[U-Boot] [PATCH] imx: mx6sabresd: fix boot hang with video
Meet the following boot hang. " U-Boot SPL 2019.04-00661-gdc80a012e4 (Apr 25 2019 - 10:31:57 +0800) Trying to boot from MMC1
U-Boot 2019.04-00661-gdc80a012e4 (Apr 25 2019 - 10:31:57 +0800)
CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz) CPU: Automotive temperature grade (-40C to 125C)Reset cause: POR Model: Freescale i.MX6 Quad SABRE Smart Device Board Board: MX6-SabreSD I2C: ready DRAM: 1 GiB Video device 'ipu@2400000' cannot allocate frame buffer memory -ensure the device is set up before relocation Error binding driver 'ipuv3_video': -28 Video device 'ipu@2800000' cannot allocate frame buffer memory -ensure the device is set up before relocation Error binding driver 'ipuv3_video': -28 Some drivers failed to bind Error binding driver 'generic_simple_bus': -28 Some drivers failed to bind initcall sequence 4ffe4500 failed at call 1780dfb7 (err=-28) "
1. fdtdec_get_alias_seq will use "video" as base, however in alias node, we use ipux, so add new alias for U-Boot dts. 2. DM_VIDEO is enabled, however reserve_video is called before relocation, so to make DM_VIDEO work before relocation, need to set SYS_MALLOC_F_LEN 3. defconfig is updated with savedefconfig
Note: I do not have a video panel to test, but with this patch, U-Boot boots up again, below log.
" U-Boot SPL 2019.04-00662-g0b62453bff (Apr 25 2019 - 10:36:31 +0800) Trying to boot from MMC1
U-Boot 2019.04-00662-g0b62453bff (Apr 25 2019 - 10:36:31 +0800)
CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz) CPU: Automotive temperature grade (-40C to 125C) at 34C Reset cause: POR Model: Freescale i.MX6 Quad SABRE Smart Device Board Board: MX6-SabreSD I2C: ready DRAM: 1 GiB PMIC: PFUZE100 ID=0x10 MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 3 Loading Environment from MMC... *** Warning - bad CRC, using default environment
PCI: pcie phy link never came up In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 "
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx6q.dtsi | 1 + arch/arm/dts/imx6qdl.dtsi | 1 + configs/mx6sabresd_defconfig | 6 +++--- 3 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/imx6q.dtsi b/arch/arm/dts/imx6q.dtsi index ab1716b6b0..bc104f7bbb 100644 --- a/arch/arm/dts/imx6q.dtsi +++ b/arch/arm/dts/imx6q.dtsi @@ -9,6 +9,7 @@ / { aliases { ipu1 = &ipu2; + video1 = &ipu2; spi4 = &ecspi5; };
diff --git a/arch/arm/dts/imx6qdl.dtsi b/arch/arm/dts/imx6qdl.dtsi index c0a9478008..83eeb5cc59 100644 --- a/arch/arm/dts/imx6qdl.dtsi +++ b/arch/arm/dts/imx6qdl.dtsi @@ -33,6 +33,7 @@ i2c1 = &i2c2; i2c2 = &i2c3; ipu0 = &ipu1; + video0 = &ipu1; mmc0 = &usdhc1; mmc1 = &usdhc2; mmc2 = &usdhc3; diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index eaf0f01004..5b527cbd5b 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -4,13 +4,13 @@ CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_MX6SABRESD=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y -CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 -# CONFIG_SYS_MALLOC_F is not set +CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y @@ -62,6 +62,7 @@ CONFIG_OF_LIST="imx6q-sabresd imx6qp-sabresd imx6dl-sabresd" CONFIG_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_OF_LIST="imx6dl-sabresd imx6q-sabresd imx6qp-sabresd" +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SPL_DM=y @@ -97,4 +98,3 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_IPUV3=y -# CONFIG_VIDEO_SW_CURSOR is not set
On Thu, 25 Apr 2019 02:36:22 +0000 Peng Fan peng.fan@nxp.com wrote: ...
Reviewed-by: Anatolij Gustschin agust@denx.de
Applied to u-boot-video/master after rebasing defconfig changes. Thanks!
-- Anatolij
Anatolij Gustschin
Peng Fan
