[U-Boot] [PATCH] wandboard: Enable SATA for quad
Having sata first will makes preference to sata boot if both sata0 and mmc0 have a boot partition
This change was not tested against wanboard solo/dual, but it does operate correctly when there is no sata disk connected on quad. (it falls back to mmc0 boot)
Tested with current u-boot 2017.03-rc2 with Fedora 25 workstation armhfp
Signed-off-by: Nicolas Chauvet kwizart@gmail.com --- include/configs/wandboard.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 7e9757a..3101d1b 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -128,6 +128,7 @@ BOOTENV
#define BOOT_TARGET_DEVICES(func) \ + func(SATA, sata, 0) \ func(MMC, mmc, 0) \ func(MMC, mmc, 1) \ func(USB, usb, 0) \
Have you tested with a non quad device that doesn't have sata? It doesn't appear to be special cased, just blanket added.
-- 2.7.4
Hi Nicholas,
Just FYI: I decided to not merge it because I have not myself non quad Wandboard and this must be tested before merging. I let the patch for a long while, but I have not seen that someone else had the possibility to test it.
Best regards, Stefano Babic
-- 2.7.4
Nicolas Chauvet
Peter Robinson
Stefano Babic
