[U-Boot] [PATCH 0/4] ARM relocation fixes
As discussed in http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/89864/focus=89905 here are the changes for r8 usage in all arm relocate_code() implementations.
Additionally there is a change to armv7 code which is persumably broken (at least when CONFIG_PRELADER is _not_ defined). Please comment on that patch, the rest should go in v2010.12.
Andreas Bießmann (4): arm: copy_loop(): use scratch register arm: relocate_code(): do not set register useless arm: fixloop(): do not use r8 for relocation armv7: fix relocation skip
arch/arm/cpu/arm1136/start.S | 20 ++++++++++---------- arch/arm/cpu/arm1176/start.S | 20 ++++++++++---------- arch/arm/cpu/arm720t/start.S | 20 ++++++++++---------- arch/arm/cpu/arm920t/start.S | 20 ++++++++++---------- arch/arm/cpu/arm925t/start.S | 20 ++++++++++---------- arch/arm/cpu/arm926ejs/start.S | 20 ++++++++++---------- arch/arm/cpu/arm946es/start.S | 20 ++++++++++---------- arch/arm/cpu/arm_intcm/start.S | 20 ++++++++++---------- arch/arm/cpu/armv7/start.S | 24 ++++++++++++------------ arch/arm/cpu/ixp/start.S | 20 ++++++++++---------- arch/arm/cpu/lh7a40x/start.S | 20 ++++++++++---------- arch/arm/cpu/pxa/start.S | 20 ++++++++++---------- arch/arm/cpu/s3c44b0/start.S | 20 ++++++++++---------- arch/arm/cpu/sa1100/start.S | 20 ++++++++++---------- 14 files changed, 142 insertions(+), 142 deletions(-)
This patch uses r1 as scratch register for copy_loop(). Therefore we do not longer need r7 for the storage of relocate_code()'s 'addr_moni' (the destination address of relocation). Therefore r7 can be used later on for other purposes.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- arch/arm/cpu/arm1136/start.S | 10 +++++----- arch/arm/cpu/arm1176/start.S | 10 +++++----- arch/arm/cpu/arm720t/start.S | 10 +++++----- arch/arm/cpu/arm920t/start.S | 10 +++++----- arch/arm/cpu/arm925t/start.S | 10 +++++----- arch/arm/cpu/arm926ejs/start.S | 10 +++++----- arch/arm/cpu/arm946es/start.S | 10 +++++----- arch/arm/cpu/arm_intcm/start.S | 10 +++++----- arch/arm/cpu/armv7/start.S | 10 +++++----- arch/arm/cpu/ixp/start.S | 10 +++++----- arch/arm/cpu/lh7a40x/start.S | 10 +++++----- arch/arm/cpu/pxa/start.S | 10 +++++----- arch/arm/cpu/s3c44b0/start.S | 10 +++++----- arch/arm/cpu/sa1100/start.S | 10 +++++----- 14 files changed, 70 insertions(+), 70 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index eec8bee..153a881 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -186,13 +186,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
/* Set up the stack */ stack_setup: mov sp, r4
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -201,7 +201,7 @@ stack_setup:
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ - stmia r6!, {r9-r10} /* copy to target address [r1] */ + stmia r1!, {r9-r10} /* copy to target address [r1] */ cmp r0, r2 /* until source end address [r2] */ blo copy_loop
@@ -210,7 +210,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -251,7 +251,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -280,7 +280,7 @@ jump_2_ram: add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index cd8f016..5046765 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -240,13 +240,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -255,7 +255,7 @@ stack_setup:
@@ -264,7 +264,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -343,7 +343,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -372,7 +372,7 @@ _nand_boot: .word nand_boot add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index 46050da..c34ec44 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -155,13 +155,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -170,7 +170,7 @@ stack_setup:
@@ -179,7 +179,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -220,7 +220,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -244,7 +244,7 @@ clbss_l:str r2, [r0] /* clear loop... */ add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index 01edb9b..cae0e3c 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -201,13 +201,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -216,7 +216,7 @@ stack_setup:
@@ -225,7 +225,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -266,7 +266,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -297,7 +297,7 @@ _nand_boot_ofs: add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index ce590a7..ebce803 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -192,13 +192,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -207,7 +207,7 @@ stack_setup:
@@ -216,7 +216,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -257,7 +257,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -288,7 +288,7 @@ _nand_boot_ofs: add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 6dcc9b4..a099f7d 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -191,13 +191,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -206,7 +206,7 @@ stack_setup:
