[U-Boot] [PATCH 07/11 v4] UBI: Add basic UBI support to U-Boot (Part 6/8)
This patch adds basic UBI (Unsorted Block Image) support to U-Boot. It's based on the Linux UBI version and basically has a "OS" translation wrapper that defines most Linux specific calls (spin_lock() etc.) into no-ops. Some source code parts have been uncommented by "#ifdef UBI_LINUX". This makes it easier to compare this version with the Linux version and simplifies future UBI ports/bug-fixes from the Linux version.
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Signed-off-by: Stefan Roese sr@denx.de --- include/exports.h | 1 + include/jffs2/load_kernel.h | 5 + include/linux/crc32.h | 27 +++++ include/linux/mtd/partitions.h | 84 +++++++++++++++ include/linux/types.h | 24 +++++ include/ubi_uboot.h | 217 ++++++++++++++++++++++++++++++++++++++++ lib_generic/vsprintf.c | 23 ++++ 7 files changed, 381 insertions(+), 0 deletions(-) create mode 100644 include/linux/crc32.h create mode 100644 include/linux/mtd/partitions.h create mode 100644 include/ubi_uboot.h
diff --git a/include/exports.h b/include/exports.h index 6377875..0620e9e 100644 --- a/include/exports.h +++ b/include/exports.h @@ -25,6 +25,7 @@ char *getenv (char *name); int setenv (char *varname, char *varvalue); long simple_strtol(const char *cp,char **endp,unsigned int base); int strcmp(const char * cs,const char * ct); +int ustrtoul(const char *cp, char **endp, unsigned int base); #ifdef CONFIG_HAS_UID void forceenv (char *varname, char *varvalue); #endif diff --git a/include/jffs2/load_kernel.h b/include/jffs2/load_kernel.h index 551fd0c..e9b7d6e 100644 --- a/include/jffs2/load_kernel.h +++ b/include/jffs2/load_kernel.h @@ -73,4 +73,9 @@ struct mtdids { #define putLabeledWord(x, y) printf("%s %08x\n", x, (unsigned int)y) #define led_blink(x, y, z, a)
+/* common/cmd_jffs2.c */ +extern int mtdparts_init(void); +extern int find_dev_and_part(const char *id, struct mtd_device **dev, + u8 *part_num, struct part_info **part); + #endif /* load_kernel_h */ diff --git a/include/linux/crc32.h b/include/linux/crc32.h new file mode 100644 index 0000000..e133157 --- /dev/null +++ b/include/linux/crc32.h @@ -0,0 +1,27 @@ +/* + * crc32.h + * See linux/lib/crc32.c for license and changes + */ +#ifndef _LINUX_CRC32_H +#define _LINUX_CRC32_H + +#include <linux/types.h> +//#include <linux/bitrev.h> + +extern u32 crc32_le(u32 crc, unsigned char const *p, size_t len); +//extern u32 crc32_be(u32 crc, unsigned char const *p, size_t len); + +#define crc32(seed, data, length) crc32_le(seed, (unsigned char const *)data, length) + +/* + * Helpers for hash table generation of ethernet nics: + * + * Ethernet sends the least significant bit of a byte first, thus crc32_le + * is used. The output of crc32_le is bit reversed [most significant bit + * is in bit nr 0], thus it must be reversed before use. Except for + * nics that bit swap the result internally... + */ +//#define ether_crc(length, data) bitrev32(crc32_le(~0, data, length)) +//#define ether_crc_le(length, data) crc32_le(~0, data, length) + +#endif /* _LINUX_CRC32_H */ diff --git a/include/linux/mtd/partitions.h b/include/linux/mtd/partitions.h new file mode 100644 index 0000000..b41e5f5 --- /dev/null +++ b/include/linux/mtd/partitions.h @@ -0,0 +1,84 @@ +/* + * MTD partitioning layer definitions + * + * (C) 2000 Nicolas Pitre nico@cam.org + * + * This code is GPL + * + * $Id: partitions.h,v 1.17 2005/11/07 11:14:55 gleixner Exp $ + */ + +#ifndef MTD_PARTITIONS_H +#define MTD_PARTITIONS_H + +#include <linux/types.h> + + +/* + * Partition definition structure: + * + * An array of struct partition is passed along with a MTD object to + * add_mtd_partitions() to create them. + * + * For each partition, these fields are available: + * name: string that will be used to label the partition's MTD device. + * size: the partition size; if defined as MTDPART_SIZ_FULL, the partition + * will extend to the end of the master MTD device. + * offset: absolute starting position within the master MTD device; if + * defined as MTDPART_OFS_APPEND, the partition will start where the + * previous one ended; if MTDPART_OFS_NXTBLK, at the next erase block. + * mask_flags: contains flags that have to be masked (removed) from the + * master MTD flag set for the corresponding MTD partition. + * For example, to force a read-only partition, simply adding + * MTD_WRITEABLE to the mask_flags will do the trick. + * + * Note: writeable partitions require their size and offset be + * erasesize aligned (e.g. use MTDPART_OFS_NEXTBLK). + */ + +struct mtd_partition { + char *name; /* identifier string */ + u_int32_t size; /* partition size */ + u_int32_t offset; /* offset within the master MTD space */ + u_int32_t mask_flags; /* master MTD flags to mask out for this partition */ + struct nand_ecclayout *ecclayout; /* out of band layout for this partition (NAND only)*/ + struct mtd_info **mtdp; /* pointer to store the MTD object */ +}; + +#define MTDPART_OFS_NXTBLK (-2) +#define MTDPART_OFS_APPEND (-1) +#define MTDPART_SIZ_FULL (0) + + +int add_mtd_partitions(struct mtd_info *, const struct mtd_partition *, int); +int del_mtd_partitions(struct mtd_info *); + +#if 0 +/* + * Functions dealing with the various ways of partitioning the space + */ + +struct mtd_part_parser { + struct list_head list; + struct module *owner; + const char *name; + int (*parse_fn)(struct mtd_info *, struct mtd_partition **, unsigned long); +}; + +extern int register_mtd_parser(struct mtd_part_parser *parser); +extern int deregister_mtd_parser(struct mtd_part_parser *parser); +extern int parse_mtd_partitions(struct mtd_info *master, const char **types, + struct mtd_partition **pparts, unsigned long origin); + +#define put_partition_parser(p) do { module_put((p)->owner); } while(0) + +struct device; +struct device_node; + +int __devinit of_mtd_parse_partitions(struct device *dev, + struct mtd_info *mtd, + struct device_node *node, + struct mtd_partition **pparts); +#endif + +#endif diff --git a/include/linux/types.h b/include/linux/types.h index df4808f..1b0b4a4 100644 --- a/include/linux/types.h +++ b/include/linux/types.h @@ -119,6 +119,30 @@ typedef __s64 int64_t; * Below are truly Linux-specific types that should never collide with * any application/library that wants linux/types.h. */ +#ifdef __CHECKER__ +#define __bitwise__ __attribute__((bitwise)) +#else +#define __bitwise__ +#endif +#ifdef __CHECK_ENDIAN__ +#define __bitwise __bitwise__ +#else +#define __bitwise +#endif + +typedef __u16 __bitwise __le16; +typedef __u16 __bitwise __be16; +typedef __u32 __bitwise __le32; +typedef __u32 __bitwise __be32; +#if defined(__GNUC__) +typedef __u64 __bitwise __le64; +typedef __u64 __bitwise __be64; +#endif +typedef __u16 __bitwise __sum16; +typedef __u32 __bitwise __wsum; + + +typedef unsigned __bitwise__ gfp_t;
