[U-Boot] [PATCH v2 2/3] TI: DaVinci: Add board specific code for da850 EVM
Provides initial support for TI OMAP-L138/DA850 SoC devices on a Logic PD EVM board.
Provides: Initial boot and configuration. Support for i2c. UART support (console).
Signed-off-by: Sudhakar Rajashekhara sudhakar.raj@ti.com --- This patch applies to u-boot-ti branch.
Since the previous version following are the changes: Macro used for conditional compilation has changed.
board/davinci/da8xxevm/Makefile | 1 + board/davinci/da8xxevm/da850evm.c | 124 +++++++++++++++++++++++++++++++ include/asm-arm/arch-davinci/hardware.h | 1 + 3 files changed, 126 insertions(+), 0 deletions(-) create mode 100644 board/davinci/da8xxevm/da850evm.c
diff --git a/board/davinci/da8xxevm/Makefile b/board/davinci/da8xxevm/Makefile index 20f4915..bcf315c 100644 --- a/board/davinci/da8xxevm/Makefile +++ b/board/davinci/da8xxevm/Makefile @@ -28,6 +28,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(BOARD).a
COBJS-$(CONFIG_MACH_DAVINCI_DA830_EVM) += da830evm.o +COBJS-$(CONFIG_MACH_DAVINCI_DA850_EVM) += da850evm.o
COBJS := $(sort $(COBJS-y))
diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c new file mode 100644 index 0000000..92548e2 --- /dev/null +++ b/board/davinci/da8xxevm/da850evm.c @@ -0,0 +1,124 @@ +/* + * (C) Copyright 2009, Texas Instruments, Inc. http://www.ti.com/ + * + * Based on da830evm.c + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Parts are shamelessly stolen from various TI sources, original copyright + * follows: + * ----------------------------------------------------------------- + * + * Copyright (C) 2004 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#include <common.h> +#include <i2c.h> +#include <asm/arch/hardware.h> +#include <asm/io.h> +#include "../common/misc.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define pinmux &davinci_syscfg_regs->pinmux + +#ifdef CONFIG_SPI_FLASH +/* SPI0 pin muxer settings */ +const struct pinmux_config spi1_pins[] = { + { pinmux[5], 1, 1 }, + { pinmux[5], 1, 2 }, + { pinmux[5], 1, 4 }, + { pinmux[5], 1, 5 } +}; +#endif + +/* UART pin muxer settings */ +const struct pinmux_config uart_pins[] = { + { pinmux[0], 4, 6 }, + { pinmux[0], 4, 7 }, + { pinmux[4], 2, 4 }, + { pinmux[4], 2, 5 } +}; + +/* I2C pin muxer settings */ +const struct pinmux_config i2c_pins[] = { + { pinmux[4], 2, 2 }, + { pinmux[4], 2, 3 } +}; + +int board_init(void) +{ +#ifndef CONFIG_USE_IRQ + /* + * Mask all IRQs by clearing the global enable and setting + * the enable clear for all the 90 interrupts. + */ + + writel(0, &davinci_aintc_regs->ger); + + writel(0, &davinci_aintc_regs->hier); + + writel(0xffffffff, &davinci_aintc_regs->ecr1); + writel(0xffffffff, &davinci_aintc_regs->ecr2); + writel(0xffffffff, &davinci_aintc_regs->ecr3); +#endif + + /* arch number of the board */ + gd->bd->bi_arch_number = MACH_TYPE_DAVINCI_DA850_EVM; + + /* address of boot parameters */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + /* + * Power on required peripherals + * ARM does not have access by default to PSC0 and PSC1 + * assuming here that the DSP bootloader has set the IOPU + * such that PSC access is available to ARM + */ + lpsc_on(DAVINCI_LPSC_AEMIF); /* NAND, NOR */ + lpsc_on(DAVINCI_LPSC_SPI1); /* Serial Flash */ + lpsc_on(DAVINCI_LPSC_EMAC); /* image download */ + lpsc_on(DAVINCI_LPSC_UART2); /* console */ + lpsc_on(DAVINCI_LPSC_GPIO); + + /* setup the SUSPSRC for ARM to control emulation suspend */ + writel(readl(&davinci_syscfg_regs->suspsrc) & + ~(DAVINCI_SYSCFG_SUSPSRC_EMAC | DAVINCI_SYSCFG_SUSPSRC_I2C | + DAVINCI_SYSCFG_SUSPSRC_SPI1 | DAVINCI_SYSCFG_SUSPSRC_TIMER0 | + DAVINCI_SYSCFG_SUSPSRC_UART2), + &davinci_syscfg_regs->suspsrc); + +#ifdef CONFIG_SPI_FLASH + if (davinci_configure_pin_mux(spi1_pins, ARRAY_SIZE(spi1_pins)) != 0) + return 1; +#endif + + if (davinci_configure_pin_mux(uart_pins, ARRAY_SIZE(uart_pins)) != 0) + return 1; + + if (davinci_configure_pin_mux(i2c_pins, ARRAY_SIZE(i2c_pins)) != 0) + return 1; + + /* enable the console UART */ + writel((DAVINCI_UART_PWREMU_MGMT_FREE | DAVINCI_UART_PWREMU_MGMT_URRST | + DAVINCI_UART_PWREMU_MGMT_UTRST), + &davinci_uart2_ctrl_regs->pwremu_mgmt); + + return(0); +} diff --git a/include/asm-arm/arch-davinci/hardware.h b/include/asm-arm/arch-davinci/hardware.h index 81cc8ab..3520cf8 100644 --- a/include/asm-arm/arch-davinci/hardware.h +++ b/include/asm-arm/arch-davinci/hardware.h @@ -398,6 +398,7 @@ struct davinci_syscfg_regs { #define DAVINCI_SYSCFG_SUSPSRC_EMAC (1 << 5) #define DAVINCI_SYSCFG_SUSPSRC_I2C (1 << 16) #define DAVINCI_SYSCFG_SUSPSRC_SPI0 (1 << 21) +#define DAVINCI_SYSCFG_SUSPSRC_SPI1 (1 << 22) #define DAVINCI_SYSCFG_SUSPSRC_UART2 (1 << 20) #define DAVINCI_SYSCFG_SUSPSRC_TIMER0 (1 << 27)