@@ -215,7 +215,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -256,7 +256,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -287,7 +287,7 @@ _nand_boot_ofs: add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index f4950f7..bb97143 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -163,13 +163,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -178,7 +178,7 @@ stack_setup:
@@ -187,7 +187,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -228,7 +228,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -254,7 +254,7 @@ _nand_boot: .word nand_boot add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index fcaba30..a1a548c 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -159,13 +159,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -174,7 +174,7 @@ stack_setup:
@@ -183,7 +183,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -224,7 +224,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -255,7 +255,7 @@ _nand_boot_ofs: add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 2dfdafe..e6f6d69 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -159,7 +159,6 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
/* Set up the stack */ stack_setup: @@ -169,6 +168,7 @@ stack_setup: ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ + mov r1, r6 /* r1 <- scratch for copy_loop */ cmp r0, r6 #ifndef CONFIG_PRELOADER beq jump_2_ram @@ -176,7 +176,7 @@ stack_setup:
@@ -185,7 +185,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -224,7 +224,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -246,7 +246,7 @@ jump_2_ram: add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index d1ab19b..c6dee26 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -285,13 +285,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -300,7 +300,7 @@ stack_setup:
@@ -309,7 +309,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -350,7 +350,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -374,7 +374,7 @@ clbss_l:str r2, [r0] /* clear loop... */ add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/lh7a40x/start.S b/arch/arm/cpu/lh7a40x/start.S index 5cf477b..119fe18 100644 --- a/arch/arm/cpu/lh7a40x/start.S +++ b/arch/arm/cpu/lh7a40x/start.S @@ -172,13 +172,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -187,7 +187,7 @@ stack_setup:
@@ -196,7 +196,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -237,7 +237,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -258,7 +258,7 @@ clbss_l:str r2, [r0] /* clear loop... */ add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index ae358a5..be4eb8b 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -237,13 +237,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -253,7 +253,7 @@ stack_setup: stmfd sp!, {r0-r12} copy_loop: ldmia r0!, {r3-r5, r7-r11} /* copy from source address [r0] */ - stmia r6!, {r3-r5, r7-r11} /* copy to target address [r1] */ + stmia r1!, {r3-r5, r7-r11} /* copy to target address [r1] */ cmp r0, r2 /* until source end address [r2] */ blo copy_loop ldmfd sp!, {r0-r12} @@ -263,7 +263,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -304,7 +304,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -332,7 +332,7 @@ _start_oneboot_ofs add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 8c7100c..9667eab 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -144,13 +144,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -159,7 +159,7 @@ stack_setup:
@@ -168,7 +168,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -209,7 +209,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -233,7 +233,7 @@ clbss_l:str r2, [r0] /* clear loop... */ add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 36d44da..e928bc2 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -148,13 +148,13 @@ relocate_code: mov r4, r0 /* save addr_sp */ mov r5, r1 /* save addr of gd */ mov r6, r2 /* save addr of destination */ - mov r7, r2 /* save addr of destination */
adr r0, _start + mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -163,7 +163,7 @@ stack_setup:
@@ -172,7 +172,7 @@ copy_loop: * fix .rel.dyn relocations */ ldr r0, _TEXT_BASE /* r0 <- Text base */ - sub r9, r7, r0 /* r9 <- relocation offset */ + sub r9, r6, r0 /* r9 <- relocation offset */ ldr r10, _dynsym_start_ofs /* r10 <- sym table ofs */ add r10, r10, r0 /* r10 <- sym table in FLASH */ ldr r2, _rel_dyn_start_ofs /* r2 <- rel dyn start ofs */ @@ -213,7 +213,7 @@ clear_bss: ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs ldr r3, _TEXT_BASE /* Text base */ - mov r4, r7 /* reloc addr */ + mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 mov r2, #0x00000000 /* clear */ @@ -234,7 +234,7 @@ clbss_l:str r2, [r0] /* clear loop... */ add lr, lr, r9 /* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ - mov r1, r7 /* dest_addr */ + mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
Dear =?UTF-8?q?Andreas=20Bie=C3=9Fmann?=,
In message 1291161516-21861-2-git-send-email-andreas.devel@googlemail.com you wrote:
Applied, thanks.
