[U-Boot] [PATCH] usb: ums - expose selected partition/s
By applying this patch, it will give us some flexibility to expose a selected partition/s.
e.g: 1. To expose several partitions ums 0 mmc 0:1,0:6
2. To expose the all partitions ums 0 mmc 0:0
3. To expose multiple partititions on several devices ums 0 mmc 0:1,1:6
Signed-off-by: John Tobias john.tobias.ph@gmail.com --- cmd/usb_mass_storage.c | 32 ++++++++++++++++++++++---------- 1 file changed, 22 insertions(+), 10 deletions(-)
diff --git a/cmd/usb_mass_storage.c b/cmd/usb_mass_storage.c index 0415591..3e6ec50 100644 --- a/cmd/usb_mass_storage.c +++ b/cmd/usb_mass_storage.c @@ -50,14 +50,16 @@ static void ums_fini(void)
#define UMS_NAME_LEN 16
-static int ums_init(const char *devtype, const char *devnums) +static int ums_init(const char *devtype, const char *devnums_part) { - char *s, *t, *devnum, *name; + char *s, *t, *devnum_part, *name; block_dev_desc_t *block_dev; + disk_partition_t info; + int partnum; int ret; struct ums *ums_new;
- s = strdup(devnums); + s = strdup(devnums_part); if (!s) return -1;
@@ -65,12 +67,14 @@ static int ums_init(const char *devtype, const char *devnums) ums_count = 0;
for (;;) { - devnum = strsep(&t, ","); - if (!devnum) + devnum_part = strsep(&t, ","); + if (!devnum_part) break;
- ret = get_device(devtype, devnum, &block_dev); - if (ret < 0) + partnum = get_device_and_partition(devtype, devnum_part, + &block_dev, &info, 1); + + if (partnum < 0) goto cleanup;
/* f_mass_storage.c assumes SECTOR_SIZE sectors */ @@ -86,10 +90,18 @@ static int ums_init(const char *devtype, const char *devnums) } ums = ums_new;
+ /* if partnum = 0, expose the whole device */ + if (partnum == 0) { + ums[ums_count].start_sector = 0; + ums[ums_count].num_sectors = block_dev->lba; + } else { + ums[ums_count].start_sector = info.start; + ums[ums_count].num_sectors = info.size; + } + ums[ums_count].read_sector = ums_read_sector; ums[ums_count].write_sector = ums_write_sector; - ums[ums_count].start_sector = 0; - ums[ums_count].num_sectors = block_dev->lba; + name = malloc(UMS_NAME_LEN); if (!name) { ret = -1; @@ -230,6 +242,6 @@ cleanup_ums_init:
U_BOOT_CMD(ums, 4, 1, do_usb_mass_storage, "Use the UMS [USB Mass Storage]", - "<USB_controller> [<devtype>] <devnum> e.g. ums 0 mmc 0\n" + "<USB_controller> [<devtype>] <dev[:part]> e.g. ums 0 mmc 0:0\n" " devtype defaults to mmc" );
Hi John,
e.g:
- To expose several partitions
ums 0 mmc 0:1,0:6
- To expose the all partitions
ums 0 mmc 0:0
- To expose multiple partititions on several devices
ums 0 mmc 0:1,1:6
Could you rebase this patch on top of newest mailine?
Simon Glass did some work on this file - to be precise:
dm: Drop the block_dev_desc_t typedef 4101f6879256720b30df712089a3df18565f9203
and your patch doesn't apply anymore.
Thanks in advance, Ćukasz Majewski
- char *s, *t, *devnum_part, *name; block_dev_desc_t *block_dev;
- disk_partition_t info;
- int partnum; int ret; struct ums *ums_new;
- s = strdup(devnums_part); if (!s) return -1;
for (;;) {
if (!devnum)
if (ret < 0)
devnum_part,
if (partnum == 0) {
} else {
- ums[ums_count].read_sector = ums_read_sector; ums[ums_count].write_sector = ums_write_sector;
- name = malloc(UMS_NAME_LEN); if (!name) { ret = -1;
- "<USB_controller> [<devtype>] <dev[:part]> e.g. ums 0 mmc
John Tobias
Lukasz Majewski
