[U-Boot] [PATCH 1/5] e1000: New "e1000" commands for SPI EEPROM management
For our new board ports, we are programming the EEPROMs attached to our Intel 82571EB controllers from software (using U-Boot and Linux).
This code provides a helpful set of "e1000" subcommands for performing EEPROM manipulation on e1000 devices, including displaying a hex-dump, copying to and from main memory, and verifying/updating of the software checksum.
The following commands work for programming the EEPROM from USB: usb start fatload usb 0 $loadaddr 82571EB_No_Mgmt_Discrete-LOM.bin e1000 0 eeprom program $loadaddr 0 1024 e1000 0 eeprom checksum update
Please keep in mind that the Intel-provided .eep files are organized as 16-bit words. When converting them to binary form for programming you must byteswap each 16-bit word so that it is in little-endian form.
This means that when reading and writing words to the SPI EEPROM, the bit ordering for each word looks like this on the wire:
Time >>> ------------------------------------------------------------------ ... [7, 6, 5, 4, 3, 2, 1, 0, 15, 14, 13, 12, 11, 10, 9, 8], ... ------------------------------------------------------------------ (MSB is 15, LSB is 0).
Signed-off-by: Kyle Moffett Kyle.D.Moffett@boeing.com --- drivers/net/e1000.c | 533 ++++++++++++++++++++++++++++++++++++++++++++++++++- drivers/net/e1000.h | 2 + 2 files changed, 534 insertions(+), 1 deletions(-)
diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index 43b25b2..4ff845a 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -5152,6 +5152,8 @@ void e1000_get_bus_type(struct e1000_hw *hw) } }
+static LIST_HEAD(e1000_hw_list); + /************************************************************************** PROBE - Look for an adapter, this routine's visible to the outside You should omit the last argument struct pci_device * for a non-PCI NIC @@ -5226,8 +5228,9 @@ e1000_initialize(bd_t * bis) if (e1000_check_phy_reset_block(hw)) printf("%s: ERROR: PHY Reset is blocked!\n", nic->name);
- /* Basic init was OK, reset the hardware */ + /* Basic init was OK, reset the hardware and allow SPI access */ e1000_reset_hw(hw); + list_add_tail(&hw->list_node, &e1000_hw_list);
/* Validate the EEPROM and get chipset information */ #if !(defined(CONFIG_AP1000) || defined(CONFIG_MVBC_1G)) @@ -5255,3 +5258,531 @@ e1000_initialize(bd_t * bis)
return i; } + +#ifdef CONFIG_CMD_E1000 +static struct e1000_hw *e1000_find_card(unsigned int cardnum) +{ + struct e1000_hw *hw; + + list_for_each_entry(hw, &e1000_hw_list, list_node) + if (hw->cardnum == cardnum) + return hw; + + return NULL; +} + +/*----------------------------------------------------------------------- + * SPI transfer + * + * This writes "bitlen" bits out the SPI MOSI port and simultaneously clocks + * "bitlen" bits in the SPI MISO port. That's just the way SPI works. + * + * The source of the outgoing bits is the "dout" parameter and the + * destination of the input bits is the "din" parameter. Note that "dout" + * and "din" can point to the same memory location, in which case the + * input data overwrites the output data (since both are buffered by + * temporary variables, this is OK). + * + * This may be interrupted with Ctrl-C if "intr" is true, otherwise it will + * never return an error. + */ +static int e1000_spi_xfer(struct e1000_hw *hw, unsigned int bitlen, + const void *dout_mem, void *din_mem, boolean_t intr) +{ + const uint8_t *dout = dout_mem; + uint8_t *din = din_mem; + + uint8_t mask = 0; + uint32_t eecd; + unsigned long i; + + /* Pre-read the control register */ + eecd = E1000_READ_REG(hw, EECD); + + /* Iterate over each bit */ + for (i = 0, mask = 0x80; i < bitlen; i++, mask = (mask >> 1)?:0x80) { + /* Check for interrupt */ + if (intr && ctrlc()) + return -1; + + /* Determine the output bit */ + if (dout && dout[i >> 3] & mask) + eecd |= E1000_EECD_DI; + else + eecd &= ~E1000_EECD_DI; + + /* Write the output bit and wait 50us */ + E1000_WRITE_REG(hw, EECD, eecd); + E1000_WRITE_FLUSH(hw); + udelay(50); + + /* Poke the clock (waits 50us) */ + e1000_raise_ee_clk(hw, &eecd); + + /* Now read the input bit */ + eecd = E1000_READ_REG(hw, EECD); + if (din) { + if (eecd & E1000_EECD_DO) + din[i >> 3] |= mask; + else + din[i >> 3] &= ~mask; + } + + /* Poke the clock again (waits 50us) */ + e1000_lower_ee_clk(hw, &eecd); + } + + /* Now clear any remaining bits of the input */ + if (din && (i & 7)) + din[i >> 3] &= ~((mask << 1) - 1); + + return 0; +} + +/* The EEPROM opcodes */ +#define SPI_EEPROM_ENABLE_WR 0x06 +#define SPI_EEPROM_DISABLE_WR 0x04 +#define SPI_EEPROM_WRITE_STATUS 0x01 +#define SPI_EEPROM_READ_STATUS 0x05 +#define SPI_EEPROM_WRITE_PAGE 0x02 +#define SPI_EEPROM_READ_PAGE 0x03 + +/* The EEPROM status bits */ +#define SPI_EEPROM_STATUS_BUSY 0x01 +#define SPI_EEPROM_STATUS_WREN 0x02 + +static int e1000_spi_eeprom_enable_wr(struct e1000_hw *hw, boolean_t intr) +{ + u8 op[] = { SPI_EEPROM_ENABLE_WR }; + e1000_standby_eeprom(hw); + return e1000_spi_xfer(hw, 8*sizeof(op), op, NULL, intr); +} + +#if 0 +static int e1000_spi_eeprom_disable_wr(struct e1000_hw *hw, boolean_t intr) +{ + u8 op[] = { SPI_EEPROM_DISABLE_WR }; + e1000_standby_eeprom(hw); + return e1000_spi_xfer(hw, 8*sizeof(op), op, NULL, intr); +} + +static int e1000_spi_eeprom_write_status(struct e1000_hw *hw, + u8 status, boolean_t intr) +{ + u8 op[] = { SPI_EEPROM_WRITE_STATUS, status }; + e1000_standby_eeprom(hw); + return e1000_spi_xfer(hw, 8*sizeof(op), op, NULL, intr); +} +#endif + +static int e1000_spi_eeprom_read_status(struct e1000_hw *hw, boolean_t intr) +{ + u8 op[] = { SPI_EEPROM_READ_STATUS, 0 }; + e1000_standby_eeprom(hw); + if (e1000_spi_xfer(hw, 8*sizeof(op), op, op, intr)) + return -1; + return op[1]; +} + +static int e1000_spi_eeprom_write_page(struct e1000_hw *hw, + const void *data, u16 off, u16 len, boolean_t intr) +{ + u8 op[] = { + SPI_EEPROM_WRITE_PAGE, + (off >> (hw->eeprom.address_bits - 8)) & 0xff, off & 0xff + }; + + e1000_standby_eeprom(hw); + printf("%s: Write Page @0x%04hx (0x%04hx bytes)\n", + hw->nic->name, off, len); + + if (e1000_spi_xfer(hw, 8 + hw->eeprom.address_bits, op, NULL, intr)) + return -1; + if (e1000_spi_xfer(hw, len << 3, data, NULL, intr)) + return -1; + + printf(" => Done!\n"); + return 0; +} + +static int e1000_spi_eeprom_read_page(struct e1000_hw *hw, + void *data, u16 off, u16 len, boolean_t intr) +{ + u8 op[] = { + SPI_EEPROM_READ_PAGE, + (off >> (hw->eeprom.address_bits - 8)) & 0xff, off & 0xff + }; + + e1000_standby_eeprom(hw); + printf("%s: Read Page @0x%04hx (0x%04hx bytes)\n", + hw->nic->name, off, len); + + if (e1000_spi_xfer(hw, 8 + hw->eeprom.address_bits, op, NULL, intr)) + return -1; + if (e1000_spi_xfer(hw, len << 3, NULL, data, intr)) + return -1; + + printf(" => Done!