[PATCH] cmd/mem.c: fix undefined behavior in mem cmp
My linter complains that "When using void pointers in calculations, the behaviour is undefined".
GCC does say that "In GNU C, addition and subtraction operations are supported on pointers to void"[1] but this hints at this only being supported in the GNU flavor of C. And I assume U-Boot may want to be compiled with clang/llvm?
Let's fix that warning by casting the void pointer to a u8 pointer since the size variable unit is byte.
[1] https://gcc.gnu.org/onlinedocs/gcc/Pointer-Arith.html
Fixes: 0628ab8ec598 ("sandbox: Change memory commands to use map_physmem") Signed-off-by: Quentin Schulz quentin.schulz@cherry.de --- cmd/mem.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cmd/mem.c b/cmd/mem.c index 274348068c2..08ec0aefa7d 100644 --- a/cmd/mem.c +++ b/cmd/mem.c @@ -293,8 +293,8 @@ static int do_mem_cmp(struct cmd_tbl *cmdtp, int flag, int argc, break; }
- buf1 += size; - buf2 += size; + buf1 = ((u8 *)buf1) + size; + buf2 = ((u8 *)buf2) + size;
/* reset watchdog from time to time */ if ((ngood % (64 << 10)) == 0)
--- base-commit: 56b47b8b6a09c777e74fe6c52512c832691169aa change-id: 20240927-cmd-mem-undefined-a4368d58b5b6
Quentin Schulz foss+uboot@0leil.net writes:
No, let's please not. Try enabling -Wpointer-arith and see how much churn that would require all over the tree (doing it in this one place would be pointless), and all the casts would make the code much much harder to read.
We do rely on lots of gcc extensions, and Clang has documented that it "aims to support a broad range of GCC extensions". Arithmetic on void is one of them, and that's not going to go away.
Rasmus
Hi Rasmus,
That alone is not a justification.
But this very well could/is.
1) is there a way to tell Clang that we want to follow this GNU extension for that case? Is that the default? I can see there are warnings for something seemingly related in llvm (gnu-null-pointer-arithmetic, gnu-pointer-arith, ...?).
2) do we document somewhere the GNU C extensions we use on the whole tree?
3) is anyone aware of a way to silence some specific warnings at the project level so that clang takes care of it so that linters use those settings so we avoid people sending more commits for that "issue"?
Cheers, Quentin
Quentin Schulz quentin.schulz@cherry.de writes:
Hi Rasmus,
- is there a way to tell Clang that we want to follow this GNU
For that case? No. But we do -std=gnu11 which is understood by both compilers and tells clang that we do use GNU extensions. I don't know the clang internals, but I strongly suspect that that flag would make sure that defaults for various warnings are set appropriately (that is, not warning for something which is explicitly guaranteed to work in GNU C).
In our build, yes. See CSTD_FLAG. But both gcc and clang default to some -std=gnuXX, with the exact value of XX depending on compiler version.
- do we document somewhere the GNU C extensions we use on the whole
tree?
Not that I know of explicitly, but CSTD_FLAG=-std=gnu11 kind of documents that gnu extensions are used.
Note that typeof() and inline asm() statements are also gnu extensions that we make heavy use of, as are various __attribute__(()), statement expressions (i.e. ({ stuff; }) ), omitting the middle expression in ?: , special handling of token paste ## after a comma, case ranges 'case LOW ... HIGH', etc. etc.
- is anyone aware of a way to silence some specific warnings at the
I don't quite parse that sentence. Are you saying that your linter is being invoked by clang, and you want clang to pass certain options to the linter to disable certain warnings? I don't know how clang could know that options those would be.
Rasmus
Hi Rasmus,
Hi Rasmus,
tree?
Ack, thanks for the info!
My understanding is that my linter is calling clang. So I thought it would be a nice thing to have a way to specify options for clang at the root of the project so that any linter "wrapping" clang would use those options and not warn/error on things we don't want to check.
I spent 5min looking for it and it seems we already have that: https://docs.u-boot.org/en/latest/build/gen_compile_commands.html
After running that script, my linter is happy.
Thanks! Cheers, Quentin
Quentin Schulz
Quentin Schulz
Rasmus Villemoes
