Dear Michael Schwingen,
do you still intend to maintain IXP support in uboot or can all those IXP boards be removed? I'd be great if you helped bringing them back in-line!
Thanks in advance! Marek Vasut
I still use them and would want to keep these boards (and maintain them).
I only glimpse at the mailing list from time to time - are there any open problems with these boards that need to be addressed?
cu Michael
No, I just cannot compile it with usual arm-linux-gnueabi- toolchain and that puts a bleep on my bug-radar. Is that normal? Do I need a special toolchain?
cu Michael
Best regards, Marek Vasut
Am 03/05/2012 12:54 PM, schrieb Marek Vasut:
I am using an old, locally built toolchain that identifies itself as gcc version 4.3.4 (crosstool-NG-hg_default@1471_4a88cb9bfe8f)
I can take a look at this using a newer toolchain - however, I am in the process of moving, so this will probably take some weeks.
What prebuilt toolchain should I try?
cu Michael
I was more curious if it's possible for me myself to build these. And if so, can that be done with usual arm-linux-gnueabi- toolchain? Or do I need special armeb toolchain compiled in some special way?
cu Michael
I've built a new armeb xscale toolchain available here if you want to try it. https://sourceforge.net/projects/bhundven.u/files/armeb-unknown-linux-gnueab...
I built it on x86_64. I can build it on 32-bit intel if you don't have an x86_64 build box. Let me know.
$ ct-ng show-armeb-unknown-linux-gnueabi armeb-unknown-linux-gnueabi [L X] OS : linux-3.2.8 Companion libs : gmp-5.0.2 mpfr-3.1.0 ppl-0.11.2 cloog-ppl-0.15.11 mpc-0.9 libelf-0.8.13 binutils : binutils-2.22 C compiler : gcc-4.6.3 (C,C++,Fortran,Java,Objective-C,Objective-C++) C library : eglibc-2_15 Tools : dmalloc-5.5.2 duma-2_5_15 gdb-7.3a ltrace-0.5.3 strace-4.6
cu Michael
Best regards, Marek Vasut _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear Bryan Hundven,
I've built a new armeb xscale toolchain available here if you want to try it. https://sourceforge.net/projects/bhundven.u/files/armeb-unknown-linux-gnue abi.tar.bz2/download
Ok, that's good. But can someone please answer my question (now there are two)?
1) Does usual arm-linux-gnueabi- toolchain work? (possibly if I use some switch to toggle arm core endianness) 2) Do I need any special options to build the toolchain?
On Mon, Mar 5, 2012 at 2:09 PM, Marek Vasut marex@denx.de wrote:
Dear Bryan Hundven,
On Mon, Mar 05, 2012 at 02:14:56AM +0100, Marek Vasut wrote: > Dear Michael Schwingen, > > do you still intend to maintain IXP support in uboot or can all > those IXP boards be removed? I'd be great if you helped bringing > them back in-line!
- Does usual arm-linux-gnueabi- toolchain work? (possibly if I use some switch
No, the arm and armeb toolchains are different tuples.
- Do I need any special options to build the toolchain?
You have to build an armeb toolchain with armeb as the platform in the tuple. I don't see one on mentorgraphic's site. I'm not sure if you can build a multilib arm/armeb toolchain.
-Bryan
Dear Bryan Hundven,
Dear Bryan Hundven,
> On Mon, Mar 05, 2012 at 02:14:56AM +0100, Marek Vasut wrote: >> Dear Michael Schwingen, >> >> do you still intend to maintain IXP support in uboot or can all >> those IXP boards be removed? I'd be great if you helped bringing >> them back in-line! > > I still use them and would want to keep these boards (and maintain > them). > > I only glimpse at the mailing list from time to time - are there > any open problems with these boards that need to be addressed?
I've built a new armeb xscale toolchain available here if you want to try it. https://sourceforge.net/projects/bhundven.u/files/armeb-unknown-linux-gn ue abi.tar.bz2/download
And what's the actual difference in the output code? Is it just that the code is compiled for xscale core (as usual) and the instructions are flipped or is there something else?
On Mon, Mar 5, 2012 at 2:22 PM, Marek Vasut marex@denx.de wrote:
Dear Bryan Hundven,
Dear Bryan Hundven,
Am 03/05/2012 12:54 PM, schrieb Marek Vasut: > Dear Michael Schwingen, > >> On Mon, Mar 05, 2012 at 02:14:56AM +0100, Marek Vasut wrote: >>> Dear Michael Schwingen, >>> >>> do you still intend to maintain IXP support in uboot or can all >>> those IXP boards be removed? I'd be great if you helped bringing >>> them back in-line! >> >> I still use them and would want to keep these boards (and maintain >> them). >> >> I only glimpse at the mailing list from time to time - are there >> any open problems with these boards that need to be addressed? > > No, I just cannot compile it with usual arm-linux-gnueabi- > toolchain and that puts a bleep on my bug-radar. Is that normal? > Do I need a special toolchain?
