[U-Boot] Pull request: u-boot-net
Hi Wolfgang,
Please pull following commits:
The following changes since commit c008b6f6dd6b8965e9a7654ffbce75bb9ff7a3b5: Wolfgang Denk (1): Prepare v2012.04-rc1
git://git.denx.de/u-boot-net.git master
Amit Virdi (1): net/designware: Change timeout loop implementation
Armando Visconti (2): net/designware: Consecutive writes must have delay net/designware: Set ANAR to 0x1e1
Eric Miao (1): net/eth.c: fix eth_write_hwaddr() to use dev->enetaddr as fall back
Joe Hershberger (1): Update net subsystem maintainer in doc/git-mailrc
Stefan Bigler (1): mvgbe: remove warning for unused methods
Stephan Linz (4): net: ll_temac: Add LL TEMAC driver to u-boot microblaze: Enable several ethernet driver compilation microblaze: Add faked LL_TEMAC driver configuration microblaze: Wire up LL_TEMAC driver initialization
Vikas Manocha (1): net/designware: Program phy registers when auto-negotiation is ON
Vipin KUMAR (3): net/designware: Fix to restore hw mac address net/designware: Fix the max frame length size net/designware: Phy address fix
Vipin Kumar (1): net/designware: Try configuring phy on each dw_eth_init
board/xilinx/microblaze-generic/config.mk | 6 +- .../xilinx/microblaze-generic/microblaze-generic.c | 36 ++ board/xilinx/microblaze-generic/xparameters.h | 12 +- doc/git-mailrc | 3 +- drivers/net/Makefile | 2 + drivers/net/designware.c | 128 +++++-- drivers/net/designware.h | 3 +- drivers/net/mvgbe.c | 2 + drivers/net/xilinx_ll_temac.c | 399 ++++++++++++++++++++ drivers/net/xilinx_ll_temac.h | 310 +++++++++++++++ drivers/net/xilinx_ll_temac_fifo.c | 143 +++++++ drivers/net/xilinx_ll_temac_fifo.h | 122 ++++++ drivers/net/xilinx_ll_temac_mdio.c | 180 +++++++++ drivers/net/xilinx_ll_temac_mdio.h | 53 +++ drivers/net/xilinx_ll_temac_sdma.c | 370 ++++++++++++++++++ drivers/net/xilinx_ll_temac_sdma.h | 281 ++++++++++++++ include/configs/microblaze-generic.h | 11 +- include/netdev.h | 12 + net/eth.c | 3 +- 19 files changed, 2025 insertions(+), 51 deletions(-) create mode 100644 drivers/net/xilinx_ll_temac.c create mode 100644 drivers/net/xilinx_ll_temac.h create mode 100644 drivers/net/xilinx_ll_temac_fifo.c create mode 100644 drivers/net/xilinx_ll_temac_fifo.h create mode 100644 drivers/net/xilinx_ll_temac_mdio.c create mode 100644 drivers/net/xilinx_ll_temac_mdio.h create mode 100644 drivers/net/xilinx_ll_temac_sdma.c create mode 100644 drivers/net/xilinx_ll_temac_sdma.h
Dear Joe Hershberger,
In message CANr=Z=aW+S-+zhLMRZuprznSwYcD36z5wtJG1G=rx2POGt5i0Q@mail.gmail.com you wrote:
Hi Wolfgang,
Applied, thanks.
Joe Hershberger
