[U-Boot] [PATCH v5 0/2] Add Arndale board support
The Arndale board is based on samsung's exynos5250 SOC. For spl generation, it depends on the patch at [5].
First patch provides the basic arndale board support. The second patch adds the MMC support.
Changes in v2: - split from earlier patchset at [3] as per Minkyu - Removed checkpatch errors pointed out by Wolfgang - rebased to latest u-boot-samsung master branch - created mmc_boot.c to remove dependency on consolidation patch at [4] - split the mmc support to new patch as it depends on [2]
[1] http://permalink.gmane.org/gmane.comp.boot-loaders.u-boot/162883 [2] http://comments.gmane.org/gmane.comp.boot-loaders.u-boot/159887 [3] http://comments.gmane.org/gmane.comp.boot-loaders.u-boot/157101 [4] http://comments.gmane.org/gmane.comp.boot-loaders.u-boot/156272
Changes in v3: - Used dt based serial - rebased to latest u-boot-samsung master branch
Changes in v4: - Removed the config depedency on exynos5_dt.h as it contains smdk5250 configurations rather than the common exynos5 generic configurations. - rebased to latest u-boot-samsung master branch
Changes in v5: - Fix comments suggested by Minkyu - Added SPDX-License-Identifier to new files
[5] [PATCH v2] CONFIG: EXYNOS5: Replace misnomer SMDK5250 with EXYNOS5250 and update Makefiles
Chander Kashyap (1): exynos5250: Add arndale board support
Inderpal Singh (1): exynos5250: arndale: Add mmc support
MAINTAINERS | 4 + board/samsung/arndale/Makefile | 34 ++++ board/samsung/arndale/arndale.c | 101 ++++++++++++ board/samsung/arndale/arndale_spl.c | 50 ++++++ board/samsung/dts/exynos5250-arndale.dts | 39 +++++ boards.cfg | 1 + include/configs/arndale.h | 255 ++++++++++++++++++++++++++++++ 7 files changed, 484 insertions(+) create mode 100644 board/samsung/arndale/Makefile create mode 100644 board/samsung/arndale/arndale.c create mode 100644 board/samsung/arndale/arndale_spl.c create mode 100644 board/samsung/dts/exynos5250-arndale.dts create mode 100644 include/configs/arndale.h
Arndale board is based on samsung's exynos5250 soc.
Signed-off-by: Inderpal Singh inderpal.singh@linaro.org Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- MAINTAINERS | 4 + board/samsung/arndale/Makefile | 34 ++++ board/samsung/arndale/arndale.c | 87 ++++++++++ board/samsung/arndale/arndale_spl.c | 50 ++++++ board/samsung/dts/exynos5250-arndale.dts | 21 +++ boards.cfg | 1 + include/configs/arndale.h | 255 ++++++++++++++++++++++++++++++ 7 files changed, 452 insertions(+) create mode 100644 board/samsung/arndale/Makefile create mode 100644 board/samsung/arndale/arndale.c create mode 100644 board/samsung/arndale/arndale_spl.c create mode 100644 board/samsung/dts/exynos5250-arndale.dts create mode 100644 include/configs/arndale.h
diff --git a/MAINTAINERS b/MAINTAINERS index 081cf96..56d4741 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -209,6 +209,10 @@ Matthias Fuchs matthias.fuchs@esd-electronics.com WUH405 PPC405EP CMS700 PPC405EP
+Inderpal Singh inderpal.singh@linaro.org + + Arndale ARM ARMV7 (EXYNOS5250 SoC) + Siddarth Gore gores@marvell.com
guruplug ARM926EJS (Kirkwood SoC) diff --git a/board/samsung/arndale/Makefile b/board/samsung/arndale/Makefile new file mode 100644 index 0000000..afd8db3 --- /dev/null +++ b/board/samsung/arndale/Makefile @@ -0,0 +1,34 @@ +# +# Copyright (C) 2013 Samsung Electronics +# +# SPDX-License-Identifier: GPL-2.0+ +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS += arndale_spl.o + +ifndef CONFIG_SPL_BUILD +COBJS += arndale.o +endif + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +ALL := $(obj).depend $(LIB) + +all: $(ALL) + +$(LIB): $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c new file mode 100644 index 0000000..5ec56f6 --- /dev/null +++ b/board/samsung/arndale/arndale.c @@ -0,0 +1,87 @@ +/* + * Copyright (C) 2013 Samsung Electronics + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/power.