[PATCH 0/2] Add Rockchip dwc-based PCIe controller and PHY support
This patchset add Rockchip dwc-based PCIe controller and PHY found on RK356X platforms. It could support Gen3 as a root complex.
Shawn Lin (2): phy: rockchip: Add Rockchip Synopsys PCIe 3.0 PHY pci: Add Rockchip dwc based PCIe controller driver
drivers/pci/Kconfig | 9 + drivers/pci/Makefile | 1 + drivers/pci/pcie_dw_rockchip.c | 755 ++++++++++++++++++ drivers/phy/rockchip/Kconfig | 6 + drivers/phy/rockchip/Makefile | 1 + .../phy/rockchip/phy-rockchip-snps-pcie3.c | 146 ++++ 6 files changed, 918 insertions(+) create mode 100644 drivers/pci/pcie_dw_rockchip.c create mode 100644 drivers/phy/rockchip/phy-rockchip-snps-pcie3.c
Add the Rockchip Synopsys based PCIe 3.0 PHY driver as part of Generic PHY framework.
Signed-off-by: Shawn Lin shawn.lin@rock-chips.com ---
drivers/phy/rockchip/Kconfig | 6 + drivers/phy/rockchip/Makefile | 1 + .../phy/rockchip/phy-rockchip-snps-pcie3.c | 146 ++++++++++++++++++ 3 files changed, 153 insertions(+) create mode 100644 drivers/phy/rockchip/phy-rockchip-snps-pcie3.c
diff --git a/drivers/phy/rockchip/Kconfig b/drivers/phy/rockchip/Kconfig index 2318e71f35..b794cdaf6a 100644 --- a/drivers/phy/rockchip/Kconfig +++ b/drivers/phy/rockchip/Kconfig @@ -18,6 +18,12 @@ config PHY_ROCKCHIP_PCIE help Enable this to support the Rockchip PCIe PHY.
+config PHY_ROCKCHIP_SNPS_PCIE3 + bool "Rockchip Snps PCIe3 PHY Driver" + depends on PHY && ARCH_ROCKCHIP + help + Support for Rockchip PCIe3 PHY with Synopsys IP block. + config PHY_ROCKCHIP_TYPEC bool "Rockchip TYPEC PHY Driver" depends on ARCH_ROCKCHIP diff --git a/drivers/phy/rockchip/Makefile b/drivers/phy/rockchip/Makefile index 44049154f9..f6ad3bf59a 100644 --- a/drivers/phy/rockchip/Makefile +++ b/drivers/phy/rockchip/Makefile @@ -5,4 +5,5 @@
obj-$(CONFIG_PHY_ROCKCHIP_INNO_USB2) += phy-rockchip-inno-usb2.o obj-$(CONFIG_PHY_ROCKCHIP_PCIE) += phy-rockchip-pcie.o +obj-$(CONFIG_PHY_ROCKCHIP_SNPS_PCIE3) += phy-rockchip-snps-pcie3.o obj-$(CONFIG_PHY_ROCKCHIP_TYPEC) += phy-rockchip-typec.o diff --git a/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c b/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c new file mode 100644 index 0000000000..3132f811b9 --- /dev/null +++ b/drivers/phy/rockchip/phy-rockchip-snps-pcie3.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Rockchip PCIE3.0 phy driver + * + * Copyright (C) 2021 Rockchip Electronics Co., Ltd. + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dm/lists.h> +#include <generic-phy.h> +#include <syscon.h> +#include <asm/io.h> +#include <dm/device_compat.h> +#include <regmap.h> +#include <reset-uclass.h> + +#define GRF_PCIE30PHY_CON1 0x4 +#define GRF_PCIE30PHY_CON6 0x18 +#define GRF_PCIE30PHY_CON9 0x24 + +struct rockchip_p3phy_priv { + void __iomem *mmio; + int mode; + struct regmap *phy_grf; + struct reset_ctl p30phy; + struct clk ref_clk_m; + struct clk ref_clk_n; + struct clk pclk; +}; + +static int rochchip_p3phy_init(struct phy *phy) +{ + struct rockchip_p3phy_priv *priv = dev_get_priv(phy->dev); + int ret; + + ret = clk_enable(&priv->ref_clk_m); + if (ret < 0 && ret != -ENOSYS) + return ret; + + ret = clk_enable(&priv->ref_clk_n); + if (ret < 0 && ret != -ENOSYS) + goto err_ref; + + ret = clk_enable(&priv->pclk); + if (ret < 0 && ret != -ENOSYS) + goto err_pclk; + + reset_assert(&priv->p30phy); + udelay(1); + + /* Deassert PCIe PMA output clamp mode */ + regmap_write(priv->phy_grf, GRF_PCIE30PHY_CON9, + (0x1 << 15) | (0x1 << 31)); + + reset_deassert(&priv->p30phy); + udelay(1); + + return 0; +err_pclk: + clk_disable(&priv->ref_clk_n); +err_ref: + clk_disable(&priv->ref_clk_m); + return ret; +} + +static int rochchip_p3phy_exit(struct phy *phy) +{ + struct rockchip_p3phy_priv *priv = dev_get_priv(phy->dev); + + clk_disable(&priv->ref_clk_m); + clk_disable(&priv->ref_clk_n); + clk_disable(&priv->pclk); + reset_assert(&priv->p30phy); + return 0; +} + +static int rockchip_p3phy_probe(struct udevice *dev) +{ + struct rockchip_p3phy_priv *priv = dev_get_priv(dev); + struct udevice *syscon; + int ret; + + priv->mmio = (void __iomem *)dev_read_addr(dev); + if ((fdt_addr_t)priv->mmio == FDT_ADDR_T_NONE) + return -EINVAL; + + ret = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, + "rockchip,phy-grf", &syscon); + if (ret) { + pr_err("unable to find syscon device for rockchip,phy-grf\n"); + return ret; + } + + priv->phy_grf = syscon_get_regmap(syscon); + if (IS_ERR(priv->phy_grf)) { + dev_err(dev, "failed to find rockchip,phy_grf regmap\n"); + return PTR_ERR(priv->phy_grf); + } + + ret = reset_get_by_name(dev, "phy", &priv->p30phy); + if (ret) { + dev_err(dev, "no phy reset control specified\n"); + return ret; + } + + ret = clk_get_by_name(dev, "refclk_m", &priv->ref_clk_m); + if (ret) { + dev_err(dev, "failed to find ref clock M\n"); + return PTR_ERR(&priv->ref_clk_m); + } + + ret = clk_get_by_name(dev, "refclk_n", &priv->ref_clk_n); + if (ret) { + dev_err(dev, "failed to find ref clock N\n"); + return PTR_ERR(&priv->ref_clk_n); + } + + ret = clk_get_by_name(dev, "pclk", &priv->pclk); + if (ret) { + dev_err(dev, "failed to find pclk\n"); + return PTR_ERR(&priv->pclk); + } + + return 0; +} + +static struct phy_ops rochchip_p3phy_ops = { + .init = rochchip_p3phy_init, + .exit = rochchip_p3phy_exit, +}; + +static const struct udevice_id rockchip_p3phy_of_match[] = { + { .compatible = "rockchip,rk3568-pcie3-phy" }, + { }, +}; + +U_BOOT_DRIVER(rockchip_pcie3phy) = { + .name = "rockchip_pcie3phy", + .id = UCLASS_PHY, + .of_match = rockchip_p3phy_of_match, + .ops = &rochchip_p3phy_ops, + .probe = rockchip_p3phy_probe, + .priv_auto = sizeof(struct rockchip_p3phy_priv), +};
Hi Shawn,
nits below
help
Can you mention the features here?
- Rockchip PCIE3.0 phy driver
- Copyright (C) 2021 Rockchip Electronics Co., Ltd.
Check header order
https://www.denx.de/wiki/U-Boot/CodingStyle
void __iomem *mmio;
int mode;
please add comments for members
struct clk pclk;
int ret;
return ret;
goto err_ref;
goto err_pclk;
udelay(1);
udelay(1);
+err_pclk:
+err_ref:
blank line before final return (please fix throughout)
return ret;
在 2021/1/14 23:42, Simon Glass 写道:
Hi Shawn,
Thanks for reviewing it, and will fix them in V2.
nits below
help
- config PHY_ROCKCHIP_TYPEC bool "Rockchip TYPEC PHY Driver" depends on ARCH_ROCKCHIP
Check header order
void __iomem *mmio;
int mode;
struct clk pclk;
int ret;
return ret;
goto err_ref;
goto err_pclk;
udelay(1);
udelay(1);
+err_pclk:
+err_ref:
return ret;
Add Rockchip dwc based PCIe controller driver for rk356x platform. Driver support Gen3 by operating as a Root complex.
drivers/pci/Kconfig | 9 + drivers/pci/Makefile | 1 + drivers/pci/pcie_dw_rockchip.c | 755 +++++++++++++++++++++++++++++++++ 3 files changed, 765 insertions(+) create mode 100644 drivers/pci/pcie_dw_rockchip.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 65498bce1d..b1de38f766 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -281,6 +281,15 @@ config PCIE_ROCKCHIP Say Y here if you want to enable PCIe controller support on Rockchip SoCs.
+config PCIE_DW_ROCKCHIP + bool "Rockchip DesignWare based PCIe controller" + depends on ARCH_ROCKCHIP + select DM_PCI + select PHY_ROCKCHIP_SNPS_PCIE3 + help + Say Y here if you want to enable DW PCIe controller support on + Rockchip SoCs. + config PCI_BRCMSTB bool "Broadcom STB PCIe controller" depends on DM_PCI diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 8b4d49a590..5ed94bc95c 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -48,5 +48,6 @@ obj-$(CONFIG_PCIE_INTEL_FPGA) += pcie_intel_fpga.o obj-$(CONFIG_PCI_KEYSTONE) += pcie_dw_ti.o obj-$(CONFIG_PCIE_MEDIATEK) += pcie_mediatek.o obj-$(CONFIG_PCIE_ROCKCHIP) += pcie_rockchip.o +obj-$(CONFIG_PCIE_DW_ROCKCHIP) += pcie_dw_rockchip.o obj-$(CONFIG_PCI_BRCMSTB) += pcie_brcmstb.o obj-$(CONFIG_PCI_OCTEONTX) += pci_octeontx.o diff --git a/drivers/pci/pcie_dw_rockchip.c b/drivers/pci/pcie_dw_rockchip.c new file mode 100644 index 0000000000..aa2cc15e15 --- /dev/null +++ b/drivers/pci/pcie_dw_rockchip.c @@ -0,0 +1,755 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Rockchip DesignWare based PCIe host controller driver + * + * Copyright (c) 2021 Rockchip, Inc. + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <generic-phy.h> +#include <pci.h> +#include <power-domain.h> +#include <power/regulator.h> +#include <reset.