\n"); + return 0; +} + +static int e1000_spi_eeprom_poll_ready(struct e1000_hw *hw, boolean_t intr) +{ + int status; + while ((status = e1000_spi_eeprom_read_status(hw, intr)) >= 0) { + if (!(status & SPI_EEPROM_STATUS_BUSY)) + return 0; + } + return -1; +} + +int e1000_spi_eeprom_dump(struct e1000_hw *hw, + void *data, u16 off, unsigned int len, boolean_t intr) +{ + /* Interruptibly wait for the EEPROM to be ready */ + if (e1000_spi_eeprom_poll_ready(hw, intr)) + return -1; + + /* Dump each page in sequence */ + while (len) { + /* Calculate the data bytes on this page */ + u16 pg_off = off & (hw->eeprom.page_size - 1); + u16 pg_len = hw->eeprom.page_size - pg_off; + if (pg_len > len) + pg_len = len; + + /* Now dump the page */ + if (e1000_spi_eeprom_read_page(hw, data, off, pg_len, intr)) + return -1; + + /* Otherwise go on to the next page */ + len -= pg_len; + off += pg_len; + data += pg_len; + } + + /* We're done! */ + return 0; +} + +int e1000_spi_eeprom_program(struct e1000_hw *hw, + const void *data, u16 off, u16 len, boolean_t intr) +{ + /* Program each page in sequence */ + while (len) { + /* Calculate the data bytes on this page */ + u16 pg_off = off & (hw->eeprom.page_size - 1); + u16 pg_len = hw->eeprom.page_size - pg_off; + if (pg_len > len) + pg_len = len; + + /* Interruptibly wait for the EEPROM to be ready */ + if (e1000_spi_eeprom_poll_ready(hw, intr)) + return -1; + + /* Enable write access */ + if (e1000_spi_eeprom_enable_wr(hw, intr)) + return -1; + + /* Now program the page */ + if (e1000_spi_eeprom_write_page(hw, data, off, pg_len, intr)) + return -1; + + /* Otherwise go on to the next page */ + len -= pg_len; + off += pg_len; + data += pg_len; + } + + /* Wait for the last write to complete */ + if (e1000_spi_eeprom_poll_ready(hw, intr)) + return -1; + + /* We're done! */ + return 0; +} + +static int do_e1000_eeprom_show(cmd_tbl_t *cmdtp, struct e1000_hw *hw, + int argc, char *argv[]) +{ + unsigned int length = 0; + u16 i, offset = 0; + u8 *buffer; + int err; + + if (argc > 3) { + cmd_usage(cmdtp); + return 1; + } + + /* Parse the offset and length */ + if (argc >= 2) + offset = simple_strtoul(argv[1], NULL, 0); + if (argc == 3) + length = simple_strtoul(argv[2], NULL, 0); + else if (offset < (hw->eeprom.word_size << 1)) + length = (hw->eeprom.word_size << 1) - offset; + + /* Extra sanity checks */ + if (!length) { + printf("%s: ERROR: Requested zero-sized dump!\n", + hw->nic->name); + return 1; + } + if ((0x10000 < length) || (0x10000 - length < offset)) { + printf("%s: ERROR: Can't dump past 0xFFFF!\n", hw->nic->name); + return 1; + } + + /* Allocate a buffer to hold stuff */ + buffer = malloc(length); + if (!buffer) { + printf("%s: ERROR: Out of Memory!\n", hw->nic->name); + return 1; + } + + /* Acquire the EEPROM and perform the dump */ + if (e1000_acquire_eeprom(hw)) { + printf("%s: EEPROM SPI cannot be acquired!", hw->nic->name); + free(buffer); + return 1; + } + err = e1000_spi_eeprom_dump(hw, buffer, offset, length, TRUE); + e1000_release_eeprom(hw); + if (err) { + printf("%s: Interrupted!