[PATCH] Nokia RX-51: Add link for u-boot-gen-combined script to README file
This patch updates Nokia RX-51 README file.
Signed-off-by: Pali Rohár pali@kernel.org --- doc/README.nokia_rx51 | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/doc/README.nokia_rx51 b/doc/README.nokia_rx51 index 33c275b416..320b5efc7d 100644 --- a/doc/README.nokia_rx51 +++ b/doc/README.nokia_rx51 @@ -16,6 +16,11 @@ SD card or internal eMMC memory. If this fails or keyboard is closed then the appended kernel image will be booted using some generated and some stored ATAGs (see boot order).
+For generating combined image of u-boot and kernel there is a simple script +called u-boot-gen-combined. It is available in following repository: + + https://github.com/pali/u-boot-maemo + There is support for hardware watchdog. Hardware watchdog is started by NOLO so u-boot must kick watchdog to prevent reboot device (but not very often, max every 2 seconds). There is also support for framebuffer display
Applied to u-boot-ti next.
Thanks and regards, Lokesh
Lokesh Vutla
Pali Rohár
