjustments into this single script would be better +# for code maintainance. All the make targets related to the configuration +# (make %config) should be invoked via this script. +# See doc/README.kconfig for further information of Kconfig. +# +# Copyright (C) 2014, Masahiro Yamada yamada.m@jp.panasonic.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +set -e + +# Set "DEBUG" enavironment variable to show debug messages +debug () { + if [ $DEBUG ]; then + echo "$@" + fi +} + +# Useful shorthands +build () { + debug $progname: $MAKE -f $srctree/scripts/Makefile.build obj="$@" + $MAKE -f $srctree/scripts/Makefile.build obj="$@" +} + +autoconf () { + debug $progname: $MAKE -f $srctree/scripts/Makefile.autoconf obj="$@" + $MAKE -f $srctree/scripts/Makefile.autoconf obj="$@" +} + +# Make a configuration target +# Usage: +# run_make_config <target> <objdir> +# <target>: Make target such as "config", "menuconfig", "defconfig", etc. +# <objdir>: Target directory where the make command is run. +# Typically "", "spl", "tpl" for Normal, SPL, TPL, respectively. +run_make_config () { + target=$1 + objdir=$2 + + # Linux expects defconfig files in arch/$(SRCARCH)/configs/ directory, + # but U-Boot has them in configs/ directory. + # Give SRCARCH=.. to fake scripts/kconfig/Makefile. + options="SRCARCH=.. KCONFIG_OBJDIR=$objdir" + if [ "$objdir" ]; then + options="$options KCONFIG_CONFIG=$objdir/$KCONFIG_CONFIG" + mkdir -p $objdir + fi + + build scripts/kconfig $options $target +} + +# Parse .config file to detect if CONFIG_SPL, CONFIG_TPL is enabled +# and returns: +# "" if neither CONFIG_SPL nor CONFIG_TPL is defined +# "spl" if CONFIG_SPL is defined but CONFIG_TPL is not +# "spl tpl" if both CONFIG_SPL and CONFIG_TPL are defined +get_enabled_subimages() { + if [ ! -r "$KCONFIG_CONFIG" ]; then + # This should never happen + echo "$progname: $KCONFIG_CONFIG not found" >&2 + exit 1 + fi + + sed -n -e 's/^CONFIG_(SPL|TPL)=y$/\1/p' $KCONFIG_CONFIG | \ + tr '[A-Z]' '[a-z]' +} + +do_silentoldconfig () { + run_make_config silentoldconfig + subimages=$(get_enabled_subimages) + + for obj in $subimages + do + mkdir -p $obj/include/config $obj/include/generated + run_make_config silentoldconfig $obj + done + + # If the following part fails, include/config/auto.conf should be + # deleted so "make silentoldconfig" will be re-run on the next build. + autoconf include include/autoconf.mk include/autoconf.mk.dep || { + rm -f include/config/auto.conf + exit 1 + } + + # include/config.h has been updated after "make silentoldconfig". + # We need to touch include/config/auto.conf so it gets newer + # than include/config.h. + # Otherwise, 'make silentoldconfig' would be invoked twice. + touch include/config/auto.conf + + for obj in $subimages + do + autoconf $obj/include $obj/include/autoconf.mk || { + rm -f include/config/auto.conf + exit 1 + } + done +} + +cleanup_after_defconfig () { + rm -f configs/.tmp_defconfig + # ignore 'Directory not empty' error without using non-POSIX option + # '--ignore-fail-on-non-empty' + rmdir arch configs 2>/dev/null || true +} + +do_board_defconfig () { + defconfig_path=$srctree/configs/$1 + tmp_defconfig_path=configs/.tmp_defconfig + + mkdir -p arch configs + sed -n -e '/^[+A-Z]*:/!p' -e 's/^+[A-Z]*://p' $defconfig_path \ + > configs/.tmp_defconfig + + run_make_config .tmp_defconfig || { + cleanup_after_defconfig + exit 1 + } + + for img in $(get_enabled_subimages) + do + symbol=$(echo $img | cut -c 1 | tr '[a-z]' '[A-Z]') + sed -n -e 's/^[+A-Z]*'$symbol'[A-Z]*://p' $defconfig_path \ + > configs/.tmp_defconfig + run_make_config .tmp_defconfig $img || { + cleanup_after_defconfig + exit 1 + } + done + + cleanup_after_defconfig +} + +do_defconfig () { + if [ "$KBUILD_DEFCONFIG" ]; then + do_board_defconfig $KBUILD_DEFCONFIG + echo "*** Default configuration is based on '$KBUILD_DEFCONFIG'" + else + run_make_config defconfig + fi +} + +do_savedefconfig () { + if [ -r "$KCONFIG_CONFIG" ]; then + subimages=$(get_enabled_subimages) + else + subimages= + fi + + run_make_config savedefconfig + + output_lines= + + # -r option is necessay because some string-type configs may include + # backslashes as an escape character + while read -r line + do + output_lines="$output_lines $line" + done < defconfig + + for img in $subimages + do + run_make_config savedefconfig $img + + symbol=$(echo $img | cut -c 1 | tr '[a-z]' '[A-Z]') + unmatched= + + while read -r line + do + tmp= + match= + + # coalesce common lines together + for i in $output_lines + do + case "$i" in + "[+A-Z]*:$line") + tmp="$tmp $unmatched" + i=$(echo "$i" | \ + sed -e "s/^([^:])*/\1$symbol/") + tmp="$tmp $i" + match=1 + ;; + "$line") + tmp="$tmp $unmatched" + tmp="$tmp +$symbol:$i" + match=1 + ;; + *) + tmp="$tmp $i" + ;; + esac + done + + if [ "$match" ]; then + output_lines="$tmp" + unmatched= + else + unmatched="$unmatched $symbol:$line" + fi + done < defconfig + done + + rm -f defconfig + for line in $output_lines + do + echo $line >> defconfig + done +} + +# Usage: +# do_others <objdir>/<target> +# The field "<objdir>/" is typically empy, "spl/", "tpl/" for Normal, SPL, TPL, +# respectively. +# The field "<target>" is a configuration target such as "config", +# "menuconfig", etc. +do_others () { + target=${1##*/} + + if [ "$target" = "$1" ]; then + objdir= + else + objdir=${1%/*} + fi + + run_make_config $target $objdir +} + +progname=$(basename $0) +target=$1 + +case $target in +*_defconfig) + do_board_defconfig $target;; +*_config) + do_board_defconfig ${target%_config}_defconfig;; +silentoldconfig) + do_silentoldconfig;; +defconfig) + do_defconfig;; +savedefconfig) + do_savedefconfig;; +*) + do_others $target;; +esac
Tested-by: Igor Grinberg grinberg@compulab.co.il
Thanks Masahiro!