\n", hw->nic->name); + free(buffer); + return 1; + } + + /* Now hexdump the result */ + printf("%s: ===== Intel e1000 EEPROM (0x%04hX - 0x%04hX) =====", + hw->nic->name, offset, offset + length - 1); + for (i = 0; i < length; i++) { + if ((i & 0xF) == 0) + printf("\n%s: %04hX: ", hw->nic->name, offset + i); + else if ((i & 0xF) == 0x8) + printf(" "); + printf(" %02hx", buffer[i]); + } + printf("\n"); + + /* Success! */ + free(buffer); + return 0; +} + +static int do_e1000_eeprom_dump(cmd_tbl_t *cmdtp, struct e1000_hw *hw, + int argc, char *argv[]) +{ + unsigned int length; + u16 offset; + void *dest; + + if (argc != 4) { + cmd_usage(cmdtp); + return 1; + } + + /* Parse the arguments */ + dest = (void *)simple_strtoul(argv[1], NULL, 16); + offset = simple_strtoul(argv[2], NULL, 0); + length = simple_strtoul(argv[3], NULL, 0); + + /* Extra sanity checks */ + if (!length) { + printf("%s: ERROR: Requested zero-sized dump!\n", + hw->nic->name); + return 1; + } + if ((0x10000 < length) || (0x10000 - length < offset)) { + printf("%s: ERROR: Can't dump past 0xFFFF!\n", hw->nic->name); + return 1; + } + + /* Acquire the EEPROM */ + if (e1000_acquire_eeprom(hw)) { + printf("%s: EEPROM SPI cannot be acquired!", hw->nic->name); + return 1; + } + + /* Perform the programming operation */ + if (e1000_spi_eeprom_dump(hw, dest, offset, length, TRUE) < 0) { + printf("%s: Interrupted!\n", hw->nic->name); + e1000_release_eeprom(hw); + return 1; + } + + e1000_release_eeprom(hw); + printf("%s: ===== EEPROM DUMP COMPLETE =====\n", hw->nic->name); + return 0; +} + +static int do_e1000_eeprom_program(cmd_tbl_t *cmdtp, struct e1000_hw *hw, + int argc, char *argv[]) +{ + unsigned int length; + const void *source; + u16 offset; + + if (argc != 4) { + cmd_usage(cmdtp); + return 1; + } + + /* Parse the arguments */ + source = (const void *)simple_strtoul(argv[1], NULL, 16); + offset = simple_strtoul(argv[2], NULL, 0); + length = simple_strtoul(argv[3], NULL, 0); + + /* Acquire the EEPROM */ + if (e1000_acquire_eeprom(hw)) { + printf("%s: EEPROM SPI cannot be acquired!", hw->nic->name); + return 1; + } + + /* Perform the programming operation */ + if (e1000_spi_eeprom_program(hw, source, offset, length, TRUE) < 0) { + printf("%s: Interrupted!\n", hw->nic->name); + e1000_release_eeprom(hw); + return 1; + } + + e1000_release_eeprom(hw); + printf("%s: ===== EEPROM PROGRAMMED =====\n", hw->nic->name); + return 0; +} + +static int do_e1000_eeprom_checksum(cmd_tbl_t *cmdtp, struct e1000_hw *hw, + int argc, char *argv[]) +{ + uint16_t i, length, checksum, checksum_reg; + uint16_t *buffer; + boolean_t upd; + + if (argc == 1) + upd = 0; + else if ((argc == 2) && !strcmp(argv[1], "update")) + upd = 1; + else { + cmd_usage(cmdtp); + return 1; + } + + /* Allocate a temporary buffer */ + length = sizeof(uint16_t) * (EEPROM_CHECKSUM_REG + 1); + buffer = malloc(length); + if (!buffer) { + printf("%s: ERROR: Unable to allocate EEPROM buffer!\n", + hw->nic->name); + return 1; + } + + /* Acquire the EEPROM */ + if (e1000_acquire_eeprom(hw)) { + printf("%s: EEPROM SPI cannot be acquired!", hw->nic->name); + return 1; + } + + /* Read the EEPROM */ + if (e1000_spi_eeprom_dump(hw, buffer, 0, length, TRUE) < 0) { + printf("%s: Interrupted!