[U-Boot] [PATCH] sunxi: Select a bunch of CONFIG_foo options from ARCH_SUNXI
Select a bunch of CONFIG_foo options from ARCH_SUNXI, instead of having them set to y in every single sunxi defconfig.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/Kconfig | 3 +++ configs/A10-OLinuXino-Lime_defconfig | 3 --- configs/A10s-OLinuXino-M_defconfig | 3 --- configs/A13-OLinuXinoM_defconfig | 3 --- configs/A13-OLinuXino_defconfig | 3 --- configs/A20-OLinuXino-Lime2_defconfig | 3 --- configs/A20-OLinuXino-Lime_defconfig | 3 --- configs/A20-OLinuXino_MICRO_defconfig | 3 --- configs/Ainol_AW1_defconfig | 1 - configs/Ampe_A76_defconfig | 1 - configs/Auxtek-T004_defconfig | 3 --- configs/Bananapi_defconfig | 3 --- configs/Bananapro_defconfig | 3 --- configs/CSQ_CS908_defconfig | 3 --- configs/Chuwi_V7_CW0825_defconfig | 1 - configs/Colombus_defconfig | 3 --- configs/Cubieboard2_defconfig | 3 --- configs/Cubieboard_defconfig | 3 --- configs/Cubietruck_defconfig | 3 --- configs/Et_q8_v1_6_defconfig | 1 - configs/Hummingbird_A31_defconfig | 3 --- configs/Hyundai_A7HD_defconfig | 1 - configs/Ippo_q8h_v1_2_a33_1024x600_defconfig | 1 - configs/Ippo_q8h_v1_2_defconfig | 1 - configs/Ippo_q8h_v5_defconfig | 1 - configs/Linksprite_pcDuino3_Nano_defconfig | 3 --- configs/Linksprite_pcDuino3_defconfig | 3 --- configs/Linksprite_pcDuino_defconfig | 3 --- configs/MK808C_defconfig | 3 --- configs/MSI_Primo73_defconfig | 3 --- configs/MSI_Primo81_defconfig | 2 -- configs/Marsboard_A10_defconfig | 3 --- configs/Mele_A1000G_quad_defconfig | 3 --- configs/Mele_A1000_defconfig | 3 --- configs/Mele_I7_defconfig | 3 --- configs/Mele_M3_defconfig | 3 --- configs/Mele_M5_defconfig | 3 --- configs/Mele_M9_defconfig | 3 --- configs/Merrii_A80_Optimus_defconfig | 3 --- configs/Mini-X_defconfig | 3 --- configs/Orangepi_defconfig | 3 --- configs/Orangepi_mini_defconfig | 3 --- configs/Sinlinx_SinA33_defconfig | 3 --- configs/TZX-Q8-713B7_defconfig | 1 - configs/UTOO_P66_defconfig | 1 - configs/Wexler_TAB7200_defconfig | 3 --- configs/Wits_Pro_A20_DKT_defconfig | 3 --- configs/Yones_Toptech_BD1078_defconfig | 1 - configs/ba10_tv_box_defconfig | 3 --- configs/forfun_q88db_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/i12-tvbox_defconfig | 3 --- configs/iNet_3F_defconfig | 1 - configs/iNet_3W_defconfig | 1 - configs/iNet_86VS_defconfig | 1 - configs/jesurun_q5_defconfig | 3 --- configs/mixtile_loftq_defconfig | 3 --- configs/mk802_a10s_defconfig | 3 --- configs/mk802_defconfig | 3 --- configs/mk802ii_defconfig | 3 --- configs/r7-tv-dongle_defconfig | 3 --- configs/sunxi_Gemei_G9_defconfig | 3 --- 62 files changed, 3 insertions(+), 150 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 0829235..6c4d138 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -645,10 +645,13 @@ config ARCH_SOCFPGA config ARCH_SUNXI bool "Support sunxi (Allwinner) SoCs" select DM + select DM_ETH select DM_GPIO + select DM_USB if !USB_MUSB_SUNXI select OF_CONTROL select OF_SEPARATE select SPL_DISABLE_OF_CONTROL + select USB
config TARGET_SNOWBALL bool "Support snowball" diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 87ade90..78e799f 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -11,7 +11,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPC(3),USB_ # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 5a450af..26fadcb 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -13,7 +13,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP152_POWER,SUNXI_EMAC,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index 213ece6..2bce5c8 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -17,7 +17,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index d71c11c..9f9dc2d 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -18,7 +18,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2,AXP209_POWER,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 6445b25..c7cf48b 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -12,8 +12,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3 # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 650670f..aac3ab9 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -9,8 +9,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPC(3),USB_ # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 3f92504..726b59b 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -13,8 +13,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_ # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index f94cd5a..ec1fc8e 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -19,5 +19,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index 99aa141..c7cddf8 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -18,5 +18,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2,AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 016ccd9..7427bd7 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -10,7 +10,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP152_POWER,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 3e186f6..4c2b4be 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -10,8 +10,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHC # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 5bd2fd6..27c95ea 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -12,8 +12,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHC # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 54f4846..d2e595d 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -11,10 +11,7 @@ CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI,SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_AXP221_DLDO1_VOLT=3300 CONFIG_AXP221_ALDO1_VOLT=3300 -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index 3a2a219..0c2ca9a 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -18,7 +18,6 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y