[PATCH] riscv: spacemit: k1: probe dram size during boot phase.
--- This patch introduce improvement for get dram size on bananapi BPI-F3, retrieving the dram size dynamically. Have tested on bananapi BPIF3 4G and jupiter 8G.
Signed-off-by: Huan Zhou me@per1cycle.org --- arch/riscv/cpu/k1/dram.c | 40 ++++++++++++++++++++++++++++++++++++++-- 1 file changed, 38 insertions(+), 2 deletions(-)
diff --git a/arch/riscv/cpu/k1/dram.c b/arch/riscv/cpu/k1/dram.c index c477c15cbfb19f0e3a0ee72985b602f5bda352d7..095217f2a4c053f7477d62c0776bcb51e623db47 100644 --- a/arch/riscv/cpu/k1/dram.c +++ b/arch/riscv/cpu/k1/dram.c @@ -4,17 +4,53 @@ */
#include <asm/global_data.h> +#include <asm/io.h> #include <config.h> +#include <bitfield.h> #include <fdt_support.h> #include <linux/sizes.h>
+#define DDR_BASE 0xC0000000 DECLARE_GLOBAL_DATA_PTR;
+static inline u32 map_format_size(u32 val) +{ + u32 tmp; + + if (val & 0x1 == 0) + return 0; + + tmp = bitfield_extract(val, 16, 5); + switch (tmp) { + case 0xd: + return 512; + case 0xe: + return 1024; + case 0xf: + return 2048; + case 0x10: + return 4096; + case 0x11: + return 8192; + default: + pr_info("Invalid DRAM density %x\n", val); + return 0; + } +} + +u32 ddr_get_density(void) +{ + u32 cs0_size = map_format_size(readl((void *)DDR_BASE + 0x200)); + u32 cs1_size = map_format_size(readl((void *)DDR_BASE + 0x208)); + u32 ddr_size = cs0_size + cs1_size; + + return ddr_size; +} + int dram_init(void) { gd->ram_base = CFG_SYS_SDRAM_BASE; - /* TODO get ram size from ddr controller */ - gd->ram_size = SZ_4G; + gd->ram_size = (u64)ddr_get_density() * SZ_1M; return 0; }
--- base-commit: 19fc0b7f7d907119a13e9c207991899f0817f8fc change-id: 20250108-get-dram-size-65cf59a15201
Hi Huan:
On 16:49 Wed 08 Jan , Huan Zhou wrote:
remove above "---"? otherwise following commit message will be dropped during patch application..
- u32 tmp;
- if (val & 0x1 == 0)
please add brackets explicitly, something like if ((val & 0x1) == 0)
- tmp = bitfield_extract(val, 16, 5);
- switch (tmp) {
- case 0xd:
return 512;
- case 0xe:
return 1024;
- case 0xf:
return 2048;
- case 0x10:
return 4096;
- case 0x11:
return 8192;
- default:
- u32 cs0_size = map_format_size(readl((void *)DDR_BASE + 0x200));
- u32 cs1_size = map_format_size(readl((void *)DDR_BASE + 0x208));
- u32 ddr_size = cs0_size + cs1_size;
- return ddr_size;
- gd->ram_size = (u64)ddr_get_density() * SZ_1M;
while using cast, why not define ddr_get_density() return as same type? also it's more reasonable to use phys_size_t as I checked gd_t
return 0; }
Am 8. Januar 2025 12:11:05 MEZ schrieb Yixun Lan dlan@gentoo.org:
Hi Huan:
- u32 tmp;
We tend to avoid == 0 in U-Boot
if (val & BIT(0))
- switch (tmp) {
- case 0xd:
return 512;
- case 0xe:
return 1024;
- case 0xf:
return 2048;
- case 0x10:
return 4096;
- case 0x11:
return 8192;
- default:
- return ddr_size;
This is C and not C++. We don't need a cast to assign here.
Best regards
Heinrich
return 0; }
Hi Huan:
- u32 tmp;
ok, got it.
if (val & BIT(0))
- switch (tmp) {
- case 0xd:
return 512;
- case 0xe:
return 1024;
- case 0xf:
return 2048;
- case 0x10:
return 4096;
- case 0x11:
return 8192;
- default:
- return ddr_size;
ok, will fixed and retested, links to test log will be added too.
Best regards
Heinrich
return 0; }
Hi Huan:
- u32 tmp;
if (val & BIT(0))
That's reversed.
if (!(val & BIT(0)) {
I have really complicated rules about when to use ! vs == 0. https://staticthinking.wordpress.com/2024/02/20/when-to-use-0/
- switch (tmp) {
- case 0xd:
return 512;
- case 0xe:
return 1024;
- case 0xf:
return 2048;
- case 0x10:
return 4096;
- case 0x11:
return 8192;
- default:
- return ddr_size;
I assumed the cast was to prevent an integer overflow. The commit message mentions 8GB? I agree with Yixun Lan that the type of ddr_get_density() should be fixed and probably SZ_1M should be declared as unsigned long as well.
regards, dan carpenter
Hi Huan:
- u32 tmp;
if (val & BIT(0))
it should be (val & 0x1) == 0 here, i test that version of patch and do some simplification on the origin code.. but forgot test here, btw personally i would keep the (==0) here...