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <asm/arch-rockchip/clock.h> +#include <dm/device_compat.h> +#include <linux/iopoll.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct rk_pcie { + struct udevice *dev; + struct udevice *vpcie3v3; + void *dbi_base; + void *apb_base; + void *cfg_base; + fdt_size_t cfg_size; + struct phy phy; + struct clk_bulk clks; + int first_busno; + struct reset_ctl_bulk rsts; + struct gpio_desc rst_gpio; + struct pci_region io; + struct pci_region mem; +}; + +enum { + PCIBIOS_SUCCESSFUL = 0x0000, + PCIBIOS_UNSUPPORTED = -ENODEV, + PCIBIOS_NODEV = -ENODEV, +}; + +#define msleep(a) udelay((a) * 1000) + +/* Parameters for the waiting for iATU enabled routine */ +#define PCIE_CLIENT_GENERAL_DEBUG 0x104 +#define PCIE_CLIENT_HOT_RESET_CTRL 0x180 +#define PCIE_LTSSM_ENABLE_ENHANCE BIT(4) +#define PCIE_CLIENT_LTSSM_STATUS 0x300 +#define SMLH_LINKUP BIT(16) +#define RDLH_LINKUP BIT(17) +#define PCIE_CLIENT_DBG_FIFO_MODE_CON 0x310 +#define PCIE_CLIENT_DBG_FIFO_PTN_HIT_D0 0x320 +#define PCIE_CLIENT_DBG_FIFO_PTN_HIT_D1 0x324 +#define PCIE_CLIENT_DBG_FIFO_TRN_HIT_D0 0x328 +#define PCIE_CLIENT_DBG_FIFO_TRN_HIT_D1 0x32c +#define PCIE_CLIENT_DBG_FIFO_STATUS 0x350 +#define PCIE_CLIENT_DBG_TRANSITION_DATA 0xffff0000 +#define PCIE_CLIENT_DBF_EN 0xffff0003 +#define RK_PCIE_DBG 0 + +/* PCI DBICS registers */ +#define PCIE_LINK_STATUS_REG 0x80 +#define PCIE_LINK_STATUS_SPEED_OFF 16 +#define PCIE_LINK_STATUS_SPEED_MASK (0xf << PCIE_LINK_STATUS_SPEED_OFF) +#define PCIE_LINK_STATUS_WIDTH_OFF 20 +#define PCIE_LINK_STATUS_WIDTH_MASK (0xf << PCIE_LINK_STATUS_WIDTH_OFF) + +#define PCIE_LINK_CAPABILITY 0x7c +#define PCIE_LINK_CTL_2 0xa0 +#define TARGET_LINK_SPEED_MASK 0xf +#define LINK_SPEED_GEN_1 0x1 +#define LINK_SPEED_GEN_2 0x2 +#define LINK_SPEED_GEN_3 0x3 + +#define PCIE_MISC_CONTROL_1_OFF 0x8bc +#define PCIE_DBI_RO_WR_EN BIT(0) + +#define PCIE_LINK_WIDTH_SPEED_CONTROL 0x80c +#define PORT_LOGIC_SPEED_CHANGE BIT(17) + +/* + * iATU Unroll-specific register definitions + * From 4.80 core version the address translation will be made by unroll. + * The registers are offset from atu_base + */ +#define PCIE_ATU_UNR_REGION_CTRL1 0x00 +#define PCIE_ATU_UNR_REGION_CTRL2 0x04 +#define PCIE_ATU_UNR_LOWER_BASE 0x08 +#define PCIE_ATU_UNR_UPPER_BASE 0x0c +#define PCIE_ATU_UNR_LIMIT 0x10 +#define PCIE_ATU_UNR_LOWER_TARGET 0x14 +#define PCIE_ATU_UNR_UPPER_TARGET 0x18 + +#define PCIE_ATU_REGION_INDEX1 (0x1 << 0) +#define PCIE_ATU_REGION_INDEX0 (0x0 << 0) +#define PCIE_ATU_TYPE_MEM (0x0 << 0) +#define PCIE_ATU_TYPE_IO (0x2 << 0) +#define PCIE_ATU_TYPE_CFG0 (0x4 << 0) +#define PCIE_ATU_TYPE_CFG1 (0x5 << 0) +#define PCIE_ATU_ENABLE (0x1 << 31) +#define PCIE_ATU_BAR_MODE_ENABLE (0x1 << 30) +#define PCIE_ATU_BUS(x) (((x) & 0xff) << 24) +#define PCIE_ATU_DEV(x) (((x) & 0x1f) << 19) +#define PCIE_ATU_FUNC(x) (((x) & 0x7) << 16) + +/* Register address builder */ +#define PCIE_GET_ATU_OUTB_UNR_REG_OFFSET(region) \ + ((0x3 << 20) | ((region) << 9)) +#define PCIE_GET_ATU_INB_UNR_REG_OFFSET(region) \ + ((0x3 << 20) | ((region) << 9) | (0x1 << 8)) + +/* Parameters for the waiting for iATU enabled routine */ +#define LINK_WAIT_MAX_IATU_RETRIES 5 +#define LINK_WAIT_IATU 10000 + +static int rk_pcie_read(void __iomem *addr, int size, u32 *val) +{ + if ((uintptr_t)addr & (size - 1)) { + *val = 0; + return PCIBIOS_UNSUPPORTED; + } + + if (size == 4) { + *val = readl(addr); + } else if (size == 2) { + *val = readw(addr); + } else if (size == 1) { + *val = readb(addr); + } else { + *val = 0; + return PCIBIOS_NODEV; + } + + return PCIBIOS_SUCCESSFUL; +} + +static int rk_pcie_write(void __iomem *addr, int size, u32 val) +{ + if ((uintptr_t)addr & (size - 1)) + return PCIBIOS_UNSUPPORTED; + + if (size == 4) + writel(val, addr); + else if (size == 2) + writew(val, addr); + else