[U-Boot] Pull request: u-boot-arm/master
Hi Tom,
The following changes since commit be9f643ae6aa9044c60fe80e3a2c10be8371c692:
Merge branch 'for-tom' of git://git.denx.de/u-boot-dm (2014-09-26 20:10:48 -0400)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to c19a8bc5711ec63e905ef91f045a1489f0aa3cb0:
vf610twr: Tune DDR initialization settings (2014-10-07 13:08:31 +0200)
---------------------------------------------------------------- Albert ARIBAUD (1): Merge branch 'u-boot-marvell/master' into 'u-boot-arm/master'
Anthony Felice (1): vf610twr: Tune DDR initialization settings
DrEagle (5): ARM: sheevaplug: change env location ARM: sheevaplug: add MVSATA driver ARM: sheevaplug: add MTD defaults ARM: sheevaplug: redefine MTDPARTS ARM: sheevaplug: add HUSH parser
Masahiro Yamada (7): mtd: denali: add Denali controller configs to Kconfig mtd: denali: add Denali NAND driver for SPL serial: add UniPhier serial driver ARM: UniPhier: add UniPhier SoC support code ARM: UniPhier: add Kconfig and defconfig MAINTAINERS: add me as a maintainer of UniPhier platform git-mailrc: add me as a maintainer of UniPhier platform
Michael Walle (1): lsxl: convert to generic board and fix typo
MAINTAINERS | 9 + arch/arm/Kconfig | 5 + arch/arm/cpu/armv7/uniphier/Kconfig | 32 + arch/arm/cpu/armv7/uniphier/Makefile | 23 + arch/arm/cpu/armv7/uniphier/board_common.c | 32 + arch/arm/cpu/armv7/uniphier/board_late_init.c | 91 ++ arch/arm/cpu/armv7/uniphier/cache_uniphier.c | 154 +++ arch/arm/cpu/armv7/uniphier/cmd_pinmon.c | 33 + arch/arm/cpu/armv7/uniphier/cpu_info.c | 59 ++ arch/arm/cpu/armv7/uniphier/dram_init.c | 37 + arch/arm/cpu/armv7/uniphier/init_page_table.c | 1068 ++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/lowlevel_init.S | 159 +++ arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c | 33 + arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c | 16 + .../armv7/uniphier/ph1-ld4/board_postclk_init.c | 42 + arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c | 63 ++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c | 189 ++++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c | 44 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c | 162 +++ arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c | 16 + .../armv7/uniphier/ph1-pro4/board_postclk_init.c | 39 + arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c | 66 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c | 45 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c | 168 +++ .../arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c | 18 + arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c | 75 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c | 136 +++ arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c | 16 + .../armv7/uniphier/ph1-sld8/board_postclk_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c | 57 ++ arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c | 201 ++++ .../arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c | 51 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c | 142 +++ arch/arm/cpu/armv7/uniphier/reset.c | 29 + arch/arm/cpu/armv7/uniphier/smp.S | 54 + arch/arm/cpu/armv7/uniphier/spl.c | 17 + arch/arm/cpu/armv7/uniphier/support_card.c | 180 ++++ arch/arm/cpu/armv7/uniphier/timer.c | 39 + arch/arm/include/asm/arch-uniphier/arm-mpcore.h | 46 + arch/arm/include/asm/arch-uniphier/bcu-regs.h | 30 + arch/arm/include/asm/arch-uniphier/board.h | 35 + arch/arm/include/asm/arch-uniphier/boot-device.h | 20 + arch/arm/include/asm/arch-uniphier/led.h | 101 ++ arch/arm/include/asm/arch-uniphier/sbc-regs.h | 108 ++ arch/arm/include/asm/arch-uniphier/sc-regs.h | 62 ++ arch/arm/include/asm/arch-uniphier/sg-regs.h | 182 ++++ arch/arm/include/asm/arch-uniphier/ssc-regs.h | 67 ++ arch/arm/include/asm/arch-uniphier/umc-regs.h | 119 +++ arch/arm/include/asm/arch-vf610/imx-regs.h | 49 +- arch/arm/include/asm/arch-vf610/iomux-vf610.h | 44 +- arch/arm/include/asm/imx-common/iomux-v3.h | 2 + board/freescale/vf610twr/vf610twr.c | 94 +- configs/ph1_ld4_defconfig | 8 + configs/ph1_pro4_defconfig | 8 + configs/ph1_sld8_defconfig | 8 + doc/README.nand | 6 - doc/git-mailrc | 1 + drivers/mtd/Kconfig | 1 + drivers/mtd/nand/Kconfig | 42 + drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/denali_spl.c | 231 +++++ drivers/serial/Makefile | 1 + drivers/serial/serial.c | 2 + drivers/serial/serial_uniphier.c | 204 ++++ include/configs/lsxl.h | 4 +- include/configs/ph1_ld4.h | 59 ++ include/configs/ph1_pro4.h | 61 ++ include/configs/ph1_sld8.h | 61 ++ include/configs/sheevaplug.h | 46 +- include/configs/uniphier-common.h | 266 +++++ 84 files changed, 5675 insertions(+), 74 deletions(-) create mode 100644 arch/arm/cpu/armv7/uniphier/Kconfig create mode 100644 arch/arm/cpu/armv7/uniphier/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/board_common.c create mode 100644 arch/arm/cpu/armv7/uniphier/board_late_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/cache_uniphier.c create mode 100644 arch/arm/cpu/armv7/uniphier/cmd_pinmon.c create mode 100644 arch/arm/cpu/armv7/uniphier/cpu_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/dram_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/init_page_table.c create mode 100644 arch/arm/cpu/armv7/uniphier/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/reset.c create mode 100644 arch/arm/cpu/armv7/uniphier/smp.S create mode 100644 arch/arm/cpu/armv7/uniphier/spl.c create mode 100644 arch/arm/cpu/armv7/uniphier/support_card.c create mode 100644 arch/arm/cpu/armv7/uniphier/timer.c create mode 100644 arch/arm/include/asm/arch-uniphier/arm-mpcore.h create mode 100644 arch/arm/include/asm/arch-uniphier/bcu-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/board.h create mode 100644 arch/arm/include/asm/arch-uniphier/boot-device.h create mode 100644 arch/arm/include/asm/arch-uniphier/led.h create mode 100644 arch/arm/include/asm/arch-uniphier/sbc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sg-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/ssc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/umc-regs.h create mode 100644 configs/ph1_ld4_defconfig create mode 100644 configs/ph1_pro4_defconfig create mode 100644 configs/ph1_sld8_defconfig create mode 100644 drivers/mtd/nand/Kconfig create mode 100644 drivers/mtd/nand/denali_spl.c create mode 100644 drivers/serial/serial_uniphier.c create mode 100644 include/configs/ph1_ld4.h create mode 100644 include/configs/ph1_pro4.h create mode 100644 include/configs/ph1_sld8.h create mode 100644 include/configs/uniphier-common.h
Amicalement,
On Tue, Oct 07, 2014 at 01:16:00PM +0200, Albert ARIBAUD wrote:
Hi Tom,
- .../armv7/uniphier/ph1-ld4/board_postclk_init.c | 42 +
- .../armv7/uniphier/ph1-pro4/board_postclk_init.c | 39 +
- .../armv7/uniphier/ph1-sld8/board_postclk_init.c | 1 +
Albert ARIBAUD