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); + return 0; +} + +int dram_init(void) +{ + int i; + u32 addr; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); + gd->ram_size += get_ram_size((long *)addr, SDRAM_BANK_SIZE); + } + return 0; +} + +int power_init_board(void) +{ + set_ps_hold_ctrl(); + return 0; +} + +void dram_init_banksize(void) +{ + int i; + u32 addr, size; + + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { + addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); + size = get_ram_size((long *)addr, SDRAM_BANK_SIZE); + + gd->bd->bi_dram[i].start = addr; + gd->bd->bi_dram[i].size = size; + } +} + +static int board_uart_init(void) +{ + int err = 0, uart_id; + + for (uart_id = PERIPH_ID_UART0; uart_id <= PERIPH_ID_UART3; uart_id++) { + err = exynos_pinmux_config(uart_id, PINMUX_FLAG_NONE); + if (err) { + debug("UART%d not configured\n", + (uart_id - PERIPH_ID_UART0)); + return ret; + } + } + return ret; +} + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ + int err; + + err = board_uart_init(); + if (err) { + debug("UART init failed\n"); + return err; + } + return err; +} +#endif + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + printf("\nBoard: Arndale\n"); + + return 0; +} +#endif diff --git a/board/samsung/arndale/arndale_spl.c b/board/samsung/arndale/arndale_spl.c new file mode 100644 index 0000000..2949c08 --- /dev/null +++ b/board/samsung/arndale/arndale_spl.c @@ -0,0 +1,50 @@ +/* + * Copyright (c) 2012 The Chromium OS Authors. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/spl.h> + +#define SIGNATURE 0xdeadbeef + +/* Parameters of early board initialization in SPL */ +static struct spl_machine_param machine_param + __attribute__((section(".machine_param"))) = { + .signature = SIGNATURE, + .version = 1, + .params = "vmubfasirM", + .size = sizeof(machine_param), + + .mem_iv_size = 0x1f, + .mem_type = DDR_MODE_DDR3, + + /* + * Set uboot_size to 0x100000 bytes. + * + * This is an overly conservative value chosen to accommodate all + * possible U-Boot image. You are advised to set this value to a + * smaller realistic size via scripts that modifies the .machine_param + * section of output U-Boot image. + */ + .uboot_size = 0x100000, + + .boot_source = BOOT_MODE_OM, + .frequency_mhz = 800, + .arm_freq_mhz = 1000, + .serial_base = 0x12c30000, + .i2c_base = 0x12c60000, + .mem_manuf = MEM_MANUF_SAMSUNG, +}; + +struct spl_machine_param *spl_get_machine_params(void) +{ + if (machine_param.signature != SIGNATURE) { + /* Will hang if SIGNATURE dont match */ + while (1) + ; + } + + return &machine_param; +} diff --git a/board/samsung/dts/exynos5250-arndale.dts b/board/samsung/dts/exynos5250-arndale.dts new file mode 100644 index 0000000..d3c0527 --- /dev/null +++ b/board/samsung/dts/exynos5250-arndale.dts @@ -0,0 +1,21 @@ +/* + * SAMSUNG Arndale board device tree source + * + * Copyright (c) 2013 Samsung Electronics Co., Ltd. + * http://www.samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ +*/ + +/dts-v1/; +/include/ ARCH_CPU_DTS + +/ { + model = "SAMSUNG Arndale board based on EXYNOS5250"; + compatible = "samsung,arndale", "samsung,exynos5250"; + + aliases { + serial0 = "/serial@12C20000"; + console = "/serial@12C20000"; + }; +}; diff --git a/boards.cfg b/boards.cfg index 6a368de..dcf89c1 100644 --- a/boards.cfg +++ b/boards.cfg @@ -317,6 +317,7 @@ omap5_uevm arm armv7 omap5_uevm ti oma dra7xx_evm arm armv7 dra7xx ti omap5 s5p_goni arm armv7 goni samsung s5pc1xx smdkc100 arm armv7 smdkc100 samsung s5pc1xx +arndale arm armv7 arndale samsung exynos origen arm armv7 origen samsung exynos s5pc210_universal arm armv7 universal_c210 samsung exynos snow arm armv7 smdk5250 samsung exynos diff --git a/include/configs/arndale.h b/include/configs/arndale.h new file mode 100644 index 0000000..ed44a04 --- /dev/null +++ b/include/configs/arndale.h @@ -0,0 +1,255 @@ +/* + * Copyright (C) 2013 Samsung Electronics + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Configuration settings for the SAMSUNG Arndale board. + */ + +#ifndef __CONFIG_ARNDALE_H +#define __CONFIG_ARNDALE_H + +/* High Level Configuration Options */ +#define CONFIG_SAMSUNG /* in a SAMSUNG core */ +#define CONFIG_S5P /* S5P Family */ +#define CONFIG_EXYNOS5 /* which is in a Exynos5 Family */ +#define CONFIG_EXYNOS5250 + +#include <asm/arch/cpu.h> /* get chip and board defs */ + +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Enable fdt support for Exynos5250 */ +#define CONFIG_ARCH_DEVICE_TREE exynos5250 +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + +/* Allow tracing to be enabled */ +#define CONFIG_TRACE +#define CONFIG_CMD_TRACE +#define CONFIG_TRACE_BUFFER_SIZE (16 << 20) +#define CONFIG_TRACE_EARLY_SIZE (8 << 20) +#define CONFIG_TRACE_EARLY +#define CONFIG_TRACE_EARLY_ADDR 0x50000000 + +/* Keep L2 Cache Disabled */ +#define CONFIG_SYS_DCACHE_OFF + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define CONFIG_SYS_TEXT_BASE 0x43E00000 + +/* input clock of PLL: SMDK5250 has 24MHz input clock */ +#define CONFIG_SYS_CLK_FREQ 24000000 + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING + +/* Power Down Modes */ +#define S5P_CHECK_SLEEP 0x00000BAD +#define S5P_CHECK_DIDLE 0xBAD00000 +#define S5P_CHECK_LPA 0xABAD0000 + +/* Offset for inform registers */ +#define INFORM0_OFFSET 0x800 +#define INFORM1_OFFSET 0x804 + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (4 << 20)) + +/* select serial console configuration */ +#define CONFIG_BAUDRATE 115200 +#define EXYNOS5_DEFAULT_UART_OFFSET 0x010000 +#define CONFIG_SILENT_CONSOLE + +/* Console configuration */ +#define CONFIG_CONSOLE_MUX +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define EXYNOS_DEVICE_SETTINGS \ + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + EXYNOS_DEVICE_SETTINGS + +/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_SDHCI +#define CONFIG_S5P_SDHCI +#define CONFIG_DWMMC +#define CONFIG_EXYNOS_DWMMC +#define CONFIG_SUPPORT_EMMC_BOOT + + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* PWM */ +#define CONFIG_PWM + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command definition*/ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_ELF +#define CONFIG_CMD_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_NET +#define CONFIG_CMD_HASH + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +/* USB */ +#define CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_EXYNOS +#define CONFIG_USB_STORAGE + +/* MMC SPL */ +#define CONFIG_SPL +#define COPY_BL2_FNPTR_ADDR 0x02020030 + +#define CONFIG_SPL_LIBCOMMON_SUPPORT + +/* specific .lds file */ +#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" +#define CONFIG_SPL_TEXT_BASE 0x02023400 +#define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024) + +#define CONFIG_BOOTCOMMAND "mmc read 40007000 451 2000; bootm 40007000" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT "ARNDALE # " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x5E00000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) + +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_RD_LVL + +#define CONFIG_NR_DRAM_BANKS 8 +#define SDRAM_BANK_SIZE (256UL << 20UL) /* 256 MB */ +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) +#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + (2 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + (3 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_5 (CONFIG_SYS_SDRAM_BASE + (4 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_5_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_6 (CONFIG_SYS_SDRAM_BASE + (5 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_6_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_7 (CONFIG_SYS_SDRAM_BASE + (6 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_7_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_8 (CONFIG_SYS_SDRAM_BASE + (7 * SDRAM_BANK_SIZE)) +#define PHYS_SDRAM_8_SIZE SDRAM_BANK_SIZE + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH +#undef CONFIG_CMD_IMLS +#define CONFIG_IDENT_STRING " for ARNDALE" + +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SECURE_BL1_ONLY + +/* Secure FW size configuration */ +#ifdef CONFIG_SECURE_BL1_ONLY +#define CONFIG_SEC_FW_SIZE (8 << 10) /* 8KB */ +#else +#define CONFIG_SEC_FW_SIZE 0 +#endif + +/* Configuration of BL1, BL2, ENV Blocks on mmc */ +#define CONFIG_RES_BLOCK_SIZE (512) +#define CONFIG_BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ +#define CONFIG_BL2_SIZE (512UL << 10UL) /* 512 KB */ +#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ + +#define CONFIG_BL1_OFFSET (CONFIG_RES_BLOCK_SIZE + CONFIG_SEC_FW_SIZE) +#define CONFIG_BL2_OFFSET (CONFIG_BL1_OFFSET + CONFIG_BL1_SIZE) +#define CONFIG_ENV_OFFSET (CONFIG_BL2_OFFSET + CONFIG_BL2_SIZE) + +/* U-boot copy size from boot Media to DRAM.*/ +#define BL2_START_OFFSET (CONFIG_BL2_OFFSET/512) +#define BL2_SIZE_BLOC_COUNT (CONFIG_BL2_SIZE/512) + +#define CONFIG_SPI_BOOTING +#define EXYNOS_COPY_SPI_FNPTR_ADDR 0x02020058 +#define SPI_FLASH_UBOOT_POS (CONFIG_SEC_FW_SIZE + CONFIG_BL1_SIZE) + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_PART +#define CONFIG_PARTITION_UUIDS + + +#define CONFIG_IRAM_STACK 0x02050000 + +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_IRAM_STACK + +/* I2C */ +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_HARD_I2C +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C_SPEED 100000 /* 100 Kbps */ +#define CONFIG_DRIVER_S3C24X0_I2C +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_MAX_I2C_NUM 8 +#define CONFIG_SYS_I2C_SLAVE 0x0 +#define CONFIG_I2C_EDID + +/* PMIC */ +#define CONFIG_PMIC +#define CONFIG_PMIC_I2C +#define CONFIG_PMIC_MAX77686 + +#define CONFIG_DEFAULT_DEVICE_TREE exynos5250-arndale + +/* Ethernet Controllor Driver */ +#ifdef CONFIG_CMD_NET +#define CONFIG_SMC911X +#define CONFIG_SMC911X_BASE 0x5000000 +#define CONFIG_SMC911X_16_BIT +#define CONFIG_ENV_SROM_BANK 1 +#endif /*CONFIG_CMD_NET*/ + +/* Enable PXE Support */ +#ifdef CONFIG_CMD_NET +#define CONFIG_CMD_PXE +#define CONFIG_MENU +#endif + +/* Enable devicetree support */ +#define CONFIG_OF_LIBFDT + +/* Enable Time Command */ +#define CONFIG_CMD_TIME + +#endif /* __CONFIG_H */
This patch adds mmc support to the arndale board.
Signed-off-by: Inderpal Singh inderpal.singh@linaro.org --- board/samsung/arndale/arndale.c | 14 ++++++++++++++ board/samsung/dts/exynos5250-arndale.dts | 18 ++++++++++++++++++ 2 files changed, 32 insertions(+)
diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c index 5ec56f6..6d81b90 100644 --- a/board/samsung/arndale/arndale.c +++ b/board/samsung/arndale/arndale.c @@ -6,6 +6,7 @@
#include <common.h> #include <asm/arch/pinmux.h> +#include <asm/arch/dwmmc.h> #include <asm/arch/power.h>
DECLARE_GLOBAL_DATA_PTR; @@ -48,6 +49,19 @@ void dram_init_banksize(void) } }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + int ret; + /* dwmmc initializattion for available channels */ + ret = exynos_dwmmc_init(gd->fdt_blob); + if (ret) + debug("dwmmc init failed\n"); + + return ret; +} +#endif + static int board_uart_init(void) { int err = 0, uart_id; diff --git a/board/samsung/dts/exynos5250-arndale.dts b/board/samsung/dts/exynos5250-arndale.dts index d3c0527..c700e45 100644 --- a/board/samsung/dts/exynos5250-arndale.dts +++ b/board/samsung/dts/exynos5250-arndale.dts @@ -18,4 +18,22 @@ serial0 = "/serial@12C20000"; console = "/serial@12C20000"; }; + + mmc@12200000 { + samsung,bus-width = <8>; + samsung,timing = <1 3 3>; + }; + + mmc@12210000 { + status = "disabled"; + }; + + mmc@12220000 { + samsung,bus-width = <4>; + samsung,timing = <1 2 3>; + }; + + mmc@12230000 { + status = "disabled"; + }; };
Chander Kashyap