if (size == 1) + writeb(val, addr); + else + return PCIBIOS_NODEV; + + return PCIBIOS_SUCCESSFUL; +} + +static u32 __rk_pcie_read_apb(struct rk_pcie *rk_pcie, void __iomem *base, + u32 reg, size_t size) +{ + int ret; + u32 val; + + ret = rk_pcie_read(base + reg, size, &val); + if (ret) + dev_err(rk_pcie->dev, "Read APB address failed\n"); + + return val; +} + +static void __rk_pcie_write_apb(struct rk_pcie *rk_pcie, void __iomem *base, + u32 reg, size_t size, u32 val) +{ + int ret; + + ret = rk_pcie_write(base + reg, size, val); + if (ret) + dev_err(rk_pcie->dev, "Write APB address failed\n"); +} + +static inline u32 rk_pcie_readl_apb(struct rk_pcie *rk_pcie, u32 reg) +{ + return __rk_pcie_read_apb(rk_pcie, rk_pcie->apb_base, reg, 0x4); +} + +static inline void rk_pcie_writel_apb(struct rk_pcie *rk_pcie, u32 reg, + u32 val) +{ + __rk_pcie_write_apb(rk_pcie, rk_pcie->apb_base, reg, 0x4, val); +} + +static int rk_pcie_get_link_speed(struct rk_pcie *rk_pcie) +{ + return (readl(rk_pcie->dbi_base + PCIE_LINK_STATUS_REG) & + PCIE_LINK_STATUS_SPEED_MASK) >> PCIE_LINK_STATUS_SPEED_OFF; +} + +static int rk_pcie_get_link_width(struct rk_pcie *rk_pcie) +{ + return (readl(rk_pcie->dbi_base + PCIE_LINK_STATUS_REG) & + PCIE_LINK_STATUS_WIDTH_MASK) >> PCIE_LINK_STATUS_WIDTH_OFF; +} + +static void rk_pcie_writel_ob_unroll(struct rk_pcie *rk_pcie, u32 index, + u32 reg, u32 val) +{ + u32 offset = PCIE_GET_ATU_OUTB_UNR_REG_OFFSET(index); + void __iomem *base = rk_pcie->dbi_base; + + writel(val, base + offset + reg); +} + +static u32 rk_pcie_readl_ob_unroll(struct rk_pcie *rk_pcie, u32 index, u32 reg) +{ + u32 offset = PCIE_GET_ATU_OUTB_UNR_REG_OFFSET(index); + void __iomem *base = rk_pcie->dbi_base; + + return readl(base + offset + reg); +} + +static inline void rk_pcie_dbi_write_enable(struct rk_pcie *rk_pcie, bool en) +{ + u32 val; + + val = readl(rk_pcie->dbi_base + PCIE_MISC_CONTROL_1_OFF); + + if (en) + val |= PCIE_DBI_RO_WR_EN; + else + val &= ~PCIE_DBI_RO_WR_EN; + writel(val, rk_pcie->dbi_base + PCIE_MISC_CONTROL_1_OFF); +} + +static void rk_pcie_setup_host(struct rk_pcie *rk_pcie) +{ + u32 val; + + rk_pcie_dbi_write_enable(rk_pcie, true); + + /* setup RC BARs */ + writel(PCI_BASE_ADDRESS_MEM_TYPE_64, + rk_pcie->dbi_base + PCI_BASE_ADDRESS_0); + writel(0x0, rk_pcie->dbi_base + PCI_BASE_ADDRESS_1); + + /* setup interrupt pins */ + val = readl(rk_pcie->dbi_base + PCI_INTERRUPT_LINE); + val &= 0xffff00ff; + val |= 0x00000100; + writel(val, rk_pcie->dbi_base + PCI_INTERRUPT_LINE); + + /* setup bus numbers */ + val = readl(rk_pcie->dbi_base + PCI_PRIMARY_BUS); + val &= 0xff000000; + val |= 0x00ff0100; + writel(val, rk_pcie->dbi_base + PCI_PRIMARY_BUS); + + val = readl(rk_pcie->dbi_base + PCI_PRIMARY_BUS); + + /* setup command register */ + val = readl(rk_pcie->dbi_base + PCI_COMMAND); + val &= 0xffff0000; + val |= PCI_COMMAND_IO | PCI_COMMAND_MEMORY | + PCI_COMMAND_MASTER | PCI_COMMAND_SERR; + writel(val, rk_pcie->dbi_base + PCI_COMMAND); + + /* program correct class for RC */ + writew(PCI_CLASS_BRIDGE_PCI, rk_pcie->dbi_base + PCI_CLASS_DEVICE); + /* Better disable write permission right after the update */ + + val = readl(rk_pcie->dbi_base + PCIE_LINK_WIDTH_SPEED_CONTROL); + val |= PORT_LOGIC_SPEED_CHANGE; + writel(val, rk_pcie->dbi_base + PCIE_LINK_WIDTH_SPEED_CONTROL); + + rk_pcie_dbi_write_enable(rk_pcie, false); +} + +static void rk_pcie_configure(struct rk_pcie *pci, u32 cap_speed) +{ + u32 val; + + rk_pcie_dbi_write_enable(pci, true); + + val = readl(pci->dbi_base + PCIE_LINK_CAPABILITY); + val &= ~TARGET_LINK_SPEED_MASK; + val |= cap_speed; + writel(val, pci->dbi_base + PCIE_LINK_CAPABILITY); + + val = readl(pci->dbi_base + PCIE_LINK_CTL_2); + val &= ~TARGET_LINK_SPEED_MASK; + val |= cap_speed; + writel(val, pci->dbi_base + PCIE_LINK_CTL_2); + + rk_pcie_dbi_write_enable(pci, false); +} + +static void rk_pcie_prog_outbound_atu_unroll(struct rk_pcie *pci, int index, + int type, u64 cpu_addr, + u64 pci_addr, u32 size) +{ + u32 retries, val; + + dev_dbg(pci->dev, "ATU