[U-Boot-Users] PPC 8260 Linux boot
I am trying to boot Linux 2.4.25 (code from denx linux-2-4-devel) The board is similar to MPC8260ADS What happens is that the kernel is starting but after a short while gets an exception and the board is reset again. We tried looking at the kernel sources to see where we get, we did this by lighting hardware LEDS we have on the board. We tried to find where in the kernel we get the exception, we could not find exactly where it happens, but we did find that it happens somewhere in the function prom_init called from early_init inside arch/ppc/kernel/setup.c
Does anyone have any idea what we should look next?
-- Ori Idan
Arghh... A description like this is absolutley useless, and misleading. Your probably even fooling yourself. Similar? In that it uses the same processor? Or is everything IDENTICAL?
Please define "after a short while". Do you see any boot messages on the console? Do you see any messages when you do a post mortem dump of the log_buf memory? [See http://www.denx.de/twiki/bin/view/DULG/LinuxPostMortemAnalysis]
I see. Please remove ALL this code and try again. perhaps it is just your debugging code which crashes the system. [This has been discussed before, both here and in the linuxppc mailing lists. Search the archives.]
OK, I'll give you two hints:
1) get yourself a BDI2000. You will need it.
2) Check your memory map, and the init sequence of your SDRAM [no, I'm not going to explain this here again. Search the archives.]
Thank you for your quick answer.
If it was not IDENTICAL I would not have mentioned this board.
I do not see any boot messages, I can't exactly define how long it takes until the reset but it is a very short time that during this time I expected at least one line saying this is the kernel.
I tried removing all my code and tried again, that was the first thing I thought that maybe I crash the system. I tried again and again and the problem was the same.
Unfortunatly the archives are not searchable, otherwise that would be the first thing I would do, could you give me some hints on what do you mean init sequence of SDRAM? As for the memory map, I made sure I have RAM starting from 0x0000, I have 128Mb of RAM. The IMMR is set to 0xF0000000.
-- Ori Idan
So it is identical? Then why did you write "similar to" in the first place?
And if it's really identical I thinkt he standard MPC8260ADS code should work identical, too.
I repeat:
You cannot make such a claim. The _symptoms_ may have been the same. The problem may have been a different one.
- Check your memory map, and the init sequence of your SDRAM [no,
The GMANE archive _is_ searchable.
IO mean the initialization sequence that is required for the SDRAM chips. In 98% of all porting problems this is the culprit.
Did you read the FAQ? How about the "clocks_in_mhz" setting? Or the bd_info structure used by the Linux kernel?
I repeat:
I think I don't understand something in your explenation of post mortem, how can I do grep log_buf system.map when I have nothing but UBOOT prompt?
What is the GNAME archive?
I still do not understand what do you mean by init sequence of SDRAM, If I had any hint of what you mean by that I would check for it. All I know is that I have 128MB of RAM mapped from 0x0000 I have checked it again.
Yes, I have thought about the clock value and made sure it is passed Ok, since I am using kernel 2.4.25 I understand that the clock should be in Hz and that is what U-boot transfers.
-- Ori Idan
You do have a development system which you used to compile and link your Linux kernel, don't you? And you do have the "grep" command installed on that host, right?
http://news.gmane.org/gmane.comp.boot-loaders.u-boot
[Why didn't a google search for "gmane u-boot" return useful links for you?]
Read the documentation provided by the manufacturer of your RAM chips. It shosuld contain a section about the SDRAM init sequence.
And what about bd_info?
Ok, I think it should be written clearly in the wiki that this is the host system.
Isn't the fact that I have RAM from 0x0000 means that RAM is initialized? I have checked in Uboot that I can write and read this RAM so I am sure I have it. What other initialization should be done?
I have checked bd_info and it transfers the clock in Hz and also transfer the right RAM and IMMR information.
-- Ori Idan
You are the first person to misunderstand this.
No, it does not. Mapping some address space in the memory controller and actually initializing a device are completely different issues.
Please read the archives. Simple read and write access are easy; this still does not give any guarantee that burst mode accesses will work.
I already told you:
READ THE DOCUMENTATION PROVIDED BY THE MANUFACTURER OF YOUR RAM CHIPS. IT SHOULD CONTAIN A SECTION ABOUT THE REQUIRED INIT SEQUENCE.
And _please_ read the mail list archive.
Argh... You make it really difficult to help you.
Did you check ALL items of the FAQ "Linux hangs after uncompressing the kernel", i. e. did you really make sure that U-Boot and Linux are using the SAME version of bd_info?
Ok, it seems Linux is booting now or at least we think so There is not exception now but all we get is few unmeaningfull character on the terminal We belive Linux is booting but the kernel is miscalculating the baud rate. The clock information in bd_info seems to be Ok but I will double check this tomorow.
Does someone has any clue for what may cause this problem?
-- Ori Idan
Ori Idan
