[U-Boot] [PATCH V2 1/4] tools: imx8image: check lseek return value
Check lseek return value.
Fix Coverity CID: 184236 184235 184232
Reported-by: Coverity Signed-off-by: Peng Fan peng.fan@nxp.com ---
V2: Per Fabio's comments, use ret = lseek; if (ret) < 0) coding style.
tools/imx8image.c | 27 +++++++++++++++++++++++---- 1 file changed, 23 insertions(+), 4 deletions(-)
diff --git a/tools/imx8image.c b/tools/imx8image.c index e6b0a146b6..03debe547e 100644 --- a/tools/imx8image.c +++ b/tools/imx8image.c @@ -301,6 +301,7 @@ static void copy_file_aligned(int ifd, const char *datafile, int offset, unsigned char *ptr; uint8_t zeros[0x4000]; int size; + int ret;
if (align > 0x4000) { fprintf(stderr, "Wrong alignment requested %d\n", align); @@ -333,7 +334,13 @@ static void copy_file_aligned(int ifd, const char *datafile, int offset, }
size = sbuf.st_size; - lseek(ifd, offset, SEEK_SET); + ret = lseek(ifd, offset, SEEK_SET); + if (ret < 0) { + fprintf(stderr, "%s: lseek error %s\n", + __func__, strerror(errno)); + exit(EXIT_FAILURE); + } + if (write(ifd, ptr, size) != size) { fprintf(stderr, "Write error %s\n", strerror(errno)); exit(EXIT_FAILURE); @@ -359,7 +366,7 @@ static void copy_file (int ifd, const char *datafile, int pad, int offset) int tail; int zero = 0; uint8_t zeros[4096]; - int size; + int size, ret;
memset(zeros, 0, sizeof(zeros));
@@ -387,7 +394,13 @@ static void copy_file (int ifd, const char *datafile, int pad, int offset) }
size = sbuf.st_size; - lseek(ifd, offset, SEEK_SET); + ret = lseek(ifd, offset, SEEK_SET); + if (ret < 0) { + fprintf(stderr, "%s: lseek error %s\n", + __func__, strerror(errno)); + exit(EXIT_FAILURE); + } + if (write(ifd, ptr, size) != size) { fprintf(stderr, "Write error %s\n", strerror(errno)); @@ -762,6 +775,7 @@ static int build_container(soc_type_t soc, uint32_t sector_size, char *tmp_filename = NULL; uint32_t size = 0; uint32_t file_padding = 0; + int ret;
int container = -1; int cont_img_count = 0; /* indexes to arrange the container */ @@ -883,7 +897,12 @@ static int build_container(soc_type_t soc, uint32_t sector_size, } while (img_sp->option != NO_IMG);
/* Add padding or skip appended container */ - lseek(ofd, file_padding, SEEK_SET); + ret = lseek(ofd, file_padding, SEEK_SET); + if (ret < 0) { + fprintf(stderr, "%s: lseek error %s\n", + __func__, strerror(errno)); + exit(EXIT_FAILURE); + }
/* Note: Image offset are not contained in the image */ tmp = flatten_container_header(&imx_header, container + 1, &size,
Fix: CID 184234: (TAINTED_SCALAR) Using tainted variable "header.num_images - 1" as an index into an array "header.img".
Reported-by: Coverity Signed-off-by: Peng Fan peng.fan@nxp.com --- tools/imx8image.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/tools/imx8image.c b/tools/imx8image.c index 03debe547e..019b875773 100644 --- a/tools/imx8image.c +++ b/tools/imx8image.c @@ -666,8 +666,10 @@ static int get_container_image_start_pos(image_t *image_stack, uint32_t align) }
ret = fread(&header, sizeof(header), 1, fd); - if (ret != 1) + if (ret != 1) { printf("Failure Read header %d\n", ret); + exit(EXIT_FAILURE); + }
fclose(fd);
Fix: CID 184233: (NEGATIVE_RETURNS) Using variable "container" as an index to array "imx_header.fhdr".
Reported-by: Coverity Signed-off-by: Peng Fan peng.fan@nxp.com --- tools/imx8image.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/tools/imx8image.c b/tools/imx8image.c index 019b875773..ac89c821c9 100644 --- a/tools/imx8image.c +++ b/tools/imx8image.c @@ -812,6 +812,10 @@ static int build_container(soc_type_t soc, uint32_t sector_size, case SCFW: case DATA: case MSG_BLOCK: + if (container < 0) { + fprintf(stderr, "No container found\n"); + exit(EXIT_FAILURE); + } check_file(&sbuf, img_sp->filename); tmp_filename = img_sp->filename; set_image_array_entry(&imx_header.fhdr[container], @@ -825,6 +829,10 @@ static int build_container(soc_type_t soc, uint32_t sector_size, break;
case SECO: + if (container < 0) { + fprintf(stderr, "No container found\n"); + exit(EXIT_FAILURE); + } check_file(&sbuf, img_sp->filename); tmp_filename = img_sp->filename; set_image_array_entry(&imx_header.fhdr[container],
If there is no CONTAINER entry, there is no need to flatten container header.
Signed-off-by: Peng Fan peng.fan@nxp.com --- tools/imx8image.c | 22 ++++++++++++---------- 1 file changed, 12 insertions(+), 10 deletions(-)
diff --git a/tools/imx8image.c b/tools/imx8image.c index ac89c821c9..6e8ac464e7 100644 --- a/tools/imx8image.c +++ b/tools/imx8image.c @@ -914,17 +914,19 @@ static int build_container(soc_type_t soc, uint32_t sector_size, exit(EXIT_FAILURE); }
- /* Note: Image offset are not contained in the image */ - tmp = flatten_container_header(&imx_header, container + 1, &size, - file_padding); - /* Write image header */ - if (write(ofd, tmp, size) != size) { - fprintf(stderr, "error writing image hdr\n"); - exit(EXIT_FAILURE); - } + if (container >= 0) { + /* Note: Image offset are not contained in the image */ + tmp = flatten_container_header(&imx_header, container + 1, + &size, file_padding); + /* Write image header */ + if (write(ofd, tmp, size) != size) { + fprintf(stderr, "error writing image hdr\n"); + exit(EXIT_FAILURE); + }
- /* Clean-up memory used by the headers */ - free(tmp); + /* Clean-up memory used by the headers */ + free(tmp); + }
/* * step through the image stack again this time copying
Hi Peng,
Thanks for the respin.
Reviewed-by: Fabio Estevam festevam@gmail.com
Hi Peng,
On 05/11/18 14:06, Fabio Estevam wrote:
Hi Peng,
Yes, thanks for this. I admit that I prefer in this way as Fabio, but I admit that it is not thinkable that lseek() will change the API, and I agree that change could be more or less a question of taste. Anyway, I prefer in this way...
I merged the series together with:
- MAINTAINERS: add NXP linux team maillist as i.MX reviewer - ARM: dts: fsl-imx8qxp-mek: Move regulator outside "simple-bus" - mx8mq_evk: README: Delete file introduced by mistake
I do not see any other open points and I will send PR to Tom.
Best regards, Stefano
Fabio Estevam
Peng Fan
Stefano Babic