programmed with: index: %d, type: %d, cpu addr: %8llx, pci addr: %8llx, size: %8x\n", + index, type, cpu_addr, pci_addr, size); + + rk_pcie_writel_ob_unroll(pci, index, PCIE_ATU_UNR_LOWER_BASE, + lower_32_bits(cpu_addr)); + rk_pcie_writel_ob_unroll(pci, index, PCIE_ATU_UNR_UPPER_BASE, + upper_32_bits(cpu_addr)); + rk_pcie_writel_ob_unroll(pci, index, PCIE_ATU_UNR_LIMIT, + lower_32_bits(cpu_addr + size - 1)); + rk_pcie_writel_ob_unroll(pci, index, PCIE_ATU_UNR_LOWER_TARGET, + lower_32_bits(pci_addr)); + rk_pcie_writel_ob_unroll(pci, index, PCIE_ATU_UNR_UPPER_TARGET, + upper_32_bits(pci_addr)); + rk_pcie_writel_ob_unroll(pci, index, PCIE_ATU_UNR_REGION_CTRL1, + type); + rk_pcie_writel_ob_unroll(pci, index, PCIE_ATU_UNR_REGION_CTRL2, + PCIE_ATU_ENABLE); + + /* + * Make sure ATU enable takes effect before any subsequent config + * and I/O accesses. + */ + for (retries = 0; retries < LINK_WAIT_MAX_IATU_RETRIES; retries++) { + val = rk_pcie_readl_ob_unroll(pci, index, + PCIE_ATU_UNR_REGION_CTRL2); + if (val & PCIE_ATU_ENABLE) + return; + + udelay(LINK_WAIT_IATU); + } + dev_err(pci->dev, "outbound iATU is not being enabled\n"); +} + +static int rk_pcie_addr_valid(pci_dev_t d, int first_busno) +{ + if ((PCI_BUS(d) == first_busno) && (PCI_DEV(d) > 0)) + return 0; + if ((PCI_BUS(d) == first_busno + 1) && (PCI_DEV(d) > 0)) + return 0; + + return 1; +} + +static uintptr_t set_cfg_address(struct rk_pcie *pcie, + pci_dev_t d, uint where) +{ + int bus = PCI_BUS(d) - pcie->first_busno; + uintptr_t va_address; + u32 atu_type; + + /* Use dbi_base for own configuration read and write */ + if (!bus) { + va_address = (uintptr_t)pcie->dbi_base; + goto out; + } + + if (bus == 1) + /* + * For local bus whose primary bus number is root bridge, + * change TLP Type field to 4. + */ + atu_type = PCIE_ATU_TYPE_CFG0; + else + /* Otherwise, change TLP Type field to 5. */ + atu_type = PCIE_ATU_TYPE_CFG1; + + /* + * Not accessing root port configuration space? + * Region #0 is used for Outbound CFG space access. + * Direction = Outbound + * Region Index = 0 + */ + d = PCI_MASK_BUS(d); + d = PCI_ADD_BUS(bus, d); + rk_pcie_prog_outbound_atu_unroll(pcie, PCIE_ATU_REGION_INDEX1, + atu_type, (u64)pcie->cfg_base, + d << 8, pcie->cfg_size); + + va_address = (uintptr_t)pcie->cfg_base; + +out: + va_address += where & ~0x3; + + return va_address; +} + +static int rockchip_pcie_rd_conf(const struct udevice *bus, pci_dev_t bdf, + uint offset, ulong *valuep, + enum pci_size_t size) +{ + struct rk_pcie *pcie = dev_get_priv(bus); + uintptr_t va_address; + ulong value; + + debug("PCIE CFG read: bdf=%2x:%2x:%2x\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + + if (!rk_pcie_addr_valid(bdf, pcie->first_busno)) { + debug("- out of range\n"); + *valuep = pci_get_ff(size); + return 0; + } + + va_address = set_cfg_address(pcie, bdf, offset); + + value = readl(va_address); + + debug("(addr,val)=(0x%04x, 0x%08lx)\n", offset, value); + *valuep = pci_conv_32_to_size(value, offset, size); + + rk_pcie_prog_outbound_atu_unroll(pcie, PCIE_ATU_REGION_INDEX1, + PCIE_ATU_TYPE_IO, pcie->io.phys_start, + pcie->io.bus_start, pcie->io.size); + + return 0; +} + +static int rockchip_pcie_wr_conf(struct udevice *bus, pci_dev_t bdf, + uint offset, ulong value, + enum pci_size_t size) +{ + struct rk_pcie *pcie = dev_get_priv(bus); + uintptr_t va_address; + ulong old; + + debug("PCIE CFG write: (b,d,f)=(%2d,%2d,%2d)\n", + PCI_BUS(bdf), PCI_DEV(bdf), PCI_FUNC(bdf)); + debug("(addr,val)=(0x%04x, 0x%08lx)\n", offset, value); + + if (!rk_pcie_addr_valid(bdf, pcie->first_busno)) { + debug("- out of range\n"); + return 0; + } + + va_address = set_cfg_address(pcie, bdf, offset); + + old = readl(va_address); + value = pci_conv_size_to_32(old, value, offset, size); + writel(value, va_address); + + rk_pcie_prog_outbound_atu_unroll(pcie, PCIE_ATU_REGION_INDEX1, + PCIE_ATU_TYPE_IO, pcie->io.phys_start, + pcie->io.bus_start, pcie->io.size); + + return 0; +} + +static void rk_pcie_enable_debug(struct rk_pcie *rk_pcie) +{ +#if RK_PCIE_DBG + rk_pcie_writel_apb(rk_pcie, PCIE_CLIENT_DBG_FIFO_PTN_HIT_D0, + PCIE_CLIENT_DBG_TRANSITION_DATA); + rk_pcie_writel_apb(rk_pcie, PCIE_CLIENT_DBG_FIFO_PTN_HIT_D1, + PCIE_CLIENT_DBG_TRANSITION_DATA); + rk_pcie_writel_apb(rk_pcie, PCIE_CLIENT_DBG_FIFO_TRN_HIT_D0, + PCIE_CLIENT_DBG_TRANSITION_DATA); + rk_pcie_writel_apb(rk_pcie, PCIE_CLIENT_DBG_FIFO_TRN_HIT_D1, + PCIE_CLIENT_DBG_TRANSITION_DATA); + rk_pcie_writel_apb(rk_pcie, PCIE_CLIENT_DBG_FIFO_MODE_CON, + PCIE_CLIENT_DBF_EN); +#endif +} + +static void rk_pcie_debug_dump(struct rk_pcie *rk_pcie) +{ +#if RK_PCIE_DBG + u32 loop; + + dev_info(rk_pcie->dev, "ltssm = 0x%x\n", + rk_pcie_readl_apb(rk_pcie, PCIE_CLIENT_LTSSM_STATUS)); + for (loop = 0; loop < 64; loop++) + dev_info(rk_pcie->dev, "fifo_status = 0x%x\n", + rk_pcie_readl_apb(rk_pcie, PCIE_CLIENT_DBG_FIFO_STATUS)); +#endif +} + +static inline void rk_pcie_link_status_clear(struct rk_pcie *rk_pcie) +{ + rk_pcie_writel_apb(rk_pcie, PCIE_CLIENT_GENERAL_DEBUG, 0x0); +} + +static inline void rk_pcie_disable_ltssm(struct rk_pcie *rk_pcie) +{ + rk_pcie_writel_apb(rk_pcie, 0x0, 0xc0008); +} + +static inline void rk_pcie_enable_ltssm(struct rk_pcie *rk_pcie) +{ + rk_pcie_writel_apb(rk_pcie, 0x0, 0xc000c); +} + +static int is_link_up(struct rk_pcie *priv) +{ + u32 val; + + val = rk_pcie_readl_apb(priv, PCIE_CLIENT_LTSSM_STATUS); + if ((val & (RDLH_LINKUP | SMLH_LINKUP)) == 0x30000 && + (val & GENMASK(5, 0)) == 0x11) + return 1; + + return 0; +} + +static int rk_pcie_link_up(struct rk_pcie *priv, u32 cap_speed) +{ + int retries; + + if (is_link_up(priv)) { + printf("PCI Link already up before configuration!\n"); + return 1; + } + + /* DW pre link configurations */ + rk_pcie_configure(priv, cap_speed); + + /* Rest the device */ + if (dm_gpio_is_valid(&priv->rst_gpio)) { + dm_gpio_set_value(&priv->rst_gpio, 0); + msleep(1000); + dm_gpio_set_value(&priv->rst_gpio, 1); + } + + rk_pcie_disable_ltssm(priv); + rk_pcie_link_status_clear(priv); + rk_pcie_enable_debug(priv); + + /* Enable LTSSM */ + rk_pcie_enable_ltssm(priv); + + for (retries = 0; retries < 10000000; retries++) { + if (is_link_up(priv)) { + dev_info(priv->dev, "PCIe Link up, LTSSM is 0x%x\n", + rk_pcie_readl_apb(priv, PCIE_CLIENT_LTSSM_STATUS)); + rk_pcie_debug_dump(priv); + return 0; + } + + dev_info(priv->dev, "PCIe Linking... LTSSM is 0x%x\n", + rk_pcie_readl_apb(priv, PCIE_CLIENT_LTSSM_STATUS)); + rk_pcie_debug_dump(priv); + msleep(1000); + } + + dev_err(priv->dev, "PCIe-%d Link Fail\n", dev_seq(priv->dev)); + /* Link maybe in Gen switch recovery but we need to wait more 1s */ + msleep(1000); + return -EINVAL; +} + +static int rockchip_pcie_init_port(struct udevice *dev) +{ + int ret; + u32 val; + struct rk_pcie *priv = dev_get_priv(dev); + + /* Set power and maybe external ref clk input */ + if (priv->vpcie3v3) { + ret = regulator_set_value(priv->vpcie3v3, 3300000); + if (ret) { + dev_err(priv->dev, "failed to enable vpcie3v3 (ret=%d)\n", + ret); + return ret; + } + } + + msleep(1000); + + ret = generic_phy_init(&priv->phy); + if (ret) { + dev_err(dev, "failed to init phy (ret=%d)\n", ret); + return ret; + } + + ret = generic_phy_power_on(&priv->phy); + if (ret) { + dev_err(dev, "failed to power on phy (ret=%d)\n", ret); + goto err_exit_phy; + } + + ret = reset_deassert_bulk(&priv->rsts); + if (ret) { + dev_err(dev, "failed to deassert resets (ret=%d)\n", ret); + goto err_power_off_phy; + } + + ret = clk_enable_bulk(&priv->clks); + if (ret) { + dev_err(dev, "failed to enable clks (ret=%d)\n", ret); + goto err_deassert_bulk; + } + + /* LTSSM EN ctrl mode */ + val = rk_pcie_readl_apb(priv, PCIE_CLIENT_HOT_RESET_CTRL); + val |= PCIE_LTSSM_ENABLE_ENHANCE | (PCIE_LTSSM_ENABLE_ENHANCE << 16); + rk_pcie_writel_apb(priv, PCIE_CLIENT_HOT_RESET_CTRL, val); + + /* Set RC mode */ + rk_pcie_writel_apb(priv, 0x0, 0xf00040); + rk_pcie_setup_host(priv); + + ret = rk_pcie_link_up(priv, LINK_SPEED_GEN_3); + if (ret < 0) + goto err_link_up; + + return 0; +err_link_up: + clk_disable_bulk(&priv->clks); +err_deassert_bulk: + reset_assert_bulk(&priv->rsts); +err_power_off_phy: + generic_phy_power_off(&priv->phy); +err_exit_phy: + generic_phy_exit(&priv->phy); + return ret; +} + +static int rockchip_pcie_parse_dt(struct udevice *dev) +{ + struct rk_pcie *priv = dev_get_priv(dev); + int ret; + + priv->dbi_base = (void *)dev_read_addr_index(dev, 0); + if (!priv->dbi_base) + return -ENODEV; + + dev_dbg(dev, "DBI address is 0x%p\n", priv->dbi_base); + + priv->apb_base = (void *)dev_read_addr_index(dev, 1); + if (!priv->apb_base) + return -ENODEV; + + dev_dbg(dev, "APB address is 0x%p\n", priv->apb_base); + + ret = gpio_request_by_name(dev, "reset-gpios", 0, + &priv->rst_gpio, GPIOD_IS_OUT); + if (ret) { + dev_err(dev, "failed to find reset-gpios property\n"); + return ret; + } + + ret = reset_get_bulk(dev, &priv->rsts); + if (ret) { + dev_err(dev, "Can't get reset: %d\n", ret); + return ret; + } + + ret = clk_get_bulk(dev, &priv->clks); + if (ret) { + dev_err(dev, "Can't get clock: %d\n", ret); + return ret; + } + + ret = device_get_supply_regulator(dev, "vpcie3v3-supply", + &priv->vpcie3v3); + if (ret && ret != -ENOENT) { + dev_err(dev, "failed to get vpcie3v3 supply (ret=%d)\n", ret); + return ret; + } + + ret = generic_phy_get_by_index(dev, 0, &priv->phy); + if (ret) { + dev_err(dev, "failed to get pcie phy (ret=%d)\n", ret); + return ret; + } + + return 0; +} + +static int rockchip_pcie_probe(struct udevice *dev) +{ + struct rk_pcie *priv = dev_get_priv(dev); + struct udevice *ctlr = pci_get_controller(dev); + struct pci_controller *hose = dev_get_uclass_priv(ctlr); + int ret; + + priv->first_busno = dev_seq(dev); + priv->dev = dev; + + ret = rockchip_pcie_parse_dt(dev); + if (ret) + return ret; + + ret = rockchip_pcie_init_port(dev); + if (ret) + return ret; + + dev_info(dev, "PCIE-%d: Link up (Gen%d-x%d, Bus%d)\n", + dev_seq(dev), rk_pcie_get_link_speed(priv), + rk_pcie_get_link_width(priv), + hose->first_busno); + + for (ret = 0; ret < hose->region_count; ret++) { + if (hose->regions[ret].flags == PCI_REGION_IO) { + priv->io.phys_start = hose->regions[ret].phys_start; /* IO base */ + priv->io.bus_start = hose->regions[ret].bus_start; /* IO_bus_addr */ + priv->io.size = hose->regions[ret].size; /* IO size */ + } else if (hose->regions[ret].flags == PCI_REGION_MEM) { + priv->mem.phys_start = hose->regions[ret].phys_start; /* MEM base */ + priv->mem.bus_start = hose->regions[ret].bus_start; /* MEM_bus_addr */ + priv->mem.size = hose->regions[ret].size; /* MEM size */ + } else if (hose->regions[ret].flags == PCI_REGION_SYS_MEMORY) { + priv->cfg_base = (void *)(priv->io.phys_start - priv->io.size); + priv->cfg_size = priv->io.size; + } else { + dev_err(dev, "invalid flags type!\n"); + } + } + + dev_dbg(dev, "Config space: [0x%p - 0x%p, size 0x%llx]\n", + priv->cfg_base, priv->cfg_base + priv->cfg_size, + priv->cfg_size); + + dev_dbg(dev, "IO space: [0x%llx - 0x%llx, size 0x%lx]\n", + priv->io.phys_start, priv->io.phys_start + priv->io.size, + priv->io.size); + + dev_dbg(dev, "IO bus: [0x%lx - 0x%lx, size 0x%lx]\n", + priv->io.bus_start, priv->io.bus_start + priv->io.size, + priv->io.size); + + dev_dbg(dev, "MEM space: [0x%llx - 0x%llx, size 0x%lx]\n", + priv->mem.phys_start, priv->mem.phys_start + priv->mem.size, + priv->mem.size); + + dev_dbg(dev, "MEM bus: [0x%lx - 0x%lx, size 0x%lx]\n", + priv->mem.bus_start, priv->mem.bus_start + priv->mem.size, + priv->mem.size); + + rk_pcie_prog_outbound_atu_unroll(priv, PCIE_ATU_REGION_INDEX0, + PCIE_ATU_TYPE_MEM, + priv->mem.phys_start, + priv->mem.bus_start, priv->mem.size); + return 0; +} + +static const struct dm_pci_ops rockchip_pcie_ops = { + .read_config = rockchip_pcie_rd_conf, + .write_config = rockchip_pcie_wr_conf, +}; + +static const struct udevice_id rockchip_pcie_ids[] = { + { .compatible = "rockchip,rk3568-pcie" }, + { } +}; + +U_BOOT_DRIVER(rockchip_dw_pcie) = { + .name = "pcie_dw_rockchip", + .id = UCLASS_PCI, + .of_match = rockchip_pcie_ids, + .ops = &rockchip_pcie_ops, + .probe = rockchip_pcie_probe, + .priv_auto = sizeof(struct rk_pcie), +};
Hi Shawn,
select DM_PCI
help
Rockchip SoCs.