Personally, I think this change isn't justified; I see no reason to replace the perfectly working existing script. Still, if that's what's desired...
Agreed, it seems unfortunate - long shell scripts are so much harder to work with IMO. Is it really not possible to make code compatible with both? Also we have lost the docs at the top of the file I think.
On 08/18/2014 10:27 AM, Simon Glass wrote:
On 18 August 2014 10:20, Stephen Warren <swarren@wwwdotorg.org mailto:swarren@wwwdotorg.org> wrote:
On 08/16/2014 10:56 PM, Masahiro Yamada wrote: Commit 51148790 added scripts/multiconfig.py written in Python 2 to adjust Kconfig for U-Boot. It has been hard for Python 3 users because Python 2 and Python 3 are not compatible with each other. We are not happy about adding a new host tool dependency (in this case, Python version dependency) for the core build process. After some discussion, we decided to use only basic tools. The script may get a bit unreadable by shell scripting, but we believe it is worthwhile. In addition, this commit revives "<board>_config" target that is equivalent to "<board>_defconfig" for backwards compatibility. It is annoying to adjust various projects which use U-Boot. Personally, I think this change isn't justified; I see no reason to replace the perfectly working existing script. Still, if that's what's desired...
It might well be possible to be compatible with both Python 2 and 3, but the solution mentioned earlier in the thread was as simple as:
- #!/usr/bin/python + #!/usr/bin/python2
That would only fail on systems:
a) Without Python2 (which seems a little unlikely at the moment, and even if that's the case by default, there's enough Python2 code that surely a compat package would be available)
b) So old that there is no python2 symlink, just python. I don't know when python2 was added.
Hi Stephen,
On Mon, 18 Aug 2014 10:36:48 -0600 Stephen Warren swarren@wwwdotorg.org wrote:
- #!/usr/bin/python
- #!/usr/bin/python2
We can change the top Makefile as follows:
diff --git a/Makefile b/Makefile index b5d5e01..e830d3d 100644 --- a/Makefile +++ b/Makefile @@ -338,7 +338,7 @@ OBJCOPY = $(CROSS_COMPILE)objcopy OBJDUMP = $(CROSS_COMPILE)objdump AWK = awk PERL = perl -PYTHON = python +PYTHON = python2 DTC = dtc CHECK = sparse
To be more supportive for b), we can also do
PYTHON = $(if $(shell which python2 2>/dev/null), python2, python)
I don't know exactly when 'python2' was added but I think it existed at least from python 2.4. We can not (need not) support older versions than it. The switch above might not be necessary.
Best Regards Masahiro Yamada
Hi.
In that case, I wanted you to stop me earlier. I wrote this patch during my summer vacation. :-(
Actually, it is easy to have scripts/multiconfig.py work on python2.6, python 2.7 and python3.x.
Apply this http://patchwork.ozlabs.org/patch/380316/
and then fix a print statement as follows:
--- a/scripts/multiconfig.py +++ b/scripts/multiconfig.py @@ -336,7 +336,7 @@ def do_defconfig(cmd): cmd: should always be a string 'defconfig' """ KBUILD_DEFCONFIG = os.environ['KBUILD_DEFCONFIG'] - print "*** Default configuration is based on '%s'" % KBUILD_DEFCONFIG + print("*** Default configuration is based on '%s'" % KBUILD_DEFCONFIG) do_board_defconfig(KBUILD_DEFCONFIG)
Pretty easy, isn't it?
But the problem I see here is that the "except foo, bar " statement was replaced with "except foo as bar" and Python 3.x dropped the backwards compatibility.
[1] Python 2.5 or older only understands "except foo, bar"
[2] Python 2.6 thru 2.7 accepts both "except foo, bar" and "except foo as bar"
[3] Python 3.x only accepts "excpet foo as bar"
If we take [3], we have to cut [1].
We need to choose either [1]+[2] (python 2.4 or later, but not python 3.x) or [2]+[3] (python 2.6 or later).
(Python 2.5 is still used in some long-term support distributions, isn't it? Tom?)
The docs at the top of file is duplication of doc/README.kconfig http://patchwork.ozlabs.org/patch/380310/ That is why I just wrote a pointer, "See doc/README.kconfig".
It is true docstrings in each function provide much nicer documentation.
On Tue, Aug 19, 2014 at 11:34:38AM +0900, Masahiro Yamada wrote:
Hi.
Thank you for doing it on your vacation! Yes, I'm _not_ comfortable making python a requirement for _everyone_ to build U-Boot. I'm willing to consider replacing MAKEALL with buildman since that's a more U-Boot developer tool. But for the average user we're making things more complicated than we must just so they can use our software.
participants (5)
Igor Grinberg
Masahiro Yamada
Stephen Warren