CONFIG_VIDEO_LCD_SPI_CS="PA0" CONFIG_VIDEO_LCD_SPI_SCLK="PA1" diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index 9d84901..4c3312e 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -11,9 +11,6 @@ CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI,SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_AXP221_ALDO1_VOLT=3300 -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index 0fbaa23..667b742 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -10,8 +10,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_ # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 0d0051e..243e8b7 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -9,7 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8),USB_ # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 57a3847..1857c34 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -11,8 +11,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(1 # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Et_q8_v1_6_defconfig b/configs/Et_q8_v1_6_defconfig index e36895c..50b4da8 100644 --- a/configs/Et_q8_v1_6_defconfig +++ b/configs/Et_q8_v1_6_defconfig @@ -19,7 +19,6 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y CONFIG_AXP221_DLDO1_VOLT=3300 CONFIG_AXP221_ALDO1_VOLT=3000 diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index 02c657a..ee80c0d 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -13,9 +13,6 @@ CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_AXP221_ALDO1_VOLT=3300 -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index 7800fa2..c4a566b 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -20,5 +20,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y diff --git a/configs/Ippo_q8h_v1_2_a33_1024x600_defconfig b/configs/Ippo_q8h_v1_2_a33_1024x600_defconfig index 63910c2..6af061e 100644 --- a/configs/Ippo_q8h_v1_2_a33_1024x600_defconfig +++ b/configs/Ippo_q8h_v1_2_a33_1024x600_defconfig @@ -19,7 +19,6 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y CONFIG_AXP221_DLDO1_VOLT=3300 CONFIG_AXP221_ALDO1_VOLT=3000 diff --git a/configs/Ippo_q8h_v1_2_defconfig b/configs/Ippo_q8h_v1_2_defconfig index ab62210..2d89512 100644 --- a/configs/Ippo_q8h_v1_2_defconfig +++ b/configs/Ippo_q8h_v1_2_defconfig @@ -19,7 +19,6 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y CONFIG_AXP221_DLDO1_VOLT=3300 CONFIG_AXP221_ALDO1_VOLT=3000 diff --git a/configs/Ippo_q8h_v5_defconfig b/configs/Ippo_q8h_v5_defconfig index 312a38c..e23fd6a 100644 --- a/configs/Ippo_q8h_v5_defconfig +++ b/configs/Ippo_q8h_v5_defconfig @@ -19,7 +19,6 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y CONFIG_AXP221_DLDO1_VOLT=3300 CONFIG_AXP221_ALDO1_VOLT=3000 diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 04ec7ab..8b86fbb 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -12,8 +12,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(2 # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 6d7690d..4e0ed67 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -10,8 +10,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPH(2),USB_ # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index ddd162f..836bb31 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -9,7 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_EMAC,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index a6db139..22fd604 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -9,7 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index 6e0d246..9d6ca79 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -15,7 +15,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 9787e34..c53256a 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -18,7 +18,6 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y CONFIG_AXP221_DLDO1_VOLT=3300 CONFIG_VIDEO_LCD_SSD2828_TX_CLK=27 @@ -27,4 +26,3 @@ CONFIG_VIDEO_LCD_SPI_CS="PH9" CONFIG_VIDEO_LCD_SPI_SCLK="PH10" CONFIG_VIDEO_LCD_SPI_MOSI="PH11" CONFIG_VIDEO_LCD_SPI_MISO="PH12" -CONFIG_USB=y diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index ed41af6..7f4f12a 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -8,7 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index 6e0a493..9c7bb48 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -11,12 +11,9 @@ CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI,SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_AXP221_DCDC1_VOLT=3300 CONFIG_AXP221_DLDO1_VOLT=3300 CONFIG_AXP221_DLDO4_VOLT=3300 CONFIG_AXP221_ALDO1_VOLT=3300 -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 983ffdc..df356d6 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -9,7 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI,USB_ # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 7f083a7..65398d8 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -11,12 +11,9 @@ CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI,SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_AXP221_DCDC1_VOLT=3300 CONFIG_AXP221_DLDO1_VOLT=3300 CONFIG_AXP221_DLDO4_VOLT=3300 CONFIG_AXP221_ALDO1_VOLT=3300 -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 73d87c3..8bfd32f 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -12,8 +12,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 79c5901..300679a 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -11,8 +11,5 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,USB_EHCI,STATUSLED=234" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index e017ad7..8bfd9b1 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -11,12 +11,9 @@ CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI,SUNXI_GMAC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_AXP221_DCDC1_VOLT=3300 CONFIG_AXP221_DLDO1_VOLT=3300 CONFIG_AXP221_DLDO4_VOLT=3300 CONFIG_AXP221_ALDO1_VOLT=3300 -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index b02b1a3..23ab5dc 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -12,7 +12,4 @@ CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-optimus" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index da57711..aa3f5c4 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -8,7 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index ba89a25..325d9f8 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -13,8 +13,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHC # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 8f03815..c602533 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -15,8 +15,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHC # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index e9e62da..0ba53c0 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -9,8 +9,5 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y CONFIG_AXP221_ALDO1_VOLT=3000 -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/TZX-Q8-713B7_defconfig b/configs/TZX-Q8-713B7_defconfig index 68961fc..e398bc0 100644 --- a/configs/TZX-Q8-713B7_defconfig +++ b/configs/TZX-Q8-713B7_defconfig @@ -18,5 +18,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2,AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index c3b13b7..59d5e4e 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -23,4 +23,3 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index d9180c7..321226d 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -13,7 +13,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index bb8dd29..0a30ef8 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -15,8 +15,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,RGMII,AHCI,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index aab580e..40583d3 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -24,5 +24,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index c84e82e..07e3540 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -11,7 +11,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_EMAC,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/forfun_q88db_defconfig b/configs/forfun_q88db_defconfig index 85c807a..cc9391a 100644 --- a/configs/forfun_q88db_defconfig +++ b/configs/forfun_q88db_defconfig @@ -17,5 +17,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 315627d..3bc1a52 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -21,7 +21,6 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y CONFIG_AXP221_DLDO1_VOLT=3300 CONFIG_AXP221_ALDO1_VOLT=3000 diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 3a69422..7477953 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -9,8 +9,5 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,MACPWR=SUNXI_GPH(21),USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index 54de300..7b5948b 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -19,5 +19,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index e1beac8..92a384c 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -19,5 +19,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index 627e211..1f91e8f 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -17,5 +17,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 4b09a33..a4c7d1e 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -9,7 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_EMAC,USB_EHCI,MACPWR=SUNXI_GPH(19)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index a8c497c..48fe570 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -12,9 +12,6 @@ CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI,SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_AXP221_ALDO1_VOLT=3300 -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index dc78fa4..ce308d9 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -11,7 +11,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP152_POWER,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 31bde00..1098bd4 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -9,7 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index ffa7891..635273c 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -8,7 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index ac7928d..edf7b8a 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -10,7 +10,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP152_POWER,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index e95cbe4..5ee6fd9 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -15,7 +15,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,USB_EHCI" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set -CONFIG_DM_ETH=y CONFIG_DM_SERIAL=y -CONFIG_USB=y -CONFIG_DM_USB=y
Ug, sorry, I was waiting for some build results to come out before posting my version of this.
To update the USB side: $ for F in `git grep -l SYS_EXTRA.*USB_EHCI`;do sed -i -e 's/,USB_EHCI//' -e 's/USB_EHCI,//' $F && echo CONFIG_USB_EHCI_HCD=y >> $F;done
And was there a reason you didn't include a 'select DM_SERIAL' in yours?
[snip]
- select DM_ETH select DM_GPIO
- select DM_USB if !USB_MUSB_SUNXI select OF_CONTROL select OF_SEPARATE select SPL_DISABLE_OF_CONTROL
- select USB
We really don't want to leave USB as a board choice?
No problem.
Yes setting that for all boards breaks booting of boards which do not have a serial port as drivers/serial/serial-uclass.c: serial_find_console_or_panic() will then panic (runtime error, yeah).
And we've one such board. I've a fix for this, next step is to merge your and mine patches as both have some good things the other one does not have (I like your work on setting CONFIG_USB_EHCI_HCD, but you're not selecting CONFIG_USB).
I've run out of steam for today, so I will try to get this done tomorrow.
[snip]
- select USB
All sunxi SoCs have 2 - 4 (*) usb controllers, and there does not exist a single board which does not at least uses one usb controller, and I like to keep things consistent where ever possible to reduce the combinatorial explosion problem all these Kconfig options give us.
Regards,
Hans
*) 3 - 6 if you count ehci/ohci seperately.
Hans de Goede