Signed-off-by: Andreas Bießmannandreas.devel@googlemail.com
Acked-By: Albert ARIBAUD albertaribaud@free.fr
Amicalement,
In case we are still at relocation target address before relocation we do not need to load the registers needed for relocation. We should instead skip the whole relocation part and jump over to clear_bss immediately.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- arch/arm/cpu/arm1136/start.S | 4 ++-- arch/arm/cpu/arm1176/start.S | 4 ++-- arch/arm/cpu/arm720t/start.S | 4 ++-- arch/arm/cpu/arm920t/start.S | 4 ++-- arch/arm/cpu/arm925t/start.S | 4 ++-- arch/arm/cpu/arm926ejs/start.S | 4 ++-- arch/arm/cpu/arm946es/start.S | 4 ++-- arch/arm/cpu/arm_intcm/start.S | 4 ++-- arch/arm/cpu/armv7/start.S | 8 ++++---- arch/arm/cpu/ixp/start.S | 4 ++-- arch/arm/cpu/lh7a40x/start.S | 4 ++-- arch/arm/cpu/pxa/start.S | 4 ++-- arch/arm/cpu/s3c44b0/start.S | 4 ++-- arch/arm/cpu/sa1100/start.S | 4 ++-- 14 files changed, 30 insertions(+), 30 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 153a881..7ba7245 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -192,12 +192,12 @@ stack_setup: mov sp, r4
adr r0, _start + cmp r0, r6 + beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ - cmp r0, r6 - beq clear_bss
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index 5046765..f9c8671 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -246,12 +246,12 @@ stack_setup: mov sp, r4
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index c34ec44..6a6af1b 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -161,12 +161,12 @@ stack_setup: mov sp, r4
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index cae0e3c..cdf0920 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -207,12 +207,12 @@ stack_setup: mov sp, r4
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index ebce803..54f2339 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -198,12 +198,12 @@ stack_setup: mov sp, r4
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index a099f7d..59db6b5 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -197,12 +197,12 @@ stack_setup: mov sp, r4
adr r0, _start + cmp r0, r6 + beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy loop */ ldr r2, _TEXT_BASE ldr r3, _bss_start_ofs add r2, r0, r3 /* r2 <- source end address */ - cmp r0, r6 - beq clear_bss
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index bb97143..90ae0cf 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -169,12 +169,12 @@ stack_setup: mov sp, r4
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index a1a548c..e53eaa7 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -165,12 +165,12 @@ stack_setup: mov sp, r4
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index e6f6d69..1c2b36b 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -165,14 +165,14 @@ stack_setup: mov sp, r4
adr r0, _start - ldr r2, _TEXT_BASE - ldr r3, _bss_start_ofs - add r2, r0, r3 /* r2 <- source end address */ - mov r1, r6 /* r1 <- scratch for copy_loop */ cmp r0, r6 #ifndef CONFIG_PRELOADER beq jump_2_ram #endif + mov r1, r6 /* r1 <- scratch for copy_loop */ + ldr r2, _TEXT_BASE + ldr r3, _bss_start_ofs + add r2, r0, r3 /* r2 <- source end address */
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index c6dee26..d176869 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -291,12 +291,12 @@ stack_setup: mov sp, r4
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/lh7a40x/start.S b/arch/arm/cpu/lh7a40x/start.S index 119fe18..73cdda4 100644 --- a/arch/arm/cpu/lh7a40x/start.S +++ b/arch/arm/cpu/lh7a40x/start.S @@ -178,12 +178,12 @@ stack_setup: mov sp, r4
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index be4eb8b..d37797a 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -243,12 +243,12 @@ stack_setup: mov sp, r4
stmfd sp!, {r0-r12} copy_loop: diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 9667eab..ac8f913 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -150,12 +150,12 @@ stack_setup: mov sp, r4
copy_loop: ldmia r0!, {r9-r10} /* copy from source address [r0] */ diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index e928bc2..61ac21f 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -154,12 +154,12 @@ stack_setup: mov sp, r4
In message 1291161516-21861-3-git-send-email-andreas.devel@googlemail.com you wrote:
Signed-off-by: Andreas BieÃmann andreas.devel@googlemail.com
Applied, thanks.
