[U-Boot] [PULL] u-boot-usb/master
The following changes since commit 0f9258228e2b2070368ffccf5c243218128770a8:
of: clean up OF_CONTROL ifdef conditionals (2015-08-18 13:46:05 -0400)
git://git.denx.de/u-boot-usb.git HEAD
for you to fetch changes up to 7a1386f96bca550240670fa3461d3a0dc060aa01:
usb: dwc2: Rename to dwc2_usb (2015-08-19 22:31:39 +0200)
---------------------------------------------------------------- Adrian Alonso (4): imx: usb: ehci-mx6: reg accessor cleanups imx: usb: ehci-mx6: document board specific functions imx: usb: ehci-mx6: add usb support for imx7d soc imx: usb: ehci-mx6: wait_for_bit to check reg status
Kishon Vijay Abraham I (3): usb: gadget: ether: Perform board initialization from ethernet gadget driver usb: host: xhci-omap: invoke board_usb_cleanup in xhci_hcd_stop usb: gadget: ether: populate _reset_ callback
Marek Vasut (2): usb: dwc2: Add original Synopsys compat string usb: dwc2: Rename to dwc2_usb
Sergey Temerkhanov (1): usb: xhci: Fix a potential NULL pointer dereference
Stefan Roese (1): usb: spear: Add support for both SPEAr600 EHCI controllers
arch/arm/cpu/arm926ejs/spear/cpu.c | 4 ++ arch/arm/include/asm/arch-spear/hardware.h | 2 + drivers/usb/gadget/ether.c | 5 +++ drivers/usb/host/Makefile | 1 + drivers/usb/host/dwc2.c | 3 +- drivers/usb/host/ehci-mx6.c | 211 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------ drivers/usb/host/ehci-spear.c | 38 +++++++++++++++-- drivers/usb/host/xhci-omap.c | 1 + drivers/usb/host/xhci.c | 19 ++++++--- 9 files changed, 223 insertions(+), 61 deletions(-)
But two notes: xilinx_zynqmp_ep nows has a ton of warnings and h2200 fails to link. Please look into this Marek, thanks!
The following changes since commit 0f9258228e2b2070368ffccf5c243218128770a8: of: clean up OF_CONTROL ifdef conditionals (2015-08-18 13:46:05 -0400)
are available in the git repository at: git://git.denx.de/u-boot-usb.git HEAD
for you to fetch changes up to 7a1386f96bca550240670fa3461d3a0dc060aa01: usb: dwc2: Rename to dwc2_usb (2015-08-19 22:31:39 +0200)
Kishon, that h2200 breakage is introduced by your patch: usb: gadget: ether: Perform board initialization from ethernet gadget driver please send a fix ; should be very easy.
Best regards, Marek Vasut