Yes, the toolchain output's xscale optimized binaries and is configured for big-endian. For autoconf based projects, it actually checks the platform part of the tuple to figure out if it is little (arm) or big endian (armeb).
I'd prefer just using the -EL or -EB flags on arm-unknown-linux-gnueabi, but as I said before, I'm not sure if you can build a multilib arm/armeb toolchain.
Dear Bryan Hundven,
Dear Bryan Hundven,
Dear Bryan Hundven,
> Am 03/05/2012 12:54 PM, schrieb Marek Vasut: > > Dear Michael Schwingen, > > > >> On Mon, Mar 05, 2012 at 02:14:56AM +0100, Marek Vasut wrote: > >>> Dear Michael Schwingen, > >>> > >>> do you still intend to maintain IXP support in uboot or can > >>> all those IXP boards be removed? I'd be great if you helped > >>> bringing them back in-line! > >> > >> I still use them and would want to keep these boards (and > >> maintain them). > >> > >> I only glimpse at the mailing list from time to time - are > >> there any open problems with these boards that need to be > >> addressed? > > > > No, I just cannot compile it with usual arm-linux-gnueabi- > > toolchain and that puts a bleep on my bug-radar. Is that normal? > > Do I need a special toolchain? > > I am using an old, locally built toolchain that identifies itself > as gcc version 4.3.4 (crosstool-NG-hg_default@1471_4a88cb9bfe8f) > > I can take a look at this using a newer toolchain - however, I am > in the process of moving, so this will probably take some weeks. > > What prebuilt toolchain should I try?
I've built a new armeb xscale toolchain available here if you want to try it. https://sourceforge.net/projects/bhundven.u/files/armeb-unknown-linux -gn ue abi.tar.bz2/download
Check this (oneliner patch below) ... Michael/Bryan, can you actually try fixing the remaining issues and try with normal ARM toolchain + this patch, if these uboot images are bootable:
marex@mashiro:~/U-Boot/u-boot-marex$ CROSS_COMPILE=arm-linux-gnueabi- ARCH=arm ./MAKEALL actux4 Configuring for actux4 board... IxEthAcc.c: In function ‘ixEthAccInit’: IxEthAcc.c:105:21: warning: comparison between ‘IxEthDBStatus’ and ‘enum <anonymous>’ [-Wenum-compare] IxEthDBAPISupport.c: In function ‘ixEthDBPortAddressSet’: IxEthDBAPISupport.c:633:18: warning: variable ‘ackPortAddressLock’ set but not used [-Wunused-but-set-variable] IxQMgrDispatcher.c: In function ‘ixQMgrLLPShow’: IxQMgrDispatcher.c:1194:18: warning: variable ‘q’ set but not used [-Wunused- but-set-variable] actux4.c: In function ‘board_init’: actux4.c:57:27: error: ‘MACH_TYPE_ACTUX4’ undeclared (first use in this function) actux4.c:57:27: note: each undeclared identifier is reported only once for each function it appears in actux4.c:93:2: warning: left shift count >= width of type [enabled by default] actux4.c:93:2: warning: left shift count >= width of type [enabled by default] make[1]: *** [actux4.o] Error 1 make: *** [board/actux4/libactux4.o] Error 2 arm-linux-gnueabi-size: './u-boot': No such file
--------------------- SUMMARY ---------------------------- Boards compiled: 1 Boards with warnings or errors: 1 ( actux4 ) ---------------------------------------------------------- marex@mashiro:~/U-Boot/u-boot-marex$ git diff diff --git a/arch/arm/cpu/ixp/config.mk b/arch/arm/cpu/ixp/config.mk index 9149665..c8b8440 100644 --- a/arch/arm/cpu/ixp/config.mk +++ b/arch/arm/cpu/ixp/config.mk @@ -28,6 +28,8 @@ PLATFORM_RELFLAGS += -fno-common -ffixed-r8 -msoft-float - mbig-endian
PLATFORM_CPPFLAGS += -mbig-endian -march=armv5te -mtune=strongarm1100
+PLATFORM_LDFLAGS += -EB + # -fdata-sections triggers "section .bss overlaps section .rel.dyn" linker error PLATFORM_RELFLAGS += -ffunction-sections LDFLAGS_u-boot += --gc-sections
Am 03/05/2012 11:14 PM, schrieb Bryan Hundven:
to toggle arm core endianness) No, the arm and armeb toolchains are different tuples.
I think I did this (quite some time ago, for a different project), although IIRC, it required some tweaking of the multilib options when building gcc.
cu Michael
Bryan Hundven
Michael Schwingen
Michael Schwingen