struct ustat { __kernel_daddr_t f_tfree; diff --git a/include/ubi_uboot.h b/include/ubi_uboot.h new file mode 100644 index 0000000..295f2c0 --- /dev/null +++ b/include/ubi_uboot.h @@ -0,0 +1,217 @@ +/* + * Header file for UBI support for U-Boot + * + * Adaptation from kernel to U-Boot + * + * Copyright (C) 2005-2007 Samsung Electronics + * Kyungmin Park kyungmin.park@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#ifndef __UBOOT_UBI_H +#define __UBOOT_UBI_H + +#include <common.h> +#include <malloc.h> +#include <div64.h> +#include <linux/crc32.h> +#include <linux/mtd/mtd.h> + +#ifdef CONFIG_CMD_ONENAND +#include <onenand_uboot.h> +#endif + +#include <asm/errno.h> + +#define DPRINTK(format, args...) \ +do { \ + printf("%s[%d]: " format "\n", __func__, __LINE__, ##args); \ +} while (0) + +/* configurable */ +#define CONFIG_MTD_UBI_WL_THRESHOLD 4096 +#define CONFIG_MTD_UBI_BEB_RESERVE 1 +#define UBI_IO_DEBUG 0 + +/* debug options (Linux: drivers/mtd/ubi/Kconfig.debug) */ +#undef CONFIG_MTD_UBI_DEBUG +#undef CONFIG_MTD_UBI_DEBUG_PARANOID +#undef CONFIG_MTD_UBI_DEBUG_MSG +#undef CONFIG_MTD_UBI_DEBUG_MSG_EBA +#undef CONFIG_MTD_UBI_DEBUG_MSG_WL +#undef CONFIG_MTD_UBI_DEBUG_MSG_IO +#undef CONFIG_MTD_UBI_DEBUG_MSG_BLD +#define CONFIG_MTD_UBI_DEBUG_DISABLE_BGT + +/* compiler options */ +#define uninitialized_var(x) x = x + +/* build.c */ +#define get_device(...) +#define put_device(...) +#define ubi_sysfs_init(...) 0 +#define ubi_sysfs_close(...) do { } while (0) +static inline int is_power_of_2(unsigned long n) +{ + return (n != 0 && ((n & (n - 1)) == 0)); +} + +/* FIXME */ +#define MKDEV(...) 0 +#define MAJOR(dev) 0 +#define MINOR(dev) 0 + +#define alloc_chrdev_region(...) 0 +#define unregister_chrdev_region(...) + +#define class_create(...) __builtin_return_address(0) +#define class_create_file(...) 0 +#define class_remove_file(...) +#define class_destroy(...) +#define misc_register(...) 0 +#define misc_deregister(...) + +/* vmt.c */ +#define device_register(...) 0 +#define volume_sysfs_init(...) 0 +#define volume_sysfs_close(...) do { } while (0) + +/* kapi.c */ + +/* eba.c */ + +/* io.c */ +#define init_waitqueue_head(...) do { } while (0) +#define wait_event_interruptible(...) 0 +#define wake_up_interruptible(...) do { } while (0) +#define print_hex_dump(...) do { } while (0) +#define dump_stack(...) do { } while (0) + +/* wl.c */ +#define task_pid_nr(x) 0 +#define set_freezable(...) do { } while (0) +#define try_to_freeze(...) 0 +#define set_current_state(...) do { } while (0) +#define kthread_should_stop(...) 0 +#define schedule() do { } while (0) + +/* upd.c */ +static inline unsigned long copy_from_user(void *dest, const void *src, + unsigned long count) +{ + memcpy((void *)dest, (void *)src, count); + return 0; +} + +/* common */ +typedef int spinlock_t; +typedef int wait_queue_head_t; +#define spin_lock_init(...) +#define spin_lock(...) +#define spin_unlock(...) + +#define mutex_init(...) +#define mutex_lock(...) +#define mutex_unlock(...) + +#define init_rwsem(...) do { } while (0) +#define down_read(...) do { } while (0) +#define down_write(...) do { } while (0) +#define down_write_trylock(...) 