[U-Boot] Changes in uEnv.txt does not work
Hi, I am Manish and i have recently started working on beagleboard xm. I am facing certain issues. Need guidance to solve it.
Background: I am using beagleboard xm, uboot version 9 of 2011
Intention: Current version of uboot has the environment variable loaduimage set for ext3 partition.Now i want the uboot to pick the uimage from fat partition. I can do it by modifying the uboot code and use the rebuilt uboot but i want to remove dependency on building uboot for future version. So i was trying to play around with uEnv.txt
Exercise: Initially i tried to update loaduimage to fatload mmc ${mmcdev} ${loadaddr} uImage and tried booting but was unsuccessful. I tried to uncover the problem by echo statements to track the code flow. I observed that the 1.Same command works when i change the omap3_beagle.h and rebuild the uboot but it does not work if i change it using uEnv.txt. 2.Also that the error is returned from mmcboot->bootm command saying the image is in wrong format. But i am using the same image as in case 1.
Can some on guide me how do i achive this. I want to use uEnv.txt for better maintanibilty
On Fri, Jan 27, 2012 at 9:38 AM, manishdkanchan manishdkanchan00@gmail.com wrote:
What are the contents of your uEnv.txt? With v2011.09 and uEnv.txt that contains:
fromuenv=true loaduimage=silly
I see: Hit any key to stop autoboot: 0 The user button is currently NOT pressed. SD/MMC found on device 0 reading uEnv.txt
31 bytes read Loaded environment from uEnv.txt Importing environment from mmc ... Unknown command 'silly' - try 'help' ...
manishdkanchan
