[U-Boot] [PATCH] armv8: fsl-layerscape: Fix SECURE_BOOT config
Without a prompt in Kconfig, SECURE_BOOT cannot be selected by defconfig. The option was dropped unintentionally when defconfig files were cleaned up. Three targets were impacted ls1043ardb_SECURE_BOOT, ls2080ardb_SECURE_BOOT, ls2080aqds_SECURE_BOOT.
Signed-off-by: York Sun york.sun@nxp.com
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 2 +- configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + 4 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index cc0dc88..b78db03 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -93,7 +93,7 @@ config NUM_DDR_CONTROLLERS default 1
config SECURE_BOOT - bool + bool "Secure Boot" help Enable Freescale Secure Boot feature
diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index ae2efeb..3f2e0db 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1043ARDB=y +CONFIG_SECURE_BOOT=y CONFIG_SYS_FSL_DDR4=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_FIT=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 1ed6e05..358457e 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080AQDS=y +CONFIG_SECURE_BOOT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 848abbc..1f13f6c 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y +CONFIG_SECURE_BOOT=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y
It might be worth pointing to your README in the Kconfig help.
- Simon
You meant the README for secure boot, didn't you? I wish there is such file.
York
Signed-off-by: York Sun york.sun@nxp.com Reviewed-by: Simon Glass sjg@chromium.org
Applied to fsl-qoriq master, awaiting upstream.
York
York Sun
york sun
