[U-Boot] [PATCH 1/4] arm: rmobile: Add register infomation for i2c of R8A7791
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/include/asm/arch-rmobile/r8a7791.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/include/asm/arch-rmobile/r8a7791.h b/arch/arm/include/asm/arch-rmobile/r8a7791.h index 2afda0a..3a3277a 100644 --- a/arch/arm/include/asm/arch-rmobile/r8a7791.h +++ b/arch/arm/include/asm/arch-rmobile/r8a7791.h @@ -407,6 +407,12 @@ #define CCI_AXI_IPMMUDSDVMCR 0xFF880414 #define CCI_AXI_AX2ADDRMASK 0xFF88041C
+/* I2C */ +#define CONFIG_SYS_I2C_SH_BASE0 0xE6500000 +#define CONFIG_SYS_I2C_SH_BASE1 0xE6510000 +#define CONFIG_SYS_I2C_SH_BASE2 0xE60B0000 +#define CONFIG_SYS_I2C_SH_NUM_CONTROLLERS 3 + #ifndef __ASSEMBLY__ #include <asm/types.h>
The koelsch board has one sh-ether device. This supports sh-ether.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- board/renesas/koelsch/koelsch.c | 77 +++++++++++++++++++++++++++++++++++++++++ include/configs/koelsch.h | 23 ++++++++++-- 2 files changed, 98 insertions(+), 2 deletions(-)
diff --git a/board/renesas/koelsch/koelsch.c b/board/renesas/koelsch/koelsch.c index 7153f65..1975672 100644 --- a/board/renesas/koelsch/koelsch.c +++ b/board/renesas/koelsch/koelsch.c @@ -16,6 +16,8 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/arch/rmobile.h> +#include <netdev.h> +#include <miiphy.h> #include <i2c.h> #include "qos.h"
@@ -207,6 +209,10 @@ void s_init(void) #define SMSTPCR7 0xE615014C #define SCIF0_MSTP721 (1 << 21)
+#define MSTPSR8 0xE61509A0 +#define SMSTPCR8 0xE6150990 +#define ETHER_MSTP813 (1 << 13) + #define PMMR 0xE6060000 #define GPSR4 0xE6060014 #define IPSR14 0xE6060058 @@ -241,9 +247,16 @@ int board_early_init_f(void)
mstp_clrbits_le32(MSTPSR7, SMSTPCR7, SCIF0_MSTP721);
+ /* Ether */ + mstp_clrbits_le32(MSTPSR8, SMSTPCR8, ETHER_MSTP813); + return 0; }
+/* LSI pin pull-up control */ +#define PUPR5 0xe6060114 +#define PUPR5_ETH 0x3FFC0000 +#define PUPR5_ETH_MAGIC (1 << 27) int board_init(void) { /* adress of boot parameters */ @@ -252,7 +265,57 @@ int board_init(void) /* Init PFC controller */ r8a7791_pinmux_init();
+ /* Ether Enable */ + gpio_request(GPIO_FN_ETH_CRS_DV, NULL); + gpio_request(GPIO_FN_ETH_RX_ER, NULL); + gpio_request(GPIO_FN_ETH_RXD0, NULL); + gpio_request(GPIO_FN_ETH_RXD1, NULL); + gpio_request(GPIO_FN_ETH_LINK, NULL); + gpio_request(GPIO_FN_ETH_REFCLK, NULL); + gpio_request(GPIO_FN_ETH_MDIO, NULL); + gpio_request(GPIO_FN_ETH_TXD1, NULL); + gpio_request(GPIO_FN_ETH_TX_EN, NULL); + gpio_request(GPIO_FN_ETH_TXD0, NULL); + gpio_request(GPIO_FN_ETH_MDC, NULL); + gpio_request(GPIO_FN_IRQ0, NULL); + + mstp_clrbits_le32(PUPR5, PUPR5, PUPR5_ETH & ~PUPR5_ETH_MAGIC); + gpio_request(GPIO_GP_5_22, NULL); /* PHY_RST */ + mstp_clrbits_le32(PUPR5, PUPR5, PUPR5_ETH_MAGIC); + + gpio_direction_output(GPIO_GP_5_22, 0); + mdelay(20); + gpio_set_value(GPIO_GP_5_22, 1); + udelay(1); + + return 0; +} + +#define CXR24 0xEE7003C0 /* MAC address high register */ +#define CXR25 0xEE7003C8 /* MAC address low register */ +int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_SH_ETHER + int ret = -ENODEV; + u32 val; + unsigned char enetaddr[6]; + + ret = sh_eth_initialize(bis); + if (!eth_getenv_enetaddr("ethaddr", enetaddr)) + return ret; + + /* Set Mac address */ + val = enetaddr[0] << 24 | enetaddr[1] << 16 | + enetaddr[2] << 8 | enetaddr[3]; + writel(val, CXR24); + + val = enetaddr[4] << 8 | enetaddr[5]; + writel(val, CXR25); + + return ret; +#else return 0; +#endif }
