[U-Boot] [PATCH v2 1/2] ARM: mx25: Print the silicon revison
Print the silicon revison during boot.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Handle the unkown silicon revision in the same way as for mx31.
arch/arm/cpu/arm926ejs/mx25/generic.c | 32 +++++++++++++++++++++++++++- arch/arm/include/asm/arch-mx25/imx-regs.h | 3 ++ 2 files changed, 33 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index 76e4b5c..dca8d98 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -105,12 +105,40 @@ ulong imx_get_perclk (int clk) return lldiv (fref, div); }
+ +u32 get_cpu_rev(void) +{ + u32 srev; + u32 system_rev = 0x25000; + + /* read SREV register from IIM module */ + struct iim_regs *iim = (struct iim_regs *)IMX_IIM_BASE; + srev = readl(&iim->iim_srev); + + switch (srev) { + case 0x00: + system_rev |= CHIP_REV_1_0; + break; + case 0x01: + system_rev |= CHIP_REV_1_1; + break; + default: + system_rev |= 0x8000; + break; + } + + return system_rev; +} + #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo (void) { char buf[32]; - - printf ("CPU: Freescale i.MX25 at %s MHz\n\n", + u32 cpurev = get_cpu_rev(); + + printf("CPU: Freescale i.MX25 rev%d.%d%s at %s MHz\n\n", + (cpurev & 0xF0) >> 4, (cpurev & 0x0F), + ((cpurev & 0x8000) ? " unknown" : ""), strmhz (buf, imx_get_armclk ())); return 0; } diff --git a/arch/arm/include/asm/arch-mx25/imx-regs.h b/arch/arm/include/asm/arch-mx25/imx-regs.h index 7e34050..d0c6d00 100644 --- a/arch/arm/include/asm/arch-mx25/imx-regs.h +++ b/arch/arm/include/asm/arch-mx25/imx-regs.h @@ -352,4 +352,7 @@ struct aips_regs { #define GPIO3_BASE_ADDR IMX_GPIO3_BASE #define GPIO4_BASE_ADDR IMX_GPIO4_BASE
+#define CHIP_REV_1_0 0x10 +#define CHIP_REV_1_1 0x11 + #endif /* _IMX_REGS_H */
Print the source of reset during boot.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - Fix the logic for detecting the reset cause
arch/arm/cpu/arm926ejs/mx25/generic.c | 25 ++++++++++++++++++++++++- 1 files changed, 24 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index dca8d98..ed4b3e0 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -105,6 +105,28 @@ ulong imx_get_perclk (int clk) return lldiv (fref, div); }
+static char *get_reset_cause(void) +{ + /* read RCSR register from CCM module */ + struct ccm_regs *ccm = + (struct ccm_regs *)IMX_CCM_BASE; + + u32 cause = readl(&ccm->rcsr) & 0x0f; + + if (cause == 0) + return "POR"; + else if (cause == 1) + return "RST"; + else if ((cause & 2) == 2) + return "WDOG"; + else if ((cause & 4) == 4) + return "SW RESET"; + else if ((cause & 8) == 8) + return "JTAG"; + else + return "unknown reset"; + +}
u32 get_cpu_rev(void) { @@ -136,10 +158,11 @@ int print_cpuinfo (void) char buf[32]; u32 cpurev = get_cpu_rev(); - printf("CPU: Freescale i.MX25 rev%d.%d%s at %s MHz\n\n", + printf("CPU: Freescale i.MX25 rev%d.%d%s at %s MHz\n", (cpurev & 0xF0) >> 4, (cpurev & 0x0F), ((cpurev & 0x8000) ? " unknown" : ""), strmhz (buf, imx_get_armclk ())); + printf("Reset cause: %s\n\n", get_reset_cause()); return 0; } #endif
Changes since v1:
Applied to u-boot-imx as a fix, thanks.
Best regards, Stefano Babic
Hi Stefano,
On Fri, Sep 2, 2011 at 12:38 PM, Fabio Estevam fabio.estevam@freescale.com wrote:
Changes since v1:
Does v2 look good now?
Regards,
Fabio Estevam
On 09/09/2011 01:21 PM, Fabio Estevam wrote:
Hi Stefano,
Changes since v1:
Sorry, no answer because I had no comments...it looks good ! I will merge still for this release, because IMHO it is a fix.
Changes since v1:
Fabio Estevam
Fabio Estevam
Stefano Babic