- Rockchip DesignWare based PCIe host controller driver
- Copyright (c) 2021 Rockchip, Inc.
that one should go at the end
+struct rk_pcie {
void *dbi_base;
void *apb_base;
void *cfg_base;
struct phy phy;
int first_busno;
these members need comments
+enum {
Can you use a different error? This is used by drive model to know when there is no device, but generally there is a device in a driver!
That is in linux/delay.h I think
Can you rely on DEBUG in this file instead?
- iATU Unroll-specific register definitions
- From 4.80 core version the address translation will be made by unroll.
- The registers are offset from atu_base
Perhaps these should be inline functions? The second one doesn't seem to ue used, so could be dropped.
If this is milliseconds, how about a _MS suffix?
*val = 0;
if (size == 4) {
*val = readl(addr);
*val = readw(addr);
*val = readb(addr);
} else {
*val = 0;
if (size == 4)
writel(val, addr);
else if (size == 2)
writew(val, addr);
else if (size == 1)
writeb(val, addr);
else
function comment. Many of the functions below need some sort of comment as to what they do.
int ret;
u32 val;
if (ret)
return val;
int ret;
if (ret)
u32 val)
u32 reg, u32 val)
u32 val;
if (en)
else
u32 val;
/* setup RC BARs */
val &= 0xffff00ff;
val |= 0x00000100;
val &= 0xff000000;
val |= 0x00ff0100;
Please use clrsetbits_le32() as it does this sort of thing more easily
val &= 0xffff0000;
setbits_le32()
Please fix globally
function comment
u32 val;
val |= cap_speed;
val |= cap_speed;
function comment. Also this can fail so should return an error and be checked by callers.
u32 retries, val;
type);
PCIE_ATU_ENABLE);
* and I/O accesses.
return;
return -EIO or something
return 1;
This is strange because it is a relative bus number, not the actual PCI bus number. Would it be better as rel_bus, perhaps? Or am I misunderstanding this? It could use a comment.
u32 atu_type;
if (!bus) {
goto out;
if (bus == 1)
else
* Region Index = 0
+out:
return va_address;
ulong value;
ulong old;
+#endif +}
u32 loop;
+#endif +}
u32 val;
return 1;
Needs function comment, with return values.
int retries;
return 1;
msleep(1000);
Make this a #define with a comment as to why so long. This is a huge delay to have in a driver.
/* Enable LTSSM */
Too many retries...how about 5? This effectively hangs forever if there is a problem.
msleep(1000);
msleep(1000);
return -EINVAL;
-EIO or something like that. We use -EINVAL when we cannot read args from the device tree, for example.
int ret;
u32 val;
Is there an autoset option for this so this info can go in the device tree instead?
if (ret) {
ret);
return ret;
msleep(1000);
if (ret) {
return ret;
if (ret) {
goto err_exit_phy;
if (ret) {
if (ret) {
/* Set RC mode */
if (ret < 0)
goto err_link_up;
+err_link_up:
+err_deassert_bulk:
+err_power_off_phy:
+err_exit_phy:
Blank line before final return
return ret;
int ret;
return -ENODEV;
return -ENODEV;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
&priv->vpcie3v3);
return ret;
if (ret) {
return ret;
int ret;
priv->dev = dev;
if (ret)
return ret;
if (ret)
return ret;
hose->first_busno);
} else {
priv->cfg_size);
priv->io.size);
priv->io.size);
priv->mem.size);
priv->mem.size);
PCIE_ATU_TYPE_MEM,
Need to check error whenever this function is called
.id = UCLASS_PCI,
2.17.1
Hi Simon
Thanks you for reviewing it.
Hi Shawn,
----8<------
int ret;
u32 val;
I think we should control this by driver as other PCIe drivers did, as we can't guarantee all kernel dtbs doing the right thing and 3v3 power is very important for both of devices and PHY block.
if (ret) {
ret);
return ret;
Hi Shawn,
On Fri, 15 Jan 2021 at 02:15, Shawn Lin shawn.lin@rock-chips.com wrote:
Hi Simon
Hi Shawn,
----8<------
int ret;
u32 val;
That's OK. Note that U-Boot uses its own devicetree so you can make sure it is correct in a separate patch if you like.
Shawn Lin
