[PATCH 1/1] tools: spkgimage: correct printf specifier
Compiling on armv7 results in:
tools/renesas_spkgimage.c: In function ‘spkgimage_parse_config_line’: tools/renesas_spkgimage.c:76:66: warning: format ‘%ld’ expects argument of type ‘long int’, but argument 3 has type ‘size_t’ {aka ‘unsigned int’} [-Wformat=] 76 | "config error: unknown keyword on line %ld\n", | ~~^ | | | long int | %d 77 | line_num); | ~~~~~~~~ | | | size_t {aka unsigned int}
The correct printf specifier for size_t is '%zu'.
Fixes: afdfcb11f97c ("tools: spkgimage: add Renesas SPKG format") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- tools/renesas_spkgimage.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/renesas_spkgimage.c b/tools/renesas_spkgimage.c index fa0a468cc4..605d0ab149 100644 --- a/tools/renesas_spkgimage.c +++ b/tools/renesas_spkgimage.c @@ -73,7 +73,7 @@ static int spkgimage_parse_config_line(char *line, size_t line_num) conf.padding = check_range(name, value, 1, INT_MAX); } else { fprintf(stderr, - "config error: unknown keyword on line %ld\n", + "config error: unknown keyword on line %zu\n", line_num); return -EINVAL; }
return -EINVAL; }"config error: unknown keyword on line %zu\n", line_num);
Reviewed-by: Marek Vasut marek.vasut+renesas@mailbox.org
Tom, can you pick this directly for 2023.07 ? It is low impact and fixes a warning.