That's reversed.
- switch (tmp) {
- case 0xd:
return 512;
- case 0xe:
return 1024;
- case 0xf:
return 2048;
- case 0x10:
return 4096;
- case 0x11:
return 8192;
- default:
- return ddr_size;
ok, will fixed in next version, thx.
Hi Dan,
Hi Huan:
- u32 tmp;
if (val & BIT(0))
That's reversed.
I mostly agree with that and it provides some motivation for the conventions which have built up over the years in Linux/U-Boot/etc.
If you want to send a patch:
$ git grep 'if (ret != EFI_SUCCESS)' |wc 864 4841 51380
I think the only place I would differ is with strcmp(), where I've got used to 0 meaning success, like in much other code.
Regards, SImon
On Wed, Jan 08, 2025 at 10:03:08AM -0700, Simon Glass wrote:
Hi Dan,
Hi Huan:
- u32 tmp;
if (val & BIT(0))
That's reversed.
To be clear here, we have ~900 examples of EFI_SUCCESS and ~250 examples of other FOO_SUCCESS type tests. And if we're going to make some sort of change here, we should (a) document it and (b) fix it everywhere.
And at the risk of confusing your intentions Simon, Dan has a well deserved reputation in the Linux kernel for fixing what I would call "C is trickier than you think, even if you're been doing it for decades" bugs so just changing EFI code would be silly.
Hi Dan,
Hi Huan:
- u32 tmp;
if (val & BIT(0))
That's reversed.
Huh... I've never thought about it as a success/fail thing.
I feel like I've seens quite a few reversed strcmp() functions but it's hard to catch these sorts of bugs with static analysis because it totally depends on the context if you want the strings to be equal or not equal. I can't imagine what a static checker rule would look like.
Hi Dan,
Hi Dan,
Hi Huan:
- u32 tmp;
if (val & BIT(0))
That's reversed.
I have evolved on that one.
There's no substitute for tests and naming is hard. We could have a streq() function which just returns 0 or 1, but it would presumably have to return 1/true when equal, thus creating confusion with strcmp(). Perhaps strcheckeq() would be a better name for a function that returns '0' on success?
On Wed, Jan 08, 2025 at 07:11:05PM +0800, Yixun Lan wrote:
Hi Huan:
- u32 tmp;
ok, mb, will correct and test in next version.
- switch (tmp) {
- case 0xd:
return 512;
- case 0xe:
return 1024;
- case 0xf:
return 2048;
- case 0x10:
return 4096;
- case 0x11:
return 8192;
- default:
- return ddr_size;
ok, got it.
return 0; }
-- Yixun Lan (dlan) Gentoo Linux Developer GPG Key ID AABEFD55
Hi Huan:
ill have a check.
- u32 tmp;
ok, sry for this dummy mistake ;(
- switch (tmp) {
- case 0xd:
return 512;
- case 0xe:
return 1024;
- case 0xf:
return 2048;
- case 0x10:
return 4096;
- case 0x11:
return 8192;
- default:
- return ddr_size;
this two line not sure why it appear, also will be removed in next version
ok, will fixed in next version.
return 0; }
Hi Huan Zhou
Thanks!
Tested-by: Marcel Ziswiler marcel@ziswiler.com # BPI-F3 16G
diff --git a/arch/riscv/cpu/k1/dram.c b/arch/riscv/cpu/k1/dram.c index c477c15cbfb19f0e3a0ee72985b602f5bda352d7..095217f2a4c053f7477d62c0776bcb51e623db47 100644 --- a/arch/riscv/cpu/k1/dram.c +++ b/arch/riscv/cpu/k1/dram.c @@ -4,17 +4,53 @@ */ #include <asm/global_data.h> +#include <asm/io.h> #include <config.h> +#include <bitfield.h> #include <fdt_support.h> #include <linux/sizes.h> +#define DDR_BASE 0xC0000000 DECLARE_GLOBAL_DATA_PTR; +static inline u32 map_format_size(u32 val) +{
- u32 tmp;
- switch (tmp) {
- case 0xd:
return 512;
- case 0xe:
return 1024;
- case 0xf:
return 2048;
- case 0x10:
return 4096;
- case 0x11:
return 8192;
- default:
- return ddr_size;
return 0; }
Cheers
Marcel
participants (7)
Dan Carpenter
Huan Zhou
Marcel Ziswiler
Yixun Lan