\n", hw->nic->name); + e1000_release_eeprom(hw); + return 1; + } + + /* Compute the checksum and read the expected value */ + for (i = 0; i < EEPROM_CHECKSUM_REG; i++) + checksum += le16_to_cpu(buffer[i]); + checksum = ((uint16_t)EEPROM_SUM) - checksum; + checksum_reg = le16_to_cpu(buffer[i]); + + /* Verify it! */ + if (checksum_reg == checksum) { + printf("%s: INFO: EEPROM checksum is correct! (0x%04hx)\n", + hw->nic->name, checksum); + e1000_release_eeprom(hw); + return 0; + } + + /* Hrm, verification failed, print an error */ + printf("%s: ERROR: EEPROM checksum is incorrect!\n", hw->nic->name); + printf("%s: ERROR: ...register was 0x%04hx, calculated 0x%04hx\n", + hw->nic->name, checksum_reg, checksum); + + /* If they didn't ask us to update it, just return an error */ + if (!upd) { + e1000_release_eeprom(hw); + return 1; + } + + /* Ok, correct it! */ + printf("%s: Reprogramming the EEPROM checksum...\n", hw->nic->name); + buffer[i] = cpu_to_le16(checksum); + if (e1000_spi_eeprom_program(hw, &buffer[i], i * sizeof(uint16_t), + sizeof(uint16_t), TRUE)) { + printf("%s: Interrupted!\n", hw->nic->name); + e1000_release_eeprom(hw); + return 1; + } + + e1000_release_eeprom(hw); + return 0; +} + +int do_e1000(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + struct e1000_hw *hw; + + if (argc < 4) { + cmd_usage(cmdtp); + return 1; + } + + /* Make sure we can find the requested e1000 card */ + hw = e1000_find_card(simple_strtoul(argv[1], NULL, 10)); + if (!hw) { + printf("e1000: ERROR: No such device: e1000#%s\n", argv[1]); + return 1; + } + + /* We only support an "eeprom" sub-command right now */ + if (strcmp(argv[2], "eeprom")) { + cmd_usage(cmdtp); + return 1; + } + + /* Make sure it has an SPI chip */ + if (hw->eeprom.type != e1000_eeprom_spi) { + printf("%s: No attached SPI EEPROM found!\n", hw->nic->name); + return 1; + } + + /* Check the eeprom sub-sub-command arguments */ + if (!strcmp(argv[3], "show")) + return do_e1000_eeprom_show(cmdtp, hw, argc - 3, argv + 3); + + if (!strcmp(argv[3], "dump")) + return do_e1000_eeprom_dump(cmdtp, hw, argc - 3, argv + 3); + + if (!strcmp(argv[3], "program")) + return do_e1000_eeprom_program(cmdtp, hw, argc - 3, argv + 3); + + if (!strcmp(argv[3], "checksum")) + return do_e1000_eeprom_checksum(cmdtp, hw, argc - 3, argv + 3); + + cmd_usage(cmdtp); + return 1; +} + +U_BOOT_CMD( + e1000, 7, 0, do_e1000, + "Intel e1000 controller management", + /* */"<card#> eeprom show [<offset> [<length>]]\n" + "e1000 <card#> eeprom dump <addr> <offset> <length>\n" + "e1000 <card#> eeprom program <addr> <offset> <length>\n" + "e1000 <card#> eeprom checksum [update]\n" + " - Manage the e1000 card's SPI EEPROM" +); + +#endif /* CONFIG_CMD_E1000 */ diff --git a/drivers/net/e1000.h b/drivers/net/e1000.h index 8573511..68a3409 100644 --- a/drivers/net/e1000.h +++ b/drivers/net/e1000.h @@ -34,6 +34,7 @@ #define _E1000_HW_H_
#include <common.h> +#include <linux/list.h> #include <malloc.h> #include <net.h> #include <netdev.h> @@ -1043,6 +1044,7 @@ typedef enum {
/* Structure containing variables used by the shared code (e1000_hw.c) */ struct e1000_hw { + struct list_head list_node; struct eth_device *nic; unsigned int cardnum;
To make it possible to use the "sspi" command with the e1000 firmware EEPROM we add a small "generic SPI" driver wrapper around the existing e1000 SPI backend.