Acked-by: Albert ARIBAUD albert.aribaud@free.fr
Amicalement,
(note: other patches in the series have a typo in my e-mail address -- missing dot between my name and surname. In my case, lack not of beer but of coffee.)
Amicalement,
r8 is used for global_data and should therefore be left alone!
For C code the compiler flag --fixed-r8 does the job, but in assembler we need to be aware of that fact.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- arch/arm/cpu/arm1136/start.S | 6 +++--- arch/arm/cpu/arm1176/start.S | 6 +++--- arch/arm/cpu/arm720t/start.S | 6 +++--- arch/arm/cpu/arm920t/start.S | 6 +++--- arch/arm/cpu/arm925t/start.S | 6 +++--- arch/arm/cpu/arm926ejs/start.S | 6 +++--- arch/arm/cpu/arm946es/start.S | 6 +++--- arch/arm/cpu/arm_intcm/start.S | 6 +++--- arch/arm/cpu/armv7/start.S | 6 +++--- arch/arm/cpu/ixp/start.S | 6 +++--- arch/arm/cpu/lh7a40x/start.S | 6 +++--- arch/arm/cpu/pxa/start.S | 6 +++--- arch/arm/cpu/s3c44b0/start.S | 6 +++--- arch/arm/cpu/sa1100/start.S | 6 +++--- 14 files changed, 42 insertions(+), 42 deletions(-)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 7ba7245..fa56cd0 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -221,10 +221,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index f9c8671..278ae50 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -275,10 +275,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/arm720t/start.S b/arch/arm/cpu/arm720t/start.S index 6a6af1b..9b34e89 100644 --- a/arch/arm/cpu/arm720t/start.S +++ b/arch/arm/cpu/arm720t/start.S @@ -190,10 +190,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index cdf0920..914ab27 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -236,10 +236,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index 54f2339..f7a0d0e 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -227,10 +227,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 59db6b5..8ab237e 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -226,10 +226,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index 90ae0cf..29a48fd 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -198,10 +198,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index e53eaa7..4bbd130 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -194,10 +194,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 1c2b36b..5d79f34 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -196,10 +196,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index d176869..6a34160 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -320,10 +320,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/lh7a40x/start.S b/arch/arm/cpu/lh7a40x/start.S index 73cdda4..ddef42a 100644 --- a/arch/arm/cpu/lh7a40x/start.S +++ b/arch/arm/cpu/lh7a40x/start.S @@ -207,10 +207,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index d37797a..dcfee63 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -274,10 +274,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index ac8f913..27cf2bd 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -179,10 +179,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index 61ac21f..a5b6903 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -183,10 +183,10 @@ fixloop: ldr r0, [r2] /* r0 <- location to fix up, IN FLASH! */ add r0, r0, r9 /* r0 <- location to fix up in RAM */ ldr r1, [r2, #4] - and r8, r1, #0xff - cmp r8, #23 /* relative fixup? */ + and r7, r1, #0xff + cmp r7, #23 /* relative fixup? */ beq fixrel - cmp r8, #2 /* absolute fixup? */ + cmp r7, #2 /* absolute fixup? */ beq fixabs /* ignore unknown type of fixup */ b fixnext
In message 1291161516-21861-4-git-send-email-andreas.devel@googlemail.com you wrote:
Applied, thanks.
Amicalement,
I doubt the stack_setup() was defective before: we load the current location of _start and compare against destination of relocate_code(). If we are already there we shoud skip the relocation and jump over to clear_bss. Before the clear_bss was also skipped.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- Dear Albert, (or whoever works with armv7 currently)
However I doubt there is another issue when CONFIG_PRELOADER is not set! Then the bss will never be setup, is that correct?
arch/arm/cpu/armv7/start.S | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 5d79f34..7e31cc2 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -165,9 +165,9 @@ stack_setup: mov sp, r4
adr r0, _start - cmp r0, r6 #ifndef CONFIG_PRELOADER - beq jump_2_ram + cmp r0, r6 + beq clear_bss /* skip relocation */ #endif mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r2, _TEXT_BASE
That is correct and had to be fixed indeed. Thanks!
Amicalement,
In message 1291161516-21861-5-git-send-email-andreas.devel@googlemail.com you wrote:
Applied, thanks.
Acked-by: Albert ARIBAUD albertaribaud@free.fr
Amicalement,
Albert ARIBAUD
Andreas Bießmann