int dram_init(void) @@ -263,6 +326,20 @@ int dram_init(void) return 0; }
+/* koelsch has KSZ8041NL/RNL */ +#define PHY_CONTROL1 0x1E +#define PHY_LED_MODE 0xC0000 +#define PHY_LED_MODE_ACK 0x4000 +int board_phy_config(struct phy_device *phydev) +{ + int ret = phy_read(phydev, MDIO_DEVAD_NONE, PHY_CONTROL1); + ret &= ~PHY_LED_MODE; + ret |= PHY_LED_MODE_ACK; + ret = phy_write(phydev, MDIO_DEVAD_NONE, PHY_CONTROL1, (u16)ret); + + return 0; +} + const struct rmobile_sysinfo sysinfo = { CONFIG_RMOBILE_BOARD_STRING }; diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index 59c4948..4d78388 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -18,13 +18,18 @@
-#define CONFIG_CMD_EDITENV -#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_EDITENV +#define CONFIG_CMD_SAVEENV #define CONFIG_CMD_MEMORY #define CONFIG_CMD_DFL #define CONFIG_CMD_SDRAM #define CONFIG_CMD_RUN #define CONFIG_CMD_LOADS +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NFS #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_FLASH
@@ -123,6 +128,20 @@ #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN)
+/* SH Ether */ +#define CONFIG_NET_MULTI +#define CONFIG_SH_ETHER +#define CONFIG_SH_ETHER_USE_PORT 0 +#define CONFIG_SH_ETHER_PHY_ADDR 0x1 +#define CONFIG_SH_ETHER_PHY_MODE PHY_INTERFACE_MODE_RMII +#define CONFIG_SH_ETHER_CACHE_WRITEBACK +#define CONFIG_SH_ETHER_CACHE_INVALIDATE +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_BITBANGMII +#define CONFIG_BITBANGMII_MULTI +#define CONFIG_SH_ETHER_ALIGNE_SIZE 64 + /* Board Clock */ #define CONFIG_SYS_CLK_FREQ 10000000 #define CONFIG_SH_TMU_CLK_FREQ CONFIG_SYS_CLK_FREQ
This supports sh_i2c on koelsch board.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- include/configs/koelsch.h | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index 4d78388..0c3f7f8 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -149,4 +149,16 @@ #define CONFIG_SYS_TMU_CLK_DIV 4 #define CONFIG_SYS_HZ 1000
+/* I2C */ +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_SH +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_SH_SPEED0 400000 +#define CONFIG_SYS_I2C_SH_SPEED1 400000 +#define CONFIG_SYS_I2C_SH_SPEED2 400000 +#define CONFIG_SH_I2C_DATA_HIGH 4 +#define CONFIG_SH_I2C_DATA_LOW 5 +#define CONFIG_SH_I2C_CLOCK 10000000 + #endif /* __KOELSCH_H */
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- board/renesas/koelsch/koelsch.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/board/renesas/koelsch/koelsch.c b/board/renesas/koelsch/koelsch.c index 1975672..b52043b 100644 --- a/board/renesas/koelsch/koelsch.c +++ b/board/renesas/koelsch/koelsch.c @@ -355,6 +355,14 @@ int board_late_init(void) return 0; }
+#define I2C_POWERIC_CHIP 0x58 /* da9063 */ +#define I2C_POWERIC_ADDR 0x13 void reset_cpu(ulong addr) { + u8 val; + + i2c_set_bus_num(2); /* PowerIC connected to ch2 */ + i2c_read(I2C_POWERIC_CHIP, I2C_POWERIC_ADDR, 1, &val, 1); + val |= 0x02; + i2c_write(I2C_POWERIC_CHIP, I2C_POWERIC_ADDR, 1, &val, 1); }
Nobuhiro Iwamatsu