Signed-off-by: Kyle Moffett Kyle.D.Moffett@boeing.com --- drivers/net/e1000.c | 92 ++++++++++++++++++++++++++++++++++++++++++++++++++- drivers/net/e1000.h | 7 ++++ 2 files changed, 98 insertions(+), 1 deletions(-)
diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index 4ff845a..70457f1 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -5259,7 +5259,7 @@ e1000_initialize(bd_t * bis) return i; }
-#ifdef CONFIG_CMD_E1000 +#if defined(CONFIG_E1000_SPI) || defined(CONFIG_CMD_E1000) static struct e1000_hw *e1000_find_card(unsigned int cardnum) { struct e1000_hw *hw; @@ -5338,6 +5338,96 @@ static int e1000_spi_xfer(struct e1000_hw *hw, unsigned int bitlen,
return 0; } +#endif /* defined(CONFIG_E1000_SPI) || defined(CONFIG_CMD_E1000) */ + +#ifdef CONFIG_E1000_SPI +static inline struct e1000_hw *e1000_hw_from_spi(struct spi_slave *spi) +{ + return container_of(spi, struct e1000_hw, spi); +} + +/* Not sure why all of these are necessary */ +void spi_init_r(void) { /* Nothing to do */ } +void spi_init_f(void) { /* Nothing to do */ } +void spi_init(void) { /* Nothing to do */ } + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + /* Find the right PCI device */ + struct e1000_hw *hw = e1000_find_card(bus); + if (!hw) { + printf("ERROR: No such e1000 device: e1000#%u\n", bus); + return NULL; + } + + /* Make sure it has an SPI chip */ + if (hw->eeprom.type != e1000_eeprom_spi) { + printf("%s: No attached SPI EEPROM found!\n", hw->nic->name); + return NULL; + } + + /* Argument sanity checks */ + if (cs != 0) { + printf("%s: No such SPI chip: %u\n", hw->nic->name, cs); + return NULL; + } + if (mode != SPI_MODE_0) { + printf("%s: Cannot support SPI modes other than MODE-0\n", + hw->nic->name); + return NULL; + } + + /* TODO: Use max_hz somehow */ + printf("%s: EEPROM SPI access requested\n", hw->nic->name); + return &hw->spi; +} + +void spi_free_slave(struct spi_slave *spi) +{ + struct e1000_hw *hw = e1000_hw_from_spi(spi); + printf("%s: EEPROM SPI access released\n", hw->nic->name); +} + +int spi_claim_bus(struct spi_slave *spi) +{ + struct e1000_hw *hw = e1000_hw_from_spi(spi); + + if (e1000_acquire_eeprom(hw)) { + printf("%s: EEPROM SPI cannot be acquired!", hw->nic->name); + return -1; + } + + return 0; +} + +void spi_release_bus(struct spi_slave *spi) +{ + struct e1000_hw *hw = e1000_hw_from_spi(spi); + e1000_release_eeprom(hw); +} + +/* Skinny wrapper around e1000_spi_xfer */ +int spi_xfer(struct spi_slave *spi, unsigned int bitlen, + const void *dout_mem, void *din_mem, unsigned long flags) +{ + struct e1000_hw *hw = e1000_hw_from_spi(spi); + int ret; + + if (flags & SPI_XFER_BEGIN) + e1000_standby_eeprom(hw); + + ret = e1000_spi_xfer(hw, bitlen, dout_mem, din_mem, TRUE); + + if (flags & SPI_XFER_END) + e1000_standby_eeprom(hw); + + return ret; +} + +#endif /* CONFIG_E1000_SPI */ + +#ifdef CONFIG_CMD_E1000
/* The EEPROM opcodes */ #define SPI_EEPROM_ENABLE_WR 0x06 diff --git a/drivers/net/e1000.h b/drivers/net/e1000.h index 68a3409..f504c90 100644 --- a/drivers/net/e1000.h +++ b/drivers/net/e1000.h @@ -41,6 +41,10 @@ #include <asm/io.h> #include <pci.h>
+#ifdef CONFIG_E1000_SPI +#include <spi.h> +#endif + #define E1000_ERR(args...) printf("e1000: " args)
#ifdef E1000_DEBUG @@ -1046,6 +1050,9 @@ typedef enum { struct e1000_hw { struct list_head list_node; struct eth_device *nic; +#ifdef CONFIG_E1000_SPI + struct spi_slave spi; +#endif unsigned int cardnum;
pci_dev_t pdev;
To ease the implementation of other MPC85xx board ports, several common GPIO helpers are added to <asm/mpc85xx_gpio.h>.
