[U-Boot] [PATCH] gunzip.c: Only include gzwrite on CONFIG_CMD_UNZIP
Only when we have CONFIG_CMD_UNZIP enabled do we have the 'gzwrite' command. While this command should be separated from CONFIG_CMD_UNZIP we should also only include the write portion of the gz code in that case as well.
Signed-off-by: Tom Rini trini@konsulko.com --- lib/gunzip.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/lib/gunzip.c b/lib/gunzip.c index bdd85c4..7cbb88f 100644 --- a/lib/gunzip.c +++ b/lib/gunzip.c @@ -70,6 +70,7 @@ int gunzip(void *dst, int dstlen, unsigned char *src, unsigned long *lenp) return zunzip(dst, dstlen, src, lenp, 1, i); }
+#ifdef CONFIG_CMD_UNZIP __weak void gzwrite_progress_init(u64 expectedsize) { @@ -259,6 +260,7 @@ out:
return r; } +#endif
/* * Uncompress blocks compressed with zlib without headers