0 +#define up_read(...) do { } while (0) +#define up_write(...) do { } while (0) + +struct kmem_cache { int i; }; +#define kmem_cache_create(...) 1 +#define kmem_cache_alloc(obj, gfp) malloc(sizeof(struct ubi_wl_entry)) +#define kmem_cache_free(obj, size) free(size) +#define kmem_cache_destroy(...) + +#define cond_resched() do { } while (0) +#define yield() do { } while (0) + +#define KERN_WARNING +#define KERN_ERR +#define KERN_NOTICE +#define KERN_DEBUG + +#define GFP_KERNEL 0 +#define GFP_NOFS 1 + +#define __user +#define __init +#define __exit + +#define kthread_create(...) __builtin_return_address(0) +#define kthread_stop(...) do { } while (0) +#define wake_up_process(...) do { } while (0) + +#define BUS_ID_SIZE 20 + +struct rw_semaphore { int i; }; +struct device { + struct device *parent; + struct class *class; + char bus_id[BUS_ID_SIZE]; /* position on parent bus */ + dev_t devt; /* dev_t, creates the sysfs "dev" */ + void (*release)(struct device *dev); +}; +struct mutex { int i; }; +struct kernel_param { int i; }; + +struct cdev { + int owner; + dev_t dev; +}; +#define cdev_init(...) do { } while (0) +#define cdev_add(...) 0 +#define cdev_del(...) do { } while (0) + +#define MAX_ERRNO 4095 +#define IS_ERR_VALUE(x) ((x) >= (unsigned long)-MAX_ERRNO) + +static inline void *ERR_PTR(long error) +{ + return (void *) error; +} + +static inline long PTR_ERR(const void *ptr) +{ + return (long) ptr; +} + +static inline long IS_ERR(const void *ptr) +{ + return IS_ERR_VALUE((unsigned long)ptr); +} + +/* Force a compilation error if condition is true */ +#define BUILD_BUG_ON(condition) ((void)sizeof(char[1 - 2*!!(condition)])) + +/* module */ +#define THIS_MODULE 0 +#define try_module_get(...) 0 +#define module_put(...) do { } while (0) +#define module_init(...) +#define module_exit(...) +#define EXPORT_SYMBOL(...) +#define EXPORT_SYMBOL_GPL(...) +#define module_param_call(...) +#define MODULE_PARM_DESC(...) +#define MODULE_VERSION(...) +#define MODULE_DESCRIPTION(...) +#define MODULE_AUTHOR(...) +#define MODULE_LICENSE(...) + +#include "../drivers/mtd/ubi/ubi.h" + +/* functions */ +extern int ubi_mtd_param_parse(const char *val, struct kernel_param *kp); +extern int ubi_init(void); + +extern struct ubi_device *ubi_devices[]; + +#endif diff --git a/lib_generic/vsprintf.c b/lib_generic/vsprintf.c index 6e903db..767dde1 100644 --- a/lib_generic/vsprintf.c +++ b/lib_generic/vsprintf.c @@ -55,6 +55,29 @@ long simple_strtol(const char *cp,char **endp,unsigned int base) return simple_strtoul(cp,endp,base); }
+int ustrtoul(const char *cp, char **endp, unsigned int base) +{ + unsigned long result = simple_strtoul(cp, endp, base); + switch (**endp) { + case 'G' : + result *= 1024; + /* fall through */ + case 'M': + result *= 1024; + /* fall through */ + case 'K': + case 'k': + result *= 1024; + if ((*endp)[1] == 'i') { + if ((*endp)[2] == 'B') + (*endp) += 3; + else + (*endp) += 2; + } + } + return result; +} + #ifdef CONFIG_SYS_64BIT_STRTOUL unsigned long long simple_strtoull (const char *cp, char **endp, unsigned int base) {
Stefan Roese