Since each of these compiles to no more than 4-5 instructions it would be very inefficient to call them out of line, therefore we put them entirely in the header file.
Signed-off-by: Kyle Moffett Kyle.D.Moffett@boeing.com --- arch/powerpc/include/asm/mpc85xx_gpio.h | 67 +++++++++++++++++++++++++++++++ 1 files changed, 67 insertions(+), 0 deletions(-) create mode 100644 arch/powerpc/include/asm/mpc85xx_gpio.h
diff --git a/arch/powerpc/include/asm/mpc85xx_gpio.h b/arch/powerpc/include/asm/mpc85xx_gpio.h new file mode 100644 index 0000000..dc6bfb2 --- /dev/null +++ b/arch/powerpc/include/asm/mpc85xx_gpio.h @@ -0,0 +1,67 @@ +/* + * Copyright 2010 eXMeritus, A Boeing Company + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/immap_85xx.h> + +static inline void mpc85xx_gpio_set(unsigned int mask, + unsigned int dir, unsigned int val) +{ + volatile ccsr_gpio_t *gpio; + + /* First mask off the unwanted parts of "dir" and "val" */ + dir &= mask; + val &= mask; + + /* Now read in the values we're supposed to preserve */ + gpio = (void *)(CONFIG_SYS_MPC85xx_GPIO_ADDR + 0xc00); + dir |= (in_be32(&gpio->gpdir) & ~mask); + val |= (in_be32(&gpio->gpdat) & ~mask); + + /* Now write out the new values, writing the direction first */ + out_be32(&gpio->gpdir, dir); + asm("sync; isync":::"memory"); + out_be32(&gpio->gpdat, val); +} + +static inline void mpc85xx_gpio_set_in(unsigned int gpios) +{ + mpc85xx_gpio_set(gpios, 0x00000000, 0x00000000); +} + +static inline void mpc85xx_gpio_set_low(unsigned int gpios) +{ + mpc85xx_gpio_set(gpios, 0xFFFFFFFF, 0x00000000); +} + +static inline void mpc85xx_gpio_set_high(unsigned int gpios) +{ + mpc85xx_gpio_set(gpios, 0xFFFFFFFF, 0xFFFFFFFF); +} + +static inline unsigned int mpc85xx_gpio_get(unsigned int mask) +{ + volatile ccsr_gpio_t *gpio; + unsigned int ret; + + /* Read the requested values */ + gpio = (void *)(CONFIG_SYS_MPC85xx_GPIO_ADDR + 0xc00); + ret = mask & in_be32(&gpio->gpdat); + + return ret; +}
Whoops!
Please ignore this grouping of patches (1-3 of 5), I accidentally specified the wrong commit range and sent 3 emails before I realized.
I've since resent the correct patch queue.
My apologies!
Cheers, Kyle Moffett
Kyle Moffett
Moffett, Kyle D
